Subaru XT Turbo Forester
-Frank P.
I do agree that if you're on the fence, it would be good to wait until just before the 3/36 expires to decide whether you want the warranty. If you have not had a single problem, then maybe not.
-juice
If you decide to wait a while on purchasing a Forester XT, you might want to consider joining
IMBA and then you can purchase a new Subaru at invoice price after you've been a member in IMBA for 6 months. The program is called the Subaru VIP Partners Program. Here is a link to the details of the program on IMBA's web site:
http://www.imba.com/tcc/subaru.html
I purchased a 2003 Outback wagon using this program a couple of months ago and it was the most pain-free auto buying experience I have ever had. I contacted IMBA when I was ready to buy the car and told them what Subaru dealer I would use. IMBA contacted Subaru for me and Subaru mailed me a voucher which I presented to the dealer. The voucher states that the dealer must sell the vehicle with all factory options at invoice and that any dealer/customer incentives reduces your invoice price.
You would have to negotiate the price for any dealer-added options. I purchased my Outback at $1,000 under invoice (there was a $1000 cash to dealer incentive)and then I had to negotiate for the few dealer-added options that I wanted. The cost to join IMBA is only $25 for an individual or $75 for a family.
Neil
Edmunds doesn't have a schedule for an XT yet. For a 2003 XS it shows $128 at 7500 miles, about $200 at 15000 miles, and about $400 at 30000 miles.
-juice
Cheers
Pat
Out of habit, I kept downshifting to 4th to pass trucks and RVs on the 2-lane sections. I did that five or ten times before breaking the habit and just charging around the dawdler in 5th.
With this much power on tap and with such low (high numerical) gearing, the throttle is quite sensitive. Just shifting positions can move your throttle foot enough to inadvertently add 5mph. I'm still limiting my usage of the cruise control for awhile longer, but at sustained highway speeds the XT (more than most cars) is more pleasant on cruise than off.
I'm still not wild about running 3,000-3,500 rpms to maintain highway cruising speeds of 70-80 mph. A car with this much wide-band power should be geared to reach those speeds at more like 2,500-2,800 rpm.
Now I have just 1,000 more miles remaining on my extended break-in. I'll change the oil and filter this weekend, and will continue to generally observe a 3,500-4,000 rpm rev limit until I reach 2,000 miles. Then the fun starts.
I read an item in another forum recommending a 'Whiteline steering rack bushing'. As one who'd like more road feedback and feel through the steering, this sounded interesting. Anyone here have any firsthand knowledge of what this bushing accomplishes and how difficult the installation is?
jb
Ken
http://www.mototuneusa.com/break_in_secrets.htm
http://www.car-videos.com/performance/view.asp?id1=277&id2=0
The catch is there's only space for 225/60R16s, just 6mm taller than stock, unless you get rims with a different offset and/or lift the body to create more room. Plus that's too big to fit in the spare tire well.
I did that myself. My spare is inflated at a higher psi, and both my differentials are open, which would help absorb the difference. 225/60R16 is also a very common tire size if I ever needed to find one in a pinch.
corkfish: I'm eager to see a response from a manufacturer about that break-in period strategy.
-juice
Does the clearance limitation relate mainly to tire width or to diameter? A different aspect ratio (say, 215/70x16 or maybe 225/70x16) would provide increased diameter without drastically reducing the strut-to-sidewall clearance.
I'm not so sure I'd like the look, but switching to the largest-diameter tires that will fit would be cheaper than replacing the ring-and-pinion gears.
jb
The rear tire is close to the strut base. You have maybe 1/2" of clearance diagonally there, so height and width come into play. I'm pretty sure a 215/70 would rub, 225/70 would rub there for sure. You might squeeze a 215/65 or a 225/60 with stock rims.
Up front, when you turn the wheel, mine are mighty close to the mud guards. So there the limitation is the fender. I think 235/60 would rub with my current offset. 225/65 would probably rub. It's sooooo close, so I could not go any bigger unless it was lifted.
So it would help a tiny bit, but it would not have the impact you're after.
-juice
jb: I agree -- getting bigger tires is going to be a lot cheaper than dropping the transmission.
Ken
The estimated 0-30 time is slower than the C/D figure for the XT and only as good as what C/D achieved with an Enzo Ferrari. So when one of you XT MT owners meets up with an Enzo Ferrari at a stop light, let us know whether you were able to beat it to 30 mph or just keep up with it.
Bob
I don't think current XT owners will be very happy to hear that, LOL.
-juice
1) The manufacturer has intentionally or unintentionally published incorrect specifications. The victims of this are usually horsepower and torque, but sometimes it can be gear ratios, axle ratio, electronic speed limiter, etc.
That seems to go against the popular belief that the XT's HP is understated.
Ken
Cheers
Pat
Ken- You're right, kinda shoots Juice's theory down the tubes. I gotta admit though that it never made sense to me why a manufacturer would under report HP numbers. Not in this "my engine is bigger than yours" testosterone fueled era.
-Frank P.
Even if the XT carried 3.9 gears (let alone 4.11), we wouldn't have to give up anywhere near that much performance. An XT with 3.9 gears would still reach 60 in well under 6 seconds, and would still run the quarter in the low 14's at 93-94mph! That level of performance would still be universally acclaimed and applauded. People would be raving about it - and especially about the relaxed, quiet, more-economical freeway cruising. No one would even think of complaining about numbers like those from any car in the Forester's class and price range.
jb
(for non-Crew members, LWC has spend a year or two schooling others, not to mention the typing speed schooling she provides in the weekly chats!).
Maybe if you found a wrecked 2003 GT auto....
Frank/Ken: could be, I guess. I wonder if gas mileage would be better if they actually did give it 250hp but relaxed the gearing to 4.1:1 or 3.9:1.
But after driving in, hitting the gas in 3rd gear at very low revs, I dunno, it sure felt like more than 210 horses...
USA Today complained about the automatic too, though he focused on shift smoothness. My problem with it was hesitation.
-juice
Why would Subaru understate the HP on the XT in the time of such HP showmanship? Two models: WRX and STi. It's all about positioning. If you browse over to NASIOC, you can see first hand the WRX enthusiasts that are in denial of the 0-60 numbers.
I buy the fact that 60% of Forester owners are women (smart ones at that!), BUT I think the XT numbers are going to be a bit different especially with the MT. However, given that MT Foresters are relatively rare so the average probably will not even budge.
Ken
What does everyone think about manual vs. automatic transmission with the turbo-charged engine, specifically the performance at high elevations in Colorado (10,000 ft)?
I was surprised but my salesman at Fitz said they had not sold an XT yet, as of yesterday.
Carrie: if you compare the two trannies on the XT, the 5 speed felt much quicker. It has more ratios, more closely spaced.
The auto hesitates a little to downshift, and has a taller 1st gear. So it's not as fast.
HOWEVER, compare it to the competition, and...wait, there is no competition. Even with the auto it makes the Escape and CR-V seem like slugs. Only the Vue Redline is remotely comparable, and that won't be out until next year.
At elevation, whatever advantage the XT has will only stretch, as normally aspirated engines will wheeze and gasp for air. I have asthma so I know how they must feel! :-)
-juice
I bought a 5-speed XT a month ago, but I also test-drove one with the automatic. If absolute maximum performance is your top priority, get the MT. However, I think the automatic may be the better all-around choice. Its taller gear ratios are better matched to the XT's extremely short 4.44 axles.
jb
jb
http://www.fyilondon.com/wheels/
The other two articles didn't even mention it.
-juice
This one does mention 0-60 - 6 seconds. Did the writer lift this from SOC's 0-60 kph in 6.1? Who knows?
I don't understand why some people think that Foresters are ugly. As small UTE styling goes, I think the Forester is one of the better looking designs. The Pontiac Aztec is ugly, the Forester is not.
I stopped by the Subaru dealer this weekend and asked my salesman how XTs are selling. He said there is not yet as much interest as he had expected. I am kind of suprised to hear that. I am on the east coast and near sea level. maybe XTs will sell better at higher elevations. The more I drive mine the better I like it.
I know its generally pretty accurate, but I'm getting a lot of "Their price is way to low" from my local Subaru dealers. I Suspect that they're just trying to get a higher markup over invoice. I can live with that if they just tell me up front. Yeah, I know they're car salesmen.....
Any input appreciated.
Larry
It's not ugly by any means, just utilitarian. Function over form.
-juice
If I encountered a dealer who claimed that my 'invoice price' is "way too low", I'd go back with detailed printouts from three or four different sites, and say "OK, show me where these are all wrong". Or I'd point him to the website, cars101.com . This is maintained by a Seattle Subaru dealer, and provides complete MSRP and invoice pricing detail for all new Subarus.
DaveM
Subaru Forester: Prices Paid & Buying Experience
(let us know that it's the XT Turbo flavor too - thanks!)
I would not regard an 'advertising fee' as legitimate. I paid no such add-on for the XT I bought a month ago. I paid straight invoice price, exactly as published on the various websites (including cars101.com, operated by a Seattle Subaru dealer), plus dealer cost for each option I chose, plus exactly $100 over invoice.
jb
DaveM
-juice
DaveM
Larry
