2005 Kia Spectra/Cerato
check it out
http://www.canadiandriver.com/news/040429-1.htm
When will the Kia get tested?
-juice
backy- for those who have the extra 2 or 3 grand to spend, you're getting a lot more car with the Mazda 3i. More pep, more room, better handling, better styling (subjective), better safety, better ride, better fuel economy, greater resale, better range of colors and options. Mazda hit it out of the ballpark. The Hyundai is also an excellent offering at the price, but in terms of an overall package, the Mazda is in a league of its own.
~alpha
Link:
http://nhtsa.gov/NCAP/Cars/2004Cmpt.html
Elantra scores better (5/4/5/4), FWIW.
Mazda6 got a similarly warm reception but it has big rebates now, $2000 IIRC. So if you buy a Mazda3 sans rebate, and later on Mazda piles on incentives, resale might not match your expectations.
I haven't driven one, but I do like the Volvo S40.
-juice
About resale- the Mazda 3 competes better in its segment than does the 6. Once it starts getting the press it deserves (i.e.... probably the Top Rating for all cars in the segment, which is coming in the August issue of Consumer Reports), I think sales will pick up, which would mitigate the rebate issue. Its almost scary the pull that CR has over everyday consumers.
Its too bad that I dont think the new Spectra will have been available in time for that report- CR logs about 6000 miles on their test cars before publishing. For the August report, the Scion xB and xA will also be rated, as will the unimpressive (IMO) Suzuki Forenza. Skip that offering and just get a Specrra!
~alpha
NHTSA only tests the cheapest model, hence no side curtains on the one tested. They will re-test only if the manufacturer donates the car, Mazda must have chosen not to.
I don't doubt it would do far better with them.
-juice
"NHTSA only tests the cheapest model, hence no side curtains on the one tested. They will re-test only if the manufacturer donates the car, Mazda must have chosen not to."
NHTSA has little rhyme or reason as to which trim lines they test.
~alpha
Back to Kia, making them standard was smart. In the past crash tests haven't been a strength, not they might just be an advantage.
-juice
I think the 3 is an excellent small car, especially in 3s guise. But when a person could spend $4000 less compared to the 3i sedan and get a sedan or hatchback with power everything, moonroof, ABS/traction, leather, Kenwood MP3 stereo, alloys w/Michelins, SABs, a great balance of ride and handling, the best seat adjuster in the industry (per C/D), proven "above average" reliability (per CR), and a longer warranty to boot, with only 10 horses less than the 3, I think that's a compelling bargain. As for IIHS ratings, we'll have to wait until they release the scores for the 3 and for the '04 Elantra--I suspect they'll do that at the same time, since they usually release test results of like-class cars together.
I just got back from an out of town trip where Hertz gave me a Corolla. I could not wait to get out of that car! The seating position is terrible, the HVAC knobs feel cheap, and the ride, though smooth, is too bouncy for my taste. And I missed the little niceties like map lights, sunglasses holder, and a softly padded center arm rest. Compared to the new Spectra, the Spectra is the better car overall IMO. The ride is better, the interior styling a little bolder (same boring color palette as the Corolla though), brakes far superior (4-wheel discs vs. the groaning of the Corolla's brakes), standard side curtains, peppier engine, and more room inside. Much better driving position too (although not as good as the Elantra's). A better looking car also, IMO--more flair than the Corolla's "don't offend anyone" lines. Once Kia gets their quality reputation up a notch, Toyota should be worried. They already have Hyundai breathing down their necks on quality and reliability, now Kia is starting to make some fine cars.
~alpha
Anyway...the 3 is a great car to drive... but after the initial excitement is over you will realize it is not perfect. The drivers bottom cushion has no angle adjustment and when you raise the seat, it sort of feels like it's tipping you forward. The tires will cost you an arm to replace and the 3 is not available with normal wheels/tires unless you get the base model i sedan. According to the maintenance forum, people are having not-so-minor problems already.
As for the 3's seat height adjuster, for one thing it is optional on the 3i. The other thing is that Kia made a big mistake IMO and did the same thing with the new Spectra that Mazda did with the 3--went with a single-lever seat height adjuster instead of the dual-knob arrangement that they used on the previous models (the Protege for Mazda). Why they went with an inferior design on these new models, which has the drawback you mentioned, is beyond me--unless it's a cost-cutting move. But if Hyundai/Kia can afford to use the dual-knob adjuster on inexpensive cars like the Accent and Rio, I can't see where cost would be much of an issue. The 3's driving position is tolerable for me, but the new Spectra's is not--which is too bad for me because otherwise it's a fine small car.
Rios and Spectras depreciate like a bat out of hell. Sorentos get God Awful gas mileage, and have a serious problem shifting into 4x4 on a slope. Better than some, yes. Better than Toyota or Honda??? Not even in the same league
MODERATOR /ADMINISTRATOR
Review your vehicle
http://www.kiaspectra.com/site.html
Also I looked again at the NHTSA site and compared the 2001 Elantra with the 2004. The 2001 had a driver's side HIC of about 482 and the 2004 was about 308 bringing the rating up from 4 stars to 5.
http://www.nhtsa.com/NCAP/Cars/1694.html
http://www.nhtsa.com/NCAP/Cars/2814.html
We still need to see if IIHS will test the 2004, because their test is more realistic.
As for the "8-way" adjustable seat, let's do some counting:
1. Seat slides fore and aft.
2. Seatback reclines.
3. Seat cushion height adjusts in a single arc, using a single control.
4. Lumbar support adjusts.
5. Headrest adjusts up and down.
I'm not sure how they get 8. In fact, I'm not sure how Hyundai gets 8 even though they have an additional adjustment (total of 6). Maybe they both count "fore and aft" or "up and down" separately? ;-)
I happened to check some of Kia's comparison data to other cars on the Spectra site, and based on the inaccuracies there (e.g. Elantra does not have an audio system standard, Mazda3s does not have power locks or mirrors standard) I don't know how much I can trust their other data.
But whered the $2000 base rebate come from?
~alpha
Hope that helps
~alpha
Whatever the case, every zip Ive tried for NJ shows only a $1000 rebate on carsdirect.com.
Jchan- yes.
~alpha
jchan- Check out Kia's website- Eligible Competitive Bonus vehicles are plainly posted there.
~alpha
-juice
http://www.kia.nl/
thanks!
Review your vehicle
BTW, I noticed Kia is offering a $1000 Competitive Bonus on the All-New 2004 Spectra, in addition to the $1000 rebate, but it is a strange bonus. It includes most compact cars, but no Hyundais (don't want to compete with the sister company I guess). It also includes most Mitsubishi models, including the Galant and SUVs! It's clear which automaker Kia is focusing on with this bonus--kick Mitsu while they're down! There's also a $1000 Loyalty bonus for current Kia owners. (Can use only the Competitive Bonus or Loyalty bonus, not both.)
Very imaginative folks here! :-)
-juice
About rebates- do note that the basic rebate can be combined with EITHER (as backy pointed out) the customer loyalty or the competitive bonus rebate. So you can still get two rebates.
~alpha
