BTW, "cold max" is the proper level when the engine is cold and the power steering has not been running. It does not pertain to weather!
Craig
I have the 05 Legacy 2.5i wagon. During the last few months here in Los Angeles it has been quite warm so I really got to test my air conditioner. Needles to say I was disappointed. It was cool but I never felt cold. The dealer admitted there was a problem and put in a new compressor. I was told the problem was fixed. It was in the upper 90’s when I picked the car up and while I was on the highway it did seem a little cooler but once I got in stop and go traffic it once again felt inadequate. Over the next few days with temperatures in the upper 90’s I was always just shy of being completely comfortable even with the air on full blast.
I had it back to the dealer two more times. The last time they gave me a Legacy 04 turbo sedan as a loaner. The air from that car was great so I assume at least some models have good air conditioning. When I picked my car up this last time the service rep told me they had made all the adjustments they could and that it met Subaru’s specs. He implied that that was as good as it gets in the 05.
The 04 I drove had automatic climate controls that went to a low of 65 degrees. I’m wondering if this is the temperature I should be getting out of my vents and what is the most accurate way of measuring it Does the Limited Legacy or OB have a stronger air conditioner than the base model? Do Subarus generally have weak air? I don’t know if I should accept what the dealer tells me or demand they look at it again.
Thanks, Laurn
key in, key on, 20 times, key off, key out, key in, key on, 20 times, key off, key out, key in, start car, voila, no more chimes.
I gotta admit, I'm still chuckling but oh so pleased to have silenced the lambs ... now I just gotta know, who/how in the hell did someone figure this procedure out??!!
I'm worried that I've also caused some inadvertent disruption in the time/space continuim ... like the old Steven Wright line:
"I've got this light switch in my house that doesn't do anything, so every day when I walk by I flip the switch. The other day I got a call from a woman in China ... she said, 'Cut it out.'"
Anyway, thanks again for the heads up.
You should be able to measure the temperature coming out the AC vents and verify that it meets the correct temperature accordingto specs. There are specs on the system temperature -- with the temp knob on minimum and the intake air damper set to recirculation, it should be blowing a certain number of degrees below the ambient temperature (someone else may have exact numbers, but it's supposed to be pretty cold air, on the order of 55F-60F if my memory is right). BTW, the 65F setting on the auto climate control systems is for the target cabin temperature, but the air coming out the vents is cooler than that when running "max" AC.
I hope some of the others can add to my comments with more precise info. Once you get all the facts, and perhaps measure hard numbers on your AC temps, it may be a good idea to try another dealer and/or call the Subaru 1-800 number to set up a case and get their input. If the system is not meeting the minimum temperature spec, then something is definitely wrong and they will have to fix it under warranty.
Good luck,
Craig
The only drawback is that if/when you have the car serviced if they disconnect the battery the Chime Gremlins will be back. Just repeat the process.
Follow-Up Test: 2005 Subaru Outback
Make sure you put it on recirc, not fresh air, so you're not cooling fresh/hot air all the time.
Under the hood, some folks have added extra insulation to the ducts but you shouldn't need to do that.
-juice
They complain about the tranny but it doesn't sound like they even tried the Sport mode!
This my fave:
refined and glamorous beauty
-juice
I noticed that for some reason, the indicator light continues to flash even though the chimes stop after buckling right away.
So, I buckled, waited until the indicator stopped flashing and finished the remaining 19X reps waiting for the light to turn out every time.
Ahhhh. Now I can just listen to the sound of the engine idle with no chiming.
Ken
My 05 GT Wagon's AC works very, very well. Despite the black leather interior and large interior space, I've found the AC to get things cool very fast. I'm up in the Bay Area and about three weeks ago when we had the extended heat wave of 90+ degrees for over a week, my car was about the coolest place I could be.
You mentioned a 04 Legacy turbo. Do you mean an 05 Legacy? There hasn't been a turbo Legacy in years.
Either the 2.5i A/C is not as strong as the turbo engine or there might be something still wrong with the A/C. Can you perhaps try a different dealer?
Ken
I agree with everyone else, the AC on my Subarus have been fine despite high temps. There must be something wrong with yours. The AC kicks in very fast on my '05.
The problem is in SoCal there are very few Subie dealers (not a big market for awd- most SUVs there are rwd) but try and find another one if your dealer can't fix it.
tom
Doug
I've heard over at Legacygt.com that the GT got pretty good reviews.
Here's a quote:
"The TSX and LGT are better overall than the 35K 9-3 or Jag X and the LGT driving experience is close to a 40K 330i".
Ken
I ask because we know the air bag sensors measure the weight in the seat, so the data is available.
Saab and Jaguar, eat your hearts out.
BMW - Look out!
-juice
Better than the Malibu...
-juice
I've not had a passenger - wife or pooch - since silencing the driver's chimes last night, so I'm unclear if the procedure has to be done on each seatbelt to keep 'em quiet.
My buddy told me about a couple of other ideas that I will post in the next few. Some are goofy, others are somewhat useful.
Speaking as a former South Texan, I'd say your car has an A/C problem.
Here are a couple of quick checks that YOU can do before going back to the dealer:
1) When the weather is at least in the mid-80s (good luck in Vermont this time of year), and the car hasn't been running for awhile, and with the car not super-heated by sitting in the blazing sun, hop in and fire up the A/C on MAX. Then go around and open the hood and locate the high-pressure and low-pressure A/C lines (these are typically aluminum-colored metal tubes about 1/2" in diameter). Once the A/C's been running for a few minutes, the low-pressure line should be distinctly cold, and the high-pressure line quite hot (almost too hot to touch). If this isn't the case, stop right there and report the findings to your dealer.
2) If you're "making cold" then get into your car with a room thermometer with an open bulb, turn the fan to MAX, make certain the air is only coming out through the dash vents, and get that thermometer as close as possible to the most robust vent (fastest airflow) and hold it there for a few minutes. While there's some variation, a properly running A/C (and this is why it needs to be warm enough outside) should put out cold air (at the dash vents) in the range of the upper 40s. If your system (as measured by this crude test) is warmer than the low 50s, then it's defective somewhere "downstream" of the compressor.
TO OTHERS: Anyone know if Laurn's model has a sight valve where she can check the R134a charge?
Good luck - hope this helps!
Ken in (sunny and cool) Seattle
I will keep on the dealer until I resolve this problem.
Laurn
Hmmm, now that is interesting. I know the outside temp is used in the auto climate control system on my 2.5XT, maybe it has a function on the system in your 2.5i as well.
Craig
Well, I guess everyone outside will be able to listen to my music too. ;-)
Anyone install some dynamat or equivalent sound deadening in the doors?
tom
Also forgot to mention that I got the 5at and it is amazing!
Thanks. I'm glad to hear that the whining sound will probably go away as I put more miles on the car. I mentioned to my husband that you thought it might be the belt and he is going to check that for me, but he didnt think so.
Craig - Duh! I figured the Cold meant the whether. I told my DH last night and he knew that since he used to work on cars, but I guess I assumed it meant the temperature. But I guess it still is a bit of a problem because when he checked the power steering fluid, the engine was hot (I just got home from work) so it should have been at Hot max, atleast. But instead it was at cold max.
Seat belt chimes - I am going to try this again! I don't think I took the key out of the ignition the first time I tried it.
Kristen
I found putting the car into sport mode was the most fun, as the transmission reacted smoothly form start to finish. The OB seemed to have a bit more throaty sound to it, and the Leg felt a bit more smoother ride. The OB did feel better going over potholes, and on the dirt road in back of the dealership. I have to say that I liked the feel of the OB a little bit more. Maybe I'm biased from driving an OB all these years.
There is a noticable differnce between my 2000 OB and the 05's. The interior is a lot cleaner, and it feels less cluttered. I liked the dual climate control feature. No more arguing between my wife and I on who is cold, or hot:-).
Overall, very pleased, and I look forward to taking another drive in the OB in the future.
Mark
Unfortuantely, there is no way to have the passenger side temp track the driver side temp. It was a hassle at first, but I find myself adjusting both without realizing it now.
Ken
I really like the new 4-position settings. With my Forester, I found the 2-position settings to be either "pretty warm" and "very hot". I could never keep the seat heaters on very long.
The extra positions on my LGT seem to have more lower settings that give just the right amount of heat. Also, the heating elements seem to go up further the seatback just about to the bottom of my shoulder blades. With the Forester, it stopped about right in the small of my back.
Ken
tom
Dave
I was quite impressed by the headlights, coming from a 2003 Sequioa, 2002 Passat, and having driven around MBs, Lexus, and RX-8s with HIDs find them much better than expected. I think to get significantly brighter you'd need illegal offroad lights. Now, the color spectrum is warmer than HIDs, so they may not seem as 'bright' but you can definitely see things from far off coming at you (at 100+mph) ;-)
tom
http://www.investors.com/breakingne...=23348524&brk=1
I believe the 05 Leg/OB has some of the best non-HID lights. But, I can see some folks not being happy about how sharp the cutoffs are.
Good to hear Subie sales are up! Wow, I didn't know Legacy sales were higher than OB sales.
Ken
I am jealous! I miss fall weather in New England, actually I miss the winter weather too! One of these days I will move up to VT where I can really use the seat heaters!
Craig
Dave
Don
Don
Craig
Craig
Frank
