Visitor Agreement.
Thanks for the info. My specialty installer (a well-respected national chain) wouldn't even touch the installation after talking to Delphi/xM and Subaru. No way to direct input/wire the antenna due to the new wiring layout. Craig here has come up with a way to tap in, but the installer wouldn't consider doing it after subaru scared the manager out of doing it.
I'm not totally clear as to what your dealer did.Glad yours is working but I'm not real hot about having an extra modulator mounted somewhere.
I suspect XM/Delphi will come up with some sort of "adapter" like they use on other cars to install the XM Commander. I'm going to wait a little bit and see if somebody comes up with one and if not, I'll try Craig's fix. Otherwise, the only option is to go to the transmitter type such as the Delphi Roady, but I'll be danged if I can figure out a good place to mount it.
Anyway, thanks for the info and I guess I will check with the dealer next to see what they "suggest".
A closed deck has no gap between the cylinder walls and the engine block. In contrast, a fully open deck has a large amount of space between the two as shown in the picture below:
http://www.cobbtuning.com/images/sohc-engine05.jpg
A semi-closed deck is somewhere in between. There are open gaps, but fewer in order to strengthen the engine block. I couldn't find a good photo that demonstrates this concept, but imagine the above photo with a few areas around the cylinder that connect to the rest of the block.
Ken
Thanks. Understood.
Are those gaps in the open and semi closed blocks used for circulating coolant? Or is it just an air gap?
Karl
Here's an even better link:
http://www.cgperformance.com/subaru_block.htm
Ken
If your installer comes up with a "solution", I would love to know it. Thanks.
As with many things in life, you get what you pay for. Now that being said, I don't think you need $2000 rims, nor would they be guaranteed not to bend if you hit a pothole hard enough!
I've seen a lot of Rotas on the Subies around me and people seem to like them enough. They are decently light cast wheels, (they don't make forged) and like most cast wheels they are mass produced in Asia (Phillipines, IIRC) so hitting a pothole hard (very hard!) will bend them, especially with low profile rubber on them. But your OB has more rubber between the rim and the road than my GT, so it seems unlikely you'd bend one if you drive carefully. And even if you do hit a massive pothole, it's certainly much less expensive to replace a Rota wheel than a BBS wheel. They have some mesh pattern wheels which should be quite strong, maybe stronger than the stockers.
Unless you are racing your OB, I don't see the advantage of a forged wheel. It would just be something to attract thieves! While you can't really go wrong with a BBS wheel, there are a lot of decent reasonably priced cast aftermarket wheels out there too, in OEM sizes for your OB.
Good luck
tom
I have the OBXT Limited wagon. My dealer didn't properly install the XM Commander satellite radio. He didn't even come close.
I found a really bright guy in Florida while on vacation, who owned his own specialty shop installing high end car stereos, etc. He spent two hours to finally properly install the XM Commander. So I believe that an ordinary dealer guy will be in over his head with this type of installation. My advice is to first make sure they put the antenna on the roof of your vehicle, not inside. Then thoroughly test the satellite radio before taking delivery. If there is any static or station overlap occurring, insist that the dealer correct it.
My impression of my Subaru dealer in Valley Stream, Long Island was that he really wanted no part of selling me the XM radio in the first place. He had never even heard of it. He begged me to not make it part of the purchase and wanted me to have it installed on my own. But I insisted since I wanted one stop shopping.
I'd had good success with an XM radio on my Lexus GS430 which I purchased six months before but apparently Lexus is out front on new technology while Subaru lacks the experience.
Anyway, all's well that ends well. I'm very pleased with the XM but then I'm easy to please.
Bob
Long Island
I've travelled along I70 going from NYC to the Kentucky side of Cinncinatti. Nice road, especially when going through the Appalachians.
Mark
Bob
If you are using a wireless FM transmitter, then it will really be a no brainer install.
Craig
I think they got scared off by Subaru who said there were "impedance" problems and "so on" if you tapped in like you did. I need to press them a little harder on what they thought the "real' problem is but if your works fine, that's good enough for me. I'll see what they say.
Problem with wireless transmitters is finding one that will actually fit into an OXBT (permanently mounted as I'm not interested in mobile useage). The Roady alsmost fits in the sunglass shelf, but not quite. Any other location would look pretty crude I think.
Thanks for the help.
It's easy to solve. Subaru sells an accessory armrest extension for the '05 Legacy / Outback.
http://www.subaruparts.com/catalog/?section=540
DaveM
Congrats, btw. Enjoy your trip as well.
Mark
DaveM
Let us know what you think of the seats after your trip. A few of us find them uncomfortable for long trips. My butt hurts after anything over two hours, my wife is the same, plus she thinks the angle of the seat bottom is wrong for her. Unfortunately, that cannot be adjusted on the passenger's side which has only a 4-way adjustment instead of 8-way.
Have a nice trip!
Sly
~c
DC Steve
DC Steve
Peace.
I guess a little extra bracing goes a long way.
Ken
This was supposedly $100 over dealer cost which I believe to be true or close to it because of prior one I bought at another dealer for my Forester turbo last year and I saw the dealer book.
Well, let's hope they really know what they're talking about -- I would feel more comfortable if they said they were aware of the issues with the 05 radio and knew of the solution! As I said before, a wireless transmitter is easy, but using a wired FM modulator or direct line in involves some custom solutions. What type of connection did you have in the MAXX?
CRaig
c_hunter, "Subaru Crew: 2005+ Subaru Legacy/Outback" #4529, 7 Oct 2004 9:47 pm
Craig
Peace.
Is it possible the tires are tramlining?? This means they would react to road irregularities and skitter back and forth, sideways. You might want to read the reviews of that tire on the TireRack and see if anyone else reports tramlining or an unstable feel. It is common with some tires, and it is worse on some cars than others. This may also explain the sensitivity to crosswinds you notice. My 05 is not any more susceptible to crosswinds than my 02 was (they are both equally sensitive, in other words).
Craig
Sly
Sly
-mike
I have read elsewhere that check engine condition will blow the cruise away. (Not at all an acceptable situation, in my view.) I have not seen any mention of the fuel gauge going haywire.
About an hour later, the gauge came back, but the rest is still out.
I will consult the dealer, but wondered about the fuel gauge involvement, and about others' opinions of disabling cruise unnecessarily (assuming the info about that is correct).
I have 4,500 miles on my OBXT and best mileage I got was 25mpg on trip to Florida. That's enough for me.
You can get an arm rest extender to balance out your elbows. It cost me $200 with installation.
Bob
I paid $40 or half hour labor for the arm rest extender installation. And the unit cost $149.
Bob
I just returned from a 1,600 round mile trip in my '05 OBXT and averaged 23.5 mpg. This was at 75 to 80 mph most of the time, and driving through a couple of mountain passes, some city driving in San Francisco too. On my return the car had 2,900 miles on it.
Had one stretch of level ground where I averaged 25 mpg at a 75 mph average.
Not great, but not bad either for an all wheel drive car driven slightly aggressively at times.
If my average mileage goes up to 25 or 26 mpg in those conditions I will be satisfied.
Eric.
That sounds close to one of my first road trips on my Legacy GT wagon. I went up to Yosemite this summer and I averaged about 26mpg with similar driving conditions as you mentioned.
Ken
Nice to see yet another new member here. I bought mine in Aug, and am still dying to get to try her out in the snow!
Fyi, I experienced similar mileage results in my '05 OBXTL-5MT on my first road trip. To be honest, I don't think 25MPG is bad whatsoever for these cars; not with full-time AWD (as you had said) and certainly not for the amount of "performance on-tap" which comes with it. If someone were to show me another car on the market which was even close to what the OBXT had to offer (including the kind of gas mileage they're capable of), I'd be interested in hearing about it.
All in all, I'm very satisfied with my purchase.
Welcome to the board!
Tim G.
'05 OBXTL-5MT
6700 miles and counting!
-mike
thanks!
