Visitor Agreement.
I've been trying to figure out what the major differences between the
different submodels?
LX
LXI
GTC
Touring
Limited
thanks,
m
thanks,
m
then my battery light turned on
i drove home like normal with no "problems" save the light.
my car still always starts, however after about 300-400 yards the light comes back on.
other things wrong with the car... the rpm gage, and the mileage keep turring on and off randomly.
someitmes they stay on for a week
sometimes they turn on ater i "get going"
sometimes they just dont turn on at all.
other then that What could be up with my car?
while i was driving one by one things turnd off on my car.. till i couldnt even get the emergancy lights to work. its dead in the water now
Peter
Two discussions where you might find the answer to your problem:
1. Chrysler Sebring Owners: Problems & Solutions
2. Got a Quick, Technical Question?
My question is about safety. I will be traveling with my wife and our 2-yr. old son. Does the Sebring have LATCH anchors in the rear seats? Will I have any problems fitting a car seat in the back? Is this a bad idea, and should I just rent a regular sedan?
My son is currently in a phase of being fascinated by convertibles, so I thought this might be fun for him. We'll be in LA/San Diego, so I think weather should not be a problem.
think this to be a wise choice.
We test drove a Sebring the other day and my 5yr old which loves convertibles
absolutely hated it. -- And I never went over 45!
mike
Recently I noticed that the edges of the top have started to separate at the bottom part of my back window. It almost looks like the adhesive or whatever is used to attach the window to the top is no longer working. It started with about an inch on each side of the bottom part of the window--now it is up to 6 inches. Is replacing the back window or the entire top the only options I have? Please help!
Any luck with your warranty rep?
GCK
I had a 300ZTT that had a nasty shake two it. Couldn't get it solved until
I had it balanced on the car -- then it ran smooth as can be.
cost wasn't that much more.
m.
Gary
Thx
When I turn on the fog lights, should a light come up on the Dash? Mine doesn't, and there is no light in the bulb check for it either.
Similar to the fog lights, there is no dash light for the Traction control. That really matters to me (canadian winters, in a snowbelt). Should I be seeing a light come on either when the traction control is engaged or disengaged or when it is activated? According to the slesman the light comes on when the traction control is turned off, but I can't get it to.
Lastly, the salesman advised to treat all the rubber gaskets around the convertible top and around the windows and doors with a silicon lubricant, spray stuff to keep them water tight, but advised that I buy aftermarket rather than pay the Mopar prices for the same stuff. Does anyone have a brand name they recommend?
Thanks for your help,
Chris :P
Bought a used and babied 98 Limited, and love the car. It is used for back and forth to work since my Dodge Ram 2500 V10 is a bit of a gas hog (BIT????). Car has had no problems as I've seen here, and my only criticism is the poor headlights. :mad: These are like brand new, and I don't feel safe driving the car at night with them. Replaced the bulbs with Silverstars, to no effect. The car had a busted foglight, so I pulled them and replaced them with some 55w H-3s. Now, I run with the high beams on, and if it gets dark, I switch to foglights/low beams. Exact opposite of nthe way it should be. High beams don't light s%$#!! No one makes after market headlights either. Dealer says that's the nature of the beast. Otherwise, great car, 27 mpg highway running 75. Gotta understand, I'm a biker, so this is just a cage to drive when the weather is crap. But I would at least like to see the road more than 10 feet in front of me.
OK sheeples, how about a response?????
My question is ..Do you have the brand name of the adhesive which worked on the rear glass window and bonded it to the vinyl top?
road, time to replace shocks/struts.
any recomendations? monroe sensamatics seem to
be what I find as a match at most places.
thanks,
m
1.I am looking for a copy of original warranty for 2000 Chrysler Sebring Convertible for research into after market warranty. I need to know what was covered to see if it makes sense to buy additional coverage which of course only covers those original items.
2. My lower glass has separated from the conv. top in back. Interior and exterior. Have read all previous comments at this site. Does anyone know the name brand of adhesive that is most probably going to work?
Reg. Frank R.
