Thanks in advance
Has anyone else had this many problems?
To add to the list of woes, I was walking out to my vehicle the other day and noticed the skid pan hanging down!!! When I crawled under there for a inspection I found the rear bolts that hold the back of the pan had fallen out. The dealership would have to remove this pan to change the oil filter. Instead of going back there I went and bought some bolts and replaced them myself. I told the guy at Infiniti that this was what I have come to expect from this dealership, he didn't have a suitable reply.
We are seriously thinking about cutting our losses and dumping this vehicle.
As an update to all of the other probelms I have had with my QX56. Since my last post I have discovered that the seat heaters are cross connected (driver switch turns on passenger seat heater) and the overhead lights have stopped working. IT goes into the shop tomorrow.
I've heard of some problems with Sirius reception and some antenna installations. Does anybody have stories about the reception with their dealer installed Sirius radios in the QX56 and what did you r dealer charge for the installation?
The real thrust of my complaint is toward Infiniti Consumer Affairs. I will start off by advising anybody who thinks this organization is there to be a service to you, you are DEAD wrong.
I will not go into all the common problems I had with my vehicle, I feel these are still being discussed in these forums. However, I will focus this post on a safety issue that Infiniti was never helpful in addressing.
Passenger Side AirBag
Ever since we owned the car, when my wife would sit in the passenger seat the "Passenger Airbag Off" light on the dash would turn on and off. We took the QX56 into the shop to have them look at it, they told me the sensor in the seat seemed to be working properly, but they would contact the technical department at infiniti for further guidance.
After this first visit, I made numerous phone calls to Consumer Affairs to see what the status of the Passenger Airbag repair was. I was continually informed that they were looking into it. My next visit to the dealer was about a month after my first visit. The dealer told me to read a document they attached to my work order, and they were still trying to get guidance from Infiniti Technical Department as how to resolve my problem. The Infiniti document the dealer gave my states the following: "Front-passenger-seat occupants weighing over 102lbs (46.3kg) and who are properly seated and using the seat belt as outlined in the Owner's Manual should not cause the passenger air bag to be automatically turned OFF". My wife is 5'7" tall and weighs 120lbs.
After another week or so not hearing from Infiniti Consumer Affairs, I decided to ask to speak to the manager in the department. I explained my situation and she said the thought Infiniti was writing a TSB on the issue but she was not sure. She assured me she would call me the next day to let me know. Well after waiting another 1 1/2 weeks and still no call back from the manager of consumer affairs I made another call back to the department. The day I called the manager was not in the office to take my call, so I explained my situation to another person in consumer affairs. She was very nice when I explained my ongoing unresolved problem and she asked to put me on hold while she contacted the technical department. When she came back on the line, her answer to me was that the weight required to make the passenger airbag work was set by the federal government and Infiniti has no control over the government mandates. I told her this is perfectly acceptable with me, and I asked her if she could tell me what the government weight requirement for passenger airbags were. She said this was a perfectly reasonable request, she did not know the answer at the time, but she would research it and contact me that day with the answer. That afternoon when I talked to Infiniti Consumer Affairs I was informed by a gentleman reading from my file that under no circumstance is Infiniti going to give me the weight requirement to make the airbag function.
As you can imagine I was getting a little upset, so I decided to contact the National Highway Traffic Safety Administration to find out for myself how much my wife needs to weight so she does not get killed in a frontal impact. I was informed by the NHTSA the airbag needs to work if the occupant exceeds 4'8" and 80lbs. According to the government mandate, my wife is 50% above the threshold to make this airbag deploy.
The next day I decided to write a letter to Infiniti Consumer Affairs hoping I would be able to solve my problem. I UPS'ed my letter overnight to them on 6/2, on 6/3 they received it. Again I waited patiently (like an idiot) thinking they were going to respond to my letter. I called them on June 21 to see if they had responded to my letter, they told me the never got my letter. I explained that I UPS'ed it to them and will call back with the name of the person who signed for it. But while I had them on the phone I asked what the status of my airbag repair was. My case worker at Infiniti Consumer Affairs told me that since the airbag parts are sensitive parts they could not be air freighted to the dealership. I asked her if I could assume the parts were being sent by ground, she said no I should not assume that. I asked her if I could assume she is being honest with me, then she got very angry with me raising her voice asking me if I was insinuating she was a lier.
When I called back with the name of the individual who signed for my UPS letter, I was informed that the letter may still be in their mail room, I asked if it was normal for a letter to take 17 days to go from the mail room upstairs to my caseworkers desk. They said they did not know how long it would take for my letter to make it upstairs. I asked them for a fax number to fax my letter over to them, instead of giving me an answer, I was informed they were looking for my letter in the mail room. I asked 3 times for the fax number and they gave me the same answer. I was not until I offered to drive my letter to their facility in Torrance were they willing to give me the fax number.
I faxed the letter to them and my case worker called me back and told me they received it. I asked if they were going to mail me a written response, she said no. So I asked what Infiniti's response was, so here it is:
I was told that this airbag problem is not an Infinit problem, the problem is with the switch manufacturer Johnson Controls. I informed her that I wrote my check to Infiniti when I purchased the car not Johnson Controls, she told me this was infinit's position.
At that point I contacted William R. McGee in california a lemon law attorney. I dropped my car off at the dealer last week and received my check today.
I would never be posting this message if it weren't for the people at Infiniti Consumer Affairs. As hard as Infiniti was trying to compete with Lexus on quality and customer service, they have fallen far short.
I just wonder if Nissan of North America cares about the people who may die in the passenger airbag, or does it cost too much to fix. If you think I am an isolated case, click on the link below and cut and paste the ODI numbers in the box. These are customers with the same complaints with the Armada and Titan, both using the same sensor.
http://www-odi.nhtsa.dot.gov/cars/problems/complain/complaintsear- ch.cfm
Nissan Titan
10073252, 10083431, 10074705, 10073293, 10074723, 10072969
Nissan Armada
10072534
Infiniti QX56
10079597
Let's hope Nissan of North America does the right thing for the families who are riding in their cars day after day.
I realize your problems were with Infiniti, whereas mine was with the dealer, but just curious.
An interesting note from one of those NHTSA complaints is that one owner noted that sitting more forward in the seat seemed to trigger the sensor.
This has all the looks of a long drawn out finger pointing exercise between Nissan and Johnson Controls. Where Nissan indicates the sensor is defective and Johnson Controls says that Nissan has installed the sensor incorrectly. Either way the consumer ends up losing (and perhaps dying).
yamamoto, thank you for your detailed posting. It has certainly made me think twice about purchasing a QX56. One question though. Is the NHTSA launching a defect investigation in this case?
Glad you got decent resolution. Unfortunately, it doesn't address the real issue: I assume you would have rather had the vehicle you shopped for and bought, rather than having to give it up because Infiniti couldn't or wouldn't make things right.
Good post, by the way. Sounds like you handled things much more professionally than most would have - that probably helped quite a bit in getting the buy-back.
Very well done. I got Chrysler to buy back my Town and Country after 3 years with a Lemon Law suit. It was very easy once I got a professional involved, the lawyer.
The lesson here is to document every little problem to build a case, if needed. Mind you, I am NOT a litigious person and it pained me to even think about suing Chrysler, but after 19 service calls in 2 years and the check engine light going off 150 miles after the warranty was out, I had enough and so did you.
Enough of that story...
Today I drove a QX 56 in Detroit and liked (not loved) the vehicle. They were not talking about any discount to speak of for a 2004 and offered me less than 20k trade on my 2002 MDX, which has a great car. I told the guy that he just killed the deal and he backpedaled a bit and would come back to me later.
Combining that behavior with the fact that I did not absolutely love a $55,000 truck, I think that I am going with the Lexus GX 470, especially if they upgrade the engine for 2005 from 235 hp to 280ish hp.
Can anyone talk some sense into me on this? The forum has lots of opinions, so please school me.
Thanks in advance for your comments
Jim
By the way, I still have yet to drive the Lexus GX 470
the nhtsa sent me a letter stating they do not have enough information regarding the QX56 to launch an investigation. However, I am sending them a letter linking all of the similar complaint together (armada and titan). Hopefully, the nhtsa will then see this in not an isolated case with just one qx56
you are right, I never wanted to be in the position I was in. But after being jerked around long enough by Infiniti Consumer Affairs, I decided I was going to dig my heals into the sand and win this fight.
It always amazed me that the people at ininiti know of the problem but chose to ignore it and hope it went away. I wonder if the people at Ford/Firestone can sleep well at night because the decisions they made helped save the companies some money. What about the families who suffered loses?
The ride was very comfortable. The kids were pretty busy watching movies.
Does anybody know if I could use the factory installed crossbars to add luggage rack or cargo box on my truck?
I would like to add a luggage rack so that on my next trip, I could use the third row seatings.
so far I haven't had any major issues with the truck. I have over 7000 mles right now and will soon be due for the 7500 miles maintenance.
Sorry, can't help with the color info.
Good luck - I love mine.
MODERATOR /ADMINISTRATOR
Review your vehicle
Has anybody heard of significant discounts or rebates to help clear out the 2004 vehicles before the 2005 arrive?
Thanks for your help!
Enhancements to the 2005 QX56 include:
· Standard active head restraints for driver and front passenger
· RearView Monitor and Rear Proximity Sensor (included as standard equipment)
My input is the last reviewer.
www.autoweek.com/article.cms?articleId=100844
Joe
Cheers,
kirstie_h
Review your vehicle
2004 Infiniti QX56 (AutoWeek)
