Mazda RX-8 Problems and Solutions
1246728
  • pr_rotarypr_rotary Member Posts: 2
    It is an amazing machine
    Can anyone tell me wich VIN numbers has the problem with the engine oil pan baffles
    sounds like you may have a bad tire air pressure sensor on one or more of your tires.
    Flooding...I'm beginning to think this is an issue that's affecting many cars. My neighbor's '03 Accord LX just did the same thing this morning ...stalled and wouldn't restart after starting breifly and then shutting it down after a few seconds(he had it flat bedded to his Honda dealer). Perhaps the winter formulation in the fuel?
  • carlikercarliker Member Posts: 285
    graphic - Starting your vehicle and abruptly turning it off before turning it on again is obviously not the best thing for your vehicle. However, flooding shouldn't be so common in a car. If a person consistently does that over time, the car will eventually break down which I can understand. I can't see it happening so soon though in so many new vehicles (even it's a little cold). This seems to be a problem that at least needs to be addressed by Mazda. It may just be an easy fix. It only seems to be a problem in certain RX-8s anyway.
    I've heard of 2-3 people having trouble with flooding the RX8. I've also heard of it happening with other makes, too (like that of my neighbor's new Accord mentioned before). That's what makes me think that the cause could be reformulated winter fuel.
    Personally, I've not had any sort of starting/flooding issues with mine...and I live in an area where the temps have dropped to the mid-30s. I don't do any sort of "warming" up procedures other than to wait a minute for the RPMs to level off after starting my car. I've also started it cold and driven for short jaunts (less than 2 miles) without running into any problems.
    The only thing that is the real variable is the fuel in different parts of the country.
  • cheezeboycheezeboy Member Posts: 218
    GGuy - I am beginning to think so, as well. This past week was nice temperatures here in FL; mid 70's to mid 80's....and the warning light never came on. But Friday it dipped down to 45 - and the next morning the light and sound came on again. I drove 5 miles or so and it went off. It stayed off all day with various driving. Then this morning (55 degrees) there it was again. And, again, after 4 or 5 miles, it went off. I watched the (sad) Dolphin game and got in my car tonight - tada - the light was back on. I will tell the dealer and have them look. Gotta be the cold. Time to move to the equator......Costa Rica? Panama? Suriname? Gabon? Brunei??
    CEL came on once with mine when I first got it....took it to the dealer. They replaced the EVAP unit. No problems since....
    graphic - I'm glad you are fortunate not to have any flooding problems in colder weather. Obviously, certain RX-8s are experiencing this which just doesn't seem right. Where this could happen with any vehicle like you mentioned, it seems that the RX-8 is more susceptible; especialy in colder weather. I still think it would be best for Mazda to address this to be sure. I've read more than 2 to 3 people on here mentioning it and I really don't think it's a conspiracy to knock the car. The same people say they really enjoy it as well.
    gkouris - I don't know if I would have done the same experiment with my own car, but try to continue posting your experiences so owners can be informed about possible solutions to this flooding if you can. Too many people post problems here and never return to explain if there really ever was one. Thus, the problems can't be taken as seriously.
    regarding flooding...I think there's a "Stalling/Flooding" thread here on Edmunds boards somewhere. I haven't looked at it for a while, but it seems that whenever winter temps hit, there are all sorts of stories, with all sorts of different makes that come up.
    Is the RX8 more susceptible to flooding? Not enough information to really say. I would bet that there are a lot more people that don't have the same issue as those that do.
    What I do know, around my area, where the temps have dropped, I've noticed a lot of people, with all sorts of different makes of cars, having the same problems. That's what has caused me to think that the cause may be more "reformulated winter fuel" related than anything else.
    Point is, regardless of the brand of car you drive, it's not a good idea to start the car for 15 seconds, turn it off, start it again for 15 seconds and turn it off. So, let your cars idle for a couple of minutes when you start it cold and you're going to drive it for less than a mile.
    Problem fixed.
  • gkouris73gkouris73 Member Posts: 2
    Carmike-- The solution to this flooding issue is to do the following:
    (1) Before going anywhere with the RX-8, let the engine run for about 4 minutes, atleast till the RPM level falls below 1000 to about 800....then go off.
    (2) Most importantly, if you plan on going short distances do #1, PLUS take her out for a short little 5 minute ride around the block and only then turn her off. If you follow those two rules, you will NEVER flood the engine.
    By the way, the MAZDA Dealership did NOT charge me anything for the Flooding (they had to reset the engine indicator and clean the combustion chamber)...I think they are getting the hint.
    Flooding the car once will not cause any damage to your vehicle, just DONT DO IT consistently....take care of her cause she is extremely sensitive
    PS: Apparently the Tire Pressure indicator that was beeping at me WAS CORRECT....my right front tire was 1/2 pound under inflated....those damn sensors are very sensitive :)
    If i can be of more service please ask
    Thnaks!
    Please don't flood your own car for the sake of having an experiment. I don't why I found that humorous, but I'm glad your service department took care of that for you free of charge. The tire pressure light working properly was a good sign; especially since it appeared that the tire pressure was okay.
    graphic - I'm picking up my new 2004 S2000 tomorrow. It's a formula red color. If I recall correctly, you have a red RX-8. Since red sports cars tend to be pulled over more often by the men who "work" for a living, I thought I should ask how your luck has been avoiding that kind of attention. Knock on wood I haven't been ticketed in seven years. Anyway, I'm glad to be behind the wheel of another high revving auto and long for the next spring/summer to arrive.
    Congrats on the S2000.
    I had originally pre-ordered a red RX8. As chance would have it, about a month before my RX8 was scheduled to be delivered, I was in my dealership trying to get a VIN # so I could do some "insurance shopping". Delivery for a newly arrived, pre-ordered winning blue RX8 was scuttled because the guy who ordered it couldn't get financed. They had the car all sparkling sitting in the "new car delivery driveway" and I fell in love with the color. Sales Manager saw me "oggling" it and tells me that it was now available due to the financing issue for the other fellow. While it had NAV on it which I didn't originally want, the dealer said he'd split the difference with me on the invoice cost of the NAV (about $1,000 off MSRP). I went to my bank, got a check and drove it home that night.
    In direct answer to your question, I've owned "arrest me red" cars before and have heard that they draw undue attention from the men/women in blue. I don't know if that's really the case, just that I've gotten tickets because I was driving well in excess of the speed limit. I don't think it would have mattered whether I was driving a white Crown Vic since I usually travel at least 10 MPH above the speed limit.
    All I do know is that anytime you are going a lot faster than the posted speed limit, you will draw attention to yourself, regardless of the color of your car. In fact, I can't seem to keep my car anywhere near the speed limit. I can't imagine anyone getting pulled over for a speeding ticket just because they were driving a red car.
    Your post was funny. I hope your son doesn't read these posts. I tend to have the same driving habits. I haven't seen a winning blue RX-8 on the road yet. I've seen a red, sunlight silver (of course), and titanium gray. Winning Blue is a good choice since it's more unique. I'll take your word for what you mentioned about the "arrest me red" cars. Hopefully, they have internet access in jail so I can notify you to send bail money. I'll try to keep the speed at what I consider the "grace limit" which is ten miles above the limit.
    I've never been one to worry about how my car's color would draw attention.
    Rightfully or wrongfully, I do see the police in my 'burg hassle the young'uns who have the "tricked out" cars and "thumping stereos". As a matter of fact, the police are real diligent about pulling over those with the loud stereos. My 17 year old has told me about several of his friends who have been "fined" ticketed and fined $250 for playing their stereos too loud.
    As I've told him, I personally don't care how loud he plays his car stereo (and yes, he's got the big subs in the trunk). As long as he's not bothering other people on the road who may not like his choice of music (me included), he can make his ears bleed. However, first ticket he gets nets him having his license lifted by me for a month. That seems to have sent the right message. Of course, that also means the only time he gets to crank his stereo is in unpopulated areas (which isn't anywhere near anyone else's listening distance or within 10 miles of our home). He tells me that's the "fun of it"...having someone else hear his stereo.
    As I've impressed upon him, I can play Tony Bennett loud in my stereo, too. He agrees he doesn't like it. So my point was made.
  • gjm4gjm4 Member Posts: 11
    The flooding problem is real since it happened to me about a month ago in cold weather (in the 20's). Drove 2 miles home from restaurant night before. Next night went to start car, car started for about 3 seconds, stalled and would not start again. Had to be towed to dealer the next day where they worked on it for a long time, changing spark plugs, etc. Don't think it has anything to do with gas formulation. May have something to do with requirement that car cannot be started and turned off before it is warm. This, however, can be inconvenient sometimes.
    I really think that Mazda should address this issue. Personally when I bought the car I didn't think I was buying a tempermental type of car. Since I bought my first car (1969 Mustang Mach I) I never had a car that flooded on me before. Of course, this is my first experience with a rotary engine. I'm not a car expert (just like to drive them) and am not sure what the benefit is of the rotary engine. Certainly not better gas mileage. Are they supposed to last longer or be cheaper to maintain? Maybe someone can enlighten me.
    The rotary is light weight and smaller. That's the benefit of it since it allows the RX-8 to have a roomy interior while still keeping the curb weight low. Otherwise, the car would be too heavy and more power would be necessary.
    I'm not sure what you own...you say you own an Infiniti FX, but you drive an RX8? Yet, you don't know the advantages of the rotary, but you bought one anyway?
    I'm confused!
  • clowngirlclowngirl Member Posts: 3
    A picture speaks a thousand words - so check this web site out for a little video clip of how the rotary engine basically works. I owned an RX-7 but this dual rotary engine in the RX-8 is 1000 times better. Quicker, quieter, peppier, ... if you want to read about more the flooding problems & what to do: also check out rx8forum.com as well.
    http://rx7.voodoobox.net/infofaq/images/Rotary.gif
    Thanks for the info on the web sites. I'll check them out. To graphicguy, I own both an FX45 and an RX8. The RX8 I bought for my son because he really liked the styling, drive, etc, not because of the rotary engine. I felt that since it was a Mazda it would be reliable. I drive the RX8 sometimes and I experienced the stalling problem. Hope this clears up your confusion.
    Do you drive the RX-8 more than your son? I assume he is quite young since you said you bought the car for him. Is that just an excuse you used to rationalize getting a fun car for yourself along with your SUV? I liked the styling and drive of a lot of cars when I was 18-20, but that didn't persuade my father to buy me a car like the RX-8.
    RENESIS ADVANTAGES
    --Lots of power from a small, lightweight power plant (1.3L produces 238 HP). This, in turn, allows engine placement flexibility, better weight distribution, better handling...
    --astronomically high reving power plant
    --great visceral sound and feel
    --very wide power band
    --fewer moving parts than a traditional piston engine
    Last question....will you adopt me?
    to follow clowngirl's lead:
    http://www.rotaryengineillustrated.com/index.html
    rotors are fun!....and very popular for light aircraft as well!!.....
  • rider1950rider1950 Member Posts: 4
    Well, I went and did it, bought the RX-8, traded in a Mercedes E Class. All this stuff about flooding has not appeared with 800 miles. My biggest problem is that every muscle car I see wants to get in a drag race on the x-way, but I don't participate. The oil guage is a joke, goes to two marks over middle immediately and never budges no matter what the car is doing. Oil level has not changed even though I was advised to watch it carefully. Handles like a dream and I am very impressed with the braking. It is a little slow off the line but once over 4000 RPM in second gear it will pace very well. The Z was horrible inside, had more power, but paled in the fast corner handling department. I have learned this RX-8 has to be pushed a little to get the fun out of it, but so be it. The young kids in my neighborhood think it is cool and come over to borrow the keys so they can just sit in it. No buyer's remorse here, except that the navi instruction manual is hard to understand without a degree from MIT. I wish it was a little faster, I am set to trade this in when Mazda reintroduces the RX-7, half the fun is anticipation, so they say.
  • c_hunterc_hunter Member Posts: 4,487
    I've seen a bunch of people posting about this, and it's usually prefaced by something like "temp dropped 20 degrees overnight". You can easily lose a couple PSI when the temp drops 20 degrees, so the tire pressure sensors ARE working correctly. Listen to them! It's important to check and adjust the pressure in your tires whenever the seasons change or when there are sudden changes in temperature.
    And, cold pressure is what matters -- if the warning goes off after you drive a few miles, it's because the tires have warmed up. It's not a malfunctioning sensor or another problem. If you get a low-pressure warning when the tires are cold, definitely add some air! That's when the reading is accurate!
    Craig
    Congrats and welcome......
    As I've told more than a few people, if the RX8 isn't fast enough for you, then I doubt the 350Z will be fast enough either, as it's only marginally quicker...and that's only in a straight line. If your desire to move into significantly faster iron, move to a Cobra or a Corvette.
    The flooding issue seems to be isolated to just a few. And to those who are conciously trying to "flood" their vehicles. As I've mentioned before, this isn't the sole province of the RX8. Given the same circumstances, you can get just about any car to "flood".
    My RX8 warms up quickly....usually within 3/4 of a mile of driving from a stone cold start. I've experienced no flooding in 20-30 degree weather...even driving short distances (3 miles or so).
    As other's have mentioned, if it's a concern, warm up the car for a few minutes before driving off or shutting down.
    Have fun in your new 8....you're going to love it.
    I don't really drive the car that much since my son now keeps it at college. He is in his 3rd year at a college about 250 miles away. Sorry to say but I enjoy driving my FX45 a lot more than the RX8. If you ever get a chance to take a FX45 for a test drive you should. It handles much better than any other SUV and has off the line pick up like you wouldn't believe. It's also very comfortable. I've had Mercedes and BMW's but, in my humble opinion, the FX45 is the best I've had yet.
  • yosarianyosarian Member Posts: 5
    When I picked up my RX-8 here in the frozen wilderness of PA (if I hear another Floridian speak about lower temps. in the 70's range, I'm going to freak :-)) I took a moment to speak with the Service Advisor, as I had worked for Mazda for a short period of time, and often heard our rotary engine tech. talk about the need to drive the car, and not baby it. Plus there were so many posts about the flooding issue, I thought it well worth my time to investigate.
    He said that Mazda was soon to come out with a hotter spark plug. How definitive an answer this would prove to be remains to be seen, but it sounds like something that none of you have been made privy to.
    I've had the RX-8 long enough to fill the tank a couple of times, and I'm seeing the kind of mpg that most of you have lamented. At best I'm about 13.5 mpg, and that's all highway mileage. Admittedly, it's at an average speed of 70 mph+, so that might have some bearing. I hope it gets better soon.
    I got beat bad recently in an impromptu race with a 350Z. Straight off of the line at a traffic light. Two points -- I was light on the gas on take off as I'm getting used to the new car, and its requisite slightly greater gas pedal pressure when pulling out. No telling which package he got for that car, and in any case, his price tag would have been about $5,000 higher. For that much more money, I'll give him the one or two seconds it takes to get to 60 mph. And I don't think he would have faired so well in the slaloms.
  • iusoftiusoft Member Posts: 2
    I've been reading the RX-8 boards for a couple months, mostly trying to decide between an RX-8 and G35. Finally I managed to get my wife to take a real drive in an RX-8 today, and while I loved it, she couldn't stop complaining about the hump on the passenger side that forces her to sit awkwardly. She claims that she could never sit in this car for a long trip since her left leg would either have to be on the hump, or pushed to the right side.
    Truthfully, has this been an issue to any of you RX-8 owners? Do front passengers feel twisted with that hump taking up their legroom? Or is this her imagination in dealing with being in the car for the first time?
    No problems here with comfort.......matter of fact, I found the RX8 more comfy than the G35c.
    yosarian...get some miles on your 8 druing break-in. MPG and performance should get better. I find the best RPM for launch in a straight line stop light war without burning the clutch is about 4K and running it to the 9K redline. I'd give up maybe a bumper's width to 350Zs by doing that. If I did an 8K RPM launch (which I won't do), I'd probably get even closer. Get them into a "bend" in the road, and you'll lose them.
    Of course, this is all hearsay...not that I do any street racing nor would have any personal experience with any of that sort of thing.....;-)
  • docsrxdocsrx Member Posts: 4
    I have my RX8 in Wisconsin and recently put Bridgestone Blizzak snow tires on. We had our first snow last week (it was icy ,too) and the car handled fine. Drove a bit slower of course, but nothing unusual.
    My 17 year old drove the car yesterday and could feel the better grip on the road with the new tires compared to the original performance tires.
    I think the 50-50 weight distribution is a plus, too, on bad road conditions.
    Also, I thought I'd add my two cents worth on the flooding issue. It did happen to me during October. I had backed the car out of the garage on a Saturday to clean it , and put it back without driving anywhere else. Of course, the next day it had to be towed.
    No trouble since then, however, because (I think) I've never shut it off without being sure the engine gauge shows it is warm.
    I don't really let it warm up for 4 or 5 minutes before driving off as some have recommended. I have reved it up to over 3,000rpms for a minute or two if the engine temp is iffy.
    It has been cold here at night since the beginning of the month and no problems at all.
    I agree, Mazda should do something so drivers don't have to worry about cold engine flooding though. I've had many cars in the 35 years I've been driving and never had that problem with any other.
    Still..... I love my Rx8. Everything else about it is fantastic!!
  • qbrozenqbrozen Member Posts: 33,818
    I bet none of those other cars over the past 35 years were rotaries.
    I'm not sure there is anything Mazda CAN do about it. It seems to me its an inherent property of a rotary engine.
    Not exactly sure what "foot space" problems you are referring to ...??
  • vtlcvtlc Member Posts: 25
    I bot my RX8 a month ago and was noticing green spots on my garage floor after a few days. Took the car in and they said it was just the hot coolant from the overflow bottle. They said if I see more in the next few weeks come back. Now I went back and they said it was comming from the engine and I need a replacement engine. Was told I would get a remanufactured one and not a new one. I somehow think they knew the problem was there and sold me the car anyways. I feel ripped off paying 40K for a car that is going to get a remaufactured engine. Any ideas on what actions to take would be great help? I asked them could they just get me into a new car and they said NO. Sad Story isnt it.
    no way you should take a rebuilt unit with only 1K on your car.
    but where the heck are they getting the rebuilt unit from anyway??? This is a new car with a new engine. I can't imagine that there are remanufactured units even available (or not many, at least). And where is it leaking from? Is it just a gasket? Why don't they just replace the gasket on your car? None of this makes any sense at all.
    vtlc....as qbrozen says....something's not right here...
    Did you buy the car new? Why did you buy it for $40K? Which package did you get? Is or was the car modified? Did you buy it new from a Mazda dealer?
    There aren't any remanufactured engines out there since the car is so new. Where are they getting the engine from?
    Did you notice any fluids around the radiator?
    Something ain't right.......
    I don't think anyone can be of assistance for vtlc. The first sign of being ripped off was the $40K he paid...unless that's Canadian dollars. Let's just move on...this sounds too ridiculous to be taken serious.
  • mazdafunmazdafun Member Posts: 2,329
    I'm sure it's not ridiculous to him.
    No one's abandoning him....we just need more details to what either sounds like a "screw job" by some mechanic, a dealer, a "mod shop", or lastly, something we hope isn't true, a bogus posting.
    I didn't mean to sound like I was abandoning anyone. Like graphic said, we need more information. The fact he says he paid $40K sends up some red flags concerning the accuracy of the post. Also, I've never heard of any service departments deciding to replace an engine with a rebuilt engine; especially with only 1K miles on it. The Mazda warranty would cover the replacement of a new engine anyway. It just sounds baffling.
  • redrpmredrpm Member Posts: 16
    You guys are so quick with opinions/judgments....think a little. If he paid list of $33.5k and tax and reg he'd pretty much be at $40k. Or if he was upside down on a trade. Or....
    As for remanufactured engine, his is not the only one getting replaced. It makes complete sense that the ones getting pulled are sent back to Japan and potentially rebuilt. It's not what I'd prefer...but certainly plausible.
    I quit posting after graphic insisted my run rich problem was only a very isolated issue. It's not. Have been to 4 different dealers in two months, and each time they tell me the number of owners suffering thru this and waiting for Mazda's official reflash mid-January is growing. It's part of buying on the leading edge, and I'm over it...albeit a bit tarnished.
    I admire the car and the owner enthusiasm surrounding it. Just don't let that enthusiasm blind you to the adverse realities other owners might be experiencing.
    I disagree.
    Flooding problems are pretty much isolated incidences. I'd be surprized of there were more than 20 such incidences in the almost 12,000 that Mazda has sold in NA. And some of those were because more than a few owners actually tried to flood their engines. If yours was one that flooded or was running rich, I'm sure it was an ordeal for you, but please don't charactorize it as an epidemic.
    If you've been to 4 different dealers, and they are all inept at fixing your problem, then there's something more amiss than just engine flooding.
    As far as engines being replaced, I know of two of them. Of those two, one was modded (and I have a sneaky suspicion the other one was, too)...a definite "no-no" with any car manufacturer. The one reported here sounds suspicious, also. There aren't any "remanufactured" engines available yet, so how a dealer can get one is beyond me.
    My opinion of anyone who pays $40,000 for an RX8, no matter what the circumstance, is something that simply makes no sense.
    Most of us do get weary, however. The RX8 has received almost unanimous accolades from the automotive press throughout the world. As soon as another "test" is done (like the one here at Edmunds) crowning the RX8 as the winner, a slew of misinformation ensues by non-owners trying to berate a great car. Within 12 hours of some simple problem (like flooding) shows up at other RX8 sites, all of a sudden it shows up here at Edmunds, too. More than just a little coincidental in my opinion.
    My intent has never been to berate the car publicly. It is the overall best performing car I've owned...and that's a good list. I just don't understand why every post on this problem thread site has to be second guessed and the poster's intentions cynically questioned. It's the defensiveness that makes me weary. We're not in court.
    My car's issue(s) has never been flooding...haven't had that dreaded occurrence. My wife drives it occasionally and I remind her everytime what NOT to do so we don't have to deal with that.
    My problem has been the cutting out above 6,000 and knocking/pinging in mid-range. I don't have the highest regard for dealers' service depts, but I also don't think all 4 are inept. Possible, but I get the sense that if I saw a 5th and a 6th you'd say they're inept too. That's what I meant by blind enthusiasm.
    I've talked with several owners while at the various dealers who have brought their cars in for the same run rich/cut out problems...multiple times such as myself. Trust me, they are real people with real problems. And if Mazda is indeed stepping up with a reflash fix mid-Jan, then they've obviously validated the problem too.
    I'll get back off the board now, but had to speak up regarding the dismissive judgments here. It's not your place, or anyone else's, to care what someone's final bill for a car was. Maybe they dropped in to bash...maybe they overpaid...or generalized in their number, whatever. But given the reception you guys gave him I'd be surprised to see them care to offer anything further.
    That's a shame.
    I bot the car at Lithia Mazda in fresno CA on 11/10/03. Paid 34,000 plus fees/tax almost 37k at 4% apr = about 40K. Got the fully loaded model GT silver with nav and all the stuff except the spare tire. It was the show room one in the building. Red/black leather 6-speed with 44 miles when driven off the lot. Was told it was brand new (well it looked, smelled, and feels like it was brand new). I drove it 2 times before I decided to buy it but I guess I wasnt smart enough to see if there were any leaks. Well I mean brand new cars are not suppose to leak right. An no I dont modify my cars or any car, I am awful with cars, all I know how to do is check the fluid levels, I cant even change a tire thats why I have AAA plus membership. I bot the lifetime oil change service because I was concerned about the oil issues in this car. The service guy said it was leaking from the second rotor housing between the back plate and the housing where a hose is attached to the top part of the engine close to the firewall. He actually showed me where it was leaking and I could see a bunch of light green fluid and some white waxy stuff all over that back part of the engine coming down to the oil pan(the big black box like thing at the bottum of the engine. I was told he ordered an engine and would be here in a week and will take another week for the work to be completed. They put me into a rental a (buick lesabre), after they put me into a 98 ford escort which was so unsafe I returned it to enterprise after 2 blocks off the lot. I wouldnt even buy it for a 500 dollors, the brakes dont even work until the pedal was pushed almost all the way to the floor.
    I'm not pulling any stunts here on this board or to anyone of you folks here. I loved the car and was willing to pay $1500 below MSRP for it. But now this problem came up and I dont know what I can do I just dont think its fair.
    is he still talking about a rebuilt unit?
    Have you tried calling Mazda about this? Even going beyond the fact that you will have a new car with a rebuilt engine, the engine and chassis will now have mismatched VIN numbers. I would consider this completely unacceptable if this were my problem.
    i agree that some folks should be a little more patient with posters and get more info before jumping to conclusions.
    HOWEVER, you have to admit that there have been quite a few posts here and the other RX8 boards where its some new member, with no other posting history, who claims they are having all kinds of problems, then disappears and never is heard from again. This is why some regulars are so dismissive.
    BUT, in vtlc's case, he has come back and clarified his problem a bit and, hopefully, will continue to post updates until a resolution is reached. This is something that is unfortunately missing from many of these boards - closure. Without closure, the problems/stories/issues/events amount to no more than rumors.
    First, if I came off as dismissive, my appologies. Not a qualifier, but as qbrozen has pointed out, there is a ton of mis/dis-information about this car being thrown around. As soon as a positive review comes in, it seems as if someone with heresay, unsubatantiated rumor, less than truthful information....all come out of the wood work.
    Now, let's get to the problems.
    vtlc....thanks for the info and the breakdown of your deal. It makes more sense, now. Sounds like your dealer has diagnosed the problem correctly....leaking seal. SO, they are sending you a new engine (not remanufactured) from Mazda in Hiroshima. That's a good thing. Don't know why they just don't replace the seal, but a new engine is a good thing, too.
    As far as rental cars are concerned, I think I'd make it an issue with the dealer that you bought a new car and expect a new "loaner" (not some beat up raggedy set of wheels they had on the back lot). Of course, the only thing Mazda promises is that they'd give you a loaner...they never stipulate what kind of car it will be. That said, I would think your dealer would bend over backwards for you given the circumstances.
    redrpm....I'm not aware of any ECU re-flash in January. I've heard bits and pieces of rumors that some needed a reflash, but nothing definitive. It still sounds like a fuel issue to me...a clogged fuel filter, perhaps? If it's cutting out at higher RPMs, it could be the computer won't let the car go to any higher RPMs because the pinging (or detonation) can be harmful to the engine. Could be just one go round with bad fuel. One tankful of bad fuel (probably less) can "muck up" a lot of things in any car.
    Honestly, if 4 or 5, or 6 dealers can't figure it out, then, yes, I'd say they are inept. What have they done to solve the detonation problem? What are they telling you? Have they checked the EVAP unit? Have they pulled and checked the plugs to see if they are fouled? Are there any cracks in the plug wires?
    It sounds like the fuel supply is being "cut-off" at some point (5K RPM, you say) to save the engine. The computer codes should tell your dealer(s) exactly what's going on. Does your CEL come on?
    The ECU can be re-flashed at any time by the dealer.
    You also may want to tell your dealer to disconnect the battery for an hour or two so the ECU re-sets itself. IF the ECU was bad, I doubt you'd even be able to start your car.
    Those would be the things I'd check.
    vtlc - I'm glad you came back to clarify your problem. The last post you left explained a lot more than what your previous one did. Like graphic said, we get a lot of fiction posted here.
    redrpm - Although some us (like me) might be quick to judge a post, that doesn't mean we're wrong. If a poster is going to state a price they paid or problem they have, you bet I have the right to question it when it seems unusual. That's why we post!
    With that said, I do agree that the RX-8 may have some problems and not everyone of them can be dismissed as an isolated incident or untrue. It's awfully paranoid to think that the car has so many enemies that would make this stuff up.
  • rx8inazrx8inaz Member Posts: 1
    HI all - I bought a red 6MT with GT package in late October. I have had none of the problems reported on this board. Where I live it can be in the thirties in the morning, and when my wife drives to work it's a pretty short drive (but she doesn't drive to work all the time, and usually takes the long way. But I park facing up a pretty steep hill, which may help the flooding issue. I do notice that sometimes when she first starts it, there is a fair amount of gray smoke, but it goes away quickly.
    But here's my problem. The dealer told me the first time I drove it that it was a very deep clutch, and it is. When first depressing the pedal, the first half of the travel seems to be taking up slack, or engaging the master cylinder. Then more resistance is felt to the floor. Not a huge amount, but noticeable if you're looking for it. And when you put it in gear and start to release the clutch, it engages very close to the floor. And it doesn't seem to shift as smoothly as I think it should. It doesn't grind, just doesn't seem as "snicky" as I think it should. Leads me to believe that the linkage is not adjusted properly. So what's the word? Where do your clutches engage?
    Thanks in advance for the help
