Mazda RX-8 Accessories and Modifications
CB.
http://www.andysautosport.com/bodykits.php?id=Ma04RX&brand=Erebuni
If so, put them on e-bay.
It is supposed to....I've heard of aftermarket ones not lining up exactly, but the problem was fixable.
Just to mention I order and install the auxmod card in my RX-8 today so I can hook my Dell MP3 player to the Tape aux.
That thing is running great witout any glitch.
You can take a look at www.sylfex.com
http://www.myradiostore.us/auxadapters/pie/factory/no-external-changer/maz-pc-alp.html
$85 w/free shipping and no tax. Hooks into the OEM stereo as if it were a CD changer. Just hit the CD button again to switch from CD (or in my case MP3) to the aux in. Works very slick.
http://www.mazdaparts.com/ProductDetail.jsp?LISTID=1E0000-1112606399
has it for $71.50-$74.50 plus shipping (nearly $10 for me) as well.
The only "gotcha" on the PIE is that the firmware of the radio has to be 9.55 or higher to work. For older RX-8s Mazdaparts can update the radio as well.
Dennis
With the NAV system you can get an expensive box (and cut some wires) and get things like games, TV, DVD video, backup camera, etc on the NAV screen.
Dennis
thnx
With a non-Bose system it should be pretty easy to add amp(s) and upgrade the speakers and add a sub. Even with the Bose system I have seen folks put in better speakers for a claimed improvement in sound. I have the Bose system in my GT and it sounds "OK" for an OEM system. The more you turn it up, the better it sounds (to a point). It could use a sub though as it is weak in the bottom end.
Dennis
I've had my 8 for quite a while and am in need of some new tires. The Potenza RE040s that came with the car were very nice (on dry) until about 8k. Then the noise started. Kept them rotated and balanced... no alignment issues, but by 12k the noise was irritating as hell. Due to this and the excessive quickness of tread wear, I don't think I'll be replacing these tires with potenzas. I was wondering if any of you had any +/- advice on tires you've used.
I've just finished adding a XM Commander radio to my '05 RX8. With a wee bit of modification it fits very nicely in the ashtray pocket, behind the flip-up door, so everything looks stock. The receiver box sits under the back end of the console between the rear seatbacks. It is direct wired into the stock radio via the connector used for the cassette deck and works quite well. PIE makes this direct interface (two parts - #maz/pc-alp and #alp/m-rca). To listen to XM you push the CD button - the RX-8 display says "EX 1" and you hear the XM. If you put in a CD it will switch from EX 1 to CD.
I'm puzzled about the MP3 add-on option. Does anyone know what form it takes? I was hoping the CD would play .wav and .mp3 files, but it only plays standard music CD's, not mp3's. What medium does the mp3 player use?
Oh- the XM commander takes up most of the area behind the flip up door, so I had to remove the cigarette lighter. No problem, don't smoke. But it's handy to have a power outlet up front. See that little round hole plug in the dash just to the left of the glove box door? There's nothing behind it. I picked up a Radio Shack power outlet and with a minimum of filing it fits perfectly in that hole. Wired it up to the old cigarette lighter wires and now have a power outlet right on the dash.
Wow, this post got too long.
If you intend to install one, be aware there is a "hidden" bolt to remove the interior panel. Talk to your dealer about where it is - they were warned after several panels were broken.
Have not had the same problem. The tires may not have been rotated to turn in a different direction. Howling can be a problem when this is not done. You can go to Tirerack.com and look up the different ways to ratate non-directional tires. Hope this helps with your new tires.
Harg">link title
Turbonator - there is a simple reason not to use this or any other non-stock intake device. Any different turbulence introduced into the intake stream will disturb the air flow measurements, which are done with a heated resistor that is cooled by the passing air. The car has been tuned with stock parts and therefore "stock turbulence" in the intake stream. If you install any different devices, you should then retune the car with the new turbulence in mind. The turbonator is supposed to help with fuel vaporization, but you have to wonder how it can do this so far from where the fuel is injected! It may work in a carburated engine, but is not a good idea on a computerized fuel injected engine - in spite of what they may say when trying to get you to buy one!
Has anyone had remote start added to their RX-8? Any problems? What about "ride flat" tires? (I think that's the terminology) Anything new from Bunnygirl?
What we really need is the immobilizer system built into the transmission insead of the engine such that it locks the car in neutral (or Park for autos) until it senses the key in the car - for those of us who need to get the car warmed up before driving it - not really applicable to the RX-8 though. I wouldn't want a remote start system to try to start my RX-8 when it's sitting at -20 deg. That's just asking for a flood!
The tires you're talking about are "run flat". Close. They work but you do have a tradeoff - they run a little rougher as they have stiffer sidewalls.
So, if you are looking at a *Mazda* genuine remote start system, the issues with the immobilizer system mentioned above do NOT apply. It does NOT disable ANYTHING that the poster mentioned.
http://www.webasto-us.com/press/en/am_auto_sunroofs_3425.html
In this connection, after installation and after the car gets to operating temperature a screaming squeal is now present from around the area near the throttle body. The dealership mechanics did not know why this noise develops nor where for certain the noise is coming from. One mechanic pinched off a rubber tube that plugged into the new cool air intake duct near the throttle body and the noise stopped until he let go of it. I thought possibly it was a leak from the rubber tubes connection so I clamped the tube on to the duct, but that did not fix the noise.
The noise sounds like either the scream of an air leak or the cavitation scream of a pump that is vapor locked and is trying to pump air istead of a liquid. The dealership finally determined the noise was not harmful only because they were stumped.
Has anyone else experanced the same thing after having this "speed" cool fresh air accessory installed to replace the stock intake box and filter holder.
Also they could not tell me how to service the K&N type filter that is included with accessory because it appears it is impossible to get to the filter without taking off the front bumper shell as they did when it was installed.
Hopefully someone can shed some light on the apparent installation problems that have developed. The dealership did admitt this is the first "Speed"cool fresh air intake they ever installed. Hopefully ther is a certified Mazda mechanic that reads this foru that will tell me what the dealership should look for or who to call for help........Please help
