Visitor Agreement.
Shell and Chevron readily admit so. Shell's V-Power is only in their premium grade, and Chevron says that their premium fuel contains more Techron than the lower grades.
Top Tier Gas anyone?
kgbkahnk "Chevy Trailblazer, GMC Envoy, Oldsmobile Bravada" Oct 27, 2004 1:38pm
Of course, I don't disagree that poorly engineered engines or defective running will create problems--that's certainly possible.
But my additive is quite expensive and I'm certainly not going to put it in very often...that would cost me over $200 a year and I don't see the cost benefit from my own past experience. YRMV.
Specific to this latest bucket of bilge water:
Modern automotive fuel contains an additive package that is designed specifically to keep all of the components of the fuel system clean and in good working order for the life of the car AND all of the scavengers necessary to keep the combustion chamber and exhaust system clean and carbon free. Any engine that exhibits premature component failure and/or carbon deposits is either incorrectly fueled (as in using premium in a car designed for regular fuel), incorrectly operated, or a non-conforming engine (as in upside down rings or induction leaks). Disagree? I'm sure you do, however, you seem to have absolutely zero proof.
Regarding your silly statement, "A lean mixture causes additional heat, and engine damage." Oh really? Says who? If you look at the science, you will see that as the fuel/air mixture leans past stoichiometric, the combustion pressures DROP rather dramatically, and as a result so do the temperatures. As you continue to lean the mixture, the pressures and temperatures continue to drop, all of the way to the point where the mixture is too lean to sustain a flame front, and essentially fails to burn. How is that hot?
In the end, assuming an owner of any given late model car follows the manufacturers’ recommendations relative to fueling and maintenance, there should be no need whatsoever to add anything extra for the life of the car.
Best Regards,
Shipo
On the other hand, marvelous mysterious oil might work better yet...........
I've been buying the cheapest gas I can find for many years now, and put no additives in, and cannot remember the last time I have even had one misfire, rough idle or anything of the sort. Of course I don't drive Hondas. Maybe they need all these Wonders-in-a-Can to operate properly.
Your posts toward gregoryc sound rude and arrogant, and you yoursefl provide no proof, only your own statements. He makes his statements; you make yours. Neither provide verifiable proof. It's your opinions. I read both and determine my own opinion.
If you disagree with someone's postings, politely reply or ignore them, please.
Personally I use Techron by Chevron. It does make a difference in the car's running after I use it. This is probably injector cleaning having an effect. I don't take my heads off to check for deposites so I don't know how residue is left inside the combustion chambers.
I attempt to provide references that support the beliefs that I state, which were developed from considerable research, wherever and whenever I can. That I cannot offer "Proofs" to disprove the factoids that gregoryc posts is rather difficult. It would be like my saying that Marvel Mystery Oil, when taken orally as a prophylactic measure, will cure zits. Then, when the guaranteed outcry comes, I simply respond with, "Oh yeah! Prove that it doesn't." It is very difficult to prove a negative in that fashion. Why? Simple, because no competent scientist would spend the time, money and energy to prove something so silly.
So, are my posts rude and arrogant? Yes, I'm trying to get him mad enough to finally do a little research on his own, and then if he does find some supporting science, THEN we have something to talk about. Until then, it's like this:
G: "Lead in the form of TEL was used to lubricate valves "
S: "No, sorry G, but lead is not now, nor has it ever been used to lubricate valves. TEL is simply an octane enhancer/knock inhibitor."
G: "Go look it up."
S: "I did, here are 5 scientific links to the likes of Universities, NACA and the SAE that specifically state the TEL was developed as an octane enhancer, and that is what it is/was used for. Please note there is no reference to the lubricity value of TEL."
S: "Here we go again..."
Regarding Techron, there was a time when it was required by the manufacturer (BMW, any others?) for some cars to keep their fuel systems in peak condition. That time has passed as there are now international standards regarding the additive packages put in the fuel that we can currently buy. Said additive packages are specifically designed to keep the fuel systems of late model cars in peak operating condition for the life of the car. In the past I posted several links supporting that statement, and if pressed, I could come up with them again.
Regarding your use of Techron, a sampling of one does not a scientific study make. That said, I can turn right around and say that two of our three cars are virtually identical twins, the only difference being the 5 model years that separate them. So? Well, the older one, which has nearly 90K miles on it runs easily as well as the newer one. Not only that but it has consistently improved its fuel economy each year since new to the point where it is now getting on average about 3 more miles per gallon on the frequent NYC to Southern New Hampshire trip that I have been driving it on since it was new.
Is that scientific either? Nope, it is just as irrelevant, however, if I was to listen to the bilge that G plasters everywhere and anywhere he can, I would be lead to believe that the older car is ready for the scrap heap simply because I have never put in SuperXXX (fill in your favorite snake oil here) in the gas and oil, or used any other "preventative" measure beyond what the manufacturer recommends.
Maybe I'm missing something, however, when someone like G posts things that are controversial, and contrary to what the engineers who designed and built the engines in our cars have said, they need to substantiate their claims. Is that too much to ask? Yes, no?
Best Regards,
Shipo
I'm sorry, my bad, I had no intention of implying such. ;-)
Best Regards,
Shipo
alcan "Oil change/fiascos" Nov 25, 2004 6:27am
alcan "Oil change/fiascos" Nov 25, 2004 11:58am
Best Regards,
Shipo
Old Volvos are notorious for a similar problem---wherein you get excellent compression readings on a basically worn out engine---because the compression rings are not affected but the oil rings are.
Compression tests alone can fool 'ya.
I have heard that it is oxygenated, which reduces pollution in older cars, but results in poorer gas mileage for everybody else. And so I've been assuming that my mileage will improve once spring rools around.
But I don't know for sure, so I'd love to hear what you folks know about it. Thanks!
Best Regards,
Shipo
If you can fit it inside, it is unlikely that you would notice the difference in your mileage unless you are driving a very small, very low powered car (and even then the difference in fuel mileage would no where near make up the cost of shipping). Consider this, 200 pounds is less weight that an extra passenger and a tank of gas.
Best Regards,
Shipo
3300 miles(1 gallon / 25 miles)($2/gal) = $264
3300 miles(1 gallon / 23.75 miles)($2/gal) = $277
As shipo indicated, it really depends on the car, however, I doubt that you could ship 200 pounds of freight for under $20 (rounded up for fluctuating gas prices).
http://www.titaniuminfogroup.co.uk/automotive.htm
Isn't gasoline regulated. I mean, 87 octane is 87 octane right?
Any thoughts?
PM
In other words, you say you get 18 mpg highway. Well if you buy a small car you might bump that up to 24. And you know, depending on how many miles you drive a year, that may not add up to many extra gallons per year. It's really only about 15 gallons per month.
So thinking gallons rather than MPG gives you a better handle on how significant switching vehicles might be.
For me for instance, to trade in my Porsche for a Toyota sedan would save me, per year, enough gallonage for two new car payments out of the twelve. That's not enough to motivate me.
When I traded for my second LeSabre, I couldn't find a way to trade the older LeSabre for a smaller car for better mileage. Having two LeSabres seemed overkill. I already owned the '93 and it got good mileage and I would have paid more to have less car with slightly better mileage if I traded it.
Now that gas prices here are solidly above $2.00 I really notice only some increase in total gas cost. I make a few less trips by consolidating small trips and probably save a lot I used to waste. I certainly am getting better mileage than the SUV owners who drive a long commute at 15 mpg. And many still haven't slowed down to save the extra gallons they could save by driving 62 instead of 75-80 between Dayton/Cincinnati. I realize some people driving a pickup because it's a work vehicle.
I have a 2000 Passat GLS and a 2004 Acura MDX. Manuals for both cars say that only premium gasoline should be used (91 or 93 octanes or better, can't remember which). However, I have heard that premium fuel is recommended for new cars, so switching to lower grades will not damage anything as the car ages. However, I have also heard that older cars benefit from premium gasoline. I need someone to set the story straight. With today's gas prices, it would be great if I could switch to regular gasoline. We only put about 500 miles per month in each vehicle, so this is not a critical thing, but it would still help. Thanks!
The age of a car has nothing to do with its octane requirements. Either your car's engine is built and designed for a certain grade of fuel or it isn't. You can't "treat" your car to a higher octane than it was designed for. That is wasting money. But you can use a lower octane as long as you can live with the lessened performance.
What you DON'T want, or should not tolerate, is what we call "pinging", which sounds exactly like a chain dragging under the engine when you accelerate. This "pinging" is actually pre-ignition, which basically means that because the octane you are using is really too low for the engine, the combustion in the engine is very ragged and un-even, causing the engine internal distress.
While I doubt your cars would experience this "pinging" under hard accleration (it's quite noticeable, this "chain" sound) if you dropped to 89 octane or even 87, still you should listen for it, and if you hear it, don't use that lower octane. I think though that your car's computer will easily adjust for 89 or 87 octane.
I use 87 octane in my V-8 Porsche no problem.
I used the mid-grade gas (89 octane) in my previous car, a 1986 Honda Civic probably 85% of the time and drove it for 15 yrs with never a ping or knock or any engine problems whatsoever.
I recently increased the tire pressure on my Corolla by about 4 or 5 pounds over the recommended pressure and recently got 34.06 MPG (city) whereas I normally get 30 or 31 MPG -
The whole thing is that the different grades of fuel take different lengths of time between the spark event and when the flame front is fully organized. The lower the grade of fuel, the quicker the flame front is developed. Engines are designed with certain combustion chamber configurations and compression ratios so that when fed the proper grade of fuel, the Peak Pressure Point (PPP), which should theoretically happen at about 15 degrees after TDC. If you use a lower grade of fuel than what is called for, your PPP occurs sooner at say 10 degrees after TDC, and that is where "Pinging" or "Detonation" (sorry Shifty, "Pre-Ignition" is where the fuel combusts on its own before the spark event, hence the name "Pre-Ignition", this condition WILL destroy and engine very quickly) occurs. Detonation is in essence the flash combustion (instead of the flame front smoothly burning all of the fuel in the combustion chamber) of some amount of end gas due to the higher pressures associated with the early PPP. The issue here is the degree of detonation, a very little is considered harmless by some and beneficial by others, personally, I'll refrain from comment. Moderate detonation, where you can hear light "Pinging", is where the problems can start. A brief Pinging event when you first press the throttle is most likely harmless, however, if said Pinging continues, engine damage (in the form of burned valves, burned pistons and broken rings) can result. Severe detonation, a condition which is extremely rare in modern engines, can destroy an engine in a matter of moments.
The flip side of using too low of a grade of fuel is using too high of a grade of fuel. Now the flame front takes too long to get fully organized, resulting a late PPP of say 18-20 degrees. Now what happens is that your fuel is far from being fully burned before the exhaust valve opens, and as such, the flame front continues burning fuel right past the valve and into the exhaust manifold. Basically harmless, but since it doesn't convert the resultant heat into mechanical energy, it is also highly inefficient.
Now let us add modern electronics into the equation. My BMW, which carries a "Premium" fuel recommendation from the manufacturer, can run safely on lower grade fuels, however, the computer senses that detonation is occurring and retards the spark event. The delayed spark keeps the PPP at that engines' designed in optimum point. Unfortunately, since the ignition has been retarded (resulting in cooler temperatures in the chamber), the engine is not running at peak thermal efficiency, hence lower mileage and power.
Regarding cars that carry a "Regular" fuel recommendation, it is unlikely that the engine in said cars was really designed for "Premium" fuel, and as such, said engines will not benefit from higher grades of fuel. Using higher grades of fuel in such a car will most likely result in LOWER mileage per gallon of fuel, and possibly INCREASE combustion chamber deposits, which is never a good thing.
Rule of thumb. Use the fuel that your manufacturer recommends.
Best Regards,
Shipo
My father-in-law has a Toyota Highlander which the manual states uses 87 octane, but the manual also states to use a higher octane "for better performance".
There really is no extra "power" in higher octane fuel. It just has a more even flame front, but if your car's engine isn't designed for that octane, it doesn't know it from 87. The car's computer has to be designed to advance timing to take advantage of higher octane. If that's not built into the computer, your engine timing will remain optimum for 87 octane, the design limit.
as I said, all I know is that the higher octane provides my car with better gas mileage -
Best Regards,
Shipo
Best Regards,
Shipo
thank you
Having said all of that, if your car was built specifically for Premium, then that is what you must use, regardless of your ignition timing or the condition of your valve seats.
Best Regards,
Shipo
The myth that high-octane fuel contains more power came about because vehicle manufacturers typically require the use of premium fuel in high-horsepower engines. However, it is not the fuel that provides the added power but rather the engine's "state-of-tune,” which involves a number of factors including compression ratio and valve timing. When these engine variables are tuned to produce greater power, the possibility of detonation also increases and, thus, the requirement for premium fuel.
Original message by -badgerfan [gregoryc1] as follow.
"I guess your preference is to waste money"! ----That is a "judgement call" on your part!----- In the Honda manual it states that the owner can use 86 or higher octane fuel in the engine.----- Not all fuels sold at stations are the same. I don't drink, smoke or gamble, so my only problem is burning premium fuel. That is not bad when you consider the results to the other things. (Drinking = health / liver issues, Smoking = Lung Cancer amd Gambling = loss of savings and life style). I will take purchasing Premium Fuel as a personal issue any day! In addition to purchasing that high priced premium fuel, I also change the oil and filter every 3,000 miles, because I love a clean crankcase, and clean oil in the engine. The oil is so clean on the dip stick of our two Honda engines, that I can harding see the old level, and the 2003 Accord has 20,000 miles on the clock. Yes, I do spend money on "preventive maintenance", and I love the total experience. Just yesterday, I took my wife's 2004 Honda Civic for a 3,000 mile oil and filter change at the dealer. I had a great experience. I arrived at the dealership with three cups of flavored coffee,(one for my wife, myself and the service writer), and in addition, I gave the mechanic $5.00 as a tip for the service rendered. Yes, I love to spend money on my things and on people that I like. Life is just too short to be cheap! -----And, I never knew anyone that was able to take their money with them when they died.----- Don't try to bring the war in under budget! ---- Life is more than a "balance sheet"!
The myth also was created by older cars, wherein you could in fact add high test fuel and then manually bump up the timing (advance it) and generally notice an increase in power.
Now of course all this timing business is done by computer, which has a map that optimizes performance and octane for your particular kind of engine. If you aren't mapped for high octane fuel (that is, if the computer won't advance the timing enough for your engine to take advantage of it), then it is a complete waste of money. Even if it is mapped for it, you may gain just a minimal amount of power at the expense of fuel mileage.
High octane just has a smoother "flame front"--it burns more evenly, so combustion is optmized in that sense.
But there's no more power in it, no more energy I mean per volume.
