There is a lady at work that is dying to buy my B3000 4WD. I'll hang onto it for the time being. But I will take a close look at the Ranger or another B-Series when that 4.0L SOHC is finally available. I'm anxious to test drive it...
I have 62K on the truck. Fit and finish is still good, even with it parked outside all the time.
Extra cab is very handy and the jump seats are great for use in a pinch but admittedly I'm not comfortable having the kids back there.
5 spd tranny is fine but the 4 cylinder doesn't cut it. Maybe the weight of the truck is too much for it and hopefully the B2500's are a whole lot better. Unloaded it drives okay on the freeways etc but moderate hills, wind, etc. means that there is no passing etc. and the need for keeping my eyes on the rear view mirrors. I would strongly recommend the 4 litre V-6.
Only electrical problem is the "Check Engine Light" that stays on. Had a sensor replaced at 40k and a bolt from the front caliper came off at 35k.
Aside from fluid changes, it has been a very reliable vehicle and handy for the lil' chores around the house.
www.kustomz.com
These induction kits also fit B-Series trucks and are available for 4 and 6 bangers...
Any idea why we can't get the lights on the dash to go off? Do you really think we should take it to the dealer and spend the money to get the problem (assuming it's minor) fixed or should we just let the lights stay on (will that hurt the truck?). Even the garage was clueless as to why the lights are still on. Your comments and suggests are welcome! Thanks
Welcome back. It has been almost a year, hasn't it? Try the following link for some mods to your B4000: www.kustomz.com
Most of the Ford Ranger upgrades will also work on the Mazda's. I would recommend the KKM Tru Rev Induction Kit. It replaces your stock air box. It is easy to install and all sensors remain in place. This site also offers Superchips and Dynomax Turbo Mufflers. Good luck with your upgrades...
http://www.pickuptruck.com/html/newyork/mazda/bseries.html
I've got an old 2.8L Ranger that I'd like to trade in this fall. I'm considering a 4cyl Ranger or B-Series for better MPG. The new 4cyl should be a nice improvement.
No, I haven't ever driven the 2.5L engine. I did own an '85 Ranger with a 2.0L. It was pretty slow. I would recommend that you give the 3.0L a test drive. It is a decent engine. I have driven mine hard for the last year with no trouble. I wouldn't describe it as fast, but it is adequate when mated with the manual tranny. And it gets pretty good mileage with a light foot. My B3000 4WD gets a solid 21MPG all purpose and 23MPG hiway. Not bad. The 2WD version should get even better. I'm glad to see that you are considering staying with the Mazda product. They are well-built and a decent value...
One reason I decided on the 3.0L was the fact that the Power Package (windows, doors, rear view mirrors) was not standard. With the 4.0L it was standard. So, I chose the smaller engine for better MPG and I saved some money by not getting the options I did not want. I'm not sure if holds true for the Troy Lee version or not...
Anyway, give the 3.0L a test drive. You can do this right now. You don't have to wait for the 2001's...
P.S. - One word of caution about the 3.0L. Some of these engines can develop pinging. Mine started it during uphill acceleration at 4500mi. I have been running 89 octane ever since with no problems...
If you are getting 21+ mpg on you 4x4 thats really good, on an average day for me, my 2.5L gets 21 mpg.
If I would get a Troy Lee, I would get the 3.0L because I would not want the power package either, and I do not need a 4x4 which the 4.0L Troy Lee is. I would also definitely get the Manual tranny no matter what I would get.
I saw in a post that someone said all the 3.0L are 150 hp in the B-Series and have 190 lbs torque. In the brochure it lists as 143/180, I was wondering if you knew exactly what your specs were. The ranger brochure lists 150/190.
Just wondering, thanks.
about the 3.0L in the the B-Series brochure it is listed as the flexible fuel but 143/150 I believe its 150/190 though.
Get after the dealer.
tacoma_trd - take the 3.0L out for a test drive!!!
I have a '98 B2500 that doing the exact same thing that xena1a described. I was wondering if you ever found out what the problem was, and if so, how to fix it?
Could anyone enlighten me as to the differences
between the B4000 and Ranger? From what I've seen
the B4000 has higher reliability ratings but
folks tell me they are identical trucks.
Can anyone resolve why this would be?
>> NOW I "hear" talk of vast improvements for 2001 << I'm very "limited" with $$$$, but I DON'T want to skimp and purchase foolishly either. PLEASE GIVE ALL COMMENTS AND SUGGESTIONS to assist me in making the "right" purchase. Should I wait until 2001? Is the 2000 Mazda "better" or "not as good" as the Nissan ?? Thanks for your help !!
The main changes to the 2001 B-Series/Rangers are the addition of the SOHC 4.0L V6 engine from the Explorer (as well as a new 4 cyl). Also 4 wheel ABS becomes standard. I have also heard that an additional 4th leaf spring will be included for the rear suspension (not sure about that one). Other than that, aside from the few cosmetic changes, the 2000's and 2001's are pretty much the same. Drive 'em both again. Like I said before, I think they are both decent alternatives to the Tacoma. Good luck...
