Visitor Agreement.
"However, Lexus might not choose the familiar route of turbo/superchargers but use hybrid systems which can produce similar results but with lower fuel economy. "
I assume you mean similar results but with higher fuel economy?
~alpha
And please, PLEASE, keep yellow directionals. I can't believe with the focus on safety in the U.S. that cars flash the brake lights to show a turn. You can't tell whether the driver is braking (and one brake light doesn't work) or it's a turn signal. Big boos to Honda and Audi for using red directionals on models that have yellow directionals elsewhere in the world.
I also agree with the Yellow/Amber signal lamp. It's much safer. I once followed a car with the rear red brake lamp signaling, and I almost hit it - I did not realized he is about to turn. Yellow lamp should be a must.
But so many cars are switching to red signal, as the toyota Sienna (the old generation DID have a yellow light), and so are most Ford models, dropping the yellow and adopt the red. And so are Chrysler & GM.
No idea why. Somebody told me that red is easier for the eyes. But if you're falling asleep while driving, a yellow light flashing in front of you would wake you up, so it's a safety issue.
Unless, of course, you got big LED lamps, like the Cadillac DeVille, then the red lamp is fine.
My PT GT (Chrysler) has lights only for two of the six window switches. No lights for power door locks or mirror controls
My MDX (Acura) has lights for all window switches and the power door lock switches, but none for the mirror controls.
To be candid, I've never missed the lights except for the rear seat power window controls in the PT. They are not located on the door. Until I read post 105 this evening, and then went out and checked the cars, I didn't know all of the control didn't have lights. Manufacturers apparently have figured out that there are enough people like me, that don't look at the switch if it is placed where one expects to find it, to make the decision to save the switch light money.
As far as I can see it's simply a cost-saving measure. A cover for the rear lights costs more with three colors than two.
Incidentally, the Dodge Caravan (and presumably other cars) has a rear light that appears to do nothing other than show a turn signal. This may be that the Caravans sold in Europe have a yellow part of the cover, but in the U.S. it's red.
The first U.S. car I drove was a Ford Taurus (the first version). It was my mother-in-laws, and in broad daylight most of her friends could not find the interior door handle because it was colored the same as the trim instead of being chrome plated.
I know this is a 2005 Toyota site, but the posts other than the last page, are so ridiculous that the forum wasn't worth contributing. Finally, the last posts have some meat.
In addition to those parts, you will notice the following.
1. Cruise controls buttons are also not illuminated. Cost must be the issue unless you can see in the dark.
2. In the Lexus, all the window buttons are auto, but in the Avalon just the drivers side. Does it matter??? Depends on how much you want to pay for that.
3. Reading the new CR April 04 issue noted only SLIGHT improvement in performance and mileage of the new Toyota 3.3L engine versus our 3.0L. Not enough in my mind to rush out and buy the latest and greatest.
4. How many of you have the compass in the auto dimming mirror and find it useful. I did not get that option and regret it a little. But the new Lexus 430 has the compass right near the speedo, in the center of the dash pod. Sweet.
"Feed the forum"
abfisch
The passenger side door key locks are no longer on some cars. Some tailgates have no key locks either. Fewer switch lights, the second horn, the wear pads for the driver's shoes, and more are examples of little missed items that potentially save the manufacturers $$$.
~alpha
As GMC found when they dropped the ABS as standard on many models.
However, people buying an Avalon or a Lexus expect to find a great deal of stuff that is an optional extra on other cars. If you sell a car on the basis that it's fully equipped (as high-end Toyotas and Lexi are) then it had better show it.
I notice that Honda's aim is to have more standard equipment on its models.
~alpha
There are too many variables in testing to compare one magazine's results with another's However, comparing cars tested by one magazine usually gives an idea of how one car performs relative to another. Keep in mind that temperature and altitude play a significant role in performance. Also, changes in weather between one car's test and another can leave one with misleading information.
The new Avalon will probably have at least a 5 speed transmission or maybe a six speed or cvt. All would give the car better maximum performance than the four speed in mine, even with the same engine used today. However, many of the cars today, even high performance ones, are dogs in high gear while my Avalon is not. The quest for that last mpg seems to have a negative effect on performance without a downshift. A non-cvt hybrid could fix that. A cvt hybrid would give better acceleration, but with more noise.
~alpha
I find reasonably quick initial go, like my Avalon has, is fine. My Avalon does not have traction control and there is very little wheel spin. I can count on a very consistent standing start performance. When the 05 comes along it will probably have quicker potential acceleration with T/C off, but the first 30 mph with T/C on will probably be similar.
While my Avalon has good passing performance I hope the new one does significantly better. Passing performance is what I look for, along with the ability to climb hills without a transmission downshift. Right now my old Avalon climbs hills in high gear. I hope the new one does too.
With gasoline prices approaching $2.50 per gallon around here, and expected to go higher this summer, fuel economy enters the picture too.
I've seen 30 mpg on trips with the Avalon, but the overall average is more like 21. I hope it doesn't take Toyota too long to offer a hybrid version. I'd like to replace my current 'trip' car (not my Avalon) with one that averages close to 30 mpg overall and has the room and comfort of the Avalon.
"Passing performance is what I look for, along with the ability to climb hills without a transmission downshift."
Completely agree with you on passing performance. But, I think you are in left field with respect to not downshifting when climbing hills. Thats an incredibly broad, vague statement. What percent grade are you talking about? And what is wrong with a downshift anyway. I can assure you that the 7 speed auto Mercedes S500 has tons of power, but will probably downshift from 7th gear when climbing a moderate grade. Whats your point?
~alpha
I have to agree with fndlyfmrflyr and disagree with alpha01. While I am not into bashing any publication, I take CR take on car reviews before anything C&D, R&T, automobile, etc. has to say. They are more thorough and have real world criticism as well as docuemented numbers to back their pros and cons up. Actually, the others pubs. promote 0-60 times, and handling and really don't focus on other vaiables, such as safety, reliability, resale value, etc.
We can see what you are getting for your money when the new Avalon arrives. My expectations would be the same drive train components and engine as the ES330, with the suspension and brake componets of the Camry. At what cost, we will see. In a car that most of us do not treat as a second car, but rather an everyday vehicle, I cannot see how the cons of excessive dive, secure but not precise handling should not be addressed rather than if it has a bit more power.
CR recommedation are much more inclusive and exhaustive than the men/women that still get their kicks out of mashing the accelaration to see if you can knock off a half a second. Some of us who drive this type of vehicle (aka Crown Victoria, Buick Park Ave Ultra, etc) have graduated high school a couple of decades ago. Some of the reviews in the "sport" mags used to be great high school reading, but seem dated and childish for a large sedan and its purposes.
abfisch
But you have to wonder about their impartiality. I saw one of those year-end "what car should I buy" guides from a car magazine. I recall looking at the review for the Ford Escort where it was described like a car salesman would, using words like "nippy" and "economical." Later in the year Ford introduced an Escort that was a major revision, and the same magazine in its monthly edition said that a new Escort was needed because the old model was "agricultural." In fact there wasn't a word of praise for the old model.
I can understand that two different writers can have two different opinions of the same car, but the difference between the year-end guide and the monthly magazine was remarkable.
But I guess Ford was happy.
MODERATOR /ADMINISTRATOR
Review your vehicle
Say what you will about the car mags being High School reading.. but the fact is that many of their mainstream comparos focus on more than just performance numbers. You're right, they dont address reliability- but thats the beauty of being able to factor more than one critical opinion, aside from that of your own- in a vehicle purchase.
~alpha
New Avalons will have 240 hp max. The suspension cannot safely handle more power without changes that might make the overall ride unacceptable to traditional Avalon purchasers. Comfort prevails over speed. Expect the 5 speed auto. Also expect to lose a little headroom or trunk space for the sake of appearance (style). And the price goes up about 1k per car compared to the 2004 model.
And if the Toyota service department says it, then we all know,......hmmmm..
Any freeway incline. There may be an occasional one that is too steep, the temperature too warm that day, or the load to much in the car for the car to make it over in high gear. I find it an annoyance to have the tranny shifting on incline after incline while driving with the flow of traffic.
My four cylinder Volvo, my four cylinder Mazda, and my four cylinder PT had/have no trouble with hills and stayed/stay in high gear no matter what the grade (so far). My Avalon stays in high gear. My Jag had trouble staying in high gear on the South bound Grapevine grade, but that's all. OTOH, my Acura shifts on half or more of inclines, even little ones. Strong head winds also make the car shift a lot even on level ground while at freeway speeds.
In short, if repeated shifting while at cruise doesn't bother someone then there is no problem. For me, it is a major annoyance. To each his/her own I suppose. Other things don't bother me that do bother others, so I guess it evens out.
My hope is the new Avalon keeps the attributes that make the Avalon so nice while adding a few to make it even nicer.
Quiet and long ride comfort, along with ease of entry and exit have become more important the older I get. Utility has become important too, but a big enough trunk and roomy back seat is all I need. There is still some boy racer left though, so power still counts too, as does handing and stopping. I'd love an Avalon with the comfort, space, and quiet of mine combined with some of the fun and utility of my PT GT. Maybe the 05 Avalon will.
I could agree more that a nice revision to the new Avalon, might be more low end torque, to decrease the downshifting on moderate-severe grades. I drive over a very steep mountain, adjacent to the Hudson River in NY state, and wind up just taping the button for O/D OFF. It does hunt just a little on grades where it should have enough low end power to make it up. Not bad, but perhaps the new engine might make a little difference, not so much in upper end HP but in lower end torque..That would be a nice improvement.
It the new one decreases head room, that is going to bum me out. I enjoy too, the ease of entry/exist, relatively good MPJ, interior space as well as trunk space. I couldn't enjoy any "boy racing" properties, until I changed the shocks, sway bar bushings, and front rotors. Now much better although a mild decrease in ride comfort.
Will see what happens. A decrease in trunk capacity would not be welcome. Any increase in fuel tank capacity would be welcome (IMO).
"Feed the forum"
abfisch
Toyota's V6s arent Honda-like high HP/ moderate torque designs, and the current 3.3L offers very substantial low-end pull. 242 foot pounds at 3600 RPM. The danger is Toyota's somewhat unimpressive 5 speed auto and drive by wire throttle. I recently drove an ES330 and floored from a stop, acceleration was quite impressive. Not TL-like, but strong and confident nonetheless. However, the car felt dumpy in "around town" driving, because to me, there was too much "thinking" going on by the throttle and transmission. Note of course, this is not something either of my parents would notice, as they are not car nuts.
Allegedly, this "thinking" is something that owners get used to, and the transmission is supposed to adapt to repeated similar driving behavior- certainly impossible given that I was driving a DEMO model.
Finally, I do understand your reasoning behind not liking excessive downshifts, but for me- if the downshifting is imperceptible, I probably wouldnt care about it.
~alpha
Reading between the lines, it's more a question of Toyota differentiating itself from other manufacturers. If hybrid engines will fit in the space current gas-only engines use and give considerable improvements in gas economy this would give Toyota an advantage that can't be matched.
When this hits the Avalon, no one knows, but the ability to put this in the Lexus RX330 and the high sales of the Prius make it likely.
I don't mean to spoil the party, but shouldn't the moderator keep the messages on topic as much as possible?
It's turned into a more general discussion because that's what people are more interested in. If you have something to say on the body shape no one's stopping you from saying it.
~alpha
I guess if I went to your file cabinet, I'd find information on refrigerators in the TV folder. Wow, that makes sense. Or maybe I should post Acura complaints in the Toyota forum. Yeah, that works. The moderator ruins forum topics by not keeping them on-topic.
The purpose of title-specific forums is to direct people to topics that interest them. If I wanted to read about hybrid engines, I'd go to that forum. Or start one. But I wouldn't muddy this TITLE-FREAKING-SPECIFIC topic up with posts like that.
Why don't you start a new topic if the purpose of this one doesn't interest you? Why ruin this one? And how would I know what stupid messages you are cluttering up this topic with if I didn't read them? We're not all Kreskin you know.
Keep the forum on topic, or don't waste the time of old AND NEW visitors who may actually think you have something to say about the actual topic.
To Alpha1: Ask yourself, do your speculations about ETC, hybrid this or that, blah, blah, blah have anything to do with the TITLE of this topic?
No, I didn't think so either.
But I just wish people would not post into a topic with a message that has no relevance to that topic. Why should we have to filter through 100 off-topic messages to find a few messages about the topic?
It would just make all the forums (and this isn't the only one guilty of this problem) a lot more meaningful for those of us who want information on that topic only. If someone doesn't police this, the next thing you know we'll be talking about Zaino Car Polish in the New Avalon Body Style forum. Do we really want that?
Personally, I prefer when the hosts lay back and let the topic twist and turn a bit.. to me it's more interesting that way. I'm sure others want it more "tight" -- I don't envy the hosts when it comes controlling the line because it can get quite blurry at times.
To piggy back on examples from above, what if I'm hoping the avalon gets a hybrid engine for '05 (yeah right), or I want to talk about how I plan to put a thick coat of Zaino on my '05 avalon as soon as I get it... am I off topic? Its a stretch, I know.
In any case, the last I heard someone mention the avalon
If Toyota could lift the veil a little, it might make me wait a few months for an improved body style, a Navigation system location lower on the dash, etc.
We'll see.......and I appreciate your post.
~alpha
I'm driving a 45,000 mile 2000 Avalon after giving my 150,000 mile 1997 Lexus to my wife. I'd rate them around equal - Lexus better in some things, Avalon better in others.
The Lexus is a lot more than just a nameplate, and when I test drove a then-current ES300 and a then-current Avalon XLS a year or so ago, the Lexus was more refined.
I don't care for this old-school grill, but I do like the Phaeton's rear end. So, I have a simple wish for Toyota, would you design the 2005 Avalon's rear end to look exactly like the VW Phaeton?. I know it a lot to ask for but it would be a big improvement over the previous Avy models. Just wishing or remote possibility?
Thanks for the pic samnoe... your's is the first one I've seen anywhere.
I seriously cannot understand the mentality of bringing this car to market with a 270hp V6, when the next $45,000 Lexus GS is going to debut with a 245hp unit. What the hell is Toyota thinking. I am personally keeping my fingers crossed that none of the information in that article is true. Nice fodder for this forum though.
~alpha
I do think it is an improvement over the current Avalon generation. Definitely sportier than the current version, IMO. That color sure doesn't do anything for it. Silver, black or white might look nice.
Thanks for the pic.
I don't believe Toyota should release this vehicle - it's not that ugly, but not special. Seems that people are that crazy about the Prius, so they copied styling a bit. The only advantage can be a HUGE trunk. but limit rear visibility.
After all, people, that's just a spy shot. Could be it isn't the real one...
I just posted the pic to hear what you guys have to say about that, and not to argue anymore on-topic or off-topic :-)
Rear-seat legroom is said to be equal to or more than the big Lexus LS430
Give me a break. Avalon has much larger rear legroom than LS430. I have ride in both. The spec also confirm my impression: 40.1":37.6"
Bottom line, I love Edmunds (we all do or else why are we here). I feel they don't need to be so jittery towards competing forums -- but hey, it's not my ad $$ I'm talking about.
It is a shame about the pic being gone -- this board LIT UP after it was posted. Oh, and as to the '05 avalon pic -- I hope it is a fake, because that car certainly looked awkward.
Review your vehicle
