******FOUND THE SOLUTION TO DISABLE THE SEAT BELT CHIME*****************
Well, no wiring mod is required. Here is the procedure:
1. Set the LCD on the combination meter to the ODO trip.
2. Press and hold the TRIP meter reset knob for ten seconds or more within six seconds of turning the ignition switch to the ON position. Fastening the driver's seat belt while holding the knob cancels the buzzer reminder. (You may have to hit the reset meter knob to cycle through b-ON to b-OFF)
3. When this occurs, the LCD displays "b-OFF". The buzzer reminder can be switched between ON and OFF each time the TRIP meter knob is pressed. The LCD displays "b-ON" or "b-OFF" according to the buzzer reminder ON/OFF status. The display changes to the ODO or trip meter if the knob is not pressed in 10 seconds.
4) Performing steps 1) and 2) again when the buzzer reminder is off exits cancel mode.
azhuyck
I just completed an nearly identical 1500+ mile trip, basically the same trip I took back in May. This time I averaged 29.7 mpg vs 28.7 in May. I used the A/C much more on this trip (~50% of the time) and ran the Ltd between 72-80 mph. Only differences was that this time I pumped the tires up to 35psi (vs 32 in May) and had 5W-30 synthetic oil vs fossil oil in May. Both times I used premium fuel.
Laser Cruise Control Protection: The 3/32" thick protective (see above email)acrylic lens I installed does not consistently work. When turned on, the LCC works for about 5-10 minutes then the C-1 fault appears but acrylic lens is not dirty. Something over time is causing the laser beam to default; thinking of possible reflection of beam on acrylic surface (acrylic lens not parallel to laser lens) or laser coupling of beam w/acrylic material. Now into a science project! Next move is to remove acrylic protective lens and replace with thinner GE Lexan protective lens. More to follow..
NWBLIZZARD
I going to at 10K, my 3rd change. Which will be in about 3 weeks unless I goto Calif in the next couple days. Then it will get done before I leave at about 8k miles.
MikeS.
Has any1 actually towed a trailer? How did it do"
I've read from earlier posts that Toyota USA doesn't recommend towing but Toyota Canada says upto 1,000 lbs.
Looks like I'm gonna have to goto Calif., 3,000 miles, and take care of my sister"s estate. I'd like to take the Avalon instead of my Tacoma 4x4. Much better ride and better gas mileage, shouldn't have much to haul back. An antique Singer treadle sewing machine and a couple other small pieces.
MikeS.
Greg
ali :surprise:
Ken
NWBLIZZARD
NWBLIZZARD
NWBLIZZARD
Please let us know how it works after you get it installed.
Greg
Mackabee
Mackabee
:shades:
Mackabee
Doug
I am driving on the latest fill up without the air conditioner on and am getting 20 mpg compared to 16.8 mpg with the air conditioner on driving the same route.
does the odo need to be on "a" "b" or just odo?
do you pust the engine start twice first without foot on the break??
I am pressing odo "B" and pressing the engine start without my foot on the break and then fastening seat belt and nothing is working???
No foot on break. Press START button 2 times and immediately press and hold the reset button for at least 10 seconds. Keep holding the reset button and fasten the seat belt.
The ODO display with show on or off. Press reset button to cycle until you see off. Hit the Start button again.
Now when you start the warning chime should be off. I think there are actually 2 warning chimes. One that goes for about 5 seconds and the other is a much longer term warning. This is the one that is shut off.
Hope this helps. Sorry didn't see the above post before I answered.
Doug
This was reviewed in earlier posts. The new Avalon has a rating of 1000lbs. I do not know if a hitch is manufactured yet for it. I have an Avalon 02 with a Draw Tite hitch on it. I pull a small very useful utility trailer 8 x 5 on a weekly basis to take care of our 43 acres. I find it very useful. The 02 models have a rating of 2000lbs, not 1000lbs. I find that around town and on rural highway it is best to take the tranny out of OD, and then the transmission does not hunt for gears. I also ungraded my brakes since I use it consistently. The wiring harness was hooked into the back light section. Easy to do.
abfisch
One thing I don't understand, though, is that even if you get the exact same mileage from both regular and premium gas, the cost difference is only $120/year (assuming 15,000 miles per year at 25 gal/mi and $0.20/gal price difference). Now, since you get better mileage from premium (let's say 2 miles more per gallon), the cost difference literally does not exist anymore on an annual expense basis. So, IMHO, the use of premium vs. regular gas should only be a preference issue.
Will not hurt car but will retard timing. I use a mix of 89 and 91. by that I mean when half empty I fill up with 89. next time when half empty I use 91. Here are some picture of my Limited, follow the link. azhuyck
http://groups.msn.com/ToyotaAvalon/2005avalon.msnw?albumlist=2
Mine is stuck too and it appears to be a design flaw because the dealer said there are problems with them and they ordered a replacement for me....same thing with the net hook in the trunk....easy fix....for a great car.
Go to the DrawTite website and you can look at it. They need to lower the two exaust pipes to install it but the hitch the becomes part of the exaust support structure.
Deanie
I tried to check the user manual and wasn't able to find any information.
I wonder if it's a simple as "hold this button to open the trunk" ? duh...
Any help is appreciated...
Ken
perico1 and limiteddriver...thanks!
Steve
From... http://chemistry.about.com/library/weekly/aabyb100401.htm
Steve...I have no idea but I will have the dealer look into it. Does anyone out there have any clues?
I thought the numbers were around 2~3% power loss with the different grades. That is more like 5~8 hp loss total.
I do get 22~23 mpg with air on in town. 26~27 mpg mixed with 87 Oct. gas.
Also, I have used 93 and 87 and see no change in mpg's. Heck, using 87 driving on a flat road, my computer showed 36.1 in 9 minutes of travel.
Anyone else have this problem? How do I find out if they put wrong struts et al on car? What is the difference between Touring and XLS suspensions? Can performance be measured with electronics, or is this just "feel".
