https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
Any thoughts?
Thanks again,
Susan
Replacement cost per the dealer is $1100.
Coincidentally, I've contacted a local Firestone dealer who indicated labor would be $470, gaskets $120, and they could likely clean the valve that probably has oil residue on it.
Questions:
Is there any aftermarket product I can purchase, spray in the manifold to help eliminate any buildup?
Has anyone been through this? Is the dealer on point? Is the Firestone shop on point in indicating the valve should be cleanable?
Thoughts?
.This is why I hate automatics my 02 infinity g20 has 232,000 kms and the 5 speed manual still shifting away.If it wasn't for my wife I would never own a automatic vehicle. :sick:
Question:
I've had a vehicle or two where I could NOT retract the pistons with a "C" clamp and had to have a special tool to twist the pistons back into their housings.
Anyone know if this is the case with the Aviator?
Thanks in advance - David
Hmmm.... I've done the front and rear brakes on a Ford Explorer and Lincoln Blackwood and both were doable with only the C clamp.
Do you have the specifics on which way to turn (clockwise / counter clockwise) (driverside / passenger)?
Thanks - David
I guess it's possible the trucks don't use the same mechanism - never had to change the pads in my Aviator so I'm not 100% sure.
Just because something is a known issue doesn't mean they're responsible for extending the warranty to cover it.
There is a reason they discontinued it and the engine.
Lexus will end up being far cheaper car to own. I bought it as a CPO and it has a 100K warranty on everything. Best resale value of all the makers.
The TSB bulletin details the problem.
Oh wait........
Every vehicle has design flaws. Vehicles are not warrantied against design flaws - they're warrantied against defects for a specific time period. While it would be nice if Ford would extend the warranty and cover these problems, I certainly don't think it's required nor would I expect the same from any other mfr.
I suspect the actual number of failures are low percentage wise and didn't warrant any special treatment. That doesn't matter to those who had the problem out of warranty.
If you want the mfr to be responsible for repairs outside of the warranty period - buy the extended warranty and you're covered. If you choose not to buy one then you take your chances. I don't hole that against Ford.
As for any company,they are always responsible for design flaws regardless of when they occur.Cosco just recalled millions of playpens that were sold as long as fifteen years ago.These too were out of warranty but were found to be defective due to design.So I do hold it against whoever designed the product that failed.Who else would be to blame? We trusted them,now they have keep our trust and make it right.
There might be one or two companies doing this, but by and large that's not how it works. The manufacturer determines up front how much they'll have to pay in warranty repairs on a vehicle and that is factored into the vehicle cost. It doesn't matter whether they cover it for 1 year or 10 years - the only difference is the cost. If they choose to only cover 4 yrs/50K miles then that's all you're paying for and if you want move coverage you buy an extended warranty.
This is not a safety issue, therefore no recall is warranted. It's not a problem that affects a high percentage of owners and there are many vehicles where this problem never occurs. So Ford does what every other mfr would do which is to fix the problem if it happens under warranty.
That's the way warranties work, whether it's cars or cell phones or universal remotes. There is no conspiracy here.
Umm......those are SAFETY defects and they're recalled and fixed BY LAW. You can't compare government mandated safety recalls with simple product failures. No company would voluntarily recall and fix a 15 yr old product other than for child safety reasons.
The DOHC heads were discontinued when the Aviator was discontinued in 2006. You don't replace the engine, just the head. If you get a replacement it will be the same head design and subject to the same failure rates as the originals.
Like I said - there are reasons why they discontinued this model.
As for Lexus, I guess you conveniently forgot that Toyota refused to cover engine sludge IN WARRANTY by blaming the customer for poor maintenance. At least Ford covers defects during the warranty period without blaming the customer. And Ford's only accelerate when your foot is on the pedal.
Component Description:
6. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 06513
Bulletin Date: Jan 2006
Vehicle: 2,004 Lincoln Aviator
Summary:
ENGINE MISFIRE WITH DIAGNOSTIC TROUBLE CODE (DTC) PEWEE, P0302, P0303, P0304, P0305, P0306, P0307, P0308, AND P0316. ( NHTSA ITEM NUMBER - 10019912 )
7. ENGINE AND ENGINE COOLING Bulletin Number: 041601
Bulletin Date: Nov 2005
Summary:
WDS COP KIT DIAGNOSTIC TIP - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING. ( NHTSA ITEM NUMBER - 10018745 )
3 days after the purchase....GUESS what??!!...Check engine light comes on...then starts to flash when i was waiting at a traffic light...I immediately drove to Pep Boy to check the code...
MISFIRE CYL #8
I now have come to realize im totally done for...I have a 3 month 3Kmiles warranty they gave me but I think its going to be a battle to have a engine rebuild covered...
I read that there is a factory extended 10 year 100+k warranty on the coils of the Aviator. you just need to have the dealer test the coil(s).. Although i fear that the valve are the unfortunate plague.
Any thoughts or suggestions?
After Warranty Adjustment?? Secret Warranties?
Im in Los Angeles any one have any luck with dealers in the San Fernando Valley? Galpin?
Thanks in advance!!
I am also pretty confident the small dealer knew about this problem and sold it to me anyways... Unfortunately, there is no way to prove this...
After, I checked the check engine light code with Pep Boy, I asked if the code could be erased from the memory...He said yes, it's easy and he thinks its quite common practice with private dealers.. the check engine light didn't come on when I test drove it and it took a few days for the computer to see the error. something like.. it has to see the error at least 3 times during 50 turn key cycles...
What a debacle... thoughts?
