door ajar stays lit while driving .......and running board lights and dome lights stay on....the problem occurs when it feels like.....did the wd40 thing work or do i have to dismantal the door panel....?
Caveat - just because of the nature of the beast, I would expect that it'll be more problematic over 149,000 than a sedan.
The dealership is saying they will have to order a new radio system.
Then again, you could have a thief who prefers to victimize that particular wheel only for some reason, perhaps because of where you park.
Funny thing is a week or two later I was at the mall and walked by a Navigator, not sure what year, and it was missing the very same hub cap as mine. Really weird.
The first time it happened we joked and said it was some animal in the back of the car. But, after the second and third time it was really perplexing. I am wondering how i would present this to the service advisors.
Could it be the rear A/C system de-pressurizing or pressurizing itself? Sounds like a small primate whooping in the forest if you understand what I mean. Like a whooping noise caused by the suction or vacuuming of air. Not loud, but noticeable. I am not kidding. Could it be the rear air suspension or auto lift gate systems? It only has 500 miles on it.
I will take the jokes as well as any advice...Thanks
i am thinking it is not the muffler since it is located on the right rear side and it sounded like a reverse air flow whistling sound. Imagine whistling but instead of blowing air out you are drawing air in to produce a whistle. Not high pitched sound but mellow. Lasts for about 1 - 2 seconds.
I will double check the muffler though. I checked the air suspension and it looked and sounded normal when lowering and raising. The sound may only occur when driving though and I couldn't check it then.
It still might be the rear A/C. Does anyone know if the navigator has a separate rear A/C unit in the right rear cargo area? If so, does it draw air from the rear area also?
I will keep posting updates.
Are there any conditions which would trigger it so I have a good chance of reproducing it for them?
Thanks NVBANKER, you are a wealth of knowlegde for me so far!
Simply put, the expansion valve in any air conditioner meters the flow of refrigerant so that it will keep the evaporator as cool as it can. If it malfunctions, you can have waves of cool, warm, cool, warm, cool, etc... It also, can make a noise like a howl, but not always. One symptom does not depend upon the other either...If it's working correctly, it will release the proper amount of refrigerant at all times, cooling your evaporator coil, which makes your cold air.
They're going to have to test it to find the problem, and it's going to be hard, as with any intermittant problem, but if you point them that direction, you may have a chance - assuming I'm right.
My advice is free, and worth the price.
The howling or whooping noise occurs only after the rear AC is turned off. If the rear AC is on then it does not howl or make any unusual noise. Once you turn it off it happens. I am not sure if the rear AC has to be activated first and then shutdown but the sound occurs with it off.
Does the rear AC expansion valve activate when you turn off the rear AC and leave it off? Therefore, the sound/noise comes from the AC expansion valve when the AC is off?? Why is valve active when the system is off? :confuse:
They are replacing the rear AC evaporator/expansion valve assembly. Should be done today. One note, they gave me loaner car from Enterprise car rental(at the dealer) and they will be charging me taxes for its use. The dealer will pickup the retal cost but not the taxes...??
This is not the dealership where I purchased my 2005 Navi from. The dealership I purchased it from does not charge me a thing. I also have the Lincoln PremiumCare extended warranty. So taxes equate to about $8 a day. Why?? :confuse:
I took it to this current Dealership service dept. b/c it was closer to where I live. For $8 a day I may drive a little further to the dealer where I bought it from.
Anyone here ever had to pay taxes for their "free loaner" car when your Lincoln was in warranty service?
They are replacing the rear AC evaporator/expansion valve assembly. Should be done today. One note, they gave me a loaner car from Enterprise car rental(at the dealer) and they will be charging me taxes for its use. The dealer will pickup the retal cost but not the taxes...??
For over $52,000 and the Extended Service Plan you expect a little more from the service dept. Didn't Lincoln include my loaner car costs in the price of the car? That is why they advertise "Free/Complimentary loaner cars."
Negatives: gas guzzler, expensive
Even though I believe in buying american made I dont think I would buy another. Its not the cars fault, but the dealer. Like I said in a previous post the service dept wrecked it 10 days after buying it. They were prompt about fixing it, but didnt offer anything to ease the pain.
Now, recently picked up my Ultimate from another dealer service department. They addressed/fixed my howling rear AC noise quickly and was going to charge me sales tax on the loaner car. When I picked it up yesterday they dinged the passenger door lower body panel trim. A three inch by two inch red mark on the lower door trim. Glad it was on the trim and not the door metal itself. It is sad to say that I am glad it was damage to something else.....there shouldn't be damage at all. Well, they were prompt in trying to remove the mark but some couldn't be fully removed. He offered to repaint it and I was sick to my stomach. He also comp'ed my taxes on the loaner car. Wish he would comp my time, energy, and frustration.
Eventually he located a new lower door trim part that is factory repainted and he will replace it without repainting. I have seen their paint matching and that is not an option to repaint the damaged old trim piece. I am worried that they will do more damage removing/installing the door trim or somewhere else on the car. We decided to go ahead with it. Waiting for part to come in next week. I will just chalk it up to more wasted time and frustration if they mess up again.
I am with you on not buying Lincolns again because of the poor quality of service. The service advisers are courteous and professional but the technicians/porters/facilities are substandard. I have less the 800 miles on my car, 90,200 more to go. I am queasy to think about future service visits on my remaining 6yr/100K mile ESP warranty.....
