Lincoln Navigator Maintenance and Repair
Problems with your Navigator? Post them here and share any solutions with other TH members.
2 days ago, I brought the car in to have the suspension looked at as the CK SUSP light came on and the compressor stopped running. The service manager had looked at it about a week earlier and said that the previous failure was due to a bad relay and replaced. While there, I asked that the technicians take a look at the Service Engine Soon light which came on recently as well.
When I picked the car up, the service manager advised that the susp failure was due to a loose ground in the car. This was located and fixed and not only is the susp working again but also the auto door locks and MPG indicator (YAY!!).
BUT, and this is a very big BUT, the service manager said they also took a look at what was causing the Service Engine Soon light to come on. When they pulled the "codes" from the car, they found that that the "left bank" was running lean. Additionally, a hose in the engine compartment was also leaking air and could be heard outside the car. They found that they car was approximately 3 quarts low on oil and compression in the #6 cylinder was low. Needless to say, they repaired the hose, filled 'er up with oil, and checked the "left bank" and the engine service light was reset. In the process, they detected a faint noise coming from the motor (bear in mind that I am not sure in what order these problems were detected). They took a closer look and concluded that the problem is "deep within the engine" and cannot be easily repaired. IT will likely require a new engine.
At the risk of sounding defensive, the car was serviced by the dealer 2 months ago and, at that time, the oil/oil filter, air filter, coolant, and transmission fluid was changed. The car does not leak or burn oil and assuming that they added the correct amount of oil 2 months ago, how could 3 quarts just disappear? Additionally, if the car was low on oil, would I not be able to tell from looking at the dashboard indicator? OR, would there be a noticeable loss in performance or excessive engine noise or something??
Let's say that my only option is to replace the motor, would the car not have to be there more than 2 days for them to determine that? AND, would they not charge me for the time they spent to investigate the problem? They also did not charge me for repairing the loose ground which resulted in my suspension failure.
As if this was not confusing enough, the service manager recommended that I trade the car in. NOT for a new Navigator but for another car and preferably not associated with their dealership.
My next step is to bring the car in to another dealership to get a second opinion. If someone out there is/has experienced this same problem, please advise. If not, I would equally be interested in hearing your thoughts on this situation and any advise you may have for me.
Thanks in advance.
I have found that a lot of service techs don't know that your Navigator takes more than the customary 5 quarts of oil, and so they don't fill it up when they service it, and you start out 2 quarts low when you leave. That may explain why it needed 3 quarts.
Why they didn't charge you could be alterior, but also they just could be sympathetic.
I'm wondering how long you have had the car. Did you by new? If not, now long ago?
Very odd they suggested you trade the truck in "elsewhere". That I totally don't get. But I agree, a second opinion is warranted. If indeed, something is detected that is serious, I also would trade it off unless it is still under warranty, which I'm doubting it is.
I had a 99 Navigator that gave me -0- trouble for 4.5 years. I have an 03 that I'm now equally happy with. I have never heard of anybody else with this bizarre story. Wishing you the best.
98 lincoln navigator
I HAPPENED TO HAVE THE SAME PROBLEM.
RIGHT NOW THE TRUCK IS AT THE DEALER FOR REPAIR.
I DONT KNOW THE RESULT OF THE REPAIR YET WILL I'M WRITING THIS NOTE.
WHAT IS YOUR DEALER RESPOND TO THE THIS PROBLEM.
PLEASE LET ME KNOW.
THANKS NOAM
I have been without my Aviator for a total of 59 days for the specific problem listed. 33 total days of service since I first purchased the vehicle in April of 2003 to April of 2004.
The listed problem is intermittent when the trans gets hot. Primarily in stop and go traffic conditions. It will engage in drive and then begin to slip until it just jumps into gear. This continues at every stop unless I stop the vehicle and put it into drive. It will still continue even afterwards on occasion.
The problem has been addressed during the service visits with parts including the solenoid body, pump bolts, pan gasket, stand pipe and o-rings. Still a recurring problem.
Has anyone had a similar experience with their Aviator and/or attended the Dispute Settlement Board trying to find resolution to their problem and what was the outcome.
Transmission problems with New 2004 Navigator with 1000 miles on it (3rd week), similar slipping, complete disengagement problems, just happened and in the shop now. I am very interested in the problems they tried to ID. I told them to come pick up THEIR car, I am trying to exchange now because I am afraid of your very situation, ongoing unidentified problems. I will pass along their diagnoses.
Does anyone else have this problem??
at the 1st time kept the truck for 3 days & replaced the intermediate column on the steering,nothing change,
the dealer rotate the wheels,1st time kept the truck for a another day, nothing change
they rebalnced the wheels 2nd time nothing change
they kept the truck a another day.
now the truck is at the dealer for four consecutive days, no result found yet,
please advise me what is my legal rights & who can help me with this situation.
they re balanced & rotate the tiers,they checked the rotors,they checked the driveshaft,they took the rear end axle down,in other words they took apart the truck & they can not figure what cause the vibration,they run the truck on the lift they dont get any vibration, ones they drive on the road the vibration is there,they took a set of tiers from a stock vehicle balance them & test drive they still have vibration,
i have a heart condition I'm on medication daily, i dont get anywhere with this dealer or ford lincoln co.
please help before i get my heart attack.
1) Ask your dealer to swap out the battery with a new one. Sometimes, those batterys can go up and down like that, unless the problem isn't that it won't crank. It was hard to tell from your description.
2) If the car did crank, forget #1. If you did #1, and it does it again anyway, then for #2, give the car to the service manager, get a loaner from him, and tell him to use your car as his own until it does it to him, and then find it, and fix it, no matter how long it takes. It's a pain in the [non-permissible content removed], but it's you're only chance to find it. Otherwise, you never know when it's going to let you down, and unless Jesus works at your dealership, it's their only chance to find it too.
FORD.
I'd have them check your coils, maybe the 2nd NHTSA bulletin will help you prevent what happened to mine.
I have an '04 Navigator ... worst reliability.
and an '01 V6 LS .... worst resale value.
Great.
OTOH, my Nav trouble free so far and it's still A#1 ride.
my LS still worth appx 50% of my new price at age 4 years.
Still ...
The Fix: The part number I was looking for is 5B322 (2L1Z*5B322*AA) and lists for 23.50. It contains just the quick connect union. Replacement was easy. Removing the old union required removing the end caps (which allows the inner collet to be pushed inward), and while keeping the inner collet push in, pulling the hose out. Installing the new union couldn't be simpler. Just push the hose into the end.
