Visitor Agreement.
The mistake then was made by the trucking company. I assume they have liability insurance or the distributor covers them for errors in placing the fuel when delivered to the station.
I wouldn't want to be that driver that put it in the wrong opening. I wouldn't even want to drive one of those tanker trucks. I always figured they carried some firepower in their cab in case of attempted hijacking. I wonder if the trucks have some kinds of trouble signals that are sent to the home office in case of problems when driving $100,000 worth of fuel? Am I in the right range?
A Speedway station north of the city had a bad delivery a few years back. A motorist called the Car Repair show on radio the next morning. His car was still at the station along with several others. His died before he got off the lot and he was filling up while the truck was dumping>>>
IIRC the mechanic recommended a lot of taking apart and replacing some things because of diesel contamination.
Helicoil would be your best bet. Replacing the manifold would be the most time-consuming and expensive, of course. Welding a new nut might screw up the readings of the O2 sensor (since it would no longer sit in the manifold at the same depth).
Perhaps someone else can chime in here with knowledge of this specific year model, but I'm not sure that a Lexus that old has electronic throttle control.
However, it still has a mechanical linkeage for the air intake. I don't recall but I don't think any car has a completely electronic throttle.
Most common reasons for sudden acceleration are:
1. Driver mistakes one pedal for another
2. Driver accidentally 'double pedals' and has foot both on gas and brake
3. Throttle gets stuck--does not release when driver removes foot from gas pedal. This feels like a 'sudden acceleration' issue because one expects the gas pedal to release when you lift your foot.
Despite some theoretical studies that show sudden acceleration to be possible (on paper at least) I've never read or seen this proven by anyone in real life.
Yes, the brakes will almost always be able to stop a car but the stopping distance might be longer with a stuck throttle. The engine can't overpower the brakes (a car stops faster 60-0 than it accelerates 0-60, in other words).
Still, experiences like this are pretty upsetting regardless of their cause.
I have no idea if it is theoretically possible for a drive by wire throttle control to get "stuck", that is, fail to register a closed throttle reading...that's one for the engineers. Seems to me that anything that has a partial mechanical component, such as for air supply, could get stuck. BUT....it couldn't get stuck past its original set point dictated by the driver's foot.
That's not quite the same as 'sudden acceleration", of course, which imiplies that the gas applies by itself without the driver's foot and that the car cannot be stopped. That seems implausible to me, as one would need both simultaneously failures of the electronics and the brake system.
But a sticking air throttle that works with an electronic gas pedal, that is, one that fails to return the gas pedal to the 'off" position----well, that seems possible at least.
As for the smoke, it could be a lot of things. The best way to test for sludge is to pop off a valve cover. If you see a kind of gunky gray mass of thick gooey stuff, you got sludge.
If the engine is clean inside, a smoking engine could be from worn piston rings, or, more likely, worn valve stem seals or worn valve guides.
You get smoke because oil is being burned in the combustion chambers, and the only way it can get there is to either by-pass the piston rings (worn rings, or sludge) or leak down through the top of the engine past valve stem seals or worn guides (also possible that valve stem seals can be attacked by sludge).
A test called a "cylinder leakdown test" should be performed after you've examined the engine for sludge. Then you'll know for SURE what's going on.
However, it is good for engine building...I used to mix a little bit of it up with oil and dip engine bearings in it before assembly...that way I knew that oil flow was nearly impossible off the bearing. :P
also, in a fully electric DBW system, if i'm not mistaken it is a servo motor that positions the throttle valve based on command and position feedback. there's still opportunity for mechanical binding, or electrical problems causing the throttle to fail to close.
back to the poster's problem, i could see a mechanical throttle binding because of the cable linkage binding. or how about the floor carpet slipping and depressing the accelerator. wasn't there a toyota recall not long ago for a problem with floor mats and the accelerator?
back to DBW, didn't one poster claim their vehicle did not accelerate when they pressed on the accelerator in the parking lot, then all of a sudden took off and they hit a curb or another car?
i'm with you on confusing the brake and the accelerator. i did that in a jeep laredo myself once. but, i think there are some other scenarios both dbw- and non-dbw possible.
snevets23
snevets
first impression was the possibility of a slipping floor mat moving forward and depressing on the accelerator.
i would have the mat, pedal, cable, and throttle body assembly all checked out.
Your post was clear, I didn't think you had hit the brake.
The reason I ask is because I'm 17, and come home fairly late on weekends, and I need to plug my car in at night (it's around -25C here). The problem being that I don't want to have to wait until 2-3am for the engine to cool down so I can plug in the block heater and have it ready for the next morning. Any suggestions?
Thanks in advance
-Ryan
That gives more life to the heater and saves you a LOT of electricity. If you plug in when you get home you'll spend more on electricity than you did for the heater.
determine the current requirement (in AMPS) of the block heater. if you are using an extension cord with the heater (and i would hope this would not be necessary, but not owning one, i don't know how much current they use), make sure it is rated to handle the current needed by the heater! if it doesn't use an extension, then you are good to go on that score.
secondly, and just as important, make sure the automatic timer is rated to be able to handle the current needed by the heater! just like extension cords - they are not all created equal with regards to how much current they will carry safely without heating and failing and possibly creating a fire. some of these timers will switch the current used by a lamp fixture with 60-100W bulb, some a coffee maker. some a heavy load.
garage fires are uncool.
Would this create problems? Would I need a two- or four-wheel alignment?
I've done this on my '99 Z28 and '99 Boxster to good effect (in these cases also with new Bilstein shocks, which I don't plan for the Civic).
Yeah, probably an alignment is a good idea, because you might also be able to tweak the settings to give you even better handling.
2004 Honda Civic
Coil Springs
Brand: Eibach
EIBACH PRO KIT, LOWERING COIL SPRINGS, SOLD IN SET OF 4 -- Front With 1" Drop, Rear With 1" Drop, Progressive Spring Design, Provides Excellent Ride Quality And High Performance Handling With A Lowered Center Of Gravity, Installs Using Original Factory Mounting Points, Backed By A Manufacturers Million Mile Warranty
Free Shipping On Orders Over $50.00
FITS SKU PRICE QTY
# 1.3L, 4 Cylinder, Electric/Gas, MFI, LDA1
Hybrid
# 1.7L, 4 Cylinder, CNG, MFI, D17A7
GX
# 1.7L, 4 Cylinder, Gas, MFI, D17A1
DX
LX
# 1.7L, 4 Cylinder, Gas, MFI, D17A2
EX
# 1.7L, 4 Cylinder, Gas, MFI, D17A6
HX
405114 $263.95
If that's the best they can do, go to another shop and watch how they do it. They should be glad to show you the free play in the ball joint.
Just drilling new holes somewhere in the floorpan sounds dangerous to me--they'd rip right out in a collision.
I agree with you, though; I don't want to do anything that would make the car unsafe. Thanks again.
I searched and could not find this question answered. I have a 2003 Yukon Denali and change my own oil. (I use Mobil 1 and wont spend what oil change places charge for synthetic oil).
I have been told but wanted to verify that this truck does NOT need chassis lubrication. I see a few zerk fittings, but no information on chassis lube. I could do this if the known locations are 'known'.
Anyone have this service manual or know the details? Denali has the AWD, 6.0L engine etc..etc..
thx
Jim
2)Read the owners manual. It 'might' show the lube points. Some do not, thinking this is beyond the average owner.
3)Read the owners manual. The maintenance schedule, carefully. If there are lube points, the maintenance schedule WILL tell you when (time and milage) the recommended schedule is for maintenance.
HelmInc Yukon
If you've got the $135, it'll seem money well spent after you look up how a couple of things are service or are put together. Sometimes you can find these on the net on auction sites.
fullcicuit
Any ideas? I'd hate to kill yet ANOTHER battery. Thanks!
Thanks for the quick reply, it is very much appreciated.
I dunno...it's such a weird problem I'm just groping here for a possible answer...
Basically, relay are heavy duty switches, used to operate those devices that draw heavy current...so a small delicate switch (say, your dashboard or stalk headlight switch) is used to trip a much heavier duty switch (the relay) and IT works your headlights.
ugh... but I don't remember what I did to fix it!
AHHH!! internet search. The little button under the dash is what I did!
You have keyless entry if you cycle the keyless remote several times it will stop the parking lights from flashing. If that doesnt work or you dont have a remote there is a little black button on two small brown wires depress this button then turn the key on and wait about 5 or 10 seconds the keyless entry will cycle and the ligths will go out. This littel black button usually sits on teh lower dash panel on Foresters however they get knocked loose or even broken and you will have to look for the button hanging somewherre under the dashe it may even be burried behind the black control unit that abotu 4 inches by 6 inches wire tired to the left kickpanel area above the fuse box
