Visitor Agreement.
I have a 2007 rabbit with 3,100 miles on it that has had 3 out-of-round tires in the same location - drivers side front. Each time that the tire was found to be defective all other tires were checked to make sure they weren't out of round; and still has only been in that same location. After 2nd brand new tire I took in my car to dealer. Dealer found nothing mechanical...however they thought it was unusual. Now this is my 3rd out-of-round tire and I will be taking in my car again. Has anyone ever heard of this being a problem on the rabbit/golf? It seems it takes a few weeks after getting new tire for it to become out-of-round, so i find it difficult dealer doesn't see anything mechanical. It is really bothersome, considering it makes my overall driving experience really unpleasant.
I would appreciate any feedback to this very annoying problem.
If an acceptable level of run-out can't be achieved, then the hub or the rim needs replacing.
seem's to me, it's probably the rim which is "out-of-round".
an easy way to see this is to dismount the tire and roll the rim on a very flat surface. if it's out of round, it will be pretty obvious.
But if you mounted the high side of the "bent" rim to the low side of the 'bent" hub and put on a straight tire, there you go, no more out of round.
I don't think it's possible to "make" a once-straight and once-mounted tire GO out of round unless you deliberately shaved it somehow. If it is, it's news to me.
If if he WAS referring to irregular tread pattern wear, then you are absolutely right.
I'm taking in the car again next week to see if maybe they overlooked something, or possibly they have techs that aren't very experienced..
I appreciate all the feedback I've received...all suggestions help me to ask the dealer the right questions..
If there are low spots (worn tread spots) in the tire, then it is pretty likely that the strut or shock to that tire is worn out and is allowing that tire to "hop".
The reason I ask is my Check Engine light is on and I'm wondering if that could be it.
Anyone ever lost one of those things and is it owner repairable?
Thanks for any help,
Lancelotlink
ever see one of the emissions stations hook their CAP to a sensing tube? they are checking the CAP for proper operation. they don't hook their sensing tube to the filler neck...
if anything, it probably went down the filler tube and is sitting in the tube or tank. if it's in the tube, i suppose it could be fixable (take it out and replace with new neck, but am not sure. Did you try looking with a flashlight or feeling with your finger to see if the "door" is still there, just no longer spring loaded?
my suggestion would be to bring your car to a parts store. many will read codes for free, and you go from there. you're just guessing what the CEL could be caused by.
i would say, if your GAS CAP were broken / leaking, then yeah, that could cause the car to throw a CEL. that's pretty easy to replace.
but without knowing the codes and googling, you're pretty much in unknown / guessing territory.
HTH.
I took your advice and lit a match so's I could see down the filler tube. My kind Doctor is typing this reply.
Just kidding of course!
The little trap door down the fuel filler neck is definitely missing though.
Forgetting the CEL then, what purpose does that trap-door serve? We checked my buddies Mini-Van and he's got one too.
just wondering,
lancelotlink
Guessing: keeps out dust / dirt / contaminants when the cap is off, and while the unleaded fuel fill nozzle isn't inserted and in the act of filling the vehicle's tank. Also serves as a barrier for the insertion of a Leaded Fuel filler nozzle.
Also, last night on my way home, I heard kind of a pop noise & the display on the radio, got really bright, then a few minutes later, another pop, the display went back to normal. This continued on evey few minutes of my 40 minute commute. My frist thought was regulator, but I just replaced the Altinator a couple of months ago & the regulator is attached...
any suggestions? :confuse:
Make them fix it, for free!
If the wire was secured properly, then it shouldn't have broken.
Unfortunately, the sensor that the wire goes to is part of the brake pads, so the pad will have to be replced, but regardless of how the wire got broke (which is how I bet they are trying to get out of warrantying it), it should be covered under warranty, unless they were using really cheap parts.
wondering when i should really change the timing belt
any other comments appreciated
thanks, w
2.5 or 2.3L?
On the 2.5 L the manufacturer's recommendation is 105,000 miles and inspect it at 60,000 miles.
On the 2.3 L the manufacturer's recommendation is to replace the belt at 60,000 miles.
Now you can see why it is so important that when you post, you supply the Year, Make, Model AND Engine of the vehicle you are asking about.
i can see why you call yourself 0 patience
you seem bothered when it is an easy response without me listing which engine
but i'm game: it's a 2.5 L engine --- if i thought it mattered i would have listed it, and i also thought this is the standard engine and the response would be for the standard engine unless was otherwise stated by the poster
but hey, what do i know
thanks again, w
Let me make this clear.........
When you answer posts for people and you need information, like which engine and they seem to not be interested in posting that information, tell me why I should bother to help anymore.
Yes, I am bothered when folks seem to think our crystal ball will tell us all the information that they so frequently leave out.
Have you any idea of how many times we (people helping) have posted that we need that information?
Then to have someone like you take offense to it??
How dare I question you? Good grief.
Don't be dense. I showed you very clearly that the information makes a difference.
There is no STANDARD engines anymore. A lot of satandard base models will come with several engines.
But what do I know? Nothing I guess. You seem to be the expert. Not sure why you were asking.
makes sense.
the problem is your reply came off condescending, like you were putting the poster down for not framing the question in the exact manner which would get him a reply of value. in this case, you could have left the latter part of the response off. it's not likely most people would think there'd be a difference which would matter. but when trying to educate, a simple statement of the fact coupled with the two pieces you provided would be of help to the original posters and others.
this is unfortunate because the information you supplied was high value. but the method of delivery?
lemme ask you - do you think you needed the follow-up? he got your point. no need to put him down several times more to drive it well past home. it just makes you look bad. way over the top. :sick:
Someone like OPatience sees every type of car and it's impossible to have all engine and transmission options at one's fingertips.
Given the fee OPatience charges and the level of expertise he offers, I see no harm in indulging his fantasies and giving him the amount of air in each tire if that's what he feels he needs.
We're all interesting in getting to the right answer, so why not shake hands, wipe the blackboard clean and just solve the problem?
sending you email.
1. Do a compression test to make sure we have a full deck.
2. If #1 is okay, I'd temporarily remove the catalytic converter by using a "test pipe" and see how the vehicle performs. If there's dramatic improvement, your catalytic is clogged or damaged.
3. Oh I forgot. If you can, try to drive a similar Jeep and see what's up.
Now ... this will be a silly question, but I gotta ask it. You're SURE its not the 4-cyl model, right??
I've got another really silly idea. I'd check to make sure the ring and pinion hasn't been swapped out. I can't say why someone would do it or even what you might put in there to get such horrible results, but it just sounds to me like your problem ain't in the engine. At 75 mph downhill on the highway, what RPMs are you turning in 5th gear?
You don't have a parking brake sticking, do you? I would have thought you'd totally wear that out if you did.
The swapped pinion idea is quite clever but sort of left field.
The 4 cylinder idea would explain everything!
the story of my life. ;b
well... except not always the "clever" part.
Oh well. No worries.
Its been fun, for the most part.
I'll bow out and leave you folks.
The guy with obviously the most technical knowledge posting on the board, and you **** him off!
And, back to the original poster about when to change your timing belt:
1) You specifically asked for 'any other comments' and then got bent out of shape when you got some.
2) You ever think about reading your owner's manual? The maintenance area will tell you when the engineers that designed your motor think you should change the belt!
Cheeze!
Otherwise, one is always suspicious of what's BEHIND a fuse box on an older car---that is, corrosion, loose wires, etc.
If anyone has any problem with another person's response, don't get into an argument. E-mail me and I'll try to take care of it for you.
You all know how easy it is to misinterpret, inflate and exaggerate in electronic communication. I'm sure nobody intended an insult.
So let it rest and we'll get back to helping each other out, okay?
MrShiftright
Carspace.com Forums
