I want to thank you all for trying to help with my frustration. To answer some of the questions you have posted. The 2nd dealership I went to did check the transmission fluid and said everything seemed fine. As far as the ball mount, when we purchased the trailer the truck and camper was put on a level ground to measure correctly. Everything was measured properly and the camper is level with everything.
Another update on the letter and e-mail I sent to the Toyotal Corporation. They basically told me that there was nothing they can do. They said I need to work with my dealership to find the issue. This is just crazy, I have been working with 2 different dealerships and nobody wants to help out. They also told me that my truck which is said in my manual to two 10800 lbs can only tow 8100lbs????? Seems a bit fishy to me. Also, they said that make sure I have the right ball mount, sway control... bars..etc. (Which I do) because that can mess with towing capacity. They wanted my vin number and all my information which I feel they don't need. They said they filed the report with what ever they do. I honestly just don't know what to do anymore. I just test drove a tundra with everything mine has, and guess what no shutter, rev'ing around corners, banging... etc. Of course I don't know about towing since it was a test drive, but it was totally different. I guess my only option now is to pay off what I can and purchase another truck. I can only hope that I can get some money back from that 5 year warranty I bought... not sure about that, but I am just stuck.....
The difference in tow rating is if your Tundra came with the factory tow pkg. or if the hitch was added by the originating dealership or at a 3rd party camper dealership. The factory tow package increases the tow rating of the Tundra. If your truck is a Double Cab 4x4 5.7 liter it maximum tow rating is 10,300lb.s with the factory tow pkg., the reg. cab 5.7 liter 4x2 has the 10,800 lb. tow rating when equipped with the factory two package.
If the truck was equipped with a receiver hitch and wiring after production at the factory then the tow rating is less. I hope that your Tundra will decide to act up when it's brought to a dealership so they "verify" your complaint. Once a dealer has verified that what your telling them is truthful they can then act with full cooperation from Toyota. Good luck. :shades:
I took the truck back to the dealer on 112809, got a call back from my service department, there were 3 factory reps at the dealer with my truck, at the direction of the 3 factory reps, they told the dealer to pull the motor out of the truck and tear the motor apart. The factory reps will return to the dealer on 120409 to look at the torn down motor to see what the problem is.
I contacted TMC and filed a case when this issue started a few months ago. I'm not here to bash toyota because I love this truck, but Toyota has the WORST customer service I have ever experienced! To all that have this engine noise, I recommend you stay on Toyota and file a case with TMC and be PERSISTANT.
Also I own a 2007 Tacoma and it is "SILKY SMOOTH" as you say so I may just trade it (TUNDRA) for another Tacoma or a 4-Runner. I don't hate Toyota! Just telling you what my truck is doing...........
I'm not sure what's going on here, but I'll be calling my service writer at the local dealership in the next week or so to see if he knows anything about, if there's a TSB as seems to be mentioned in a previous post, and what they can do about it. I'll post the result, Regards, BGood
Send to: karen@edmunds.com
1. Sagging Dash - the RF corner of the dash droops about 1/4", due to an inadequate support clip below the dash near the windshield. Toyota issued a TSB on this, and their fix is a NEW beefy clip and some insulation/padding ("Toyota Sound Dampening Material") between dash and windshield (T-SB-0080-08) covered by warranty.
2. AC/Heater vents/ducts - some folks hear loose ducts rattling around - they pull both glove boxes out and pack insulation around the duct work/vent tubes.
3. Rattle noise around speaker area - this was the noise I was hearing. It is NOT REALLY coming from the speaker/CD/Nav area, it only sounds like it is. IT IS COMING FROM THE MIRROR, where the mirror support/wires go. There is a PLASTIC COVER over the wires that "squeaks", "ticks", "rattles" intermittently or all the time. Push it down with you fingers and see if the sound stops. I can move it side-to-side and get it to squeak. You can squeeze it with thumb/index finger and un-clip it and it opens. I lubed it with some chapstick (!) and it stopped (may have to repeat application). AT LEAST I NOW KNOW WHAT/WHERE THE ANNOYING NOISE IS COMING FROM and I am not pulling my hair out anymore. Nice, quiet drives even w/o the radio on!
4. Same as above but look to the OVERHEAD CONSOLE. Some have found a loose wiring harness inside the console (passenger side) bouncing about. Tape/insulate, etc.
5. Same as above but loose wire harness BEHIND THE CLOCK. Pull clock and stuff insulation around.
6. Misc. - rear seat-belt metal clips. these rattle around and hit the plastic on the sides of the seats. I cut-out some self-sticking rubber type padding (2"X3"X1/8") and stuck that to the seat side where the clip was hitting. Done. Also, middle seat-belt clip "ticks" against the plastic button/rivet on the belt itself. Used round rubber pad (like used on bottom of calculators, etc.- get at Staples) on button. Done.
May get dealer to fix some of these under warranty.
Hope this helps. Cheers, TOY4X.
thank you for putting this summary together.
hopefully can get the dealer to fix the rattle - only thing preventing total satisfaction with the new truck!
I had to do this to get my entire engine changed...ended up being the #5 rod bearing was causing the knock.
This is what I recommend doing...good luck
--truck runs like crap after recall to adjust computer . Dealer says "Normal"
--Gutless towing my 2700 pound Tent Trailer. Advertised to tow 10,000 with ease (my Tacoma does a better job)
--Poor paint quality. Paint comes off truck with every little bump. Nothing you can rub out or touch up. Repaint the truck or live with the white undercoating showing through
--Radio volume does not work and stations drift off of where set
--Dash vents will not stay in adjusted position, you have a choice of full up or full down. Dealer reluctant to fix due to need to pull the dash. Says Dash will start to rattle when they fix it. Dash already rattles. So Add;
--Excessive dash rattle
--Loud engine noise similar to valve tapping. Dealer Says "normal" even though I have never heard it before, sounds like a diesel from inside the cab
--Tranny shifts hard when cold, You guessed it, the dealer says "normal" Did not happen in the first year of driving the truck
One more thing I should mention, the truck has a whopping 17,000 miles on it. Oh joy, I wonder what happens when I reach 20,000.
