Chevy Silverado - Continued VII
This topic is a continuation of Topic 1471....
Chevy Silverado - Continued VI. Please continue
these discussions here.
Front Porch Philosopher
thanks.
Short bed - 26
- Tim
Personally, I would have liked a 3 way learning remote in that spot.
Ryan
Kanton, any pictures of your completed lift? Specially if you have a picture next to a stock Silverado.
No wonder Ryan want to smack you.
Ryan
How's that Roger!
Ray T.
It has a tick in the motor on cold starts, it now has 6000 miles on it, it sounds like lifter tick but it seems to be lower in the motor, and it only does it cold. I can let it warm up in the morning for ten minutes and it still there. Afer you drive five miles or so it is gone. Any ideas
Cam
Roger.
Scooner
I fairly new to this site & was not my intent to upset anybody!
Ryanbab, I'm sure that your truck will look nice but I think it will look better having the same color flares as the body.
My truck was not ordered with the wheel flares, I just don't like the look of them. It makes the truck look like a 3/4 ton pickup! I'm sure a lot of people like that look, I don't!
I also don't like the idea of dirt, mud, etc. getting inside there. I know that you can wash it out but it must still rub on the paint? I have decided to order the Chevy mud flaps instead! Much cheaper & I think it makes the truck look better then the wheel flares.
I have to strongly disagree with you (ryanbab) about having the wheel flares on the Z71 off road pkg. If I had that I would remove the flares ASAP!
Thank you, fgilby!
<<A HREF="http://www.autodna.com/Vin_Decoding.htm">http://www.autodna.com/Vin_Decoding.htm>
Seems to me that you get the same info, except for $25 more for ordering over the internet.
BTW-I am talking about a 99 Silverado, not MM.
Kurt
Failing that, the first digit in your VIN will indicate the country of origin. 1,4 indicate US built. 2 means Canadian built.
The eleventh digit indicates the plant it was built in. E = Pontiac East, Z = Ft. Wayne, Ind,
1 = Oshawa, Ontario.
Mike
Mike
And for all the comments about Ryan and taking off the gloves.....at his age...How do we know they aren't mittens??
LOL
- Tim
Cam
Ryan
Maybe they switched brands because of vibration problems in the 99 models.
Ryan
I think you need to talk to your dealer about a new engine, CAM
- Tim
No loyalty change, I just like far to many vehicles. I need to win the lotto so I can enjoy more of them that's all.
I will admit that while my Silverado is finally coming around, after many trips to the dealer, I'm still a little discouraged with GM lately and that has made my eye wander elsewhere. However, not discouraged enough to even look at, or God forbid say the word, Ford or Dodge yet. I'm looking for QUALITY, and for 30+K we should be getting it.
Knowing your experiences with Toyota, unless your posts are not true, you seem to like them far east vehicles. You have owned several Toyota'a and now have a Lexus to go with your truck. Let's just say the thrill of going back to the dealer and waiting weeks for replacement parts has worn thin.
anyone else have this trouble?
Then, it will tell you which calibrations are available for your truck & brief description of each.
I got 2000 LT Z71 myself, but your aforementioned bulletin # is not coming up on my VIN for "growl".
Scooner
e-mail me the answer if you don't want to post it.
My e-mail is under my profile.
Ryan, Looks like I have to keep the flares, a body shop guy told me they are a pain in the [non-permissible content removed] to take off because you have to seperate inner/outer fender wells to get to them. He also said he has not seen any trucks w/flares prematurely rusting in that area since GM started using them.
So I guess my next step is to find a Husky dealer in my area to get the preformed mud flaps to fit flares from.
Ray T.
Key words in your statement are "in the past", I have seen the light and am a enlightened Silverado owner now. Can't get rid of the Lexus though, wifes car and she makes more money, so I think I'll let her keep it.
Ryan
Bob259 - Thanks for the info but it won't work here from my place of work. I tried to e-mail you back but it was undeliverable for some reason or other.
Ray T.
Line-X for my long bed truck and over the rails cost me $429.00 with tax. They give $25.00 back when you get some one else to buy one (one time only).
There is a company called Toff that has a spray on liner that is 1/2 thick if not thicker. Made up of supper duper soft rubber material looking stuff. Very expensive but if you throw a shovel at it it will bounce right back.
If you buy a BASE truck like I did make sure you buy the black body side moldings right away. After a month I ended with 7 dents right at the places where the molding would have gone. I bought it after wards and it covered the dents very nicely for $132.00 with tax.
USE #32 FOR WHEEL FLARES: cover dents, caused by rude people and their cheap car doors, that would have been protected if you had wheel flares to start with. If some one does not want their black set of wheel flares let me know I will buy if price right. That also goes for people with stainless steel rims, tires etc.
I don't know about no blue goo. Try Rain-x pink goo instead. Works great just like the wipe on rain-x. It also does not remove the wipe on rain-x and combined work twice as well. The only draw back is the sissy color and it cost more.
If I had to put my SILVERADO's tool box on a Tundra it would have to sit side ways.
On my last trip of over 600 miles of highway with 4.8L, standard cab, long bed, 3.78, standard transmission and no load except tool box I got almost 23 mpg. My worst in the city is a little over 17 mpg.
Ryan
Does anyone ever notice that they get "shocked" when then touch the door to close it? I almost always get a little static electricity when I close the door. Seems to happen more often than not.
Cindy
