Chevrolet Malibu Oil Changes/Service Questions
I would doubt there is much residue with todays machining techniques...but again..do what you are comfortable with...
So, with the driveability symptoms they are having I figure at their milage and all the dust we get here there is no way that thing's air filter could last that long. So after about 45 mins of work I get the thing out and it is covered in this black, fithly, thick film. Needless to say they chewed the dealer out.
Larry :-)
All other gasoline engines are designed to run on fuel that contains no more than 10% ethanol.
There are a few vehicles out there that run on E85. The new Impala has an engine option that is E85 compatible. It does reduce fuel economy pretty drastically as you indicated (less energy in fuel).
Larry :-)
Larry :-)
I think the GM oil life indicator is very sophisticated. People who insist on changing oil at 3K are doing themselves no favor as extending service intervals results in more wear as per this study:
http://www.swri.edu/3pubs/IRD1999/03912699.htm
"Testing with partially stressed oil, which contained some wear debris, produced less wear than testing with clean oil. This finding was unexpected and initially confusing (further inquiry suggested that the result was not so surprising, as many oil chemistries require time and temperature to enhance their effectiveness). Although based on limited data, the finding could be significant, and verification should be pursued. If the finding is verified, the mechanisms should be determined, and ramifications with respect to oil change intervals, filter involvement, and additive packages should be considered. A similar finding for diesel engines could have even greater significance, since the topics of extended oil drain and, in some cases heavy exhaust gas recirculation are of major interest. Although the conditioning run altered the oil, it did not stress or render it unusable (as noted, there is indication that it was tribologically improved). As such, the impact of testing with significantly stressed oil was not measured and remains a future objective."
In fact it looks to be on the other side of engine (and low) but I can't be any more specific than that without having changed oil on one myself.
I am also considering changing my oil to synthetic and wonder if there will be any issues with my mileage being so high??? thanks for your all your quick responses...
I also can't see why an Aamco or Jiffy Lube would not be able to exchange the fluid with their machines. Just make sure they carry the exact tranny fluid type stated in the manual.
would agree with Maxx4me.....use the recommended trans fluid....and have competent repair facility due the work...or a dealer you can trust....I think I saw a while back...quotes for another forum user that stated..a 50K service...anywhere in the 200 to 400 dollar range..but could be wrong.......I would simply call around to dealer service departments and ask about it...but again..check your owners manual and mygmlink.com...for recommended services
Ive been running synthetic oil in my maxx since 30K..and change it every 6500 to 7000 miles...anything sooner is a waste IMHO.....that averages out to two of the 3K dino oil changes...so the cost averages out.....dont think you will have a problem switching at this point.....
Reason why i am going to service the car at 500000 miles and not the 100000 point is because So. california driving is a bit harsher than eastern driving conditions due to higher temp average, I am in an area (desert) that 4 to 6 months out of the year 100 plus degrees are not uncommon...
Once again thanks to both of you for your quick responses, other than normal maintance, i am very pleased with this car,and will probally drive another it two or three years before i am ready to get another one....
Larry :-)
Open the glove box and remove everything. Press in very hard on the sides of the glove box and wiggle it back and forth while trying to pull it away from the dash. Its best to work on getting only one side of the glove box free before working on the other. Once you have disengaged both sides, the glove box will drop down. Now you are looking for a door that is about 2-3 inches tall and about as wide as the filter. Be careful when opening it. I snapped the latches of by trying to undo them the wrong way. Slide the filter in. Pay attention to the markings on which way the air goes on the filter. Inside the car, the air travels downward within that compartment. Close the door and then snap the glove box back in place. You're done!
If you should snap off the latches for that door, then you can a couple of pieces of strong tape (I use strapping take) to hold it in place.
Be sure there is a good solid support under the filter to prevent it getting sucked into the fan just below it.
One furnace filter that has a plastic grille is WEB. You can cut this to fit the Malibu filter compartment and then put the media filter over the grille.
However early Sept. it began shuttering at idle in drive
this went on till 5000 miles in December then the check engine lite came on
took to Chevy dealer they stated the coil(ign.mod.) was gone and cleaned 2 spark plugs one week and 170 miles later the shutting and check lite came back again this time another coil(ing.mod.) :surprise: , 1 injector and 4 new plugs we are driving a fine runing car. But we are wondering when it will pop back up again,as the chevy dealer has no clue why 2 coils(ing mod) and injector have failed. Fingers Crossed.as of 01/07 06
Thanks so much.
tuna
Larry :-)
can any one help???.
The COOLANT JOB (Red light coming on; the diagnosis was she needed to have her manifold gasket replaced):
Replaced manifold gasket 6.5 hours $585.00
Replaced worn serpentine belt 45 .00
Lube, oil, and filter completed $12.45
Gasket KI 68.78
Gasket 22.74
Seal 2.16
Coolant 24.32
Sealant 17.00
Bolt (4) 22.66
Bolt (4) 26.32
Belt 59.66
Oil filter 7.00
5W30 (6) 7.50
PARTS 250.44
gAS, OIL, grease 7.50
Misc. supplies used 16.95
TOTAL CHARGE-- $917.34
Brake Job (not sure which brakes, I'll have to check)
The brake job at the Shell Station was $469.73
SUSPENSION Job:
Replaced front strut tops, 4 wheel alignment 331.50
Mount--213.96
Nut 20.72
Hub cap35.02
Nisc. 16.95
Lab mechanical 331.50
TOTAL: 618.15
Sales Tax 37.09
Total-- 659.15
so it adds up to 659.19---suspension
976.33---coolant
469.73---brakes
$2085.25 since 4/21/06
1. I still have not changed the transmission fluid. Supposed to be good for 100K miles. Should I change at this point? Same sparkplugs as well.
2. Also, the AC unit is on the blink. This seems to be common problem with the Malibu's. AC light blinks on and off with the cold air. What's the fix for this?
Thanks, Magnus
Wxman
I use Mobil 1 synthetic in my '05 Maxx. I put it in when it had about 7,000 miles on it. Fuel economy and performance is not noticeably different from what I had with regular oil. The engine uses a very small amount of oil (as it did with regular oil). If I didn't top it up by dribbling in a few ounces here and there, it might go down 1/3 of a quart in 6,000 miles or so, which is obviously not a problem.
For the change interval, I follow the oil life monitor system. I start thinking of changing it when it gets down to 20 percent or so, and I don't think I've run it below about 14 or 15 percent, which means the oil is staying in about 7,500 miles in warm weather and 6,000 in cold weather. It could go another 1,000 or 1,500 if I took it down to zero percent, but zero could come at a time when it was not convenient to do an oil change, so I just prefer to do it a little early so I can pick the time when I do it.
I really like the oil life monitor because it takes into consideration the type of use the engine is seeing. I think it's far preferable to follow that than stick to a certain mileage figure for changes. The synthetic oil does make me feel better about those long change intervals it calls for, though.
