Anyone have experience with this yet? Know how if any differences there are from the '01-'04 Tacomas and the 2005? Any help is appreciated and will probably be welcomed by others.
You also have the Wade hood protector? How do you like it, any problems, is it all one piece that mounts under the hood or does it have brackets like the OEM toyota protector?
As for the Wade hood protector. I love it and I think it looks great. It is one piece and mounts under the hood using the pre drilled holes that are already there. Installation took all of 5 minutes tops. I would definitely recommend it.
I had better luck with the bug deflectors and found that other than the one Toyota offers, Lund and Ventshade off models for the 05 Taco. I wasn’t however able to find an 05 for the Wade. You wouldn’t happen to have a picture you could load, would you?
volley had a pic of the Wade deflector, type in "skid plate pic" and search, it will come up.
Thanks for the info on the Wade deflector, I think I made the right choice. I don't know but those brackets scare me on the OEM part and I couldn't find any good info on how the Lund and Auto Focus brands mounted.
Also, thanks for looking up the part number to the skid plate, it will save me from developing an ulcer.
I ordered mine from deflectors4less.com. With the "free shipping" it ends up being about the same price as any others I've seen so far.
Got there to test drive it, and couldn't believe how nice the leather was. I thought since it was somewhat "aftermarket," that it would be poor quality, and not fit right. Well, after seeing it, and riding in it, my mind was soon changed. (I think they had that truck there on purpose!)
I have noticed that the driver's side seat on the left side is getting a little, how do you say it, "leathery?" It's probably from sitting on the left edge of the seat when getting in the truck. I probably just need to use the conditioner that came with the truck for the leather seats.
I also left a chilled Camelback in the back seat (a no-no), and it sweated through the pack, and got the seat damp. The next day, when getting in, there was a strange smell, but after I removed the Camelback, and let it dry, everything looks fine, no stains or marks or smells anymore (thank God).
So, is it worth it, I'd say yes. My last car had cloth seats, and I prefer these over the ones I used to have. You just have to be extra careful about putting sharp edged stuff down in the seats. :P
Thx
JD
:shades:
:shades:
Is there some way to tap/fix the threads? I'm amazed that Toyota used a threaded insert that is softer than the bolts they provide. I'm also shocked at the poor engineering that went into the mounting bracket at the front; I expected more from DeeZee. The bottom, front hole in the bracket is right next to where the bracket runs at an angle, and the shoulder of the bolt has no clearance. Basically, the shoulder of the bolt is the only thing touching the bracket, and only in a very small area.
Right now I only have 5 of the 6 bolts in on the driver's side as I can't get a bolt into that hole.
Any suggestions?
Otherwise I like the look of the steps & hope they will prevent me from having any of the chipping problems others have experienced. I've had no problems so far though, for the record, my truck was manufactured 5/15/05.
-Z
I don't have kids, but most dealers will gladly try _your_ seat in the back of a truck.
Thanks fella's
Please respond to jfallonedmunds.com with your daytime contact information and a few words summarizing your opinion no later than Wednesday, June 8, 2005.
Jeannine Fallon
I love mine..not too much sweatin' yet..but they look great and match the Red TRD badging
Tip: tough to do, but try to get ur hand in behind the seat..it's helps!! Good Luck!!
I was made in Cal 04/05 and I hope they have fixed all the little problems I have read about on here. So far no leaks or rattles or chips but it did have a dint in the back quarter, which was removed without a problem.
I only problem I have is it looks like they put the rims and tires from a mid sized car on it (215/70R/15) my old Cutlass had bigger and better tires on it. Has anyone put bigger rims and tires on one of these yet and what if any problems did they run into changing the speedo to get a proper reading. I was thinking of going to something like a 245/75R/16(or bigger) that would be an increase of about 3 inches. This is just my truck/car so I don’t need some big off road thing I just want it to look better.
I love everything else about the truck.
This is a great site.
Thanks to everyone for all the info i have found here,
Asked about the redesign..they confirmed the part #
Nobody should be sellin' the old one anymore
Good prices, but i ended up gettin all my stuff from the dearler at cost
It is just the base model 2.7 access cab SR5 with 4 speed auto.
The parts guy said to talk to the tire guy about it.
I'm on my way to see a tire guy today to see what I can find out.
I am hopping the maybe the sensor or gear drive on my tranny could be changed to one from a 5 speed auto that had 16's on it.
I really don't want my speedo to be out, all I need is the wife to get a ticket because the speedo is out on the new truck. I would never hear the end of it.
I will post what I find out incase anyone else is interested.
http://toyota.com/vehicles/2005/tacoma/exterior.html
Cool site..360 views..some clips,stats, etc....This site was one of the reasons I traded my
' 04 for the ' 05 !!! My wife hates me!! :shades:
