Any guess on what it is?
Bob
New Jersey
The heat shield on the cat converter doesn't seem to be working very well. There is substantial cracking in it and I can see that at about 33 months and 25k miles, this boot will fail a couple of years from now. Anyone have any experience with this problem or know of a TSB on it?
Happy trucking -
The service mgr has an FJ model and his wipers just started making that same noise.
paul
mike
mikeeverhart@yahoo.com
is it weatherproof, keep dust out ?
how does it attach?
how's it do at highway speeds - noise?
looking to sleep in the back on trips
Noise is subtle, but really irritating-- sort of a high pitched buzz/vibration.. almost insect-like. Audible (to me at least) maybe 80% of the time I have fan on. More obvious at low fan speeds. I ititially thought a pine needle or something had gotten into the fan, but dealer say's it's clean.
Like others, I feel crazy when I describe to a dealer.. maybe I have bionic ears or something- but it irritates the crap out of me when I hear it. Anybody ever get a definitive diagnosis/remedy? I'm about to argue to just get a new fan ordered under warranty...
Honestly, Toyota should do a recall on this because it still isn't perfect and Toyota does boast that it makes a "perfect" product.
No they really don't. LEXUS boasts a Relentless Pursuit of Perfection, in various iterations over the years..... Toyota boasts very little, actually... Their reputation is nearly perfect though. They are still machines - it's a miracle they work at all. We are SO SPOILED these days....
Go find a 1957 Chevy truck, and turn the fan on (if it even had one, and if it will work) - see how the noise is...,... You won't be able to tell, because the REST of the damn thing will be so loud!
I would be using it for two driveways here in northwest PA. One is paved, about 800 feet long, with about 30 feet of elevation. The other is 600 feet, unpaved, about 50 feet of elevation from bottom to top.
Thanks in advance for your opinions/advice!
http://www.toyotanation.com/forum/showthread.php?t=209848
I have some pics and install instructions in my CarDomain. http://www.cardomain.com/ride/832238
Any info appreciated!
Thanks,,,
I have received very helpful information from this forum in the past. I hope someone can help me out. I have a 2008 TRD access cab. I am experiencing a slight whistling noise coming from the driver side of the car at speeds of 70 or greater. The noise is coming from somewhere between the access cab up to the front driver side windshield. It is a sharp whistling sound. It just started happing. I have 1400 miles on my taco. How can I fix this whistling sound?
check out this great site...it will answer lot of your octane questions..
I also use 87 octane and find no significant difference compared to 91. After you read/access the info above, you too will agree that using higher octanes in your v6 Taco is actually more harmful than not. According to the site info above, using high octane in engines with lower compression will eventually mess up your catalytic converters (hence the stink smell). Please read the info...
2008 Tacoma V6 Double Cab TRD Sport
Check out this link for answers/info to the octane question.
http://theserviceadvisor.com/octane.htm#2
2008 Tacoma Sport double cab, flowmasters (50 series).
Thank you ctrl. I guess everyone gets the V6, but with gas expected to approach $5 a gallon this summer, I'm glad I went with the 4cyl.
Do you happen to know if the auto trans has a lockup torque converter, and at what speed it locks up?
