Visitor Agreement.
When Motor trend ran all four trucks in the 1/4 mile they finished Silverado 1st, Tundra 2nd, F-150 3rd, Ram last.
Silverado beat the 2nd place Tundra by 25 feet, beat the Ford by 87 feet, and the Ram by 124 feet
The Tundra was gaining ground on the Silverado - Tundra in fact will beat the Chevy to 80mph.
Why did you say that the gears should be 3.73 for Ford and 4.10 for Chevy right after you said the gearing should be as close to equal as possible? Both manufacturer's offer 3.73's and 4.10's and even 3.55's for that matter. Why not the same for both?
Z71Bill:
Which Motor Trend test was this? I've seen several from them and Truck Trend. The latest one from Motor Trend faced off 4X4 trucks. The Chevy did win, but they forgot to mention that it had 4.10's while the Ford had 3.55's. Not quite fair. Put 3.23's in a Chevy with their 5.3 and 4.56's in a Ford six cylinder and see who wins.
I am looking to purchase a pickup that will tow a 5500 pound trailer. Do any of you tow that much with your Tundra??
DHS
I do apologize about that 4.10 thing. I had a Chevy on order and couldn't get the 3.73 gears maybe I am just jaded and trying to mentally block that whole set of gears out.
One thing I will trash is GM's new VOMs ordering system. They will put just about anything together and hope you take it. Bad marketing if you ask me.
My two favorite truck commercials as of late are the one where the Ford has a Western theme going and they make use of the Phrase "It's Time to Get Outa Dodge." and the Tundra Commercial where they race it against the Lotus and then the road runs out and the Lotus stops while the Tundra keeps going.
Anybody ever see the commercial for the S10 ZR2 about 3 or 4 years ago where they are showing all these nice luxo cars running down a twisty road through some green hilly pasteurs. The voice over is simply saying in that haughty voice the BMW 328I....The Lexus Yadda yadda etc. Each time he says a car it comes running down these twisty roads. He goes through about 4 cars and then says the Chevrolet S10 ZR2 and all of sudden this muddy ZR2 comes leaping over a hill and jumps the road the cars had been driving down. I think I am the only person who saw this commercial, it was funny as hell.
As far as the Toyota timing belt goes the service interval is 100,000 miles. The manufacturer is usually very conservative on the service interval. I owned an Acura with a 60,000 mile interval on the timing belt and I actually replaced it at 90,000 miles. The belt that I took out looked like new. YMMV.
The belt is usually pretty cheap and the labor to replace it is not outrageous. I plan to do it myself.
Toyota engines are non-interference engines. This means that when the belt breaks - valves do not hit pistons. The engine will stop running and only the belt will need to be replaced.
Tp4, sorry about the head snapping around comment. BTW, how's the neck brace working out? ...LOL
All,
Saw the other big Ford hit today, the Sport Track. Overstyled to me, in a way you could grow to love if you weren't first smitten.
Silverado/Sierra have been eating into F150 sales recently, but I think these two hybrids are the tonic to assure Ford stays in front.
Gears make a big difference with not as big an effect on mileage as people might think. The biggest problem I have seen is the lower the gearing you use the more top end "breath" you lose. My Dakota R/T really ran out of go by about 75 or 80. I know it's a truck.
Most of the Silverados and GMCs are coming out of the factory with 3.42 gears, at least down here, and as much respect I have for the 5.3 Vortech it really seems overwhelmed with 3.42 gears.
My Tundra has 3.91......Pie R Squared gearing. It is weird they stretch the ratio number out to like the 6th digit in some publications from Toyota. I was worried that this gearing would be a bit low and that I would lose some of that highway cruising ability but I am so impressed with the Tundra's ability to get off the line in a flash and still be able to cruise at 80 with plenty of passing power left.
Wow past few posts actually have the beginnings of a rational, friendly discussion of our trucks. Impressive.
The engine must turn the drive shaft 4.1 times for every 1 time the rear wheels turn with 4.1 gears. Drive shaft turns 3.08 times for every 1 time wheels turn if you have 3.08 gears.
Toyota keeps it simple by only having one rear end.
If you look here:
http://www.gates.com/shared/brochure.cfm?brochure=109
you will see that the 4.7L in the Landcrusiser is a non-interference engine (as well as all other Toyota OHC engines). The Tundra should be a non-interference engine unless they re-designed the Tundra engine to be an interference engine (If so, this would be the only Toyota engine to be so). Show me the source that says the Tundra is an interference engine.
If you don't believe me check the tow ratings with different rear end ratios. The Higher value (lower gearing) has a larger tow capacity.
The comment was made(and this will be the third time) That the performance would be aprox. equal if you have a smaller tire with a NUMERICALLY lower ratio as a if you had a taller tire with a NUMERICALLY larger ratio.
In other words 31" tires + 3.42 rear end may be equal to 33" tires + 3.91.
My original comment to all these posts was that it is tire size not rim size which dictates diameter. Arkie cleared that up.
Please stop trying to tell us what we've been saying for days, thank you.
I actually tested and researched all the trucks out. Drove a Dodge, Ford, Chevy and the Tundra.
I like the interior features, comfort, autotrac, big cabin, exterior class, etc. of the Silverado. As far as my overall like of the design, the Silverado wins for my taste. However, since new, I have had an awful pinging on 87 octane gas that I havn't had any help from GM on and nothing I have tried has fixed it. I thought that a colder firing plug would work and it did take about 95% of it away, but it still pings under load or when the AC is on. I just have gotten burnt out on paying so much money for a truck that doesn't run right and GM won't fix.
I still think that the Silverado is a great design, but there are some quality issues that GM doesn't resolve any better than any other manuf.
I liked the Dodges exterior and it's stance, but not much else. I thought the 360 was kinda sluggish for all that displacement and gets terribel mpg.
I also liked the Tundra, but it is too small and regardless of the tests, I didn't see the acceleration and power that Tundra owners see. Not knocking the truck, I just didn't see enough truck for the money.
Next to the Silverado, I liked the Ford the best. Great styling, although not as advanced as GM, Agressive engine response, smooth ride. i thought the steering and braking was a little sloppy compared the the Silverado, but not bad at all. What made this sale is the price. GM would not even come close to fair market value for my truck on trade and stuck very close to retail on their truck. None of the dealers wanted to work for the deal. Not just one but 3 different Ford dealers were trying to outdo each other, which drove the deal better and better for me. I got fair market value for my truck in trade (24,500 according to both Edmunds and KBB) and they came down to 100 over invoice on their truck (26,490).
That means that I only paid 2k difference for a brand new truck with no ping. 5.4l V8, ext cab, tow pkg, off road pkg, xlt, capt chairs, cd changer, 17" alum wheels w/265 tires, solid black with med grey int, rear sliding window, bed liner, etc. etc. etc.
I am very happy. I will miss my Silverado, but not the engine noises.
Quadrunner500. If you are out there, sorry man. I thought I got it fixed. I really am starting to think the engine noise is not a ping, but some kind of exhaust or maybe the poppet valves (fuel).
Anyway. Looks like my GM buddies will dis me for a while now! ha ha!
although i think you may have been hasty with getting rid of the silverado. I don't know about the new Vortecs, but the 1st generation Vortecs say in the owners manual that occaisional pinging is normal. have yet to hear anyone say that the truck didn't run as well or the life was decreased because of it.
I am hearing what sounds to be to be piston slap. Is this possible? I have conversed with a few other F150 5.4l owners who say it was fixed in April of 99. What is the story?
Also, after driving the 74 miles, maybe it is just me being used to my Silverado and how it runs, but the Silverado seems to have more romp to it, even when it was brand new. What do you all think?
Having second thoughts......
The Ford does have a 3:55 ls where the Silverado has 3:73 ls. Will there be that much difference?
I know when pulling a load it will show, but I have seen very little difference in normal driving acceleration between the 3:73 and the 4:10 on the Silverado's.
Also, why did they stop offering a 3:73 diff on the F150's. That is the story I got from the Ford dealer anyway. This true?
I told them I was hesitant to buy without thinking on it over the weekend. That will give me time to ponder over each trucks strengths and weeknesses as well as the money outlay to see what I want to do.
Funny thing though. It is mid 70's here today and all the way home, even with the air on....no engine noise/ping or whatever it is. I started wondering....do you all think I possibly got some oil or possibly anti-seize on the plugs when I re-gapped them?
I will keep everyone posted.
Quadrunner500, that plug change still may end up having fixed this thing. I will give it more time and let you know.
I'm afraid that one might find it difficult to use the terms "Motor Trend" and "serious automotive journalism" in the same sentence.
Having driven all the trucks, including the Toyota, I felt that the Toyota only had better acceleration over the Dodge. Ford and GM had much better acceleration. I admit, I drove the bigger 1/2 ton engines, but in my opinion, to be the best or the fastest, you should use the biggest engines and the lowest geared differentials that each manufacture offer. Again, not knocking the Tundra, but it comes last if you compare it in that light.
I'm pretty happy so far w/my truck. I've had it about 6 wks. and have around 2500 miles and no problems at all. That is the way it should be. If your are uncertain about that particular truck, see if the dealer can find another one just like it. It may take a couple of days and they may charge you another $100 to go get it but it may be worth it. The Tundra is just a little small for my tastes (and $)
I really liked the Ford I drove for the two days and I may still go back and make a deal on one, but what I REALLY want is just to keep my truck and have 100% security in knowing my ping is resolved. It just kills me knowing that each day I run it with the ping, it puts just that much extra wear on it.
Still deciding.......
Are you actually considering a Ford? It sounds as though you're content with the Silverado and just seem peeved with the "pinging".
BTW:
3.73 gears are still available for all Fords.
Roc
