Dodge Dakota - III
On the water spots issue: Check your water plant and ask what range their hardness, alkalinity and TDS/chlorides are in. If the hardness is over 120ppm a water softener may help, but get one that does not use salt. If the alkalinity is under60ppm, I do not recommend a softener. If the TDS is over 250ppm or chlorides are over 75ppm, then the problem may be salts in the water and would require a reverse-osmosis system to get it out. This is just a generalized look, but it may help.
The Durango side step items use mounts along the full length of the cab area (wheel to wheel). Even if it would fit (it doesn't) the Quad, you don't want to 'tie' the bed to the cab with a tube or anything else. Any pickup bed must 'float' on its own.
ozark - I'd just leave the bed thing alone until Dodge issues some sort of fix. The 'look' isn't that noticeable on most, though flares & gravel guards might keep the 'cooties off the quarters' so to speak.
stvdmn - if you ever feel the need to "wash it down with the hoe and take her out for a short 'joy' ride" - be sure to let us know beforehand. Sounds like something we don't want to miss.
good luck all,
robert
Thanks, I think I must have misunderstood the Saab salesman, which is understandable since I bought it in Sweeden. (My Sweedish stinks, but his English was good)
Does this mean we will all be modifying our intake boxes?
How about air pressure in the tires? Any thoughts? (Quad with no load and highway driving. Tire and handling package...)
KnK
1 Question,if I go ahead and move my air intake,to say the front grill(ram air)will my gas mileage increase, as well as horsepower?
like $690.00 is in the price range. I found a
dealer in a FANCY shop and he wanted $797.00!
Mileage update 1100 miles on truck, 4.7, 5-spd,
3.55 gears. Mileage is up alittle. From 16.2 to
16.9.
Later renegade69
You are right in saying that you will get better mileage with slightly higher pressures, but you will have lower overall costs if you run the correct pressures.
Increasing pressure without the load will lead to uneven wear on the rear tires and will reduce handling and traction (especially in the wet). By all means feel free to experiment with pressures but I would stay withing a couple of pounds of the low load pressures.
KnK
P.S. Second tank of gas was 17.3 mpg (4.7L 5sp, 3.55)
I've got a 99 x-cab. The mopar bedliner was a waste of money. It makes it difficult to access the few tie-downs that are there. You can't use a tension bar because the sides are not up against the bed wall, so you can't get good tension.
Has anyone found good tie downs that can be used with the bedliner. I've considered taking out the bedliner.
I have relatively little experience with 4wheel but 4 hi was great goin up...and 4 low coming down. What a blast. The dog thought it was great too. The wife couldn't make it that trip...he he he...too bad we can't post pics on here...would be nice to see some owner's Dakotas...Anyway, enough blabbering....Thanks again all.
R.
That said, if you can use the brackets to place linking info for an external site in your post (as most of us do from time to time), you could probably figure out the HTML command string to input your image(s). It's not that tough. I believe some of the more common HTML commands are shown in the 'FAQ's or Help area' that Edmunds has for the Town Hall users - including 'img rsc.'
Hey, we're going to have a FIRST CLASS place with our owner's club space. Not to worry. :-))
I guess I could order Durango molding and apply myself but I would have to order two each of front door moldings to get enough length to cover the longer rear door on the Quad. I am sure the parts are more expensive than $20.
Bookitty
I have a 97 Dakota with the V6. It makes a terrible racket, it is especially loud at idle. It sounds kind of like valve train noise, like a flat lifter but it is awfully loud. Some others have the opinion that it is the timing chain or the drive gear for the distributor rotor.
Anybody got any ideas?
Just a note: As of this writing my truck is in the shop getting the bed realigned to the cab.
Bookitty
does matter in a bed cover. Some covers
actually rest on the top of the bed rails,
with time they will rub the paint off. Some
dealers will apply a foam sticky back tape
on the bed rails to reduce the wear. My
opinion, do just as much homework on this
subject as you have buying that beautiful
jewel in your driveway.
good luck renegade69
Ps. never heard of the wd-40 thing, what's that?
The WD-40 reference address: http://www.wd40.com
The installer put TWO layers of thick foam tape on the CAP before inching it down on to the bedrails. He first removed the brake lamp bulb from the cab and wired in the new on in the cap.
This guy has been installing caps for many many years. He said that removing the 4 clamps will allow the cap to be lifted off at my convienence.
There is a plug in the wire going to the cap brakelight to ease removal of cap.
Trivia follows...
BTW... WD40 is a WATER DISPLACER (formula # 40) that was originally made for a government project.
The maker then went into production and the stuff is now available even in wallmart. It is used for everything BUT a water displacer.
KnK
KnK
hope this helps
Thank Will
I use synthetic, and am a fan of the benefits of it, so bear that in mind.
I would say that 3000 miles was probably a little too early to be thinking about synthetic, waiting until 5000 is probably a better bet just to make sure everything is seated properly. It shouldn't matter in modern engines, but better safe than sorry.
If you switch to synthetic then you can, theoretically, leave longer between oil change intervals. My advice would be to stick with the recommendations for the truck - but that means 7,500 miles for most people.
I would suggest a good quality oil, I use Mobil 1, but Castrol Syntec, Amsoil etc will also do the job. Make sure you use a good quality filter though - Mobil 1 is good, please, please don't use Fram.
I wouldn't suggest sticking with 10w-30 that you have used before - 5w-30 is a better bet, or maybe even 5w-50.
I have the skid plates, but I also have a friend with a lift so I don't have too much hassle, but yes they can get in the way. I wouldn't think that it warrants removal though, a little bit of care is really all that's needed - hey it's an oil change, you gotta get a bit dirty :-)
I'll leave it at that for now, if this turns into another discussion on synthetic vs. natural I'll weigh in with more.
My Jaguar has it as a design feature :-)
