Visitor Agreement.
In NewYork it will rub for sure.from the force of the pot holes. Is there a way to lift or adjust the shocks or suspension to make the tire to wheel well clearance at least higher another two inches or so to prevent it from rubbing?? I MUST have them 22s I know it'll ride like krap but I have to have them..lol
I have a Chrysler 300 and I am interested in buying an aftermarket grill. I notice that you have ordered an E&G grill. They make several. Which one did you order and why?
Does anyone know if my warranty will be voided, if I have this Mopar product(exhaust) installed?
Also, any opinions on air intake systems. Can it be installed without causing a problem to the engines computer?
Thanks, Curtis R.
I know the bolt pattern is 5x115, but there is conflicting info about the offset. I have read 32-45 and 40-45. The OEM AWD wheels are a little pedestrian but I don't want to make any changes that would mess up the integrity of the (phenomenal) ride. Cheers!
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7968333599&category=336- 45
Thanks for the info. That answers my questions. I was a little afraid of an aluninum grill because of corrosion and being just plain weak. I did not want a grill that would be bent by a large bug. I will buy stainless.
Thanks again,
Curtis R
Who has results with chips or tuner computers or adding a supercharger to the 5.7 hemi?
Treat
Thanks for any help
Any thoughts on air intake systems?
If I had it to do over again, I'd put the Borla 140125 on and not the 140112. I like the sound better.
I'm really happy with the Jet module (although it was a tight fit) because it fixes the "soft" shift points when you really get into hard throttle.
Dealer had no problem with the Borla and the AirAid. They suggested that if I bring the car in for anything that would require them to hook it up to the computer, I should probably pull the Jet module off. I have that down to a science now.
Top end? Backed off at 125 because I don't trust the continentals. I'll wait for them to wear out (which seems to be happening too fast) the I'll put pilot sports on it.
Happy driving
:shades: :shades: :shades:
Engine 24
Where did you get this smaller emblem.
CWR
anybody knows the bolt pattern of rims for 2006 chrysler 300 rwd?
for 2006 chrysler ,is 300/300c the same thing?
How is the ride?
How are the fender clearances?
What about the road clearances?
How does it handle in the corners?
Was it difficult to install?
Did the alignment people have any trouble alinging the front and rear suspensions?
What did the dealerships garage people say?
"Thanks"
