Chrysler 300: Problems & Solutions
Talk about 300 problems and share any solutions here.
However, just now I was parked outside in 90+ degrees, and it stayed at 74 for the entire 15 minute drive home. On longer drives, it usually gets un-stuck at some point, but I haven't noticed a pattern.
Guess I'll have them check this out when the fix for pulling to the right comes in.
AM reception is very poor and they have already replaced the AM modulator (did not fix) and now they are waiting for a new antenna base to see if it will fix the problem.
Also, outside temp reading locks onto a setting and does not update until 15 or 20 minutes into a drive. Chrysler tells me that they can't duplicate this while it has been in their hands so they can't fix it, they told me to bring it in again when it happens.
Please let me know if you are having these same problems.
Thanks for the info and advice. Tough part now is I am told that the sensors with this new transmission have been moved to the interior of the housing and they can no longer be removed and replaced without pulling the transmission apart.
Time will tell where this is headed?
Intermittant problem, took 10 tries over a few hours to start the car. Then the problem went away. The car was serviced and a broken module was found and replace ... hmmm ... however, the 300 has done this a few times since.
Interesting ... I am waiting to see if the problem returns on a more permanent basis as these cars are beautiful and who wants to have it in the garage
Unfortunately, has been in the shop most of the time due to faulty coolant temp. gauge. Intermentially drops to zero and engine cooling fan comes on. Happen to anyone else?
Also does pull to the right!
Thanks for the info!!
http://www.dealerrater.com/search/search.asp
It might help others BEFORE they get stuck.
fastdriver
Look for any of kinglabs's posts and click on his profile. E-mail him and have him forward my e-mail to you.
You won't get much satisfaction from the "5-STAR" OR the "factory reps"! It never changes. New model, same old crap! Having them take half your car apart trying to solve the problem won't help because they have NO clue what they're looking for!
fastdriver
My hideous AM reception remains after replacing the AM Modulator, the antenna base and the radio. Is anyone else having this problem?
with the "passenger air bag off" light occasionally. I took it to 5 star and of course they initially found nothing. The first bad vibe I received was when the grease monkey tech came to talk with me and stated that"gee this was the first time I sat in a 300 much less worked on one". In his infinite wisdom he told me that he was told the "passenger air bag off" light should be on unless there is someone in the seat. I let him know in a somewhat disgusted tone that he was told wrong.
Anyway, he went back inside to attempt to find the problem. About 20
minutes later, the asst. manager came out to tell me that they finally determined how to use the new scan tool to read any problems in my computer. He told me that they found numerous error codes and that they had no info as to what to do. I was told that they would literally have to spend numerous hours on the phone with Chrysler to fix the problems. I said that as far as I was concerned, there was only one problem, my air bag light. I was told that was an obvious problem but the computer is showing many more.
Here we go. It sounds like this is a deal whereas I would have been better off leaving well enough alone. I am so concerned that they will screw other things up.
Anyway, I have an appointment for Thursday. Of course, I had to remind the dealer that they have to give me a loaner car since that is part of Chryslers commitment to the 300.
The icing on the cake was when I got back into the car and discovered that thegrease monkey couldn't care less about dirtying my carpet and kicking the sill plate getting in and out of the car.
Also, where can I go to find the TSB description? And finally, the door sticker says the month/year built, but not the day. Where can you find the build information for the car?
Any help will be appreciated!!
On the first test drive, the salesman said I was the second person to tell him this. I went to another dealer and found the same thing happened again.
Does anyone else have a similar experience? Anyone know why this is happening?
The 300c's I drove stayed planted to the road, but the shimmy in the steering was there. Something needs to be addressed there, it sounds like the car needs a better steering linkage.
Bottom line for me on my test drive was the car hugs the road, but the shimmy made the car feel like it was loosing control. I know you are used to it , but it shouldn't be there.
Thanks for the comments.
I have a 1996 Eagle Vision TSi that has very tight steering (as did my 1995 Chrysler Concorde).
1. Car pulled to the right. Locar 5 star said "crown in the road" I brought to their attention there was a TSB on it. Their fix was an alignment. They made no mention of the cam bolt issue. Car still pulls but not as bad.
2. Cd player reads "error' when it get to the end of a cd and ejects it. They aledgedly played 6 cd's and couldn't reproduce it. I had to go down to the dealership and show their lackies myself. They weren't playing the cd to last song where problem occurs. They said they would have to order a new radio and it would take 4-6 weeks to get. Asked if they would upgrade it to a 6 dics chamger if I paid the difference. They said they were "not allowed" to do this by Chrysler.
3. Outside Temp readout gets stuck at 73. They said they could not duplicate it. Drove back while it was happening, showed the service manager myself on a 85 degree day. Their servce people looked at it and I picked it up with an invoice stating "problem could not be reproduced" they stated they were not aware of any other people having this problem.
4. Yesterday, had sunroof open, and when closed, a 1 in. wide piece of weatherstripping pulled out and stuck to the top of the roof. Took it to dealer today. They had it fixed in less than 2 hours, invoice stated "weatherstipping replace to correct position. Only problem is that the piece came from well inside the roof and would have required either removing the sunroof or taking down the headliner to get at. The piece was actually pulled out and not replaced. I have not gone back to them about that yet. Would like to hear your thoughts on how to approach this.
Part of my problem, I think, is that I did not buy the car from my local dealer who I have been taking it for service rather that the dealer I purchased it from who is 150 miles away.
I would appreiciate any thought or comments on what I should do, how I should approach the weatherstipping issue, etc.
There is no excuse for sub-par service by any 5-star dealer regardless of where the car was purchased. Chrysler pays them the same for the work either way. I would suggest a complaint to Chrysler about the local dealership. That is BS!
Anyone else notice the trunk is kind of difficult to shut on the first try? Needs a handle on the inside. That's about it.
Took it back to the dealer, they drove but didn't know what to do for it.
Took a 300C off the lot and it also pulled to the right. Still waiting for a fix.
The ride quality is firm and sporty, never floaty. The 5.7L Hemi is outstanding and more refined than I expected. Once it is warmed up, you can't even feel it idle. The transmission shifts smoothly and the autostick feature is a blast. I keep finding myself surprised that a 4000+ pound vehicle feels this light on its toes and nimble around turns.
So far, I have experienced no problems, issues or annoyances with this car. I am very impressed with this being a first year car and having the fit and finish that it does have. The interior is tight with no squeaks or rattles and all the panels are aligned properly with no rough edges.
As with any new car model, it's good to share problems and solutions with everyone else. I will post again if I find something, but so far my hopes for reliability are being met. Just in case, I purchased the 7/70k bumper to bumper fully anticipating at least some issue with a first-year model. I previously had a '97 GTP (another 1st year) that had a few minor annoyances but nothing major and ended up being a reliable car for 7 years.
Before someone posts a message completely trashing the reliability of the 300C, Chrysler or American cars in general, I would like to say that any car from any manufacturer, regardless of reputation or price, can be a gem or a lemon. My father in law is taking a substantial loss trading in his '03 Infiniti G35 (highly rated in initial quality and reliability) due a major brake problem that the shop can't diagnose.
Thanks for reading.
