Chrysler 300: Problems & Solutions
Did you ever get resolution to your problem?
Alittle annoying but I'm not ready to take it to the dealership to be tied up for a few days. Unless someone knows this can become a major problem (short in wiring?)
Only other problem I've had is the outside temp got stuck one day and now it reads about 10 degrees on the high side. Thank you for any help. Steve Swaney
These directions apply to the Automatic Temperature Control system only. I don't know about the manual control system.
The main thing is to get the mode switch set to 'Auto'. Then set the fan switch to either Auto-Low or Auto-High to suit your preference. Once you have these switches set correctly you can use the dual zone temperature switches to set the cooling level for your particular seat position. Once I got things set up like this the A/C worked beautifully - even on the hottest days.
MikeSp
Hit the gas from a stop light, all of a sudden, I thought I had blower att'd. The load "winnnning" sound. Lots more.........
Took it back to the Shop, Ha. Told the dealer, NEW TRANNY OR NEW CAR!!!
They stated that they would check it out, Bubba did. Tried to fix it. Changed out pumps, TC, flushed 2 times, etc., SAME PROBLEM.
i REQUESTED A NEW TRANNY, IN A BOX. The service rep. stated that there was no such part number in the BOOK. Went around and around, stating that if an item was made for the production line, then it could be replicated for service. Lotta BS, then all of a sudden, there was a Brand New Trans, in a box sitting on the shop floor.
Haven't picked it up yet. Should get it back today. Bottom line..............
DEMAND a new one. It been re engineered. Water problem, they say has been fixed. Funny, my letter to the design team must have worked.
Will post after test drive today!!?????????
I now have over 33K miles on the 300C, and I can proudly state that my tire wear is normal, my car does not pull to the right, and the tranny is fine so far. I have no reason to complain about any of those issues. I took my 300C to my local Chrysler-Dodge dealer (not the dealer from whom it was purchased), and they inspected the wheels. After an e-mail exchange been the service manager and D-C, I was told that a TSB for the rims had not yet been issued, although a 'how-to TSB' did exist for the maintenance and cleaning of the rims. The service manager acknowledged that the discoloration and flaking was something that D-C was "aware of", and D-C shipped four new rims to the dealership. I am having them installed tomorrow. D-C knows this is an issue, and I cannot see why any dealership would pretend otherwise.
How do I know this is the right answer? Cuz I do the same thing about once a day on mine.
Good luck!
http://www.foxnews.com/story/0,2933,169584,00.html
http://www.consumeraffairs.com/recalls04/2005/jeep_grand_cherokee.html
http://autoadvice.about.com/b/a/203575.htm
URL: http://www.msnbc.msn.com/id/9371197/
I've noticed, at my home, my heat pump has 'frozen up' in the past when the humidity has been high. Ice builds up around some of the copper components, and the system bogs down, putting out warmer air and not removing the humidity. Coincidence? I think not.
Where are all the good HVAC guys out there? Surely they could pinpoint what Chrysler is doing wrong.
One way to check if the evaporator has frozen is to actually turn the A/C off (or the car) and check for continued condensate flow. If the car continues to drop water for a minute or more, you probably had an icing problem. You would also notice decreased airflow from the vents and maybe increased HVAC blower noise. The fix is to operate the evaporator at a slightly higher temperature. 33°F is ideal. Problem is, if that 33° is not uniform across the evaporator, you could still have colder spots, which leads to local icing. From there, you get a runaway effect due to the fact that an iced evaporator cannot absorb heat as well.
THANKS STEVE
perhaps there is a loose connection with the clockspring, or the clockspring itself has some discontinuity when the wheel is sharply turned.
i would say this would be specially true if there were some means to switch from AM/FM/SAT from a control on the wheel.
Bob
Bring this TSB with you when you go to the dealer for the warranty repair.
http://www.alldata.com/tsb/Chrysler/1117004400000_1118127600000_08-027-05/271.html
http://home.comcast.net/~300_C/
dmiller5
Bob
Best,
Bob
Happy Trails
Question: Can any of you tell me if a 2005 CD or hard copy manual will be significantly different from a 2006 manual? If so, what areas of the design?
