Land Rover LR3
1222325272888
  • tropnevadtropnevad Member Posts: 18
    I wish that I could make mine bounce like a rap video, riding on 3 wheels would be great too. Has anyone installed switches yet? jk But, I would like to see it!
    Karpaydm, seize the day and make them get your rover working again!
    The beta tester comment is very true. I have recently been comparing my LR3 to Windows. "It looks great but it only takes a single fault to see the blue screen of death."
  • reichowjrreichowjr Member Posts: 86
    I have owned an HSE since 12/10 with 2000 miles and have been very pleased with the product for the most part.
    I do have some hesitation when accelerating from a stop. I have to press the accelerator very lightly to prevent a sudden jump off the line. I believe this is just a software issue.
    My brakes occasionally squeaked sounding like a school bus coming to a stop for the first 1000 miles. It seemed to go away after each time I washed the vehicle and then gradually return. I longer have squeaky brakes. The problem seems to have resolved itself.
    My brother owns an XC 90 that took a year to get it to run properly. Most of his issues with the trans and poor fuel mileage were all software related. I'm confident Ford I mean Land Rover will get this resolved.
  • michaelwillemsmichaelwillems Member Posts: 151
    This is oft reported; I suspect we all find this (I certainly do). "The thunk". Yes, you can baby it, but yes, it would be nice to see this improved.
    I was thinking that too! :-)
    When my suspension failed it was useful in one sense: I could finally explain to my wife and children why you need shock absorbers. Failed suspension actually means failed shock absorbers.
  • xiaodongxiaodong Member Posts: 39
    LR puts air AND coil suspensions for new range sport and range rover. I wonder why.
  • teldocteldoc Member Posts: 49
    If this is your first car with electronic throttle (drive-by-wire) instead of cable actuated throttle, it takes some getting used to. I had the same issue with a Sienna until I learned the power curve.
  • gw123gw123 Member Posts: 64
    For what it's worth, I filed a complaint with the National Highway Traffic Safety board on the stalling issue. My dealer stated it wasn't a safety issue as the vehicle could still be steered and stopped.
    Perhaps he hasn't tried steeing this 6000lb truck when there is no power. I do see this as a safety issue.
    If you wish to file something with this agency, go to http://www-odi.nhtsa.dot.gov/ivoq/.
    I do hope they find the cause quickly and can fix this. My LR3 has been in the shop for 8 days and counting since we picked it up 1 month ago.
  • katzatkatzat Member Posts: 45
    Tidester, or whoever does this stuff:
    The Toyota Sequoia forum is organized very well. That forum used to be as active as this one from '01 when the truck was released until probably last year when most of the initial problems were worked out and the novelty of the vehicle has subsided some. Prior to buying my Sequoia in '04 I used that forum a lot. Some of the following strings were quite fun and useful to prospective buyers and owners:
    >General Discussion.
    >Owners Problems and Solutions.
    >Prices Paid and Buying Experience.
    It also had a couple of vehicle comparison forums, but this doesn't seem appropriate to this vehicle ;)
    Thanks to all that have contributed to this forum. I became enamored with the LR3 when I first saw it, but the discussions here have convinced me that I don't need a new truck until the LR3 gets all of its systems properly integrated and the initial quality issues resolved. That said, if I wrecked my second vehicle tomorrow (or it breaks to such a degree that I refuse to repair it), I would swallow hard and buy an LR3. Of course, I would probably have to wait 6 months for delivery.
    Regards and Thanks.
  • whaleyawhaleya Member Posts: 28
    How strong is the roof of the LR3?
    I ask because the US standard on roof strength is too low (as evidenced by rollover crushing of car roofs) and I just saw that a lawsuit with the Explorer, Ford knew the Explorer's roof would crush in a rollover, but ignored the internal engineering advice to reinforce the roof.
    ...anyways this same company has a boron steel roof on the Volvo and markets it as a strong roof. After looking at video Ford released on the XC90 rolling in a test, I agree with them.
    Where does the LR3 stand? Does anyone know of published roll tests, or photos of a LR3 that has rolled? Is the roof strong like the Volvo or will it go flat like an Explorer?
    I'm not trying to stir the pot on the whole tire/Explorer issue, just focusing on IF the LR3 rolls (for whatever reason) will I end up a few inches shorter?
    I am not sure what alloy is used for the roof pillars, but I was offered some crash info. The plate of glass on the roof is obviously tempered which means that it can take a brutal direct hit. Tempered glass only breaks easily if it is hit directly from the side or if it experiences a rapid thermal transition.
    The metals used in the front of the truck are softer in the front and the alloy becomes increasingly stronger as you near the passenger compartment. If you look under the hood you will see some horizontal lines in the metal on the sides, those are the the crumple zones. There is also extra reinforcement in the back and on the sides.
    Thanks, Katz! We may be reaching a critical mass here to warrant a Prices Paid and Problems and Solutions section. I'll pass it on.
  • grommetgrommet Member Posts: 445
    I don't think the LR3 has been crashed/rolled by any US agency. I hope not to roll off a cliff anytime soon... but if I do, I'll be sure to post pictures if I survive. ;)
    The initial Land Rover marketing says:
    "The LR3/Discovery 3's body is manufactured like a conventional monocoque. Two monosides are welded to the floor, roof and bulkheads, creating a strong, single structure. Significant use is made of high-strength steels, while enormously strong boron steel is used for the A- and B-pillars, for added strength in front and side impacts.
    The roof structure can accommodate both sunroof and alpine roof. The sunroof is a conventional cassette-type design that opens rearwards, outside the vehicle. The alpine roof is a large, full width glass roof bonded into the metal structure, above the second and third-row seats. To preserve strength, it is braced by cross members, invisible from the outside. When neither sunroof nor alpine roof is fitted, the outer roof panel is a single large steel pressing with styled swages to add strength and prevent booming."
    ... I'll be sure to post pictures ...
    Can we set up a grommet-cam? ;-)
  • yogidocyogidoc Member Posts: 16
    does anyone know if a lock can be installed on glove compartment as an after market job??
    finally got my LR3 back with new air bag installed on passenger side; let's hope it does the trick......i have to get off this site soon;
    i feel if i keep up w/ the posts i'll be next for a suspension / stalling problem..........to be continued
  • evo8 driverevo8 driver Member Posts: 1
    Curious, did the Toyota have a lot of similar problems? I bought an Evo 8 when they first came out. Supposedly a LOT of problems with that car and Mitsubishi builds junk, but I have not have a single problem with mine after 40k miles. So, I was on the verge of buying an LR3 thi month but now I am VERY nervous. Even a first model year car should not have these severe problems.. isn't that what they iron out in the 4 million miles of testing they did during development?? I am very nervious. Opinions guys... a fully loaded 2004SE7 Disco for $30K or new LR3 SE7 seats ?? Sounds like the LR3 is no less problematic than the Disco.
    The Sequoia had problems that were not so mysterious as the ones posted here for the LR3. The truck is not nearly as complicated and still does not offer the features of the LR3. Completely different beast.
    Initially, the common Sequoia problems were mostly related to the front brake rotors (overheated and warped), the rear area AC unit (failed), and front end alignment problems.
    As I recall, Toyota issued TSBs on the front rotors (increased the size), and the AC unit, and had fixed all of the common complaints by model year '03. There was one fellow on that forum that had continued problems, and Toyota bought the truck back.
    As many have stated here previously, many people on the forum are there to solve a problem or to see if their problems are common. I think that a person reading this forum probably knows a lot more about the common vehicle problems and well before the service technicians. On the Sequoia forum, it was common for people to take solutions to the service department and explain to them how to implement them. Frequently, Toyota would issue a TSB on an issue and the service departments would not know it existed. Armed with the specific TSB number, they could get the common problems corrected.
    So far, it appears that LR needs to do some catching up on these problems. Once they fix them for one of you, the rest can take the solution to their respective dealerships and show them where to find the solution.
    In the case of the Sequoia, Toyota seemed to at least acknowledge and find the solutions to the problems a little quicker that LR is. I suspect this will change.
    My Sequoia has run without a problem for just over a year now -- 16,000 miles. It is good for pulling boats and hauling kids and dogs, but it is no LR3. I hope all of you dog the heck out of LR till they get all of the problems solved and the features well integrated. Then perhaps some of us sideliners can join in the fun.
  • lr3tongalr3tonga Member Posts: 7
    Suspension failure with electric air suspension is common. As a LR3 owner there are maybe 25% complaints on this vehicle. It is a great SUV and its a LANDROVER. LR3 actually is a lot better than the 2005 Range rover. Until the range rover sport and 2006 supercharged versions come out. Be happy when you drive it and thank god you have a warranty free scheduled maintenance on the truck.When its runs good u take it for granted but it rides so smooth and acceleration is amazing for a 5500 lb plus truck. We all made great choices no matter what kind of problems this truck may have. just my 2 cents
    LR3 passes all NHTSA standards regardless of stalls. The stalls have to do with the fuel adaptive system learning your driving habits
  • mac24mac24 Member Posts: 3,910
    ......The stalls have to do with the fuel adaptive system learning your driving habits.......
    Is that official, or just an inspired guess?
    LR3 is a way better vehicle than any older discovery. New jaguar 4.4 engine is amazing. This engine is smooth as silk. Id you ever drove a range rover then drove the LR3, its a big diffrence. Range Rover's engine is loud and not as smooth than the Jag 4.4. LR3 won motor trends SUV of the year for a good reason. If you own an LR3 you can tell why
    lr3tonga,
    You work for LR and I understand that you take pride for what LR was trying to achieve with this LR3. I agree that LR3 is way better than many by design and I personally like my HSE very much.
    For all the nice things that come with the car and that were said to come with car, people shelled out money and paid premium. That being said, people do have to have the confidence to go about their everyday life with this vehicle. I bought this vehicle for my wife to drive in winter time. I am not sure if she could handle at all should any of the severe problems happen while she is on the road. Not matter how nice the truck was designed to be, the reality is that misgiving is becoming a daily companion too.
    The problems are evident and serious enough to warrant serious effort. Admit the problems, swallow the pride, send team of engineers to troubled spots and get down to the real bottoms of all these problems, root out the causes on the vehicles that problems had shown and vehicles which are subject to these problems. LR seems to be quite sluggish in answering these problems and this should change.
  • cjdcjd Member Posts: 8
    Has anyone notice the deafening concussion like sound when you are driving (+/- 35 mph) with one or both of the rear windows down?
    There was wind noise with rear windows down but it was not deafening concussion like. Did you hear all the same noise with rear windows open slightly, halfway down and all the way down?
  • rov3rrov3r Member Posts: 7
    LR Corporate says, "We are aware of the stalling issue, it is the result of a cold weather belt failure. This issue has been addressed."
    I am not a mechanic, but I don't get this explanation. Anyone care to explain how that could be?
  • karpaydmkarpaydm Member Posts: 14
    I have news on my LR3 multiple suspension failures. I called late Friday afternoon to see if I was supposed to return my loaner. My service rep said "We found a faulty air suspension sensor on the right side and the part should be here Monday morning, so we will let you know." Now shouldn't they have called me to tell me this without my having to wait all day to call them and find out for myself? My sense is that I have the most problematic LR3 from this dealer, so you would think they would be more active in staying in touch with me. Anyway, since my salesman first said "I am sure my manager might be willing to buy it back at a significant loss to you" I have yet to hear back from him regarding an actual dollar amount - and I have twice now told him to ask and that time is of the essence because I am already in talks with other car companies. That part probably annoys me the most. I could already be driving a new vehicle from another dealer and not be dealing with any of this anymore.
  • finmanfinman Member Posts: 21
    This is very common in all vehicles, in particular those with space beyond the rear seat...esp. SUVs and wagons. All it is is air flow...when one window is open, an equal amount of air that gets in has to also get out. This frequently happens when sunroofs are partially opened or opened too far without a window also being open. The more open windows the easier it is to have a balanced air current (basically). Experiment with how much various windows can be opened to quiet things down. Often opening a front window just a couple inches is enough to balance an open window in the rear.
    Re: "cold weather belt failure"
    My guess is some excutive up in LR Corporate gained too much weight in the winter and his cold weather belt broke.
    Belt failure at low temperatures (colder than -20 oF) is usually catastrophic with the belt shattering so I think it's a stretch to relate it to stalling issues.
    I believe that many cars have passed NHTSA standards and were later subject to a recall.
    So how many stalls does it take before the fuel adaptive system learns that I do not like to stall?
  • johnmajorjohnmajor Member Posts: 94
    Well the sub contractor is GATES who make the "Micro-V Belts" and they are a big Ford supplier!
    Their belts operate in a broad spectrum of temperature ranges so it does seem improbable that this is the likely cause!
    W
    hy would the belts only have a LR problem?
    If this were happening there would be more than a few blown up engines!
    Dont know why LRNA doesnt speak with one consistent voice? Strange way to operate!
    I do have a sugestion for new LR3 owners; when they receive their questionnaire about their LR experience from the LR Marketing Department Executive VP Richard Beattie in charge of LR Marketing Sales & Communications instead of answering their well chosen questions write back with your "well chosen comments" and request answers!
    His address is:
    2625 Townsgate Road, Suite 100, Westlake Village, CA.91362
  • explorerx4explorerx4 Member Posts: 20,965
    ok college boys, how about this one: "cold weather belt" and opposed to "sun belt" :)
    its an inspired guess. This won't be an issue for long
  • outrageousoutrageous Member Posts: 55
    "Belt failure at low temperatures..."
    I have a feeling the "cold weather belt" refers to a northern region of the country, sort of like the "rust belt" or "grain belt".
    Today was the first time I tested the LR3 offroad in the sand on Carolina Beach.
    The transition from drive to neutral dialing in the sand setting and back to drive was seamless.
    I raised the suspension to the high setting and the whole 30 minute experience was quite effortless.
    The sand was not as dry nor as deep as it typically is in the heat of the summer. The suspension was firm enough for a descent offroad ride without being too harsh or jarring.
    The LR3 moved across the sand ruts with command and ease. Following the ruts at 15mph to 20mph tended to toss the vehicle back and forth.
    The bottom line is the vehicle was like a hot knife going through butter. The beach today did not seem like much of a challenge for the vehicle. I will be interested on the performance when the sand is deeper and dryer.
    I think we can safely add that "belt problem" comment from "Land Rover corporate" (whoever that may be) to the existing stack of misinformation and just move on. FYI: There is no service bulletin describing anything like this.
    Karpaydm,
    I have read your comment on getting the dealer to buy back the LR3 a few times, but was not sure if you were serious. If you are serious, I would get firm with the dealership quickly to determine if they wish to work with you to make this thing right. It seems that if you ask them nicely they are just going to lead you on until you own a used vehicle (as opposed to a new lemon).
    If you determine that they are completely unwilling to rectify the situation, you may have to sue. If it goes to a lemon law suit, you may not be in such a good position if you owned the truck too long or used it too much.
    I am curious: If they offered you a replacement, would you take it?
    The lemon law is quite different than bringing back a used toaster that doesn't work. You have quite a bit of time. I suggest letting them replace the sensor and see if that fixes the problem.
  • ypshanypshan Member Posts: 103
    The BMW drive by wire system that I have on my X54.4 doesn't have the problem. The throttle response is instantaneous and everything works perfectly.
    5-year-old technology instead of new on the X5. No excuse for LR to not have it right 5 years later.
    Same here with my AMG H1. Big turbo diesel, full time 4wd, smooth and powerful with a heavy or light foot on the rheostat!
    Here's another detailed post about the rear window concussion noise:
    tidester, "Volvo XC90 SUV" #930, 4 Jan 2003 12:19 am
    As Finman says, it's a common problem with many different vehicles.
    There is a note on the LR tech site about this noise. Just lower a front window an inch.
    Well, I don't know how long he has had the LR3...nor how many miles...but a 'typical' lemon law limit is ~1 year or 18,000 miles. They usually must have attempted the fix (of the same significant problem) 3 times and failed...and/or the vehicle needs to be out of service for 20-30 days. These particulars vary a bit from state to state...but those are general ranges.
    Additionally, the buyback is full payment minus any mileage (usually) at a rate of 10-20 cents per mile...again this can vary.
    I agree, he should be firm and alert them that after their ?3rd attempt at fixing it that he would be getting a lawyer and filing under the lemon law. This usually gets the attention of the regional manager and things may get moving a bit faster. Sometimes the corporation may just offer a 'goodwill' buyback with similar reimbursement as above...or offer a new vehicle at no cost. Or, sometimes they can be real a-holes and fight at every chance they can.
    I had 7,000 miles on a new GX470 that Lexus bought back, plus they reimbursed all sales taxes, registration etc. No deduction for mileage as after all I had to use the car while they tried to fix the problem. Problem was vibration at 60 mph or around 1700 rpm. The GX470 still has same problem. Some have been cured, others are living with it. No lawyer involved, just reasonable communications between me & Lexus. Lexus were above & beyond & were extremely fair & reasonable. I have no doubt LR would be also. No one wants an unhappy customer out there complaining.
  • jessekjessek Member Posts: 2
    HEY, WE ARE ABOUT TO BUY AN LR3 HSE AT THE END OF THIS MONTH. WE HAVE BEEN PATIENTLY WAITING. BUT NOW I'M HAVING SECOND THOUGHTS ABOUT THIS VEHICLE. THE SALES PERSON IS NOT VERY HELPFUL AND HAS CHANGEED THE DELIVERY DATE 3 TIMES. IN FACT, THEY CHANGED OUR SALES PERSON AND FAILED TO TELL US UNTIL WE INQUIRED ON THE DELIVERY DATE. I NEED A DEPENDABLE VEHICLE FOR THE FAMILY. SO FAR, I HAVE NOT BEEN IMPRESSED WITH LAND ROVER'S STAFF. IF YOU HAD TO DO IT OVER AGAIN, WOULD YOU STILL PURCHASE THE LR3? I NEED HELP ON THIS. PLEASE LET ME KNOW YOUR THOUGHTS. THANKS, JESSK
  • bjsbenzbjsbenz Member Posts: 14
    Jessek,
        I now have 1000 miles on my LR3 SE7. I've had Grand Cherokees, Navigators and the LR3 replaced an X5. I'm in the business and I lease and sell every make and model so I've driven everything out there and this is by far the best driving, most comfortable 7 passenger out there. By reading this forum you are reading and hearing about problems people (stalling and suspension posts are from the same 5 or 6 people) are having because this is where people come to "get the word out". Look at any of the other forums on what you're comparing to and you'll see your share of complaints also.
    Most people don't read this forum if they're happy so there are far more satisfied LR3 owners (like me) who just don't come here to shout about it! Get the truck and enjoy!!
    This has been discussed before, but not all (or even most) of the people reporting problems came for that reason. I think most were posting here before they encountered any problems.
  • xchicagoan5xchicagoan5 Member Posts: 46
    No need to SHOUT. I have owned my LR3 since 1st week in December. I have had two minor problems which were all fixed - glove box and leak - easily, no hassles. We came out of a GX470. My wife was skeptical for two reasons: because it was a 1st year vehicle and worse, a Land Rover. We owned a 1st generation Disco and she thought it like driving a tin can. Now, she tells people she likes this car better than the Lexus. I would take the posts into consideration but not put all your decision behind them. There are some Disco II owners who never had a problem and others who sued LRNA successfully and won. At the end of the day, trust you own gut. My dealer has had no issues from the vehicles they've received. I have been pleased with almost 6K. Good luck.
    I am dead serious about getting lid of my LR3. Anyone want it? :) I got the car Dec 23 and it has 1700 miles on it. And for the record, if they offered me a brand new one, I would not take it. Or maybe I would just so the trade-in would be worth more on another vehicle.
    Jessek,
    What you are describing is a supply problem. For some reason Land Rover held back (or had to) on HSEs...they are way behind...
    I ordered my HSE7 at the end of October...and my delivery date has also changed...4 times! From late December (dealer estimate), to January (1st factory estimate), to March, to May, now back to the last week of March (which will likely become April).
    Sure it will have some problems...I've owned 2 Audis in the last 3-4 years and if one reads the Audiworld fora, you'd think Audis were the most unreliable cars ever made...people go to these fora to find answers to their problems...only a few come to extoll the virtues...
    The LR3 is absolutely the closest to perfection SUV out there...handles well for a big vehicle...holds 7 full size adults, incredible versatility regarding storage and seating, true off-road capability, and just the right amount of luxury without looking pimp or ridiculous (like the Infiniti and Hummers). I will tolerate a reasonable amount of problems...as I have with my Audis...and if it has too many...at least the dealer is close and they give loaners! ;)
  • blckislandguyblckislandguy Member Posts: 1,150
    One of the ironies of the teething problems with the new LR3 is that by the time it is all sorted out, there will be a great selection of new LR3s at the right (i.e., invoice plus $200) price.
    Speaking of price, most air suspension systems are problematic and expensive to fix. The pre-03 Range Rover resale values show this. For someone who is waiting out the LR3 launch, buying a used RR at a price that would allow you to quickly scrap the troublesome air bags and convert to conventional springs would be the way to go. I think that the parts and labor is around 4K from aftermarket Rover suppliers (e.g., Rovers East). This should be an easy negotiation starting with "OK, Henry, I'll pay the prevailing (low) price on your used RR, if you let me deduct for the inevitable air bag problem."
    LR3Tonga. Someone said in an earlier post that he/she is a Rover employee. Yes? No?
