Does anyone have issues with fumes?
I park my car outside these days.
I want to add some accessories, specifically the a-frame brush bar and side steps.
I am a fairly mechanically inclined...
Does anyone have experience installing these? I would like to save the extreme LR labor rate of $109 per hour!
Are you sure your dealer will charge you shop rate?
Mine put my winch/brush guard on for a flat $600 and it took one mechanic two days!
If you plan on any offroading, Id skip the sidesteps.
FYI:
Dealers are currently taking orders for 2006 LR3s and "satellite radio" (Sirius) is not an option available, even though it is available for the 2006 Range Rover Sport which shares the exact radio system. Is this planned to be availble in the near future for LR3, or are potential buyers out of luck for MY2006? Will there be a possible "upgrade" that will be dealer installed?
Thank you for contacting the Land Rover Customer Relationship Center.
No, satellite radio is not an option for the 2006 LR3. At this time there is no information if there will be some accessory that allows it to be added later on.
If you have any questions or require additional information, please feel free to contact us at 1-800-637-6837, option 9, or by e-mail.
Sincerely,
Range Rover Will Get Sirius (Inside Line)
I guess it's possible they just didn't want to make any changes to LR3 for 2006. :confuse:
Other than "google" and a few of the listed LR accessory sites, is there a recommended site for great off road LR3/disco products, such as cb radio's/sat phone accessories etc. These would (imho) be of more use than satellite radio.
I don't think I'd have as much patience as you but I certainly wouldn't sign papers until I had vehicle in hand!
Am I missing something here? Is there any chance the 2006's will be adjustable w/o keys in the ignition? We are accustomed to making this adjustment, and are not so spoiled as to require the memory (although seems silly not to have available on a $50k car), but the reach-through and fumbling with the keys from outside the vehicle is likely a non-starter for the money.
Please help if we missed something or a modification is in the works.
The whole thing was a pain in the ---. Before landrover could tow it back to the dealership, had to get the fire dept. to verify that it was not a hazard to tow, which of course due to the leaking gas ...it was!!
Eventually the gas stopped leaking.
It's been in the shop almost 2 weeks. It took them a while to figure it out. When they first started it, it was only running on 2 cylinders and some censors were drenched in gas that must have leaked on them. It turns out the whole gas tank needs to be replaced. They said that a "few" landrovers have been having this problem. Must be since the gas tanks are back-ordered 4-6 weeks.
They also mentioned something about a bad charcoal canister. Can someone tell me what exactly is a charcoal canister??
Oh and get this, since there was a 4-6 week wait on repairs, they wanted me to return the the loaner LR3 and give me a rental suv.
I contacted Customer relations and explained the situation.
The solution they came up with is to poach a gas tank assembly from another LR3 that has about 1000 miles on it. Mine has about 650.
I suspect the reason they are doing this is because they know that I have a planned trip to Canada and then NYC and they don't want me to put the miles on their loaner, plus I'm refusing a rental.
I would appreciate any thoughts on both the gas tank situation and the "poaching solution" :sick:
This "problem" is solved on my LR3 HSE... it powers on the seat controls for a period of time after opening the door. (And since HSE has memory seat/mirrors, it can also move the seat to a keyfob programmed position optionally).
Yes, it's really stupid the seats aren't powered just like the HSE. I complained about this SE missing feature... in additional to having "6-way" instead of "8-way" adjustments. Send feedback to Land Rover.
LR3 says no changes to '06, so I guess not enough people cared...
Of course, that would partially remove one of the 4 boring "exclusive" options the HSE has in North America (8-way memory seat/mirrors, slightly higher-end stereo with rear controls, 19" wheels & optional adaptive headlights.)
Also I just traveled from the Maine coast Vermont...350 miles of state highway up and over both the White and Green Mountains. According to the trip computer I got 19.1 MPG. This was loaded with 4 people and all the STUFF for a 2 week vacation. Not bad.
I installed an after-market wood kit finally and boy does it help dress up that bland interior. Next are seat covers if I can find decent ones.
If I had to do it again, I would not choose the adaptive lights - they are a gimmick. Otherwise, everything is just right although I still don't love this vehicle like I did my Discovery II.
My oil changes are going to get done every 3750 miles even if I have to pay for every other one since the 7500 mile ones are free. But then I don't know if I'll keep this thing long enough to go that far. It's a nice vehicle, but it just does not exite me..maybe I'll go back to the Mercedes G500 ?? Now that's a truck..
However, whether you keep the vehicle long enough to appreciate the benefits is another matter.
Engine Oil - A slippery subject Part 2
Synthetic motor oil
However, on a large truck, boat, or plant where many gallons of oil are involved and bypass filtering is used, then analysis is routine and absolutely cost effective.
On a regular automobile that falls into the 'normal' range in terms of operation and servicing, I'd suggest that the benefits of 3k oil changes versus 7.5k changes won't be apparent until 100k plus, when the engine with more frequent changes will show better oil pressure, better compression, and less overall wear, deposits and possibly sludge than the engine with fewer oil changes............hence my comment on "keeping it long enough" in the earlier post.
please tell us which brand of wood kit you installed, where you got it, how much it cost, how hard it was to install, did you install all the pieces or just some of them, does it have raised edges, was it flat pieces that you bent to fit or formed shapes, etc. Thanks
Also, anyone, how many quarts is the oil change?
05 LR3 HSE7
Alveston Red/Black
Adaptive Lights
Tow Package
Heavy Duty
3rd row Rear Seat Package w/rear Climate Control
Cold Climate Package
:shades:
The LR wood has very thin strips of adhesive to hold it in place - the BDTrims stuff is covered completely on the backside with 3M adhesive, so it'll hold until the car goes to the crusher. It looks great and everyone that has seen it had positive comments. I can take pics if you want and e-mail them to you (don't know how to post them here).
I did not install all 39 pieces as I did not want overkill - just enough wood to add some "class". Veneerz.com has a 61 piece kit that includes several pieces I would like to have, so I may have to buy that kit as well. They include pieces such as door panels for the front and rear, rear console pieces, glove box accents, etc.
An oil & filter change requires 8 quarts of oil (5W-30 API-GF3 recommended). I think I'll go with Castrol 5W-30 in winter, and 10W-40 in summer (dino instead of synthetic).
Good luck to all of you, and happy "Rovering"..
BTW, 8 months on the road (Nov. 04), 6000 miles, no problems at all, love the truck.
Personally I'd do it every four months, but then I change my oil every 3k., so you can probably put me down as anal.
I too don't like the dark factory kit nor the high price. And I would't want to install every piece that comes in those kits, just some bigger ones. I'd live to see a picture or two and you could email them to me directly, but I'd bet there are others on the list that would like to see them too (maybe the host can tell us how to post a picture).
I have some samples from BDTrims, but the samples they sent are about 3/32" thick which is not very thin. They have rounded edges. And they are synthetic, not real wood. But I didn't get a sample of medium walnut, just medium burl, light burl, and walnut burl.
I haven't checked out veneerz.com but directcartrim.com also has a kit with they say the thinest wood veneer, and they say it's real. I don't have any samples yet.
Also, thanks for the info on the oil capacity. I have an ML320 and it takes 8.5 quarts which helps keep it cool but is expensive when you use synthetic.
I realize that I'm probably in the minority here, but I hate driving a vehicle with an automatic transmission... and I'd be more than happy to give up the extra horsepower for a diesel.
I'm in the market for a new SUV and the LR3 offers me everything I'm looking for except a manual tranny and a diesel motor... the V8 petrol motor, I could live with (despite the deplorable mileage) but the auto might be a deal-breaker.
That being said... any ideas as to the possibility of importing a TDV6/Manual 'Disco3' from overseas (should that combination not see our market otherwise), and what would be involved in such an endeavor?
Anyone else out there wishing for a stick?
My LR3 and I went on an extended trip this weekend and I'm happy to report 19.4 mpg !! That's with the A/C on at 70 mph. I fill up until I can see the fuel in the filler neck and calculate with a calculator so I know it's pretty correct. The car's computer had shown 19.6, so I believe it now...I even saw 20.2 mpg on occasion...
and so far NO problems at all with the vehicle (except for that creaking steering wheel).
Oil: I changed the oil & filter on my 1990 Toyota V6 religously every 3000 miles and at 200,000 the engine was completely gunked up with sludge (found out when the oil pressure went to zero and the valves started rattling). So, in my new Toyota I use full synthetic oil - will see what happens when I pull the pan at 100,000 miles to have a look. I do not plan to use synthetic in the LR3 and I'm extending my intervals to 3750 miles.
Again, good luck to all of you..
A couple of weeks ago the red light came on again. I was just getting on the highway to go to work, so I decided to just keep going because the LR dealer was right by my office. The truck's message was "Suspension slowly raising" and it was driving like it was too high. It felt top heavy. All of a sudden my rear tire blew and shredded and the truck dropped really low. I pulled over and had to get towed. Had I gotten the message at start up I would have taking my wife's beetle and left my LR3 home, but I was halfway there.
The dealer told me they think the tire was leaking and got real low and then blew, but I don't know. They were going to charge me about $250 for the tire, but then decided to put it under LR's good will and did it at no charge. That was nice. I really can't say that I believe they are correct, but it's impossible to tell because the tire was all chewed up.
So anyways, if the truck gives you a warning, listen to the truck.
Also, mileage seems to be as bad as advertised..if you go by the average on the fuel computer (which is taking the sum of the lowest re: acceleration and cruising, you'll get odd low figures such as 13.8 mpg etc) I drove from Wurzburg to Amberg (to my autobahn exit approx. 105 miles) and a little less than a quarter tank. This calculates to about 19.04444 mpg which given speeds ranging with the cruise control for about 80 mph and LR3's weight being 5000lbs plus, I believe is quite incredible.
In answer to the guy wishing for a manual and TDi..the only premium brand truck that might offer you that in the near future seems to be BWM with the x5 3.0 with manual standard (it's currently a gasoline inline 6 but a great torquey motor with same spec towing capacity as the 4.8is X5) and the newer Mercedes ML's CDi's which i was perusing the brochure last night. The ML won a comparison test between the X53.0 and Touraeg in "auto bild" this month but i think you might be hard pressed to find a manual tranny in those sadly.
'84 defender's can be had for about 5000 euro though!
Sat in the RR sport yesterday..special one without badges done also in buckingham blue (thought it was my LR3 from the front actually then noticed the sport seats and perforated plastic grill) Since it was unbadged (no RR sport designation) i thought it might have been a new freelander (it looks small, folks) I have to say, I'd find it hard to chose this over the LR3 which is a much better value. The RR sport is small comparatively such as an X5 and with the next gen BMW x5 and Audi Q7 coming soon, i don't know if i'd plunge for this particular one. The same auto bild rated this as the best "driver's premium truck" but really, if you want that, i'd suggest sticking with the Cayenne or a car. The good news for LR3 owners appears to be, if you want to retrofit the supercharger it looks very possible.
Hey Gothope,
Just curious about this deal you got...
How'd you manage it?
...I'm also in the military, but I haven't been privied to any special deals that we get on vehicles. Am I missing something?
Is it related to the fact that you're stationed overseas, or is this something I can work on here in the states?
I'm planning to get a new vehicle in the comming months, so any help you can offer woul dbe greatly appreciated.
thanks,
scott
Thanks so much for the info. I'm going to look into it right now.
Needless to say My first experience with Land Rover is not starting out on good footing. My salesman was not in at the time so no help from that side. Bottom line is I order an LR3 HSE back in Dec. '04 and wait seven months for delivery with little to no information as to when to expect the vehicle. I've had it 5 days and it will now be in the shop for it's second visit/day. Haven't gotten the Land Rover new buyer survey, but will be interesting how I decide to reply based on experience so far.
One other note. Stopped at my house with the loaner LR3 SE tonight and placed transmission in Park and tried to set the parking brake. Guess what doesn't work on the loaner. Got a red flashing parking brake sign and parking brake error message. Turned the car off and back on and still have problem with it. Will try later tonight to see if it will reset itself. Just :sick: or :lemon: Wating to decide!
