13793803823843853236
  • kyfdxkyfdx Moderator Posts: 270,805
    edited January 2012
    Any interest in a coupe?
    $8500
    In NY, and looks good all the way around...
  • qbrozenqbrozen Member Posts: 33,805
    Driver's bolster has typical wear, and the 2 pounds of keys hanging from the ignition could cause trouble down the road.
    But, it looks pretty decent otherwise. Nice color combo, tires look like they have plenty of life. This would do right around $7k at auction, so the price is right, too. My guess is the owner has been offered around $6k on trade.
  • stickguystickguy Member Posts: 54,068
    I like that one. No chance I am getting to the north shore of LI anytime soon though!
    I can live with a coupe.
    Dusting of snow today, my XK barely made it up the driveway! My first RWD car with wide, low Summer tires. I expected poor snow performance (I won't be driving it in real snow), but I was surprised at how bad it was in a dusting, probably < 1/8"!
    Interesting the the two cars on my list to possibly replace the XK in the fall (if I don't decide to snow shoe or all season it) are the "Best of the Best" in the latest Autoweek: Audi A7 and RR Evoque. I like the Evoque, I think I like the four door better than the coupe. Rear view is atrocious (in the coupe, at least, haven't sat in a four door), but overall a nice place to be. Dealer says all the Evoques they have are sold, good for them! A7 is a nice piece of work, gorgeous interior, good room with the hatch. But, $10k more than an A6? Then again, I'm a sucker for a hatch and the A6 styling is a bit of a snoozer, to me.
    So, next real snow, enjoy your nap in the garage, XK. Let's go, 2002 RX300!
    If you want to avoid money pits, just don't buy anything built in the USA, Mexico, or China.
    Then you'll be fine.
  • akanglakangl Member Posts: 3,282
    It looks like the Escort may have blown its headgasket again. I need to take it in and have it looked at, its losing antifreeze somewhere. I hope not but if so then its time to let it go on down the road, I refuse to play this game.
    My son likes the car well enough but now that he's driving it 5 days a week its starting to show signs that things are not as well as they were a year ago with it. So our thinking is if its not the headgasket and we can figure out where the antifreeze is going and fix it, then maybe squeak it by until the end of winter.
    The kid doesn't want to take it with him like originally thought since its turning into a bit of a money pit. If it has blown the headgasket again, then the plan is to fix it and cut it loose. After that buy him a newer car, maybe in the $4k range since with school this semester he needs a car.
    On the bright side, the other 2 members of the stable are behaving wonderfully. My F-150 just turned 13k, lots of driving with our daughter in the hospital since December 16th, no eta on her coming home, possibly another 3-5 weeks.
    I thought he was going into the Navy? Hard to drive to work on a sip!
    I know what you mean about old cars. It isn't just the money, but the sheer hassle of dealing with problem after problem wears you out.
    Just had to do front brakes on my sons TL yesterday. Light was flickering, and not stopping like it should. Needed pads and a bleed (got new fluid as part of that, no extra charge!). So, now it is nice and safe. On top of doing work on the heater last month it cost me some $$, but heat (when you live in the north country) and brakes are kind of important to have!
    But, seems good to go now, he likes it, and it has been (knock wood) a really good car for us. Hard to believe we have had it for over 3 years now (only put about 15K on it in that time though).
    If it makes it 1.5 years until he graduates, that is all I really ask! After that, get a job and on his own to pay for what he wants.
  • tjc78tjc78 Member Posts: 17,357
    If it is the headgasket again, shouldn't the mechanic who did the repair be liable. I remember reading about you having it done, how long ago was it? It sounds to me like something wasn't done properly with the repair.
    Or maybe the head is warped and the gasket just can't get a good seal.
    That crossed my mind too. I would have thought the mechanic would have checked that and had the head milled if needed.
    When my 93 Taurus blew the head gasket (like all Ford 3.8 V6s or the era) the mating surfaces had to be machined.
    Especially common when the block and heads are not made from the same metals. They expand and contract at different rates.
    Jolie, don't jump to conclusions. The coolant loss can be from a number of places other than the head gasket.
    As others have suggested, if it IS the head gasket, the mechanic who did the work should cover the repair given the short time it's been.
    And, yes, he should have checvked the head for warpage and milled if if necessary. Any mechanic knows this.
    Coming from a guy that owns an Audi, that's FUNNY! :P
    Yeah, it is but he seems to have gotten the reliable one. Even Audi can screw up and make a reliable car once in a while.
    Nest thing you know someone will have a reliable Volkswagen!
    They had the head machined when the gasket was replaced. The machine shop said it was a little off but should be ok. My little brother is a mechanic and mentioned the aluminium head and cast iron block is about as bad of combination as you can get. He said one risk of replacing the headgasket is that it will blow again if it can't get a good seal.
    Its been about 900 miles since the repair and there is a 12k warranty thankfully. The kid will need a car when he leaves, but if we can squeak the Escort by until June when he leaves that would be great. He can get another car later after he's moved to his new base and after basic training.
    The car is showing me symptoms I don't like, its running rough, has no power, horrible antifreeze smell when its running. Also, unless someone stole some gas out of it then the gas mileage has gone from 30 mpg down to 17 mpg which is extremely odd, especially since the worst I've seen is 27 mpg out of it. I put a locking gas cap on it yesterday, so we'll see what the next tank brings. It was a good thing I took it and filled it up at the gas station the other day, it was almost out of gas. The gas gauge doesn't work, so its a guessing game. I'll take it in sometime in the next few days and have it looked at.
    Today I'm going to wash my truck, YUCK, the thing looks horrible and I can't stand it anymore. Hard to go from washing it once a week to it hasn't had a bath since September! Good thing there's a car wash where it can still be washed by hand in a heated bay since I refuse to take it through a car wash.
    You might think it's funny, but my bank account doesn't.
    My Audi at over 85K miles has cost FAR LESS to own than a '95 Dodge Neon for 65K miles.
    At this rate, I'll have to drive about 320K miles in my Built in Germany car to reach the sum total of maintenance and repair costs the Neon absorbed.
    Just the facts. Sorry if they don't fit your PRO Bailout bonanza class warfare mindset.
    Including all costs? Purchase, insurance etc? I have a tough time believing a car costing double than what a Neon cost would be cheaper to own.
    edited January 2012
    Well okay, the A3 cost pretty much exactly double the cost of the Neon INITIALLY. So I had to pay higher sales tax, higher registration/license fees, but you have to also take into account 1994 dollars were worth more than 2006 dollars!
    Insurance is probably a dead heat as I was a "young" driver while driving the Neon, and also, the A3 benefits from being labeled a station wagon by insurance companies.
    The gas mileage in the A3 is ever so slightly superior, despite having 70 more horses under the hood, though it does use premium to do so. The A3 weights nearly 1,000 lbs. more too.
    The resale value of the Neon was neglgible at 65K miles, while my A3 is still worth something. 65K miles is pretty much the entire useful lifespan of a Chrysler based on resale values I see.
    I meant the cost to own after you pay for the vehicle. It pretty much comes down to repair costs, since all cars need maintenance.
    "Sorry if they don't fit your PRO Bailout bonanza class warfare mindset."
    Whatever made you think I supported the bailouts? :confuse:
    I am a capitalist. If you can't stay in business, you fail.
    I have also owned german cars in the past.
    Won't do that again. :lemon:
    So the maintenance costs were less, not the overall cost to own. Big difference. A BMW will cost me nothing to maintain for the first 4 years, but will still cost significantly more to own that a Civic.
    Audis are usually fairly reliable until the miles start to pile on.
    I'll take a U.S. built car over an Audi ANY day!
    Also, you are comparing it against one of the worst American cars ever built.
    Weren't most Neons built in Mexico anyway?
    Mexico is America, too....
  • Sandman6472Sandman6472 Member Posts: 7,307
    What does this mean?
    The Sandman :) :sick: :shades:
    Bwa-ha-ha! :D
    Recently I got behind a previous gen A4 with one brake light stuck on at all times. It was driving me crazy. Then a Sonata got behind me, it had one really bright headlight and one normal. I was about to have a seizure.
    That's normal around here. I can usually spot an Audi ahead of me a long ways away. The other lovely thing people around here do is purple or blue or green HID lights or for even more fun, one green and one purple. *GRUMBLE*
    That was probably the rear fog light...
    Nope, I know what those look like (my car has one too)...this was the brake light, entire right cluster was lit up at all times, when the brakes were actually used, the left side matched.
    On the light subject, I will say the weird colored HIDs can be annoying - the old Civic crowd especially seems to like these.
    And another one this morning, this a previous gen A4 cabrio, but with half a light cluster not illuminated. Those VW roots eventually show through (seems half of earlier New Beetles and 99-05 Jettas have a dead light).
  • anonymouspostsanonymousposts Member Posts: 3,802
    I do have to say that, so far (knock on wood), our Tiguan has been reliable. Now, we only have 4,000 miles on it but still .... I'm a big believer that bad cars usually start showing signs very early on. The Tiguan is a hoot to drive and regularly gets 26-27 MPG in our regular driving. That turbo engine is suited well to the Tiguan's small size and 6-speed manual.
  • corvettecorvette Member Posts: 11,626
    "Mexico is America, too...."
    I cringed when I was in Canada and caught myself asking a merchant if they accepted "American money." :mad:
    To further confuse things, technically it's the United Mexican States and I've heard people in Mexico refer to themselves as the United States (and sometimes the United States of Mexico).
    Maybe we should just make it one big AU.
    Audis are basically glorified Volkswagens and electrical problems are common.
    I found that Audi/VW's are usually pretty decent until they age a bit and get miled up. After 100,000 miles they are usually pretty shot.
    Our store wouldn't resell a VW/Audi/Volvo unless it was exceptional and had very low miles. We just got burned too many times.
    Used Land Rovers, we would wholesale as soon as they came in.
    It says Estados Unidos Mexicanos right on the money.
    The globalists would just love a union like that, a standard to race down to.
    Parts supply for older Audis can be tough too. First gen A8s and pre-98 A6s are getting thin on the ground already, survival rates have to be much lower than their competition. I won't even get into Rovers, too easy.
    The seller came down on the crazy price, and I'm now an E39 owner. The V8 pulls like a freight train!
    I'm putting together a parts order and don't know what to do about the cooling system (86,000 miles on the clock). The radiator looks new, the expansion tank is old, and I don't know about the rest. Replace everything? Convert to an electric fan while I'm at it? Or wait and keep an eye on it?
    I would change out *all* the fluids just to establish a baseline.
    I bought an 8 year old car, the seller even showed me receipts for recent dealer service, but when I changed all the fluids, both the brake fluid in the clutch system and the rear diff fluid were bad.
    Good idea, I'm probably going to order a vacuum pump to do oil changes. I plan to get a mechanic to do the brake, tranny, and diff fluid. The pollen and air filters looked clean, and I'm going to wait on the coolant until I decide which parts I'm going to replace.
    I bought new wiper blades and a headlight restoration kit at Autozone this morning, and will be doing that and other general clean-up this weekend. I will post pics once I get the car cleaned, it's filthy from being on a car carrier!
    You sound enthusiastic, make sure you get before/after pics! Good luck!
    Congrats - equipment details?
    - Ray
    2022 X3 M40i
  • ab348ab348 Member Posts: 20,598
    Uh, what's wrong with that?
    The Canadian dollar is a separate currency from the American dollar and is valued independently. "American money" is what the US dollar is called by us up here.
    Greenish silver metallic paint, sport package, heated seats, and park distance control. Has Pirelli P Zero Nero all season tires that are about half worn. Black leather interior with black headliner and wood trim. Homelink, but it didn't work when I programmed it with my garage door remote.
    According to the Carfax, it was dealer maintained up until a couple of years ago. I found a repair ticket for an SRS light, DSC light, and window regulator in the glovebox--about $1,800 two years ago.
    I managed to run the battery down last night beginning the cleanup process and trying to program the Homelink, etc., then had to get my dad to bring his Battery Tender because my jumper cables weren't long enough to go from the Altima to the jump point under the BMW's hood. It started up fine this morning after charging overnight.
    I thought a Canadian might think it was un-PC... After I said that to the merchant, I realized that it made it sound like the US was the only country in America.
    Sounds really nice - 5 speed step?
    - Ray
    LOVE my heated seats - even here in HotLanta...
    2022 X3 M40i
    edited January 2012
    Sounds like a nice car!
    A BMW that had warning lights come on ??
    Say it isn't so!
    Wiki probably Americanized the translation.
    This thread is getting a bit looney. :P
    I would have stayed away from audi in the 20th Century as well. Post 2000 Audi has shown improvements each and every year in quality and reliability.
    Times have changed. I know this is what Big 3 supporters say, but Audi did not require a bankruptcy bailout in 2008.
    I've read a few different stories/press releases on the WORST 10 or 20 American cars ever built, and for some reason, the Neon doesn't even make the list. Several news organizations have made their own "worst" lists, but the Neon seems to evade them. Seems a lot of US built cars are crap to me.
    It means if you support bailouts of failed companies, then you support class warfare, because that's the bailouts were. They are a declaration of war against the lower and middle classes.
