VW’s 2.0T is still an excellent engine. At no time did I wish the car had more power. Most of my driving today was at around 5/10ths, and I didn’t feel the need to put the DSG in sport mode or use the paddle shifters. If you’ve never driven VW’s DSG, there is a slight shudder when starting off from a dead stop as the clutch engages. This doesn’t bother me, but it’s different than most cars, and I can see how it would annoy some people. The transmission does upshift fairly early, but the 2.0T has so much torque, it never lugs and it never feels like the car doesn’t want to accelerate. I might use the sport mode if I were driving more aggressively.
The steering is less communicative than the E39 (my E39 was a 540i and therefore had recirculating ball steering, making it less communicative than six cylinder E39s). That said, it’s ideally weighted. There isn’t what I would call torque steer in the conventional sense of the car pulling at the wheel, but if you hammer the throttle, the steering becomes far less precise. I’m sure an aftermarket turbo upgrade to increase the car’s power would make this issue worse. New for 2013 is a button in the center console to disable the stability control. This button is mounted just to the right of the keyless ignition start/stop button. I think this is an ergonomic flaw and would prefer that the start/stop button be mounted closer to its traditional location on the dashboard or in the steering column.
The GTI and uplevel GLI models both come equipped with 18” Dunlop SP Sport 01 A/S tires. These appear to have the same tread pattern as the summer SP Sport 01 tires, with some additional siping to improve snow traction. Tire Rack’s reviews of the all-season tire are not positive, and I particularly don’t look forward to driving in the snow with them. Dry traction is good. I have not yet driven the car in the rain. VW uses the ABS sensors to monitor tire pressure, and there is a reset button in the glove compartment. I assume this system is less precise than using wheel-mounted sensors, but should reduce servicing costs for those who switch between winter and summer tires, as well as the fact that there are no battery powered sensors in the wheels which will eventually have to be replaced. The car rides very solidly. It isn’t as firm as my E39 with its sport suspension, but it’s not soft, either. It doesn’t feeal nearly as heavy as the E39—probably because it isn’t. The bi-xenon headlamps and cornering lamps are excellent.
The interior is very well laid out and the GLI features a soft-touch dashboard. As some reviews have noted, the tops of the door panels are not soft touch. More annoyingly, neither the glove compartment nor the pockets in the doors are lined with felt or rubber to prevent the items inside them from rattling around. (My 1999 Jetta had a felt-lined glove compartment and removable rubber mats in the door panels.) The seats are comfortable and both front seats are heated and feature adjustable lumbar support. They are upholstered in black fake leather with red stitching, and the GLI has a black headliner. VW’s fake leather isn’t as nice as BMW’s. The automatic dual-zone climate control has a feature which will synchronize the temperature of both driver and passenger zones if you wish. When driving alone, this saves you the trouble of adjusting both zones. Bluetooth works well, but the navigation and infotainment system isn’t as sophisticated as the one in the 2013 Altima. Honda’s system in the 2013 Accord blows both Nissan and VW out of the water. The VW navigation system has a small screen and lacks traffic support, but it does display driving directions in the instrument cluster. There is no Pandora integration. A three month SiriusXM subscription is complimentary. Many of the stations sound the same and I am amazed that people will pay around $20 a month for this and then pay an extra fee to be able to listen online—I get far more value out of spending $8 a month for Netflix or $36 per year to remove the ads from Pandora. I will only renew the SiriusXM subscription if I’m offered a substantial discount. Models with navigation have a backup camera, but no parking sensors, blind spot warning, or lane departure warning. Nav models also get a passive entry system and keyless ignition. The trunk is cavernous and there is a full-size spare on a 16” steel wheel inside.
The car is relatively quiet, but suffers from some wind noise. Also, VW installs a “soundaktor” to increase the sound of the engine in the GTI and GLI. It’s an electronic speaker located under the hood next to the firewall. It makes an impressive growl at high RPM, but it also appears to activate at low RPM under load—e.g., when going uphill at 1600 RPM. I plan to disconnect this device and see how the engine sounds without this “enhancement.”
It isn’t perfect, but overall, the GLI is a very enjoyable car to drive. Several years ago, I leased an Audi A4 2.0T Quattro. That remains one of my favorite cars, and there is a lot of that DNA in the GLI. As I have previously posted here, I test drove loaded versions of the 2013 Accord and Altima. I also drove a 2013 GTI before requesting that the dealer locate a GLI for me. The GTI offers a firmer suspension and real leather seats, but lacks the automatic climate control and backup camera of the GLI. Moreover, the GTI costs about $2,400 more. I was particularly impressed with the sales process in that the dealership’s first offer was not that bad, as well as the fact that the sales personnel were very businesslike and didn’t really engage in a lot of idle chatter (“what do you do for a living,” “what don’t you like about your current vehicle,” etc.)
That pretty much sums up my thoughts so far. I’d be glad to entertain any questions.
Long story at least somewhat shortened...
Late last week my daughter blew up the engine on the famous 00 Accord. I figured with looking at a junk engine (though with 63K on it) still broke $4K on a car with 271K on the clock. I start hunting landing a couple of nice candidates. The one I really liked out of those was an 04 Mazda 6 wagon with a stick and reasonably nicely loaded with a cloth interior. Gray/gray. Dealer was an hour away.
Well, one look at the picture and she saw wagon and that was a no. Meanwhile, took the other daughter's car over to the same mechanic who still had the Accord and next thing I know I OK the repair. I have it back now and they did a nice job. My daughter really loves the car and I've put her on a payment plan for the repair so she's happy. The stalk to the highbeams needs to be replaced but otherwise the car chugs on. If she gets another two years out of it it was worth it. So that takes care of that.
Unfortunately that Mazda stuck in my head. I asked a buddy in the business about it and he said they wanted too much money. Figuring I have nothing to lose I E-mailed the dealer. Well, actually I had E-mailed him back when I thought I might be putting my daughter in it. Made an offer based on what my buddy said they were they were going for at auction, allowing for the fact that he'd put some money in it and allow him profit. Well, I wake up the morning that I I ended up OKing the Accord repair and the dealer has sent me a "come on over - we can probably make a deal" E-mail. I figure I'm not going that far to dicker and went to the mechanic. I get back home and the dealer had sent another E-mail accepting my offer (I hadn't answered the first E-mail and thought I was off the hook.)
Well, that started pulling at me. I fought it for days but the lure had been set. I bought it today. Gives us 5 cars for 4 people but that is likely only temporary. But maybe not...
I love this thing. I've been in automatic purgatory for a long time. It only has 77K on it and runs like a top. I had lined up a mechanic who checked it out and the only thing he found it needed was a rear wiper blade.
So now I'm poking through the owner's manual because some of the things like the stereo and the clock are not as intuitive as the Honda or Toyota but when you read it it's actually quite logical.
Sorry for the ramble but it's late and I'm fading. Further reports coming. I had my two younger daughters in for the test drive and one of them rode back with me in the 6 while the other opted to go home with my wife.
V6, right? either engine is fine in those, but the 6 is certainly more fun.
I will probably be bummed out to find out what it cost. At least you could have overpaid to make me not feel like I missed out on something!
In a couple of more weeks, I might even have to put gas in it, for the 2nd time since I bought it in December.
Still would move into something more "comfortable" at some point if it comes along, but i can be patient. Plus, I hope to wait out the kid graduating college in may in the hopes he gets a job, so I can free up the TL too!
Back in '04 I almost bought a Mazda6 V6 manual - went for the TSX instead, but have always been fond of the 6.
Yeah, it's a shame that the new 6 wagon isn't coming to our shores. The pool of cars that I want keeps shrinking! (Not that I need it to expand!)
I suspect VW tuned the exhaust and intake to be quieter than they normally would have, knowing that they would install this device to create artificial engine noise. With it disconnected, the level of engine noise would be acceptable even in a Lexus.
Ford Focus (auto) - I'm not so sure what all the fuss is about with the 6-speed auto. It seemed fine to me. Nevertheless, I just couldn't get into it - roadburner summed it up pretty well with saying that the car doesn't have much personality. The rear seat room seems skimpy compared to the competition, and I like the interior overall in the Hyundai much better.
Impreza - surprisingly nice with probably the best rear seat room of the hatch's I've looked at. The 36 MPG (highway) is impressive considering the AWD and a decent amount of pep. I drove it right after the Focus, and the Subaru did seem more engaging. The CVT would take some getting used to, but I suppose that's why it nets the high MPG. Still not a big fan of the exterior styling, but it could grow on me. I'd like the sport model without the roof rails (maybe they're removable).
So at least I crossed the Focus off my list, but the "long-shot" Impreza moved up, so I still have a few hatch's in consideration.
All in all, I'm not in all that much of a hurry, considering the E39 I'd give up, while somewhat redundant with the 335xi I just added, is still more engaging as a second car than any of these cars.
In Canada the GTi tops out at $40k for fully loaded 5 door with DSG and Nav. Even though it's pricey I think it's one of the (if not the) best hatchbacks/sports compacts you can get on the market right now. Even compared to an Audi A3, the GTi just seems like a much better and nicer car.
Enjoy the car!
Congratulations on the 6/stick/wagon -- quite a find.
I believe that's a V6 -- a friend was interested in these and said there's a nasty problem with the PCV system; something about a valve clogging up, or the oil pick-up clogging, and in the medium term, bye-bye engine.
It sounded like one of those things were forewarned is forearmed, so you may wish to check one of the fan sites and see whether there's anything to it. I really like those as well. What keeps me from Mazda up here in MI is their tendency to rust -- aside from the fact that, like Nissans, they are fairly thin on the ground.
One of these days I'll get my Outback, but I'm really not sold on the need for AWD.
Good luck with the Six. FWD wagon FTW!
Cheers -Mathias
My wife, who has a dislike for Subarus, actually likes it. What she really likes is the tangerine orange XV Crosstrek
You and me both!
http://albany.craigslist.org/cto/3615658225.html
First gen hybrid from VW would be a great candidate for a lease, no?
Reminds me, need to check with him to see what ever happened with that. I know I can't afford it!
Count me as punched...
T I A guys!
The Sandman
The Sandman
Very nice!
Gonna share the details?
Model?
The Sandman
P.S. Got my new smart phone last night as the guy had gone to another store to get me this phone. It's an android, a HTC ONE VX...a very nice easy unit. I've been playing wth it all day and love it. Almost got the iPhone 4s but decided I wanted the newer tech and the phone cost me 1 cent...the iPhone 5 was mucho dinero. The Windows phone that my wife has, a Samsung Focus, is o k but I don't like the tiles Windows uses, was very confusing for me. I'm having an easier time with the android system. A treat for myself for going back to work after so long!
(better than a bike too. :shades: )
This car has P2 (keyless go, adaptive lights, auto close trunk, etc), pano, parktronic, lane tracking, power outlet, tiny spoiler. The last few things I didn't really want, but I am picky about color (I wanted white or "diamond silver", which is kind of a bluish silver) and pano - had to take what was available.
MSRP 63K. 3500 down, 24 months, ~560/month. There's an E facelift coming for 2014, so they are blowing them out. I also got Edmunds TMV for my trade (took a little work), so I'll be getting a nice check.
It's kind of a wasteful splurge, but I just had the itch. I also was thinking it was time to cut the cord on the old car - the longer I have it, the harder it will be for me to sell. I'm feeling OK, at least until the first payment :shades:
Barrier, I'd guess?
The bike thing is funny - I will be getting a check that would buy me a nice bike. But I doubt I will now. The traffic is just scaring me too much, and now I will have an expense to distract me.
Oh yeah, my first new car, too. Not a bad way to start, I guess :shades:
Yep. Barrier. They are close to me, and the salespeople have always been nice when I have been kicking tires in the past. I suspect the old car will sell to one of them or a tech - another guy there says he is going to try to buy it.
Drove it about 100 miles today with the soundaktor disconnected. I couldn't detect any clatter, but I had the windows up the whole time. The engine was eerily silent, though! :P
I do have concerns about carbon/gunk buildup on the valves of DI engines. It seems like the recommended preventative measures (use of specific oils and top-tier fuels) are crapshoots. I'm not aware of any evidence that they prevent valve deposits in DI engines.
I'm seeing ~30 MPG on the trip computer in the GLI.
I also like the diesel noise and sensation, and the car is beautifully finished and fairly pretty. Maybe I will buy it at lease end.
Very nice! Congrats!
You'll most likely be able to see that D350 for more than the residual value when your lease is up. Diesels hold their value extremely well.
My first Barrier experience, hope it goes well. The benefits seem good - car washes, checkups, nice facility, etc. A couple salesman there have said I should work there - as I know the cars pretty well, but I don't know if I could do it.
Also a lot smoother and relaxed ride, being on 17" wheels with normal tires. The E55 was a rough rider.
I forget what residual they gave it, but it was high, hence the cheapish lease. It'll be pretty mint when the lease is up, will have to see what happens then.
I had planned to buy some accessories for the car that day (rubber floormats etc) from them, but I was left a bit soured by my encounter with the service folks so I decided against it.
I've had fintail, W126, C43, E55, and now this. Fintail is a sentimental piece, I loved the W126 as it was such a beautiful classy machine, C43 was cool but I didn't "bond" with it, was very comfortable in the E55 but I think my emotion will fade, and now the Bluetec.
