Visitor Agreement.
I'd love to see the C250 come over but sounds like it won't be here by the time my lease is up.
The Run Flat Tire Technology has come A LONG WAY. My Mom had an '08 E90 328xi that she constanly complained about the car's harsh ride.
they are 18" though, and right now prices are nuts to replace, so I hope they can push near 50K, but I have had terrible luck lately with OEM Michelins (barely 30K on the Odyssey).
In a few years there may be more choices to pick from too. thankfully we really don't put many miles on (should stay pretty close to the 10k/year, depending on the next college location, and if we do move in another year).
I don't look forward to the cost of replacing the tires on our 3's with the staggered set up. Hopefully they last for a little while (and don't hit all at once!).
You're worrying us.
So so true.
Am I the akangl of the lower 48?
The FB25 is nice - timing chain, separate coolant flow to the heads, and easy access oil filter at the top of the engine. Could use DI to make a bit more power, though.
32mpg highway for the AWD model will be best in class.
I wasn't a huge fan of the CVT in the Impreza when I had one as a rental.
That said, I'd give up a couple MPG to do my own shifting... wonder if the 6th gear on the new-generation Subies has alleviated the screaming highway RPMs of the previous NA Outbacks?
Could be a tossup between Outback and Forester if I am forced to go Subaru to get the 3rd pedal...
The turbo CVT can also simulate 6 or 8 steps, which may feel more natural to someone who doesn't like CVTs.
6MT:
1st 3.454, 2nd 1.888, 3rd 1.296, 4th 0.972, 5th 0.780, 6th 0.695. R 3.686, Final 4.444:1
Looks like 3rd-6th are all overdrives, but the final drive ratio is pretty short.
The CVT has a HUUUGE spread, 3.581-0.570, R 3.667. Tall Final drive at 3.70:1
"60 MPH, 6th, 2100 RPM. 36.0-37.2 MPG. Still very effecient, even at a moderate speed, this is the speed I typically drive at(all highways here are 55-70 limit) and I routinely get 550-600 miles per tank(33-36 average)."
there you go.
cheers -mathias
It would be useful to compare to the OB's CVT ratios, which are:
CVT in manual mode: 1st gear 3.581, 2nd 2.262, 3rd 1.658, 4th 1,208, 5th 0.885, 6th 0.618. final 3.90
CVT in automatic D mode continuously varies between 3.581-0.618
So the Forester has a taller final drive, and a taller lowest ratio on the CVT. It can probably get away with that since it's lighter than the Outback.
You lose some aero, but not much. No wonder the Forester is rated higher in MPG.
That said, I certainly wouldn't mind an extra gear (assuming lower overall ratio) for highway cruising in both of them if it meant better fuel economy.
At least Subaru offers a stick!
The screaming RPMs were when I test drove a 2006 Outback, and 70mph was clearly above 3000rpm, seemingly rather undignified for a car of its size and class.
Also test drove a 2007 Forester, which was definitely more relaxed... didn't get on the interstate with it, but did get to 60mph at roughly 2300-2400 rpm, so it would be more like 2700-2800 at 70.
The WRX that I tested around the same time was similar to the Forester. I could about kick myself for not getting that car... we know my insurance man would have been happy!
In a perfect world, the 6-speed would have similar gearing for 5th, with a taller 6th for better cruising. And that's what I was most curious about.
The CVTs do have very tall top ratios, but if I am stuck not shifting my own, I think my next vehicle would probably be a Honda CR-V.
Drove a 2013 Jeep Grand Cherokee to Orlando yesterday...interesting vehicle. Started out slow but once that power rush hits, man...you're flying down the pike! Would never own one but it was fun for a few hours. Off tomorrow at this point and have an appointment to get the Civic's headliner replaced at my house next Wednesday, so I'll take the day off. Will probably have the brakes replaced that day also if they need it and a oil change, rotation and re-balance of the tires. Since I'm not home everyday, got to plan multiple things all together now. But after staying home for almost 2.5 years, it's nice to be out again and driving a different car every day!
The Sandman
I am really loving the low end torque of the 2.0T in the Jetta. It can accelerate at a good clip while keeping the RPMs low, and the engine feels much livelier than the one in the Altima.
I would, begging your pardon, and I just leased one... this is the second time you had a Cruze & hated it.... given your back problems, I wouldn't expect any particular love, but I disagree with your assessment of the car.
Which begs the question, since both of us have an interest in cars and some experience, what's going on? I have only driven the 1.4 T; my own car and an Eco on a test drive. Both were manual 6 speeds, and the clutch and transmission is half the reason I really like the car. The other half is the engine plus the quiet and composed ride... power isn't huge, but certainly better than just adequate.
What I'm not too happy about is the very cocooned and enclosed feeling; stepping into my Vibe, I'm struck by a sense of airiness and headroom... and also by a sense of how loud, rude, and crude the Vibe is in comparison.
Getting into and out of the Cruze is a bit harder, too. Not exactly sports-car like, but even my wife -- 5'2 and skinny -- finds it hard to climb out of the seat.
Maybe the LS with the 1.8 NA engine + automatic is a lot different, but I wouldn't know. In all seriousness, the car that most closely resembles my Cruze is a 2nd-generation A4 turbo stick I drove a decade ago; cloth seats, similar in feeling, solid and heavy and quiet and fast enough.
I had a rental Focus last year and didn't think much about it one way or the other. Go figure.
Cheers -Mathias
It had plenty of room for luggage in the trunk but my back-seat guests complained about the low position of the back seat and it was just plain hard and uncomfortable. :sick:
Maybe the new restyled Impala will have better improvements.
Will try something different next time.
Mark156
-Mathias
While in Hawaii, we rented a Buick Enclave.... very large, hard to see around the edges but a nice back-up camera. The second row had buckets which I didn't like as the third row area was piled with luggage. If we had a fifth person, we would have had to put them on the roof I guess. LOL!
It drove well and had the same controls as the Impala (air/radio, etc.).
Mark156
Can I have a link please? I have that engine in my 2012 LaCrosse and I can't feel/hear any harshess. It's not quite as refined as a Toyota 2GR, but you can rev it to 6500 and you barely can tell its working.
This was a Ward's 10 best engine a few years back.
Hemi or Pentastar V6? I'm guessing V6 since you said it started out slow...
Sometimes very harsh - I had a Ford Taurus rental with 7k miles, smoked in, and that was perhaps the most miserable car I've ever had to drive.
Thankfully I have a 3rd car, so I drove it from the body shop to home with the windows wide open, and back the day I returned it, that was it.
They could not have given me that car for free.
I thought I had read that somewhere about the Acadia, but can't find the review anymore, so I retract my statement.
I wonder if in the Impala the air intake/exhaust setup is significantly different from the other (newer) platforms that would change the character of the engine.
Mark156
Edited to add: Aha! Baruth says the GM 3.6 liter V6 "feels somewhat coarse" in the CTS.
http://southjersey.craigslist.org/cto/3627471441.html
"the bad..abs light comes on and off"
Add to that, the non-OEM wheels/tires (which look like they came off a Mustang) and lowered suspension. Also, I read the ad three times and don't see where the seller listed the mileage. And another thing: Not enough pics.
