146474951523236
  • kyfdxkyfdx Moderator Posts: 270,062
    Black steel wheels with no wheel covers... Sort of the anti-BLING look?
    Is it supposed to be cool, or is it just a budget thing? I see it a lot..
    regards,
    kyfdx
    (trying to stay hip)
  • akanglakangl Member Posts: 3,282
    I go for the alloy wheel look. The car right now only has 3 steel wheels with Blizzaks and a donut on it. The 4th one was mangled by the tree. The 17s I'm getting are off of another wrecked 97 Sebring which is also donating its quarter panel, suspension, driver's side mirror, and rear bumper cover.
    I should go take a picture of the car's bad side.......it really isn't that bad, but does explain the cheap price. It took a wild ride off the road about 2 1/2 years ago, then sat at a storage place until I got it last weekend. Amazing thing was I put the battery cable back on and the car started right up, I was stunned, ran great too.
  • woodywwwoodyww Member Posts: 1,806
    I drove a rental Taurus in 1996 thru really bad snow late at night from Madison, WI to near Dubuque, IA, at Christmas time. Then, back to Madison a few days later in moderate snow. I was amazed at the snow handling, & I'm pretty sure it didn't have snow tires. Seemed very secure, & I'm not always a huge fan of American cars. I felt like I could drive it cross-country in Winter, no problem.
    FWIW, my ex bought a 2 y.o. 1995 Volvo 850, ran up way over 100K on it, & not a lot went wrong, until it needed a $1200 A/C repair at 130K or so.....another very secure-seeming car..... but I know taurus(es) (Tauri?) are way cheaper than Volvos.....
    *As for bang-for-the-buck, nothing beats a 2000+ Taurus in decent shape.*
    A couple of weeks ago I got really into fantasizing about buying a new Tacoma P/U. I'd probably dig one, for awhile, for what it is. But what you're saying would lead me to buy a 4Runner, or MDX instead (if I owned my own Sunoco station).
    *Also, I think that pickups--especially regular cabs--are more prone to roof crush than SUVs in a rollover*
  • corvettecorvette Member Posts: 11,581
    It's just a wacky theory I have. I think you'd be safer in an extended or crew cab (more pillars and roof area) than a regular cab. And, if it has stability control, your chances of rolling it are greatly reduced (true for any vehicle).
  • steine13steine13 Member Posts: 2,825
    Ok now I feel compelled to chime in here... I don't agree with the "roof area" argument at all.
    It is not "pressure" (force/area) that will crush the roof down in a rollover accident, it is force itself. And the force is given by the weight of the car.
    IF the pillars are the same size, I'd want them close together right around me in order to hold the roof up. Any force in any one place will be better transmitted to the four other pillars, not just the nearest one.
    I strongly suspect that roofs are built to hold the weight of the car + some safety margin, and that a reg cab is just as safe or unsafe as the rest of 'em.
    But it is simplistic to make arguments based on size or area or number of pillars. Probably more engineering goes into cars than into anything else on this planet.
    -Mathias
  • andre1969andre1969 Member Posts: 26,113
    is that an SUV is going to have a higher center of gravity than its pickup truck counterpart, so it's going to be easier to flip in the first place.
    Usually, the B-pillar on a vehicle is pretty strong, so when a vehicle rolls over, most of the crushing is at the A-pillar. The B-pillar often acts kind of like a pivot point on a see-saw, where everything behind it stays up in the air when the car is upside-down, as the engine is going to weight the front of the vehicle down.
    I'd imagine that if you take a picture of a vehicle and draw an imaginary line from the front of the hood to the B-pillar, that would give you a rough idea of how much the roof ahead of the B-pillar would crush down.
    And even if the rollover is rough enough to crush the B-pillar, the C-pillar almost never gives. So you could draw another imaginary line from the front of the hood to the C-pillar, to see how much the roof might crush down in a more severe accident.
    I do remember hearing a lot of flak, not too long ago, about how pickups and SUVs don't do too well in rollover accidents, and that they're not subjected to the same standards as passenger cars. They actually LOOK much safer than in the past, with their thick roof pillars, and thick doorframes, but I think alot of that extra thickness is just sheetmetal, and not much true support underneath. If you look at pickups from days gone by, cars too for that matter, the roof pillars tend to be much thinner, especially the A-pillars. The A-pillar in my '85 Silverado looks downright dainty! And the one in my '79 NYer and in my '76 Lemans look even thinner, although part of that is because the doors don't have frames around the windows, so you lose the bulk of a window frame.
    Or even if they are beefed up, I'd imagine that the weight of the truck has gone up so much more that it more than cancels the engineering advances. For instance, my buddy's tiny little Xterra, all 178" of it, weights 4200 lb. That's about what my full-sized 212" Silverado weighs! Now I'm sure my Silverado wouldn't be too safe in a rollover either, but just imagine how much more engineering a newer equivalent pickup, which probably had 500-1000 lb or even more on my Silverado, would need.
    I don't know if this is true or not, but I've also theorized that when a truck or SUV rolls over, it's a "harder" roll than a car, because it's a taller vehicle. Kind of the same principle of when you cut down a tree, as it falls the lower part of the tree isn't falling with that much speed or force, but the top part is going to hit that much harder. So it just seems to me that the truck/SUV would be likely to smack down harder than a car would when it rolls.
  • michaellnomichaellno Member Posts: 4,120
    Well, I'm not a structural engineer, but I can tell you what the Tracker looked like after the accident.
    I didn't mention in my story above that this took place about a mile or two from home, where I was waiting for the kids - our daughter had a dentist appointment that afternoon.
    Our son, who suffered only minor injuries, called his mother at work. She called me at home, so I rushed to the scene; I actually got there before some of the emergency vehicles.
    My daughter was still in the car in the front passenger seat -- her head was sticking out of the passenger window, as one of the revolutions seems to have impacted right where the A-pillar meets the roof and crushed it with enough force to flatten it.
    Fortunately, the window was open, and I can't help but think if the angle of impact was a few degrees different, there would have been a very different outcome.
    I shudder every time I think about that image of my daughter, semi-conscious and stunned, in that car, and how close she was to sustaining major injuries.
  • asafonovasafonov Member Posts: 401
    Looks nice (and would look even better with those wheels you are putting on.)
    Are Sebring coupes of that vintage actually based on the Galant and made by Mitsubishi (unlike the sedans.) If so, this may bode well for future reliability.
    I kind of like the black steel wheel look also--makes the car look like something Bullitt (Steve McQueen) would drive perhaps. It's a pretty good looking car actually. Hopefully you can keep the steel wheels & Blizzaks for winter??
    from that era, along with the Dodge Avenger, are actually based on a stretched version of the Mitsubishi Eclipse. I think the Galant was on its own platform at that time. When the 2001 Sebring/Stratus coupes came out, they were on the same platform as the Galant, and the Eclipse was on that same platform too by that time.
    Would ever get here I can finally get my car off the trailer and drive it! My little brother has been threatened with bodily harm if he doesn't come down Saturday and fix the car.
    The car has 3 good steel wheels and 3 good Blizzaks left, the 4th one didn't survive the impact with the tree, but that's no biggie, a new steel wheel is about $30 and a new Blizzak runs $163.. I really should show a picture of other side........it don't look so good, the rear quarter panel is dented from just past the door to the rear taillight. It bent all the suspension for that rear wheel as well, little brother is replacing that Saturday. Other than that there are a couple other dents (very minor) in the front fenders and hood plus a few scratches. Not too bad for sliding off the road at 65 mph into a bunch of trees.
    Should have it totally fixed by fall time, going to take it to a body shop next week for an estimate. Its no doubt worth fixing, the car still has a book value of $6000.
    I always wanted a Sebring of this vintage (Mitsubishi), just didn't expect to end up with one this way. :blush:
    Does it have a Salvage Title or some such?
    One good thing, maybe, is that it's been "Pre-Disastered" (from the John Irving novel I think).....
    Well hello boys & girls, it seems I just sold my '04 Vibe with the stick ... for (drum roll) $11,500.
    If all goes well, we'll consummate the deal this Saturday, and then I'll have to go car shopping again... poor me :-)
    I'm thinking $4,000 Taurus and no comp/collision for this kid any more.
    Whoo-hoo!
    -Mathias
    Nope, 100% clean title, it shows one accident on Carfax (same quarter panel as got hit this time), but the second accident does not show. Its was a one owner car prior to me buying it. Title is in my name and until its fixed I just have liability on it, no comp or collision......that will be put on after the car is repaired.
  • tifightertifighter Member Posts: 3,829
    I don't know, Mathias.
    I know you have weakness for a Subaru with a manual tranny... ;)
  • qwallsqwalls Member Posts: 406
    Congrats! I'll look forward to reading about your search. I paid off the TL, and have started looking. I drove a Yaris S Sedan, Corolla, and an xB Monday. the xB had great leg room, but surprisingly I liked the Yaris the best of the bunch. The xB had a VERY smooth clutch though.
    If I could catch a sale on a Mazda 3 Hatchback, that may be the ticket. No rush as long as it stays warm since the Legend doesn't have heat. :-)
    Q
    Up and going!! Little brother fixed it today, took it out for a drive and wow, seems to be great, no shake, no pull, nothing, just drives wonderful. Sunroof is a little cranky and it might need brakes, but other than that it seems perfect.
    Here's a link to her picture off the trailer and with her new 17s. Looks a little better.
    Sebring
    From the looks of the shrubbery, spring ain't sprung quite yet in AK, eh?
    Just kidding. I just liked the steelies just fine.
    BTW, as I sold my Vibe, I'm now riding around in a '93 Villager with (cough) 210k miles. Got it on loan from a friend in the biz until he finds me a car... trouble is, I like it... I just feel more at home in a beater than a new car.
    -Mathias
    Nope, spring is pokey this year. Hopefully soon we will see some green!
    Congrats on selling the Vibe......I was surprised that you did.
    My brother was laughing at how much I love that Sebring, he said to hubby that he should have been buying me beaters all along. I'm going to drop it off at a body shop this fall to be fixed. Will probably be a summer only car, that thing is low slung! I truely prefer the Sebring to the other 2 vehicles I have (Titan and Zippy). We currently have 4 vehicles and 4 trailers in our yard......its crowded.
    Best thing about the Sebring........Its PAID FOR!!!
  • jaserbjaserb Member Posts: 820
    "I just feel more at home in a beater than a new car."
    Ain't that the truth. I found a nice potential replacement for the beater truck - 2002 Mazda B2300 X-cab. 37k miles, 1 owner, 5-speed, red. Nice little truck, overall. These have the Duratec 2.3 - same basic motor as the Mazda3, Fusion, etc. Trouble is, the owner gave me the whole "I consider it in excellent condition" speech to justify the price. This for a 4 year old, never garaged, out of warranty truck with a scratched up bed and the original tires. I'll let him sit on it for a while and maybe throw a low-ball his way.
    Then I got back in my Ram 50 - all 171k miles of it - and I didn't want the new truck anymore. :)
    -Jason
  • sandman46sandman46 Member Posts: 1,798
    The light came on again in my '03 Sentra on Friday and it sits at the dealer for the 5th time now. Warranty runs out on the 29th and I spoke to the Service Manager and asked him to please just fix the car! Got a Mitsubishi Galant as a loaner. Real sucky seat for my bad back but it sure scoots around pretty good with seamless shifts. Butt ugly also.
    The Sandman :(
    Nissan Security Plus Gold plan:
    http://www.nissanmotors.com/owning/service_plans/gold_preferred.html
    Even if you don't have the plan, the old Nissan USA would probably goodwill repair of a recurring problem outside of warranty if you called them. Not sure they would do that now, there are a lot of issues with their move to Nashville (like, losing well over half their staff) that they seem to be in denial about.
    Really thinking about cutting this car loose. Mentally, it's worn me out. Thinking about the Civic or a Vibe.
    The Sandman :(
    I hear you! That was just a suggestion in case you don't cut it loose by the 29th. I don't think you could go wrong with either the Civic or the Vibe. Might be hard to find a Vibe with the optional safety features that the Civic has standard. But, it should be much easier to get a discount on a Vibe than a Civic.
    Had one of those pesky Check Engine lights come on today with the Sebring, went over to the parts store to have them run a code check. Its the O2 Sensor........$85, add that to the front brakes that HAVE to be done (warped rotors)......$200, the airbags that need to be replaced......$1200, and I'll have a cool $2500 into this car when its all said and done. Good thing it runs good.
    The car is a blast to drive, really enjoyable.
    I'm usually an airbag fanatic, but for $1200, I'd be real tempted to go w/o. Esp. on a $650 car with body damage, etc. Besides, you might decide to sell it/trade it in 6 months.....& won't get any more for it w/airbags (I assume)..... :)
    What are the chances you could trade this troublesome Sentra for a Civic by the 29th? You could be putting your energy into getting the trade done instead of always taking the Sentra to the Nissan dlr. And, I vote for the Civic over the Vibe......
    A Sentra to trade? I say go for the new Fit.. I hear the Fit is GO!! :surprise:
  • gsemikegsemike Member Posts: 2,451
    I don't know about AK, but in NY there is no way that car would pass inspection without airbags. There must be plenty of those cars that have gone on to the next world, so there has to be used never deployed bags to be had.
  • gussguss Member Posts: 1,167
    For some reason I am linking the Yaris over the others. It's got cute written all over it.
    Of course this is all based on the T.V. commercials. I have not been closer than driving by them at the dealership.
    I have a set coming......no cost to me since I traded the Titan's wheels and its part of the deal. However, the body shop wants $1200 to put them in, that's replacing the main airbag module and sensor too which is $550. My brother said he can get that module off the car that the airbags are coming from. So hopefully that will lower the bill a bit. He said he's installed airbags before, doesn't like to do it but he will to save his sis some $$$.
    The body shop told us it was illegal to drive the car w/o airbags, little bro says that's not true it only applies if I sell the car. So I'm going to probably call DMV or the troopers to find out the real scoop. Lots of cars up here drive around w/o airbags, salvage cars are the norm up here.
    I like the Fit or the xA, because I'd want four doors in a hatchback... The Yaris gives you a 2-door hatch, or 4-door sedan..
    Otherwise, the Yaris seems like the better buy...
  • zodiac2004zodiac2004 Member Posts: 458
    Any 80's or earlier cars in AK.
    I'd imagine a majority of those don't have airbags.
    Just got back from Enterprise and swapped out the Galant for a Sonata...much more back friendly and quite spirited. Am really impressed with this car, as it drives nicely and is quite comfortable...don't feel like a pretzel while driving, which is a good thing. They can keep my Sentra for all I care now...lol!
    I wonder how the 4 cylinder Sonata drives as compared to the 6. This size car still won't fit on my side of the garage, but I can now see why I see so many Sonata's on the road here in South Florida. Finally, a real alternative for the Camcords.
    The Sandman :)
    I saw the new Sonata at the Houston Auto Show this year. Looked like a really awesome car, very pretty, nice interior. If I was in the market for a car I would give it a good look.
    However, I'm not in the market........I'm having too much fun with the Sebring.....well, except that its so low to the ground I have to really pay attention to where I drive.
  • jefferygjefferyg Member Posts: 418
    I got crazy today and went window shopping. Unfortunately it was at the dealership where about four of my friends work. Our kids go to school and play ball together....
    Anyway I mentioned to one of the guys that I would consider selling my old beater Ford Ranger and dadgum if I didn't get a call from my neighbor up the road before 6:00 p.m. He came and looked at my truck and wants to buy it. So now I'm about to be truckless.
    The wife and I have already been talking about getting rid of the 04 Mountaineer. It still has less than 20,000 miles on it and looks almost showroom perfect, so it seems that I should be able to get a good trade-in allowance on it, but alas it is a Mercury, so who knows.
    My dilemma is which truck to buy. I'd prefer a crew cab. My son is still in a booster seat and I hate those suicide doors. Been there done that.
    Here's my assessment of the various brands:
    I really love the styling of the new F-150, but I'm disappointed with its engines.
    The Titan is nice but gets pricey in a hurry.
    The Dodge's back seat is like sitting in a straight back chair.
    The Chevy/GMC twins are a bargain, but they are a bit plain on the interior.
    I'd have to wait until 2007 for the new Tundra.
    I love the new Frontier, but the full-sized Chevy gets better mileage and after rebates costs less than the smaller Frontier.
    I'm just not crazy about the looks of the new Tacoma.
    Dakota - too ugly.
    Colorado/Canyon - can't see it. My dad already has one and it's nice, but not even in the league with the other midsized trucks.
    Ranger is not completely out of the question, but I don't feel my kids would be safe in the jumpseats.
    Decisions, Decisions. What am I going to do? :sick:
    a real truck, but how about the new Ford Sport Trac. They're not for me , but you will stay in the ford family. The gas mileage though is not much better than the big 5.4l V-8. It's funny how the mileage of all pick-ups are all about 14/15 city and 18/19 hwy unless you get the diesel.
    I have always like the Tacoma crew cab , but I agree with you, the new style leaves me a little cold. They would be the perfect size for me.
  • pernaperna Member Posts: 521
    I would be inclined to get the F-150. Speaking as a huge Nissan fan, I'd still be leery of the Titan's longetivity, especially if you're going to be doing a lot of towing with it. My BiL has an '05 F-150, and after looking at Silverados and Rams with a buddy, I'd take the Ford hands-down.
    If the American auto mfgs have always done one thing right, it's pickup trucks.
    I was about to suggest the same thing. I consider the Sport Trac a real truck--it holds the same place as a Ranger crew cab would, with a smaller bed and more cabin space (just like all of the compact crew cabs that don't have a long bed option).
    I probably sound like a broken record, but if I were going to buy a new truck, I'd probably head right to the Toyota dealer. The excellent resale & reliability may help you get over the looks--but personally, I think the new Taco looks fine.......& it looks like......a truck.
    I agree in a lot of ways, however, the 06 Titans seem to be pretty good. I would steer clear of 04 and early 05 Titans however.
    I'm in a dilemma of my own over mine, I would really like to keep it, but we have a new truck on order. Hubby says the truck has to go, no way will he keep it when the warranty is almost up. Currently it has 51,500 miles on it, warranty is up at 60k.
    I keep telling myself that its been an unfaithful truck and really needs to go, but everytime I drive it my heart says........keep it keep it!! The new truck will be here the end of June........so do I just not drive the Titan at all to save myself the heartache?? Or do I try to plead its case to a very anti-Titan hubby??
    BTW, I'm having a total blast with the 97 Sebring, what a cool car!
    I was thinking about you and your spider condo yesterday, as I do everytime another spider drops down out of the headliner, door seal, or who knows where else on the Sebring. I think I have made a bunch of unhappy spiders by taking their spider condo and putting it back on the road. :blush:
    To either the Frontier or the F-150. I test drove an 06 GMC Sierra today - Yikes! The Frontier actually rides and handles much better than the Sierra. My wife said it looked like a "work truck" to her. Even with all the incentives it is definitely out of the running.
    The Frontier wins out on the "fun" factor. I think it's sharp looking and the SE Crew Cab that I'm considering comes with the sprayed in bed-liner and the utilitrack system.
    The F-150 is a better people hauler simply because of the larger size. It has by far the best ride of any pickup I've ever driven and with all the rebates it could be a really sweet deal.
    Both handle well and the two trucks I'm considering are almost identically equipped.
    One other factor is that I believe my wife would be more comfortable driving the smaller Frontier, so that tips the scale a bit more toward the Nissan. However, when all is said and done, it's probably going to come down to which dealer will give me the best trade-in allowance on the Mountaineer. I bought the Mountaineer from the Ford Dealer and am well acquainted with them. Several of my friends work at the Nissan dealer, so perhaps they will give me a break.
    I'm going in the morning to see if I can work a deal, so wish me luck! :)
    Sounds like it's basically a coin flip for you and the deciding factor is which will be better for the wallet. I don't think you can go wrong with either one. Their true cost to own over five years is probably within a few hundred of each other.
    Remember the wife factor can be huge. My wife hated driving my Aurora because it was too big and according to her an old man's car. So, if she will be driving it at all make sure you get her blessing.
    how did the Sierra compare, price-wise, to the F-150? Every once in awhile I get a craving to replace my aging '85 Silverado, and had just presumed that pricing would be cheaper on the Silverado/Sierra, compared to the F-150, so I never really even paid much attention to the Ford.
    But I guess that since Ford's not doing so hot, either, they'd be willing to deal.
    In my case though, I'd just be going for a cheap work truck, regular cab, 8-foot bed, and wouldn't really care about any comforts other than air conditioning, automatic, and a halfway decent radio!
    Forgive me for saying, but that's kind of a weird comparison. It's like trying to choose between a Nissan Xterra and a Ford Expedition. Two completely different classes of vehicle, really, with unique capabilities. The Titan and F-150 are the real competitors.
    I'd say if you're going to use it as a daily driver with only occasional hauling needs (not towing, since I don't think the Frontier can tow a whole lot), you might as well buy the Nissan and save gas. NOt to mention it's a more practical vehicle for getting around town and parking.
    Another option, if you're looking at small pickups, is see what kind of deals they have on the Ranger. I imagine you could pick one of those up for a song.
    If you're gonna buy a GM pickup on the cheap, do it fast. Once the '07s come out, the dealing on those will be done. Completely different truck, top to bottom.
    I guess there are stranger comparisons, though. For instance, my buddy narrowed his choices down to a Chevy Equinox and a Nissan Xterra. About the only thing they really have in common is that they're roughly the same size, but one is more rugged and macho feeling, whereas the other is a cross between a car and an SUV.
    And as for me, if I were to get a new car now, it would be a tossup between a Charger and an Altima. Both of which I consider to be sporty midsized cars. They may try to pass the Charger off as a big car, but considering some of the battlecruisers I've driven, it's almost a compact! :P
    As for the Chevy/GMC pickups, having the '07's come out and supply of the '06 models dry up is actually the best thing that could happen to me, financially. Because it'll keep me from buying one! Not the best choice to keep my CCB membership up, though. :shades:
  • geo9geo9 Member Posts: 735
    According to Wheels.com production on the 07 GM 1/2
    ton reg.and x-cab trucks is gonna start 5/22/06 so
    I can assume the 06 production is already finished.
    Supplies will be thining out and hopefully 06 rebates
    will increase. I will wait till spring for my new 07
    2500 x-cab to replace my 04.
