It is NEVER a good idea to just tell a dealer "do the xxMile service". This is because they often add in expensive things which are not listed in the owners manual as required to maintain your warantee. Instead, you should read the owners manual yourself and hand them a list of items which you find listed in there.
I am curious.... would you be willing to provide us with an itemized list of what they did for your 40K mile service? (and what they charged for each item)
Thanks Ray
I am a relative new owner of a 2006 Jetta TDI. This is my first diesel vehicle and I love it...with the exception of the nasty black exaust reside on my bumper. Is there any trick to keeping this off the car or is this just something you deal with when owning a diesel??? I own a white Jetta and it really shows.
Also....does anyone have any suggestions on how to remove it?? I have been using Goo Gone...but am not really sure how this would be for the finish of the car.
Anyway...just my only complaint of the car...and I guess it's a small one.
Thanks in advance,
Sue
i don't think "premium diesel" solves this sooty-bumper issue whatsoever, because i don't believe there is really such a thing as "premium diesel" in USA (except maybe for some biodiesels!)
personally i find the soot-residue on rear bumper tends to keep tailgators at bay - a nice bonus. if that doesn't work, downshifting & flooring it will often cause the 06 TDI to "blow its nose" even with ULSD, making a nice soot-cloud on the tailgator.
Perhaps you should have your IQ checked. (Injection Quality) the presense of soot usually indicates ineffecinet combustion. Are you getting less than 45MPG?
I am also wondering if the design of the new (MK5) jetta tends to 'pull' the exhaust back onto the bumper? The butt of that MK5 jetta is pretty big ;-)
You dont have a "fin" on your jetta....do you? (that sure would induce the exhaust to get pulled back onto the bumper)
bpeebled - what do you mean by a fin?? A fin on the bumper or a fin on the trunk? I don't have either.
The soot is nasty looking.....maybe I should ask the dealer.
I am looking forward to any more feedback you can offer. Thanks in advance!
Sue
Unrelated to this issue, you might also ask them to check the alignment and tire balance (should also be covered under the new car adjustment period). All the best and let us know what you find out.
A side-effect of adding a fin is to cause more exhaust fumes to get sucked onto the rear bumper. (Cuz the clean air is not flowing smoothly from the trunk-lid down onto the bumper.)
i was wondering if anybody on this forum might be able to help point me in the right direction as concerns my 2000 Jetta TDI. In a nutshell I tink I need a new motor. Can anyone recommend a mechanic in the Seattle area? thank you
In cold (-10F)weather, you will be lucky to see it reach 190F because the TDI engine is sooooo efficent. (it does not make much waste heat)
Here is Trusted TDI mechanics - by state
(Use "Ctrl-F" and search the entire webpage carefully.... Also search page "2" )
Here is VW/Audi deraler ratings
On the other hand- I also heard that Mercediez-Benz (Chrysler) and VW have been pushing the EPA pretty hard to approve the "Blue-Tec" for use in the USA
Perhaps you mistakenly understood that BlueTec will be coming to North America (ie Canada) -- but will not be available in USA.
Do you have any recient news on the EPA approval of the Blue-Tec technology for use in the USA?
:confuse:
Basics are;
OIL heaters
*)Magnetic stick-on to oilpan (wont work on Aluminum oilpan)
*)Dipstick heater (replaces oil dipstick with heating element)
*)Lightbulb placed under the oilpan (I know a guy that has done this for many years)
Antifreeze Heaters
*)Inline with the hoses (can be either electric or diesel-fuel powered)
*)replaces a frostplug in engineblock
Entire Car heater
*)Heated garage
Although the heated garage is perhaps the best choice foe a warmed engine... it promotes rusting of the body panels and I dont have a garage.
After much trial and error - Most folks end up with aTDI heater. You can experiment with your car... or go down a proven path with TDI heater.
If you are not comfortable with tools, it may be best to talk to somone who is and see if they would install for you. I would not think it would be more than 1/2 hour of time for somone comfortable with tools.
At present I'm waiting on the saleman to get back to me with the info but I though maybe someone on the forum would know.
Thank You and Merry Christmas To All.
i gotta tell ya - i think travelling with seat reclined that much is probably bad news if any collision occurs. i think passenger might slide under the belt in that case. well, sorry for that bring-down aspect, but there's your info re the seat.
i can't recommend VW TDIs strongly enough!
Merry Christmas & respective-other-holiday-cheers to all!
do not know year of your TDI..but pre 1995 diesel engines may have hoses that would leak , so you would need to change those to Viton hoses or newer hoses, in order to run biodiesel.
As you know, biodiesel has good lubricity for the fuel pump, and cleans the whole fuel system.
With the introduction of ULSD over the past several months, the problems with fuelpump seals has become even more exasterbated do to the large swing between chemical makeup betwee the 2 fuels. (1 fuel makes the seals swell while the other one makes the seals shrink.)
I have a 04 tdi wagon with 68k miles on it. I approached the dealer and service people at 60k asked if I needed a timing belt and tensioners, They said NO and that at 100k do the belt and water pump.
Well the belt broke at 68k and now has to have head worked or new Head, I opted for New Head and water pump and the works at the tune of 3200.00 I had VW place do it since I was out of town on thanksgiving. I have to say I am very unhappy with VW and the car. I dont trust it and Little gun shy of it. this is the most money I have had to spend on a car with only 68k on it. it may get 40-46 mpg but all that just went out the window. with this repair.
Another thing I see that a Class action law suit is in the works due to all these timing belt failures VW and Audi are having. Does anyone have any insight into this? seems if VW says dont change the belt untill 100k then it should be covered untill then. This will be my last VW :mad:
Traumagas
Please Get back to me the dealer is putting me off until the 15th of jan
Thanks you
Rob who also has tdi
You don’t say if it is a A3 or A4 99 since that was a conversion year. But in any case it is common for the intake manifold to clog just past the EGR. It is a toss up some cars are 90% clogged at 60K other it takes well over a 100K depends on how you drive I guess. Believe it or not it is hard to tell how clogged it is without looking since the drivability is not adversely affected until the very end. You would notice power loss but over time but it has to be real clogged to make the car very powerless. For example I test-drove a 00 with 120K on it and I could not get the car over 50MPH. On inspection, the intake only had an opening the size of a pencil. But with a opening say the size of a nickel it would run fairly well (not like unclogged car but you as a new buyer may not notice it). Consider the intake is about 2 inches in size when new. But that is not a showstopper all you need to do is take off the intake and clean it (not a small job). You may need new injectors at a 100K that is about normal.
One biggie is the timing belt and I think both the A3 and A4 in 99 was a 60K change. You want to make sure that it was changed at least once and at about 60K. If it has never been changed that is bad since it can break at any time and by by engine.
The VW TDI is a good car and with 95K it is just about broke in nice. If the car is good overall and all it needs is some normal maintenance sounds like and OK deal based on the little info you provided.
Also -- BEWARE: running BD has been known to cause seal failure on the fuelpump. (due to chemical charctoristics of the fuel)
You did not say WHICH grade of BD you are running. The last I knew, VW does not endorse use of BD over 20%. (B20)
I also have an 05 Dodge Ram 3500 dully and have ran it for 25,000 miles on SVO with no problems til fuelling up with the new diesel. Now I have to put in fuel conditioner and occasionally start it up by spraying starting fluid via the air intake.
What can I do to repair my Jetta? Starting fluid has not been successful! Can I replace the seals in the fuel pump?
I had engine symbol, and wrench lights lit a few days before breakdown and I had to fill-up with engine oil as well!
If you are engine-savvy, you can use VagCom to troubleshoot.
Your 2006 is a "pumpe-duse" engine. Each injector has its own seperate fuel pump. There are not may people in North America that have the skills to work on the fuel pumps. It is not advised that you try it at home (nor have dealership do it)
If you need to replace injectors, I recommend some of the Kerma Injectors that will give you more power and better MPG than the original injectors.
You may also wish to become a member of www.tdiclub.com website and see what the TDI experts have to say about your delima.
Biodiesel is very good for your fuel pump..it has better lubricity compared to the new diesel#2 ULSD.
But make sure it is properly filtered, or else it may/will clog fuel filter....
15,000 miles for a new fuel filter is kinda quick....especially for a newer car. I will need a new one, since I have over 110,000 miles...and the biodiesel will clear out all the gunk in the fuel system.....
Many people run biodiesel at high percentages with no problem....
however, with the new ULSD, with its low lubricity, and how it contracts seals....it is the opposite of biodiesel. One expands the seals, and the other shrinks the seals. It is this shrinking and expansion on the seals that causes failure/leakage.
I suggest if you run biodiesel, than always have some in the tank , like at least B20 or higher.
bpeebles has a good suggestion....go to the tdiclub.com to ask those experts who work on their cars all the time.
Vw should market the Sharan MPV, the (MAzda5 sized) Touran mini MPV, Yaris sized Fox, and the Tiguan here.
Check them out here!
Why does 10k miles oil change wind me up ? Well, just about every mainstream gasoline engine here in Europe runs on 20k miles oil changes; even more for some depending upon driving style in those cars that monitor it. 10k just feels like a service money-maker and I'm sure it's very conservative. However it's a relatively small price to pay for a great engine. Some day you'll catch up on oil drain intervals and we might, but only might, catch up with you guys on other things such as warranty periods, (generally 3 years/60k miles here in UK but typically only 2 years in mainland Europe).
Hi ruking1. Small world, eh ?
On your post at hand, I think you could possibly change your intervals after a careful reading of your VW specifications and seeing if the multiple specifications will web or cover your goal (higher than 10,000 mile OCI's).
So to me for all I have read, bets are off for the PD or pump duse motor. Howwever if your owners manual, technical shop manuals, Skoda web sites will let you shoe horn or fold your (engine's oil specs) way into the VW 507.00 specification, ELF shows as high as 30,000 miles per OCI.
So on the 2003 Jetta TDI motor the spec is VW 505.00, 10,000 mile OCI. Turns out Delvac One 5w40 aka Mobil One Truck and Suv DOES NOT meet VW 505.00 specifically. ROAD BLOCK. However it does meet CF-4 which is a much more stringent specification, which of course exceeds VW 505.00 specification. Next Delvac One also meets CI-4 specifications which is still FAR higher than the CF-4 specification. (this is also duplicated on the ACEA specification side). Now all this is with the up to 500 ppm LSD in mind. Even at that, most oil analysis test good to go to 15,000 to 25,000 miles. So with the advent of ULSD, or 15 ppm that is like > 90% LESS sulfur, which means it tends to generate even less by products ergo app 30,000 is now with in the useful life.
Jay
As for my TDi's OCI, I'll stick with my 505.01 for now, (i have a couple of changes' worth left), but will be looking at a new Skoda with the 2.0 TDi PD later in '07 so will be interested to see what that calls for in the way of specs and OCI. May even go mad and get the 2.5 V6 TDi. My neighbour runs an Audi A6 Quattro with 3.0 TDi. Wonderful device but maybe a bit big for my needs. On the other hand...........you only come this way once, I think. One think is certain; it will be a cold day in Hades before I go back to gasoline.
Many thanks for your always-valuable input.
It injects more fuel for several reasons including;
*)Cold engine is harder to keep running due to thicker oil.
*)Cold fuel does not ignite and burn as efficently.
*)You are loading the engine more with additional electicial equipment.
*)Battery requires more charging.
*)Cold xmission is less efficent (thicker oil...etc)
*)Cold differential takes more power (thicker oil...etc)
*)Cold wheel bearings take more power to move.
*)Rubber in tires is stiffer.
The reason you may notice this phenomena on TDI engine is because it is more efficent to begin with. (5% of 50MPG is more than 5% of 20MPG)
I hope this answers your question.
Sometimes I'll run my 04 tdi in a lower gear to increase the rpm and heat up the engine faster. I also installed a TDI Heater that really helps on very cold days.
Just curious, do diesel engines run cooler because they run at lower rpms as compared to gas cars?
