Visitor Agreement.
I am strongly attracted to diesels, but have never been willing to pay the extra up-front costs. In 2001 or 2002 I almost bought a VW Jetta TDI diesel 5-spd man wgn, but at that time the cost premium over the base gasoline engine was maybe $1500, if I recall correctly. I thought that I didn't drive enough to recover the extra up-front cost of the diesel. Also I was put off by the fact that these diesels emitted fine particulates and NOx at levels much higher than the gasoline engines. I just held onto my 1991 Dodge Spirit 2.5L throttle body injector 5-spd manual 100 hp gasser until 2004 when I gave it away (still functioning perfectly after 16.5 years of ownership by me) to someone who needed value transportation. I got a 2004 V70 as a hand me down from my wife who wanted a new Volvo with dynamic stability and traction control which the 2004 base model lacked.
That's very good but not enough to compel me to switch out, at least not at this point. In the SF Bay Area, we pay considerably more for diesel fuel than 87 regular.
If I bought a new MINI, which requires premium fuel but gets 35 mpg, I save about $450 a year if I buy a TDI.
I'd say I'd need a price differential in fuel costs of about...$1200 to $1500 a year to tempt me.
On a round trip from Dallas to San Francisco I got 32 to 34 mpg on I-40 through New Mexico and Arizona in light traffic at up to 75 - 80 mph. The orig EPA was 22/30 mpg city/hwy. (No hypermiling but driving with the accelerator and avoiding braking.) My car will run on 87 octane but the manual says that 91 octane is optimal so that's what I use. I don't hesitate to use 89 or even 87, if that is all that's available, but I think nothing about the extra cost of premium. The cost of motor fuel is not a consideration to me. The only thing I care about is the impact of my activites on other people and on the environment.
So I think your analyses & points seem possibly related to this question which I think should be of great interest for USA national security, and which President Obama may have Willie Nelson researching right now:
Q: what is the optimal distribution/% of diesel vs gas engines in the US passenger fleet, in terms of minimizing oil imports without causing diesel shortages.
A: Isn't it "obvious" that we'd do better with at least a few % more diesel cars relative to gassers, thus reducing oil imports, and without causing a diesel shortage/price-runup?
You can contact any of the "big boys" public relation or consumer help desk and ask them what cetane number is offered in your neck of the wood. Generally speaking, minimum 50 is required - but there are higher CN numbers that are sold by Shell and Murphy USA (60 to 70) in various locations. The higher the better - and you will feel the difference with a higher cetane number!
I have always wanted a Jetta or Passat TDI wagon, but I probably never will get one.
Diesel-powered vehicles which are equipped with a DPF emit no visible emissions from the exhaust pipe and far less harmful not only to the environment, but to the general health of those in the vicinity of the running vehicle. I do not see any problems in the future with this type of engine.
There have been a few complaints logged for the 09 Jetta TDI regarding the DSG at the site below.
http://www-odi.nhtsa.dot.gov/complaints/
Here is the link mentioned with details.
http://www-odi.nhtsa.dot.gov/complaints/results.cfm
If the above link does not work (somehow, when copied on Mac, it may not display results properly) go to .gov general site, input 09 VW Jetta and let the site display all complaints related to the DSG (automatic clutchless shifter).
thanks.
I have test driven a few 06's and noticed that shuddering 'delay' in starting from a slow roll or easing into an intersection.
Seems it all has to do with a 'dual mass flywheel' design flaw, (Under recall in Europe) and not the engine.
That site gives VW of America a very poor mark on dealing with this self destructing transmission issue under warranty....telling owners..
"It's a wear item" to "you don't know how to drive a standard" or a combination of both.
When do you think it will be safe to buy a 'de-bugged' one?
The lag is NOT uncommon. I have much more of a lag on a 04 Civic automatic 4 speed. At cruising speeds, it seemed to hunt for the correct gear and then downshift, etc. I used to override it by pushing harder on the accelerator. However that cause an instant drop in mpg and so I just let it do its thing.
select year - 2009
select make - VW
select model - Jetta
select radio button on left: "select this check box"
click "retrieve complaints"
here is one of them: (and there are several)
TL-THE CONTACT OWNS A 2009 VOLKSWAGEN JETTA. HE STATES THAT DSG DUEL CLUTH AUTOMATIC TRANSMISSION THAT THE TEMP SENSOR GOES BAD IT SENDS FALSE READING=S TO THE ELCTRONIC MODULE AND CAUSES THE TRANMISSION TO LOCK UP. GOING AT 70MPH ON THE HIGHWAY THE VEHICLE SHIFTED TO NEUTREL. THE VEHICLE STAYED IN NEUTRL UNTIL IT HIT 45 MPH WHEN GOT OFF THE HIGHWAY AND AT A STOP SIGN ON A OFF RAMP AND TRYING TO PASS THE TRANSMISSION CONTINUED TO LOCK UP AND ALMOST CAUSED AN ACCIDENT. THE VEHICLE WAS THEN TURNED OFF AND THEN TOWED TO AN DEALER AND THEY TOOK A LOOK AT THE VEHICLE AND THEY ARE INVESTIGATING THE PROBLEM WITH THIS VEHICLE. ALSO VOLKSWAGEN DIDNT TAKE THIS SITUATION SERIOULSY. THE FAILURE AND CURRENT MILEAGE WAS 868.
Not that this does not happen with other oems. To use an example (I am familar with and have run across), the 2006-up (new gen) Honda Civic. It has HUGE problems with the rear end. It was supposed to be a HUGE upgrade to the rear end performance!!?? In a gallows humor sort of way; AND how it WAS !!! The tires wear prematurely and it also can wear un evenly. The brake pads and rotors both front and rear have had serious issues across generation lines and not surprisingly for a number of years. So now the rear brakes wear unevenly. The suspension system needs replacing. The car tracks like a dog with broken hips. For some owners, it has been an absolute and complete nightmare.
Needless to say, Honda Civic enjoys almost complete adulation, and almost stellar resale value. !! ??
Having said that, running a 04 Civic (87,000 miles) and an 03 Jetta TDI (119,000 miles) at like miles; the Civic is going through wear able parts at roughly 2x faster than the Jetta TDI.
I also know that the Honda's automatics are problematic. If they are going to fail, that has statistically been true @ the 200,000 to 250,000 miles markers.
On the other hand, I knew what I was signing up for BEFORE I bought the Civic (eyes wide shut, love me? love mah dawg. so to speak) I am happy with its performance so far.I am also happy with the 03 Jetta TDI :confuse:
As charming as the Jetta is, you have to admit, that in the past at least, it has been a bad boy.
Of course, as with the MINI, the further the model develops, the better it gets. So maybe we're out of the woods...I'm going to follow owner's comments on 2009s very closely.
I'd hate to make a $26,000 mistake.
A tad afield , (op/ed)
VW I think has decreased costs and increased build quality and hopefully enhanced durability and as a by product reliability with the the 09 gen V. The real trench work is repairing the reputation.
I would speculate 2 - 3 years would be enough to have any bugs worked out, but only time will tell.
I still have an issue with moon-roof. Even with sun shade retracted it generates so much heat inside the vehicle in summer, when you have like 12 hours of sunshine and the car is not parked in the shade. Like I've mentioned before, I have a cardboard covered with aluminum cookin foil inbetween moon-roof and sun shade and what a difference it is!
Another issue is the soft suspension - with trailer hitch installed, I always hit the bottom of the hitch on any speed bump in a parking lot. Can't wait to have some stiff shocks installed, once they become available, or, for that matter, can't wait for Subaru Forester to bring diesels to these shores (2nd year running already in Europe).
Recalls Summary
Vehicle Make / Model: Model Year(s):
VOLKSWAGEN / JETTA 2006-2009
NHTSA CAMPAIGN ID Number: 09V164000
Summary:
VOLKSWAGEN IS RECALLING 25,594 MY 2006-2009 JETTA 5TH GENERATION EQUIPPED WITH 2.01 ENGINE. THE FASTENING SCREW CONTACT SURFACES ON THE DRIVESHAFT COVER PLATE MAY NOT HAVE BEEN MANUFACTURED TO FACTORY SPECIFICATIONS. SOME SCREWS MAY NOT HAVE BEEN TORQUED PROPERLY DURING ASSEMBLY AND COULD LOOSEN OVER TIME, CAUSING A KNOCKING SOUND WHEN THE VEHICLE IS IN MOTION. THE DRIVESHAFT SCREWS COULD LOOSEN TO THE POINT WHERE THE DRIVESHAFT DETACHES FROM THE GEARBOX.
Consequence:
IF THE VEHICLE IS MOVING WHEN THIS HAPPENS, THE DETACHED DRIVESHAFT COULD CAUSE DAMAGE THE GEARBOX HOUSING. A DAMAGE GEARBOX HOUSING COULD LEAK GEARBOX OIL ONTO THE STREET AND CREATE A RISK OF A VEHICLE CRASH FOR BOTH THE DRIVER AND OTHER MOTORISTS.
Remedy:
DEALERS WILL INSPECT THE DRIVESHAFT SCREWS AND REPLACE THE SCREWS FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN ON OR BEFORE JUNE 19, 2009. OWNERS MAY CONTACT VOLKSWAGEN AT 1-800-822-8987.
Notes:
VOLKSWAGEN RECALL NO. 40J2/S4. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
In addition, the affected VIN #s are: 3VW_ _ _ 1K _ 6M _ 618033 to 3VW _ _ _ 1K _ 9M _ 304337
In the recall notice it also mentioned TFSI, but I have no idea what that means.
• Turbo compressor
• 1,968 cc 2.0 liters in-line 4 front engine with 81.0 mm bore, 95.5 mm stroke, 16.5 compression ratio, overhead cam and four valves per cylinder
• Diesel fuel
• Diesel common rail fuel system
• 14.5 gallon main diesel fuel tank 12.1
• Power: 104 kW , 140 HP SAE @ 4,000 rpm; 236 ft lb , 320 Nm @ 1,750 rpm
I was really hoping that he would have said the VW because I really liked the solidness and handling but I bought the Mazda6 instead. In two years and 33,000 have not had one trip to the dealer other than routine maint. Absolutely nothing had to be fixed or adjusted which to me is pretty amazing.
I am still looking at the 09 TDI as I have another vehicle that needs replacing in the near future. I'll talk to him soon now that he has three years on the job and find out if his opinion has changed.
1. Honda (and their derivates such as Acura)
2. Toyota (and their derivates such as Lexus)(my son works for Toyota HQ in Torrance, Calif.)
3. Subaru
4. Nissan (and their derivates such as Infinity)(formerly Datsun - changed name because of chronic rusting problems)
5. Mitsubishi
6. Mazda
7. Suzuki
8. Isuzu (no more)
From all of the above I like Subaru the most.
My first car was a French Simca Aronde, I went through several Citroens (loved those), Renaults, Peugeots, etc. The worst: Land Rover Discovery although I was one of the first owners of Land Rover in the U.S. - that car Land Rover - was impossible to sell (in Calif), Oh well...
I too have read that VW claims that the Jettas have been too costly to produce and have figured out a way to build them faster and cheaper.
Somehow this disturbs me. Faster and cheaper is what got the Big 3 into the worst decade of Crapper Cars we have ever seen.
From reading all the Consumer Reports on the problomatic DSG and indeed the dual clutch system failures in the manual transmissions, makes me wonder how building them faster and cheaper will make them any better.
I think I will wait for the new Jettas coming out this fall to see how this all works out.
I like the look of the new front end, standard Bluetooth, more sound deadening, nicer steering wheel controls and better interior materials.
And car gossip has it that a real overhaul from the frame up is in store for 2011 Jettas.
With one 03 VW @ 119,000 miles and 6 years old I will let you know in 5/6 years how the 2009 VW fairs. Hopefully the 03 will be 11/12 years old.
Last new car I had was a Scion wagon, and that thing never even burped. A friend owns it now, at about 60,000, and it's never been in for a warranty claim--it doesn't even rattle and we got 40,000 out of the cheesy tires.
So yeah, I'm kinda spoiled, but I'll suck it up for TDI benefits. The only deterrent would be if MINI came out with a turbo diesel Clubman wagon. That's a formidable competitor to the TDI Sportwagon.
But you are right in that a TDI doesn't have an ignition system per se nor is it subject to the sludge issues of the other engines, so that may account for better reliability right there.
Nonetheless, there are certainly TDI complaints to be found on the Internet, (as with any car you can name) and some of them are not pretty. Mostly electrical it seems like, dealer complaints, and complaints of high maintenance, --seem to dominate the list.
You know, the normal ups and downs of man vs. machine.
I know quite a few people that were frustrated with non-essential (non-tow truck though) electrical problems with various accessories such as windows, etc.
But you are right in that a TDI doesn't have an ignition system per se nor is it subject to the sludge issues of the other engines, so that may account for better reliability right there. "...
Right now the "advantage/disadvantage" is the 09 VW TDI does not have much history. The real places you have to look are the ww markets and probably more true, the European markets. There will be HUGE translation issues and I do not mean language.
I performed the research late 2002 early 2003 for the 2003 Jetta TDI and concluded that most issues were for lack of a better word ,"gasser related".
This is where the "constant" improvement process paid some dividends for VW and in effect were indicators that in effect let me feel more comfortable taking a "leap".
So for example tires, brake pads, rotors, shocks/struts were still questions/issues. Hind sight and experience leaves me more than happy. "Crappy" tires lasted 112,300 miles. Brake rotors/pads @ 119,000 miles appear to be at slighty more than "half". Shocks and struts and applicable hardware will probably be changed @ the 200,000 to 250,000 mark. I did not need an alignment at 112,300 miles even as I got one @ 100,000 miles as I was intensely curious as to how it fared and was offered a special. It gets absolutely THE best mileage and I can get whatever mileage at will. (44 to 62 mpg) I normally drive to yield 48-52 mpg. Of late I have been doing "Italian" and with the A/C blasting to boot, so yield has been LOW (48 mpg). I did do the recommended TB/WP change @ 100,000, even as very close inspection indicated a min of 20,000 more would be just fine. I am swagging 400,000 500,000 miles from the "crappy" dual mass clutch. If not, $725. will buy a V6 Sachs clutch (single mass) upgrade.
If the reliability ratings are "average" and you got a great car, then maybe I'll get a turkey, so we'll achieve "average" that way?
But I think I'm willing to roll the dice.
Also I looked at the ODDS of me getting a "GREAT" car and truthfully getting one would have greatly defied the odds. I think as a result, I got a statistically "average" car. I can of course, NOT prove either scenario.
This might be off topic, but a very high percentage of MY 2006 Civic's (since I got a 2004 MY) have had HUGE and horrible rear end issues. I understand the corrective actions in a high percentage of cases have not corrected the "corrections" !!?? Honda Civic's have not suffered from bad "reliability ratings" :surprise:
In over 50 years of driving and over 35 vehicles I've never had a set of tires or brakes last anywhere near as long and I think I've had some pretty good tires at times. Maybe the experience you have with your vehicle is due in large part to the way you drive and maintain your vehicle. If I had to describe my driving habits/maint habits it would be average. To go over 100k on a set of tires and brakes you must drive very, very gently and in a straight line most of the time.
