Visitor Agreement.
Not sure if 2006 has on-board computer like the 09 does.
It's all described, how to do it, step-by-step, in user's manual. If he doesn't have one (user's manual) you can download it from the website (you don't have to print all pages, you can save it in Pdf format in your documents and access only pages that you need).
Left (driver's side) : you open a small storage area/compartment (held by to 2 rotating plastic plugs) and open (flip out) a small access cut-off panel of the interior trim. You can access bulbs from there.
Right side: you open (flip out) small cut-off interior trim panel inside and access bulbs from there.
On and off is right...remember the 70s oil crisis in his country? Detroit shrank large cars proportionally. Then cheap gas returned and we were back with gas guzzlers.
As far as diesel fuel prices in Europe, diesel fuel is cheaper than gasoline because in most countries it's tax subsidized (lower taxes on diesel fuel) and enough capacity, thanks to their armies that require diesel fuel for strategic reasons.
Diesels in Europe rule! In France, for example, there are more diesel cars than gasoline cars!
AUTOMOTIVE NEWS FORUMS
Use the "add a discussion" tab.
in jetta TDI news, the 06 auto-lock is an annoying feature. the dealer eliminated that annoying self-lock bugfeature, but only if I last-locked it via a particular one of the keyfobs! would have cost (more) $ to do for the other keyfob too.
the brake bulb swap on a TDI is really easy even for a mechanical klutz: i happened to do 06 TDI the other day.
Of course diesels can be hard to shut off as well, and I've also heard they can run backwards.
car drives great, btw. incredible torque and while I have yet to go through a full tank of gas I drove from San Diego to LA, then over the hill to Hollywood and back and still have used less than 1/4 tank!
PS
Did you buy in San Diego? Which dealer?
could it be that the difference of 25 years is more signficant than the home-country of the corporate HQ -
could it be that all manufacturers of today have learned now not to repeat the Audi PR nightmare with "unintended acceleration", independent of the home country of their corporate HQ, or their corporate culture?
Racial thing? What's racial about my statement? If anything it's an issue of mentality. Are you saying different mentalities are racial things?
Amazing...WOW! Where is this country heading when one cannot express his/her opinion....
Being an European I don't see it as "racial: statement, sorry...
your statements were racial by definition. and maybe they were accurate too,
even though i think they were obnoxious. So what - deal with it man - it's just my opinion. Now you get to say what you think too. Happy Thanksgiving, man!
My point is that any manufacturer would/will/does treat an unintended-accel issue lots differently than Audi did a few decades ago. It doesn't matter what country or what corporate-culture - the unintended-acceleration fiasco(s) are a black-hole of bad PR and all the manufacturers and industry experts are well aware of this.
I'm seeking some toyota forum here so i can understand all the technical details of the toyota situation.
I find it amazing that toyota would have to install a special system to make the brake pedal override the gas pedal in some new way. A Yugo's brakes are enough to overpower even a corvette's torque! I still don't understand why the 120 mph CHP officer who died with his family in the lexus that accelerated to 120 mph due to stuck-floormat or sticky-accelerator-pedal - why could that guy not turn off the engine and/or shift into neutral? Or apply the brakes!?
Check these links, "dude"...
http://www.latimes.com/business/la-fi-toyota-recall26-2009nov26,0,3295310.story
http://www.freep.com/article/20091125/BUSINESS01/91125018/1319/Toyota-recalls-ga- - s-pedals
http://online.wsj.com/article/SB10001424052748703499404574557540432697208.html?m- - od=WSJ_hpp_sections_business
It's a well known fact that German auto industry is on a decline since late 70's precisely for this reason - corporate culture! And there is nothing racial or racist about that...Japanese automakers surpassed Germans quite some time ago!
Enjoy your Turkey too....
Let's just get back to the TDI Jetta here. Thanks.
I believe that VW just became the world's largest automaker. That's some decline.
WallyMart also has schumacher battery-chargers too. Personally, I have the 15amp microProcessor-controlled charger from WallyMart. I am VERY impressed that it can deal with everything from lawnmower-batteries all the way up to big Diesel batteries. This little charger does the work of 3 other chargers... one of which weighs 50 Lbs.
My car will more than likely be garaged until May, so I plan on picking one up this weekend. This may seem like a naive question, but after hooking up the maintainer, should I keep the hood open or closed? Also, should the car be locked? Or, should I take the battery out of the car?
To answer your other questions:
While charging, I usually just lightly lower the hood till it clicks on the first latch.
If you want to LOCK a VW you MUST close the hood. (The hood is alarmed too!)
It really does not matter if the car is locked or not.... If you are satisfied that the garage is secure, you may leave the hood open and not lock the car.
You do not have to remove battery from vehicle to use battery-maintainer.
Reader is available from many sources on the web. Here is one.
http://www.cellularfactory.com/laptop/APPLE/4/30126/86422/
http://pocketpccentral.net/mp3c/howto/itunescdmp3.htm
I'm in the process of putting my 90-CD Deutsche Grammophon Complete Beethoven Collection onto my SDHC...
thanks again. loving this car so far!
Likewise, you can dial tel number from Garmin Nuvi using touch screen or voice command, if so equipped.
Not sure if the same applies for VW Jetta BlueTooth/nav/radio display application. I don't have that option in my 09 Jetta Wagon.
no clue on interfacing a garmin portable as I don't have one. But curious if those have an output port and what it would be. as noted in the post above, they run on BT, right?
Would the Audi cost more to repair?
Sebring95 has the right idea, don't buy one unless they make it AWD.
While the robotics (from Japan) on the assembly lines (that tighten the screws) are calibrated to the same torque, some people think it's assembled better in Germany by Germans. But if you visit the assembly plant in Ingolstadt there are not that many "Germans" doing the work...
Like it's said above, it costs more for parts and repairs in this country. Resale value still suffers from setback few years back with unintended acceleration. Some experts in this field claim Audi still did not fully recover from that setback.
Think of Audi as what Acura is to Honda, Lexus to Toyota or Infinity to Nissan. You are paying for the brand.
While it's a fine automobile (I have owned a few myself) it makes more sense (financially) to get a VW. VW also has more service authorized centers in the U.S. than Audi.
I'm glad to see that that VW has made this easier to do in the 09 wagons, but that doesn't help me.
Now if they would re-design the headlight assembly so that one doesn't have to take the front bumper off, that would help. Right now, as is, you have to take the front bumper off to get to 2 screws that hold front headlight assembly, what a chore!
Test drove a '10 TDI Sportwagen today - I specifically asked if the engine use a timing belt or chain, and the salesman said "chain, requires no maintenance." I know that was true with my old '97 Altima, but an 8-point buck killed it a few days ago at 231K so I'll never know just how far it will go. Anyhow, a few questions for current owners:
1- is that timing chain really "no maintenance", or does the VW service manual call for service/replacement at some point?
2- I've noticed some posts regarding sceduled maintenance visits - am I lining myself up for some high-dollar visits to the dealership with this car that I wouldn't with garden-variety gas engine cars?
3- test drove a wagen with the panoramic roof - wasn't planning on getting that option but now I like it. Any experience with wind noise or water leak issues out there regarding that roof?
4 - Anyone have the cornsilk interior, and notice a lot of scuffing or dirt issues?
Thanks for any help
I've found over the past five years that TDI maintenance has been less expensive than for previous cars with gas engines. Of, course, the maintenance costs for gassers may have decreased over the past five years, too.
Replaced VW ill-designed wind mesh deflector with plastic wind deflector. Not sure if 2010 has the same design though.
Scheduled maintenance is free for the first 3 years/36,000 miles - at least on 09 it is!
To my knowledge the '10 also has free schedule maintenance through 36,000, but I saw a prior post where an owner was concerned with the 40K visit and its cost.
