Acura RDX
1192022242555
    Sounds like it'll be the first sporty/premium compact SUV from an Asian brand. The Vue Redline and Forester XT have resided a little lower in the segment, and the X3 and FX a little higher.
    Let's see how it sells. I bet it does pretty well. The MDX is bigger than most people need, and probably not as fun.
    Did you like the new MDX concept, varmint? The grille is a bit bold, almost VW-like, but it almost looks like a negative of what the grille should be. Also, while the family resemblance is strong, it almost looks more like a Mazda. But I guess this will be Acura's new look?
    Profile looks great. I see some Infiniti FX in there, but in a good way. I also like the rear, and the fact that they didn't play it too "safe".
    -juice
  • 2moreyears2moreyears Member Posts: 14
    Thank you Acura, you have truely made a beautiful car. I still dont love the dash, but I'll live.
  • kyfdxkyfdx Moderator Posts: 270,651
    I wouldn't consider the RDX significantly more powerful than the X3.. The 3.0 litre six in the X3 has 225 HP.. I wouldn't bet against it, in a drag race...
    Plus, when the '07 comes out, it will likely have the new 3.0 litre six that is in the 330i.. 255 HP..
    I do agree... they will definitely be competitors.. Can't say the last time I saw an X3 towing anything..
  • jchan2jchan2 Member Posts: 4,956
    I like it. :)
    I don't think I said that...was that someone else?
    Any how, the X3 isn't slow, but it does hesitate a bit off the line. There's a lot of mass to get going. Even factoring in (very minor) turbo lag, the Forester XT is a lot quicker.
    -juice
    I think the BMW X3 will be the main target for the RDX. If you check the spec sheet, you will see the X3 can tow 3500.
    http://www.bmwusa.com/vehicles/X3/30i/techdata.htm
    Now it may be true that most folks won't tow with an RDX, but for those looking at this type of vehicle—and who do tow, I'd suggest they look elsewhere.
    Bob
  • ralston1ralston1 Member Posts: 28
    I just received the production brochures for the RDX at my dealership. The RDX will have two trim levels; Premium and a Tech Package. Both vehicles will have 240-hp, 260 ft/lbs. of torque, SH-AWD, Sport Shift 5-speed automatic with paddle shifters, VSA, ACE and dual climate control.
    The Tech Package will add Navigation with Voice Recognition, ELS sound with 10-speaker surround, Hands Free Link ( Bluetooth Handsfree ), Acura Link with real-time traffic and solar sensing climate control.
    Check your local dealer and see if they have received the new brochures.
  • helmutrothhelmutroth Member Posts: 15
    Is there a 0-60 figure in the brochure?
  • robertsmxrobertsmx Member Posts: 5,525
    I expect low to mid 7 seconds.
    What'll be in the Premium package? Leather, or is that standard?
    -juice
    If th dealers are getting brochures, the cars must not be far off.
    Bob
    That's why I'm surprised the "Element Concept" wasn't something new.
    -juice
  • la4meadla4mead Member Posts: 347
    Ahh, but for the folks who do occasionally tow, the RX, like many others in the upscale compact crossover class, is available with a much higher tow rating, and includes "tow package" upgrades like the larger radiator. I thought the rating was at least 3500#, I didn't look it up.
    The upgrades cost little as a factory package (used to be standard, but are included on nearly every vehicle sold), and even if you never tow, increase the powertrain's cooling performance at the very least.
    It does tip the scales a bit, when you are already considering a "crossover" instead of a wagon or a truck.
    For me, the X3 fits a slightly different niche (prestige of BMW), and Acura may catch a percentage of those considering one, but many folks who really want a BMW will still likely still want one. Some will like the RDX better, but some will still want the all-out performance and badge at the cost of some of the things the aisians do so well. So Acura sets it's sights high competing with the X3, however most competition will come from other makes and models.
    "I wouldn't consider the RDX significantly more powerful than the X3.. The 3.0 litre six in the X3 has 225 HP.. I wouldn't bet against it, in a drag race..."
    225 vs 240 is borderline significant in terms of hp. It take more than a little tweak here and there to get a gain like that. Remember, when this line of discussion was started we were talking about fuel economy, not acceleration. Acceleration requires things like gearing, wheel size, weight, etc. I'm comparing output alone. Which in the RDX amounts to 46 lb-ft of a difference when you look at the other measure. That is significant.
    The point being the K23 is a hard-working little block. Hence the modest fuel economy.
  • karlzunikarlzuni Member Posts: 20
    Leather is standard. See link for standard features and optional package.
    http://www.hondanews.com/catID3092?mid=2006041234841&mime=asc
    Any price guess? I'm thinking $32,000 base and $37,000 with the Tech package. :confuse:
    The upcoming Ford Edge with similar equipment prices at around $32,000. Would think an Acura would cost as much as a Ford.
    Standard towing in RX was 1500 lb. If towing is a "necessity" you would assume more would be standard, but it isn't. Is Acura targeting everybody and anybody with RDX? I don't think so. In fact, I see RDX and MDX duo like I see TSX and TL. The latter being the higher volume vehicle, and former being a smaller, less expensive, sportier alternative.
    As for X3... I don't see many of those around. See more X5 though. So, I hope Acura does better than BMW has, whether or not Acura develops an appeal for badge chasers that typically would go buy a BMW.
    Gotta feeling we might need a new thread for this topic.
    The TL vs TSX is probably a good parallel. I do wish the RDX had a little more utility, but it is positioned as the performance SUV not the family hauler. Reps at NY claimed the new MDX will not be getting significantly larger. Just a little wider. So, it will remain the utility player.
    Acura claims the RDX will accelerate faster than the X3. We shall see. The Acura has more torque to move the weight and gearing is much, much shorter (at least for the auto). That said, BMW has some magic pixie dust for problems like that and they are upgrading the engine soon. BMW also deserves respect for their suspension tuning, but I've got a feeling the +2" track of the RDX, slightly lower curb weight, and SH-AWD may be enough to give it the edge. I doubt the ride of the RDX will be has harsh as the X3. Let's just hope Acura got the steering and tires right.
    Robert - Sales for the X3 are pretty much a match for sales of the X5. Neither one is going to set the world on fire. They do 2.5 to 4K units each month. I figure Acura will match that and the MDX will continue to sell in higher volume. (BMW doesn't need the high volume as their profit margins are huge.)
  • autoboy16autoboy16 Member Posts: 992
    :) I like the rdx but not to be offensive or rude you people are like many others who often forget all the other suvs that have power, competitive prices, and some that offer other engine choices.
    These include the:
    2007 Mazda CX-7 Grand Touring 4dr SUV AWD* (2.3L 4cyl Turbo 6A)
    hp: 244 hp @ 5000 rpm
    torque: 258 ft-lbs. @ 2500 rpm
    MSRP: $28,000
    2006 Mitsubishi Endeavor
    Limited 4dr SUV AWD (3.8L 6cyl 4A)
    hp: 225 hp @ 5000 rpm
    torque: 255 ft-lbs. @ 3750 rpm
    MSRP: $32,299
    2006 Infiniti FX35 4dr SUV AWD* (3.5L 6cyl** 5A)
    hp: 280 hp @ 6200 rpm
    torque: 270 ft-lbs. @ 4800 rpm
    MSRP: $39,300
    and the 2006 Volkswagen Touareg
    V6 4dr SUV AWD (3.2L 6cyl** 6A)
    hp: 240 hp @ 6000 rpm
    torque: 229 ft-lbs. @ 3200 rpm
    MSRP: $37,410
    For the record is now the 2006 RX330 is now
    2007 Lexus RX 350 4dr SUV AWD* (3.5L 6cyl 5A)
    hp: 270 hp @ 6200 rpm
    torque: 251 ft-lbs. @ 4700 rpm
    MSRP: $38,800
    The Mazda and the RDX both have 4cylinders but in my opinion the mazda is the better deal because of its lower price so far. :mad: IT IS MY OPINION and i'm just trying to remind you about the other choices and what may be a good comparison in the future.
    This information came from the edmunds.com new car comparison. All interested in what i said... :confuse: wrote should check it out. Remember these are a few of the many overlooked vehicles today :) .
    * other drive train option available
    ** offer v8 engine
    I predict RD-x's msrp to be slotted between the tsx and tl sedans
    That would put a base price in the $31,000 range, right?
    At that price Acura could sell a lot of these...
    more like tsx competetors (is250, c230, a4) $29,995 -destination and 3t. But it'll be advertised for being under 30k! ha thats what they all say :mad:! When have you seen a new 29k lexus? But hey, no doubt they'll sell a lot. btw expect to see them priced around 1k over sticker :sick: .
    Anyone know if the rear window opens? Flips or lowers. I was surprised to see that the new Toyota Rav4 rear window does not open.
    Nope, it is all one unit. It is effortless in function as well. Probably counterbalanced somewhere in there.
    BTW, I was in NY on Saturday. Gotta say I am not too thrilled with the little RDX. Interior is catchy, and built well. The exterior is built extremely well. The styling is kinda "Eh" though. It looks like its got a bit too much junk in the trunk IMO. And the new MDX is quite similar in appearance. In person, I could barely tell the two of them apart aside from the size difference.
    On a side not, the Maxda CX is so, so, so bland :(
    Point taken, but when you start to stretch comparisons between classes, you muddy the waters and bring different buying preferences into play.
    The RDX is rumored to run 32-27K at MSRP. Several of those other rigs you mentioned are mid-size rigs which, at 37-38K, are stripped (relative to a luxury class vehicle). They will have things like a single disk CD players, cloth or faux leather seats, no moonroof, and such. Meanwhile, an RDX at $37K is going to have an ELS stereo, a top-notch NAV, leather, moonroof, etc.
    Do you think those extras are worth the extra money? Maybe... Maybe not... But if you don't want them, you are just as well off buying a loaded up Tribeca, Pilot, or Highlander and staying away from the luxury vehicles. Heck, a WRX wagon will perform better than an RDX or X3. If all you want is a single-purpose performance vehicle, that's the way to go. But if you want performance AND style AND comfort, you're going to have to pay.
    And, for the record, just because a vehicle has power does not mean it can perform. That V6 Touareg you mentioned weighs in at about 5,000 lbs. The V6 is notorious for being a dog.
  • bodble2bodble2 Member Posts: 4,514
    Did anyone notice the low clearance sited? The minimum ground clearance is not much more than that of a regular sedan! From that perspective, why bother with a SUV, or SAV, cross-over, whatever they want to call it? Just get a AWD sedan or wagon, and get better mileage and handling.
    I agree entirely... As exciting as all the new technology is, without the ability to tow much of anything (preliminary RDX tow rating, no factory "tow package") and without significant fuel economy gains from the turbocharged 4, I again ask myself where is that awesome international sleek Accord wagon - the one we don't get in the US on the TSX platform ?
    I'd love one of those with a manual transmission, and just use a truck for towing when I need to. Forget combining them into one hulk of an everyday car like an SUV, let's save some fuel and have more fun on the drive.
    This is the same recipe used for vehicles like the X5 and FX35. Both are what I like to call the hatchbacks of the SUV world. It would appear the RDX is just a smaller, less expensive version of that same design paradigm.
    Personally, I prefer the more balanced approach Acura took with the MDX. It provides a decent amount of ground clearance for getting through the rough stuff, enough towing capacity to handle sporting equipment, and more than enough cargo space inside. Yet it can still be pushed a bit when you want to make the trip from A to B a little more interesting.
    That said, I cannot fault Acura for taking this route with the RDX. I mean, half the market has been complaining that Acura doesn't provide something sporty enough. With all the whining about V8s, RWD, and bland styling you'd think people would welcome a vehicle a little more dedicated to performance and style. Instead, we're hearing from the other half of the market who appreciates the utility and functionality of Acura's current designs. They're never going to make everyone happy.
  • knvmdxknvmdx Member Posts: 8
    This may not be the place to ask, but all of you seem very knowledgeable about the MDX. What is the difference between the MDX and the Honda Pilot, with respect to the engine? Are they the same? Also is there anything different about the suspension. Does the MDX have a smoother ride? Your advice is most appreciated as I am in the look out for a MDX. I don’t want to pay more for a MDX if I can get the same with a Pilot.
    They had one, open too. It was way, way back in the far corner of the show, so it wasn't getting a lot of attention while we were there.
    More surprising, the MDX Concept was close by and when we walked by that not a single person was looking at it. Strange. :confuse:
    My reaction was a bit mixed.
    I liked the styling better in person. What seems a bit busy in photos makes more sense up in person. The MDX Concept was close to it and bears a strong family resemblance, so the look starts to make more sense.
    Detail - there are fewer seams than in some competitors, the MDX is the same way. The rear door covers all the way to the rear wheel well, so no seam there, it just looks cleaner that way.
    The rims look beefy, I liked those.
    There are too many labels on the back, it says "Acura" on the left, "RDX" on the right, "Turbo" below that, and then "SH-AWD" in small letters at the top of the bumper. Delete those last two. Turbo is the only way they come, and AWD is standard, plus the SH-AWD acronym just sounds dumb.
    The grille insert is cheap and plasticky. A simple black mesh grille (even chrome) made of metal would have worked better. We also saw the CX7 and the front end was just better sorted.
    Inside, the front seats are wonderfully shaped. The leather resembles vinyl a bit too much, but I guess it should be durable. They are very comfy, a bit wide for taking the corners.
    Some of the "pluminum" trim is painted plastic, including the stuff on the doors and steering wheel. Those feel more Honda than Acura, but it does have 3 proper spokes and a nice, wide arm rest (which could be more padded, same for the elbow rests on the doors).
    One sore spot was visibility, the D-pillar is wide and that rear quarter window is tiny. Top it off, if you raise the rear head rests those block what little view you might have had to those blind spots. Just get the NAV with the rearview camera if you ever plan on backing up, and be careful changing lanes to the right.
    The rear seat was only moderately roomy. More space than in a Forester, but not much. And that came at the cost of the cargo floor length, which seemed small. That plus the angle of the hatch eats in a bit. It's better than in an FX35, but a lot less useful room than in boxy alternatives.
    In fairness, it is roomier than the CX7. Mazda had one of those so we looked at both closely. It does seem more upscale, comfortable. Compared to an X3 it didn't seem as tall and airy, but it's a lot more high-tech and potentially more fun.
    I think that the driving experience is what is going to make or break this vehicle. A CR-V is a lot more practical, acres more rear seat room and more versatile in the cargo area as well. Same towing, too. This interior was nicer but that alone would not be enough to sell people. A 166hp base engine model would flop, IMO. It needs the turbo.
    So my opinion didn't really go up or down much. It's a little smaller than I expected, but the seats and styling sort of make up for that. I'll probably be looking at something a tad larger.
    -juice
  • stldonstldon Member Posts: 21
    Could you elaborate on your comparison to the CX7? Granted we don't know how the vehicles will be priced, but based upon what the grapevine is saying, will the RD-X be worth the premium?
    I shared impressions of the CX7 in that thread, but sure, let's compare.
    The CX7 is actually even more cozy, with even less space. I personally prefer the styling of the Mazda, very muscular and purposeful, with fewer overdone details like the RD-X had.
    Inside, though, my vote would go to the Acura. Both had rear seat cushions that were too low, but the CX7 felt like a 4 seater, while the RD-X could probably hold 5 in a pinch. I have a nanny that would occupy that 5th seat, so to me the difference is significant.
    Close call, and the driving experience would sway me either way overall.
    -juice
    I would just walk pass both and get the X3. But with crude at $70 a barrel...I should just walk right over to the Fit. ;)
    The RD-X may not be as upscale as the photos would suggest. A couple of telling omissions --- no memory seats, and still no fully-automated light control.
    I was with juice, and we both sat inside the RDX at NY.
    I thought it had pretty good legroom in the rear, but I sure wouldn't want to sit three-across back there.
    One thing I was surprised about was that there was a lot of scuffing (plastic) on the top of dashboard and around the lower edges of the doors (from feet). It could be that it was just because it was an abused show vehicle, but it also suggests that over time this is what an owner might expect.
    The interior was gray, and was okay, but nothing more. I certainly wasn't blown away by the interior, either in terms of features, styling or quality.
    Bob
    I pretty much racked that up to it being a pre-production model, but you're right. The wear was absolutely horrific, completely unacceptable. When that guy ran his finger nails over the plastic it scuffed permanently, and he wasn't even digging in.
    My Forester is 9 years old and doesn't have 1/10th that many scratch marks.
    I'm sure the production plastics will be better, they had better be. Elements had an issue with the cladding getting easily scratched, so hopefully they'll sort that out before production.
    The X3 is a little more upright, airy. It seems to have a bigger greenhouse and more headroom, but it isn't really usefully roomier. First year models had an unbearably stiff ride but I've heard they're better now, I dunno.
    -juice
    I spent a little time in an X3 last night. Just puttering around inside it. Looking at the numbers, I was surprised by a few things.
    The RDX and X3 are about the same overall width, even though the RDX has a 1.5 - 2" wider track. According to the spec sheets, the X3 has more hip room, yet it's short on shoulder room. Head room is a toss-up. Without a moonroof, the X3 has slightly more than the RDX. With the glass on top, the X3 has slightly less. The RDX has a slight advantage in measured legroom. Oddly enough, all of the above is true in both the front and rear seats.
    As is often the case, measurements like these do not tell the whole story. But it'll be interesting to see how the RDX stacks up.
    Sitting in the BMW, I felt pretty comfortable. The leather is thick, durable, and comfy. Unfortunately, the dash materials are more durable than luxurious. I'm pretty sure nobody is going to scratch the dash on an X3. On the flip side, the texture reminded me of the underside of a rubber floor mat. Maybe it's a personal thing, but it seemed more fitting for an Xterra.
    "What is the difference between the MDX and the Honda Pilot, with respect to the engine? Are they the same?"
    They are the same basic engine. Both use the J35 engine block, which is simply an enlarged version of the engine in the Accord (3.0) and Acura TL (3.2). The same 3.5 liter block is also used in the Odyssey, Ridgeline, and newest Acura RL.
    The difference is how the engine is tuned. Acura has the engine beefed up a little bit to provide more horsepower in the MDX.
    As for the suspension, the MDX is tuned for sportier driving and will actually be stiffer as a result. So, if smooth is the thing you are after, get the Pilot. However, the MDX will suffer less body roll in the turns and generally feels a bit lighter on its feet.
    Hope that helps.
    Agreed.
    Are we allowed to agree? I just felt the earth tremble. :surprise:
    I don't think the X3's seats are as low to the ground, at least that's not something I recall from sitting in one, and that's the type of thing I look for. Both the CX7 and RDX has the rear seat cushions a bit low (and short on thigh support).
    Acura may have done that to allow for more headroom, but you end up sitting with your knees splayed out a bit.
    You know what's funny? I was more impressed, astonished, really, about how much room was in the Fit. Tremendous leg room in the front and rear, plenty of passenger space. I liked it overall better than the Civic.
    -juice
    "Acura has the engine beefed up a little bit to provide more horsepower in the MDX."
    Not much difference in on-the-road performance though.
  • hladyhlady Member Posts: 2
    You guys that saw this vehicle in person, is it going to be worth the $45,000 or so they are going to sell for up here in Canada, or should one be looking for something else? Haves any colors, both exterior or interior been seen? Is it true the passenger seat is a manual adjust?
    Whether it's going to be worth it is a tough question. One way to look at it is to first ask if that's the type of vehicle you want. If so, then what else is comparable? It appears that the RDX will slot in between a fully-loaded RAV4, and a moderately-equipped X3 2.5, comparing it to others in that size category. I think it will seem like a good value compared to the X3.
    Well, if you're the type of person that would pick a TSX over an Accord V6, even though it costs more and has less power and space, then you might prefer the RDX as well.
    It's hard to answer that without driving it. The interior alone is not enough to justify the cost, IMO, on paper.
    But if it's the most fun you can have in a SUV, then sure, it would be worth it. On the road is what counts.
    For instance, this is why a Miata costs more than a Mazda3s.
    -juice
  • navigator89navigator89 Member Posts: 1,080
    I don't recall the window tint being nearly that dark. They were tinted, but in the video the windows almost look limo-dark.
    Looks good in Black. The only thing is that makes the plasti-chrome grille stick out more, so I'd go with Silver.
    Not sure why Acura needs that i-Drive like controller for the NAV. Why don't they make it touch screen?
    You could point it in 8 directions, but it did not spin like an iDrive controller does. You can push it in but it doesn't click as naturally as BMW's button.
    Ditch it and go voice-controlled and touch-screen.
    -juice
  • clarence10clarence10 Member Posts: 57
    If there is a new MDX model coming out, does that mean that there is a new Pilot coming out?
    Yes, but not for another year or so. The MDX bows at the very end of this year. I expect the Pilot will follow 8-14 months later.
    "Ditch it and go voice-controlled and touch-screen."
    It is voice-controlled.
    Touch screens have their advantages in terms of selecting from menus. The downside is the textured surface they use degrades clarity. If you don't use a textured surface, the screen gets all smudged up with fingerprints (degrading clarity).
    I meant use voice controls (and/or touch-screen) exclusively. Deleting that knob would really clean up the dash.
    My Garmin does end up with finger prints, but it never really gets that bad.
    The MDX in NY was just a concept. We'll see how close it is to production, though it seems much closer than the RD-X concept was (side mirrors, for instance).
    -juice
    Check this out:
    mack9, "Mystery car pix...." #6333, 20 Apr 2006 8:11 pm
    My guess is that's an MDX test mule. The rims match the MDX concept's and it seems about that size.
    Some folks say RDX or even CR-V, what do you think?
    -juice
    This is something that creeps into my brain every now and then. I think it represents something of a missed opportunity for Honda/Acura. Given that this RDX is supposed to be a sport SUV, it would have been a nice touch if they had added the push-button ignition from the S2000. (I think the Si could use this, too.) If they're going to have a vehicle like the S2000 serve as a performance halo, then they should steal little bits and pieces from the design and spread them around. And I think the starter would be a relatively simple way to do that.
