Personally I take my two Hyundais to the dealer for oil changes. It usually costs less than $20 with a coupon. And if anything goes wrong, e.g. stripped threads on the oil pan or loose oil filter or whatever, we all know exactly who is at fault. And they wash the car for me if I want them to.
cheers
What are peoples real life experiences with MPG's? I would be satisified with 30 MPG consistantly over the highway.
1. When backing out in reverse and then going into drive after about 2 seconds the vehicle makes a small clunking sound that can be felt in the gas pedal and barely heard. You have to have the radio off and it has to be quit but it is defintely there. Anyone have this?
2. I have the grey interior and now the hard grey plastic on the doors are showing weird light spots. I have one large one on the door and then you can see a bunch of small ones through out the doors. I've never even put anything on the doors, armor all, etc. Is this something the dealership should take care of?
If anyone has some input I would appreciate. Thanks.
If you drive 20K per year and average 30 MPG, that's 666 gallons; 34 MPG would be 590 gallons. If you assume $3/ gallon (hopefully that's high), the 6 cyl would cost $228 more per year for gas.
Under the Moss-Magnusen Act, you or your choice of mechanic are permitted to carry out the routine service without jeopardizing your warranty rights. (Prior to Moss-Magnusen, Ford and GM made it policy to require that their respective dealers carry out all maintenance to maintain the factory warranties. Congress in a rare display of intelligence finally stepped in and put the kabosh on that.) If you do your own maintenance (oil and filter changes, for instance) your only requirement is to keep the receipts for the materials (oil and filter), and log each service. Dated receipts and a handwritten log are considered by the courts as sufficient evidence for having actually done the required service, so unless the manufacturer can prove otherwise (fraud), you're in safe territory. (Since fraud is a crime, the burden of proof on the manufacturer would be "beyond a reasonable doubt" - jury trial, a unanimous finding by the jury; in other words the whole Perry Mason schmear that the manufacturer isn't likely to contest unless it's very confident.) Aftermarket oil filters are perfectly alright. Just stick with filters of recognized brand and reputation - Purolator, FRAM, Motorcraft, AC, WIX, Baldwin, Quaker State, Pennzoil, etc. Any motor oil of the recommended viscosity for your climate condtions and wearing the API "sunburst seal" on the front label, as well as current service spec. (API "SM" and ILSAC "GF-4") will meet Hyundai's requirements. There's nothing magic about the oil Hyundai dealers use. Hyundai oil filters are very well made and designed, but, again there's nothing magic about them. For the time being though, since Hyundai went to a new drop-in canister-type oil filter on the new Sonata 4 and 6 cylinder motors, your only source for filters will probably be Hyundai dealers until the independents ramp up production of equivalents. (Hyundai's not the only engine manufacturer going "back" to this type of filter, by the way. GM, Mercedes-Benz, BMW, and others have recently or already for years used them.)
If you plan to change the transmission fluid periodically yourself, Hyundai does currently have you over a barrel. The ONLY approved ATF for Hyundai automatics is "SP III". It's a proprietary Mitsubishi fluid and only available in North America through Mitsubishi (duhhh!), Hyundai, and KIA dealerships. Mitsubishi has NOT released the forumula and additive compounding for this fluid, nor licensed its production to other than Hyundai and its assignees. (Hyundai and KIA SP III are apparently blended and bottled by ConocoPhillips, though that company is contractually prohibited from selling it through normal retail channels.) If you come across any of the aftermarket brands whose "universal" ATFs purport equivalancy to SP III, you ARE risking warranty invalidation. Those ATFs are only their respective manufacturers' best guess at equivalancy.
John
On question #1, this sounds like the anti-lock brake self test. If you look under all the other car forums, everyone always asks about this. My 04 Accord Does it and my 03 Infiniti did it.
Has anyone tried rubbing these mystery spots out with some terrycloth wet with a mild soapy solution? These spots might be from leftover mold release compound. Just a thought...
I had a few scratches that were present upon delivery, but I did not have the time to address them until almost 2 months later. I would think some dealerships would say, "Whoa, you had this car for that long and you expect us to believe WE did this?" Not Hyundai! They took care of it no questions asked. Not the crappy touch-up pen either....they had an airbrush guy blend it in real nice. I hope you have a similar experience. Please keep us posted!
Hyundai just as you don't want a bad product out there because it could hurt their business, too many companies competing for you $$$. The ford Five hundred currently have a defective part that doesn't have a fix 2+ months later.
The repair looks like a quick fix by changing the brace but wanted to make sure that this wasn't an isolated problem. If this is a wide spread issue we need to make Hyundai aware. I don't want to be replacing seat covers every 10k miles.
I want Hyundai to work out the acceleration delay when one steps on the gas pedal and the car doesn't respond for a few seconds. (This has been mentioned much earlier in these discussions and everyone sort of stopped mentioning it. I noticed it when I test drove the 4 cyl automatic. A few others piped in that they, too, experienced it.)
Regardless whether the accelerator is computer controlled or not, I would expect 'instantaneous' response, not delayed response.
I'm hoping Hyundai will work this out, as well as all the other things I mentioned, and also the other points the rest of you are bringing up (e.g. spots on the plastic; no lumbar or seat controls; brake issues; paint issues; rattles; etc.)
Whether the car is a $20,000 car or a $40,000 car, it's still a fair chunk of change, and for almost 25 large, one expects quality across the board. (We're not talking a $7,000 car...) At least I expect the car to be five stars on all fronts, and I don't think that's asking or expecting too much.
Are my requests too high? Must we all simply lower our expectations? Or is it reasonable to expect all these issues will be worked out (correctly) by Sept 2006?
I have owned several Hondas, inlcuding 2 Accords. After shopping around an comparing several cars, I purchased a 2006 Sonata LX. I am amazed by this car. Certainly, from my analysis, it is far superior to the competion on a price-dependent basis. Moreover, I actually prefer it on a price-independent basis.
The issues that impressed me:
engine: as good as a Honda - which is as good as it gets. The Sonata V6 is very refined, with good power and torque across the rev band. It has that ripping smoothness at high rmp that only the finest engines produce. It is interesting to note that this engine produces more power and torque that the 3.0 liter engine in the new BMW 325i.
exterior styling: of course this is subjective, but.... I really like it. I think that Hyundai has developed a strong lookinig car, with nice design elements that integrate well. Certainly, there are styling elements from other cars, but that is not unusual. In fact, it is difficult to find any car that does not have design elements that are similar to others. I find that the Sonata's design is more independent than many other current cars.
interior styling: I think that the interior works well and looks good. The material choices and the layout of the dash, door panels, seats and console are quite nice. I particularly like the faux carbon fiber treatment that comes with the gray interior. (I am not a fan of glossy wood on car interiors).
suspension: competent but a little soft for my tastes. The car has a complian suspension that seems better in the LX than on the other models. Part of this is the tires.
quality: the Sonata has the highest quality of any car I have owned. One example is the exterior panel gaps. These are as straight as my two Mercedes and the gap is smaller. (also better than a Camry, Accord or Infinity). The fit and finish of the interior trim is also excellent.
overall: an impressive car that puts Hyundai into the top leagues of auto manufactureres. I think that this is a breakthrough car.
TEAShea
#229 of 460 Re: Long term test [backy] by teashea Oct 13, 2005 (1:49 pm)
We cross shopped the Sonata with the Accord, Camry, Mazda 6, Altima, Fusion, Maxima, and Avalon. What sold us on the Sonata was safety, engine power, features, size (passenger and trunk), warranty, value, and build quality. While each of the competitors had advantages and positive qualities, the Sonata had the best mix for our needs and wants. We don't make large purchase decisions quickly or without a lot of consideration, and in the end after multiple test drives of each car, the Sonata was the best pick for us.
I'll readily admit to being a Hyundai convert. I've been a strong supporter of Honda and Toyota, having owned many vehicles from each and convinced others to do the same, but Hyundai has blown me away with the new Sonata and Santa Fe. I wouldn't have given Hyundai a second thought a year ago, and now I find myself an owner. And a happy one at that.
-Ty
2. Try some WD40 on those spots. I think Hyundai has some issues with delivering a car with "clean" interior plastics, and the dealers aren't catching this like they should be (or they aren't using the right cleaner to remove it). I've had two 06 Sonatas (the first was the wrong trim level for the lease I'm in, so the dealer had me bring it back), and both had issues with the "smudge" showing up on the hard plastic door handles. WD40 helped remove the residue, and then I used some regular mild cleanser to remove the WD40. Try it and let us know if that helped fix the problem.
The smaller Honda V6 generates more power.
I guess that depends on how you measure power. The Honda 3.0L does put out 9 more HP, but the Hyundai 3.3L puts out 15 ft-lbs more torque.
In rear-world driving, I really couldn't discern any significant performance difference between the two power plants. When they're that close in figures, then you have to start looking at HOW the power is transferred to the wheels and WHEN it's available in the RPM range. For me it was a wash between the Accord and Sonata.
I agree with tbear, I think Honda has produced some of the best I4 and V6 engines around. I'm amazed Hyundai has come so far so quickly with their power plants, and can now successfully compete in power and gas mileage with the very best. It's a tribute to both companies how good these engines actually are.
Peak Horsepower at RPM 235@6000 244@6250
Peak Torque at RPM 226@3500 211@5000
The Sonata has not only a higher torque peak, but at a much lower rpm than the Honda. So, if both cars are being driven at that same lower rpm, the Sonata should have much more power unless the transmission downshifts.
The 2006 (GLS I think) is a completely different car; enough power to almost run with my wife's Altima 3.5, decent mileage (26 mpg, 600 miles 85% highway), smoother ride, competent handling and reasonably quiet. A good driving car. Think that the interior needs upgrading, this one was cloth seats, moonroof, hard plastics, and some sort of glossy imitation walnut that looked something from another planet. Exterior styling on the other hand - really a good looking sedan and that trunk is large enough to swallow almost anything!
It appears that this car stickers for something a little over $22k, maybe 4 or 5 grand or so less than the Altima/Accord/Camry trio similarily equipped - a really fine value and now a really decent car - if only they could do something about that Korean car perception that keeps the resale value so low.
John
Therefore, I'm asking the advice of any of you who own this particular car. Certainly the price is right for all that your getting and the warranty is great. But is it as good as what I heard. I have not driven it as yet. Would appreciate any feedback.
No issues with the car since I took delivery - in fact, I'm going back to the dealer for the first time tomorrow - for an oil change.
If anything could be better in my mind it would be the mileage on the V6. I drive about 50 miles per day, 10 of which I'd consider city, and I'm averaging about 22-23 mpg, driving 65 mph once I hit the hwy. Not bad, but not what I'd expect given that driving mix (I think they advertise 20city 30 hwy). The good news, however, is that it seems to be improving with each fillup. Lots of discussion on this topic here if you search.
Hope that helps.
Love the automatic temperature contol!
Actually, a superficial analysis. Neither car is putting out much over 20 hp at legal cruising speed. The bigger Hyundai motor delivers higher torque, but the Sonata's final drive ratio is also "taller" than that of the Honda. (Consequently the Hyundai motor revs at a slightly lower speed at any given road speed than the Honda motor does.) Other than C&D's test, the 0-60 and quarter mile posted acceleration times run by other publications of the new Sonata are no better, and in some cases ever so slightly worse than the Accord with V6 power & A/T. The differences are sufficiently minor that it's pretty much a standoff, though the Accord seems to return slighly better fuel economy (32+ mpg). But, then Honda's forte has traditionally been efficiency, so no surprise there. Racing experience does improve the breed.
As far as mileage claims it's been my experience that the average driver will get no where near what themanufacturer says on any car..
My next move is a test drive and if it's all you and the others say it is, I'm buying.
problem. If you took your foot off the accelerator at 20-40 mph, there
was a noticeable vibration in the steering wheel. I even had the salesman
drive the car, and I felt it in the passenger seat, and he definitely felt it.
He said he would have service department look at it. I wouldn't consider
this car if it is not fixed, as I had a car like this once, and it drove me crazy,
with about 20 visits to the dealer, and finally giving up.
Has anyone else had this problem, and if so, what was the explanation if fixed?
Could you please elaborate on the paint flaw your car had, and how the dealer took care of it. I have a Golden Beige LX, and there is a 2 inch circular patch of paint flaw above rear door handle. Its just lack of clear coat, and no paint flaw as such, but it is visible from an angle. I noticed it as soon as I bought the car, but didn't have time to take it to the dealer. Thought I will present this when I take it for the first oil change. My car is now 2 and half months, and 2500 miles old.
Kri
My point is that the Sonata has its torque peak at an RPM level which is much more often the level from which normal drivers will want strong acceleration. Not many of us will be driving along at 5000 RPM and then want to accelerate strongly up to redline at 6000 or 6200. More likely, at 2500 or 3500, a driver will want to accelerate briskly and if more torque is available in one car than the other at that rpm, then that first car will feel peppier.
That said, I agree with you that in a drag race, gas pedal to the floor, the two cars are pretty equal. But I was never arguing about drag racing. No argument either about Honda making great motors.
Nice comparable cars. MSRP Sonata LX /Accord EX: $22,895 $27,300. Comparable, but the EPA says Sonata is large and Accord mid-sized.
At their torque peaks, the Sonata is making 151 horsepower at 3500 RPM, the Accord 201 hp at 5000 RPM. Without seeing the torque curves relative to RPM it is hard to directly compare the motors' horsepower outputs at other RPM levels. Generally though, the Honda is a rev-happy motor which has more pull at higher rpms and less grunt at lower RPM, compared to the Hyundai which has better pull at lower rpms but runs out of breath as RPM approach redline. So it should be expected that from normal cruising speeds and/or middle of the range RPM levels, the Sonata would feel stronger so long as the transmission does not downshift while accelerating.
The overall gear ratios of the 2 cars are different to take advantage of the efficiency and torque characteristics of each motor. And the difference in ratios is not much.
I'm curious, what torque and rpm figures are you using to calculate the horsepower output of the motors at legal cruising speed?
Fuel economy? The EPA standards show Sonata slightly better than the Accord:
EPA Mileage Estimate (Sonata vs. Accord)
Fuel Economy City 20 20
Fuel Economy Highway 30 29
Combined Fuel Economy 24 23
Sonata LX vs. Accord EX V6, both 2006 models (from the Hyundai USA website)
Peak Horsepower at RPM: 235 6000; 244 6250
Peak Torque at RPM: 226 3500; 211 5000
New paint colors, a problems fixed, ...
