Dodge Dakota Crew Cab - III
1468910
  • zonkzonk Member Posts: 208
    grad57 - saw your post about your trip to Branson in your 3.9L. Having made that drive last year, I'd like to know if you found you had sufficient power on that trip and just in general driving. I am still not sure I need all the power of the 4.7L, but don't want to make the same mistake I made with my present truck (underpowered, to me, Toyota Tacoma).
    BTW, I was on a business trip to San Francisco earlier this week and saw the free bedliner offer on TV. It seemed like it was for most Dodge Pickup models, not just Dakota QCs. But my ears perked up when I heard the QC mentioned.
  • jdoerr1jdoerr1 Member Posts: 3
    I TOOK DELIVERY OF MY 2000 QUAD IN EARLY JANUARY. AS OF TODAY IT HAS ONLY 3600 MILES ON IT AND IS ON THE 4TH BATTERY!!!! YES I SAID 4TH. ANYBODY ELSE HAVING PROBLEMS? TRUNK RUNS FINE AND PERFORMS GREAT. BATTERY SEEMS TO HAVE A DRAIN--GOES DEAD OVER NIGHT IN ABOUT 2 WEEKS. DOES ANYONE HAVE A NUMBER THAT WOULD GET ME A LIVE DODGE FACTORY REP.??? jwdsc@tisd.net Thanks
    thanks fo the number. I wikk call tomorrow. jwd
  • badassbobbadassbob Member Posts: 78
    Please tell me they have tested the charging system and electricle system for Drains before replaceing the thing 4 times....Sounds like a bell should have went off on the mechanic's head after the 2nd time.....After that its pretty safe to rule out the "fluke" of getting 2 bum batteries in a row....
    One word of advise to give you is make sure your glove compartment light is properly cutting off when the lid is shut....Had a nissan that went dead after sitting for 3 days...turns out there was a defective switch for that light....Even a small bulb like that can drain even the BIG battery in the Quad after a couple of days...
    My .02cents
    Chad
  • 146nb146nb Member Posts: 2
    Since I'm new to this I hope I haven't missed this topic before. I picked up my quad in march from dealer stock. 5.9L engine, 3.92 rear, trailer pkg, SLT. Got a question, has anyone else have a problem with vibration at about 40 MPH? My dealer told me it was the tires and so far this is the third set of NEW tires. Still has the vibration, any suggestions? TKS
    Can you feel this vibration through the floorboard, Does it change frequency when you speed up / slow down...I would think that a vibration due to tires would be present at any speed(but im not a mechanic) What is your tire pressure set at....Try upping it to around 45-50psf and see if vibration is still thereor has moved to another speed...I would think that if you up the air pressure, it would cause the tire to ride more in the center tread and not as much on the sidewall lugs(im assuming you have the 31x10.50's)
    Next---Try 40 mph in different gears..ie 40mph at different engine rpms...if its the tires, the vibration will be there at any rpm
    Next try to accelerate to 40mph, and then drop it into neutraland let off the gas...If its the tires the vibration will be there at the vehicle doing 40mph and the engine at idle speed....
    If the vibration dissapears in the above two trials then i dont think it is in the tires and something in the drivetrain is out of balance(Driveshaft, missing wheel weight, SportTrac chained to your rear bumper to get above 60mph, etc)
    Once again im no mechanic....Anyone else have anyting to add???
    CHAD
  • 2drive2drive Member Posts: 90
    Just thought I would reiterate my experience with Chrysler quality. I bought a new '84 Voyager van and to date have put 392,000 miles on the original 2.2L engine, clutch and transmission without any repairs to them. In fact, I reached 250,000 without any replacements except tires, brakes and batteries. Then over the next 50,000 miles, I replaced the original cam belt, alternator, distributor, water pump, radiator, and front struts. It still has the original rear shocks, cat and entire exhaust system. (At 300,000, it was still getting 5,000 miles on a quart of oil)
    Needless to say, I had no reservations about buying a Dakota QC.
  • themacguythemacguy Member Posts: 417
    jdoerr1 - you might try taking the truck to a Walmart (or similar) & have them 'plug it in' to their computer. As badassbob explained, it is not in the battery. And an independent source such as Walmart or better yet, a full blown auto electric shop would make mince-meat of this problem in short order. Just have them tell you what it is and get an estimate - then go to your dealer (if you must). I've had a couple of electrical gremlins in the last week, and that's what I did. Then I fixed the problem myself since I don't want the tiny things fixed with a sledgehammer. I notified Dodge afterwards and noted it in my book.
    146nb - as above you might want to try an independent tire shop, brake shop and frame shop to get a 'freebie' look at your problem before the grease monkeys at the local hodge-podge-Dodge shop get a hold of your new $25k masterpiece.
    All - that's EXACTLY what I've been doing lately. I've spent so much money with various mechanics and shops over the years (as you all have) locally, that I'm just going to specialized shops at the least little hint of a problem and getting the 'straight poop' before I show up to have something 'fixed' at the local Dodge(em) joint. The real pro mechanics remember you from past business and return the favor usually - especially since it's still under warranty now - and they know if they help you a bit here and there that they'll get your out of warranty business and referrals. It's win-win, and it works.
  • grad57grad57 Member Posts: 7
    Yes the wife and I both feel that the 3.9 has plenty of power to perform very well in general driving. It handled the hills in the Ozarks very well, is able to run the 65-70 MPH on interstates with ease and has no problem at all with steep drives at motels, malls, etc. Ours is 2WD with standard wheels and tires on the SLT. For the most part it performs exactly like our 97 Club Cab with the same equipment. Maybe if you could find a used 3.9 with auto you could test drive it to see what you thought of it for your area. Hope this well help you make the right choice for you.
  • bigal1bigal1 Member Posts: 7
    Has anyone heard about Engine upgrades for the 2001 Dodge Dakota. I read on the net somewhere, I can't remember exactly, that they were going to take the 4.7 Liter V-8 Engine and create the 3.7 Liter V-6 Engine Version of it.
    I read a whole lot about the 4.7 Liter in this session, but what about the 3.9 Liter V-6 Folks? Has anyone purchased one of these and can you give us some of your input? I'm leaning towards a V-6 since I have nothing to haul and presently I have a 4 Cylinder Engine Truck. Any V-6 would be better than the Squirrel Engine I currently possess!
    BigAl1
  • bookittybookitty Member Posts: 1,303
    BigAl1, I am not certain as to D/C producing a stepped down V-6 engine prototyped by the 4.7. The
    3.9 is a very reliable tried and true motor that has a good reliability factor. So did the flat head Ford V-8's. All g=things must be relegated to
    change. In my humble opinion, the 3.9 liter V-6 is
    marginal for usage in a vehicle the size and weight of the Quad Cab. That is compounded by the
    use of an automatic transmission which is not always as power efficient as a manual. If you add
    the chore of towing, you further "compound the felony." I had driven the Quad Cab with the V-6 (3.9)and the V-8 (4.7) in both 2X4 and 4X4 configurations. All vehicles were equipped with automatic transmission, as no 5 speeds were available. I was not too impressed with the performance of the V-6, nor was I surprised. I ended up special ordering the V-8 with a manual.
    Unfortunately, I did not take note of the gear ratio (differential) on the tested vehicle(s), but I ordered the 3.55 LSD although I tow on some
    occasions. I am extremely pleased with the performance of my Quad, and envision absolutely no
    problem with towing my lightly loaded 5X8 trailer.
    Bookitty
    stepped down V6 engine prototyped by the 4.7. The
    3.9 is a "tried and true" motor that has a good reliability factor. So did the flat head Ford V8. All things must be relegated to change. In my humble opinion, the 3.9 liter V6 is marginal for usage in a vehicle the size and weight of the Quad Cab. That is further compounded by the use of an automatic transmission which is not as power efficient as a manual. If you add the chore of towing, you "compound the felony." I had driven the Quad Cab with the V6(3.9)and the V8 (4.7) in both the 2X4 and 4X4 configuration. All vehicles were equipped with the automatic transmission, as no 5 speeds were available. I was not too impressed with the performance of the V-6, nor was I surprised. I ended up special ordering the V8 with a manual. Unfortunately, I did not take note of the gear ratio(differential) on the tested vehicle(s), but I ordered the 3.55 LSD although I tow on some occasions. I am extremely pleased with the performance of my Quad thus far, and envision absolutely no problem with towing my lightly loaded 5X8 trailer.
    Bookitty
  • gsu1gsu1 Member Posts: 43
    If you want information on the new V-6 go to this web site www.car-truck.com. This is the best DC web site I have found. From what I gather the new V-6 if for the new Jeep Cherokee and maybe down the road the Dakota.
    bookitty-load that trailer up and you still won't have any problems. Last weekend I took 4 adults, two Seedo's and all our junk to the lake. The truck seemed to beg for more. I have the 4.7 with 3.55 lsd on a 4x4.
    When you get to the web site click on the buzz.
  • towcrazy2towcrazy2 Member Posts: 337
    Just a quick note of agreement with BOO on the 3.9's capability in a Quad. It's a GREAT engine for around town stuff, but we must remember that the Quad is a HEAVY truck!
    Curb weight on the QC is about 300 lbs. less than my standard-cab, shortbed Ram... Not a lot of difference there!!!
    Just received the Westin Safari Bar and poking around underneath the front end to scope out the installation. Westin's instructions are marginal at best, so I thought I'd fish for some tips from anyone who's done their own install.
    Specifically, the Westin sheet says "Remove plastic trim clips that retain cover under and behind front bumper and remove cover."
    It's clear that they're talking about the body-colored fascia on the Sport, but their illustrations are sadly lacking. Has anyone here removed the bumper fascia? If so, any suggestions or cautions to offer?
    It's cold and rainy, so it'll be another day or two... But thought I might throw this out to get a bit of advice... Thanks in advance for any tips.
    Thanks for the vote of confidence regarding the capabilities of the 4.7, 5 speed and 3.55 rear(s).
    As a rule I take stuff (Jeep hardtop) back and forth from our PA home to our NJ shore home. Once in a while I pick up some furniture or lumber for our son, but that's the extent of it. I don't have
    a trailer for the boat, because it sits in the water behind the house. The thing I don't miss is towing the boat and putting it overboard. Then when that is over, loading it on the trailer and dragging it home. But, it is good to know that the
    capability exists if needed.
    Bookitty
    Thanks for the input everyone. There is a Dodge Dealer around the corner from my Office and I have a Test Drive Scheduled for both powerplants. Like I said, I'm not looking for Screaming Horsepower since the only things I'll be hauling are things like yard debris, bikes, firewood, and the occassional 8-Point Buck during Archery Season. I let you all know what I think once I've tried both engines. Thanks again!
    BigAl1
    Does anyone know if Dodge has anything for truck owners like Jeep has for it owners. What I am talking about is the Camp Jeep that they put on all over the USA with a big get together in August. This sound like it would be a great way for Quad owner to get together and show off their truck and talk to each other. We can get tech. advise from the Mopar professionals. Go to the Jeep web site and look at what all they do and your might get mad Dodge is not doing the same. The only reason I bring this up is my wife has a Jeep and we got information in the mail the other day about Camp Jeep. I bet if enough of us write DC they might so the same for us.
  • steve234steve234 Member Posts: 460
    I have to agree that the v6 is marginal with the Quad cab. If you don't haul a load, the v6 will be adequate, but the 4.7 will probably give you just as good gas mileage and more piece of mind. I drive a V6, auto CC at work and it is plenty powerful for routine activities. Now as much as I hate to disagree with Bookity, today's automatics are as efficient as manual transmissions. Sometimes even more efficient, depending on the driver. Most drivers today are not proficient enough to get the best performance/economy from a manual and it requires more effort from the driver. Good luck and keep us informed.
  • texaszachtexaszach Member Posts: 119
    Armed with the information which Bookitty so graciously provided, I am now on hold with D/C Customer Service. I just spoke with the sales manager at the dealership at which my Quad order is placed . He gave me my VON and we went over todays list of Dakota constraints. He could not find any reason that my order should still be in BGL status.
    Meanwhile I have found two loaded out SLT Plus Quads . Both of which are automatics , one is a 4.7L and the other the 5.9L. The truck I ordered was the 4.7L but I remember reading somewhere that the 5.9L comes with the old heavy duty tranny. Any thoughts guys?
    Oh, one more thing, D/C Customer Service just told me that all Quad orders were cut off on May 5th, what the heck?
    Well, folks, I made a big mitake today. I went
    out and test drove a 4.7L and then a 3.9L QC. The
    only thing I can say is Whoeeee! The 4.7 is not
    bad, not bad at all. As much power as you could
    want, comfort, styling - Mercy! Seriously, the 3.9 is ok, but kind of lugs down if you need a little oomph at 60-65, it's all right in city driving, but I noticed a little strain going up a fairly steep hill. Of course, the 4.7 had no problems - very smooth, no clunking, etc. I have just made it a lot harder on myself. Now I see what you guys have been talking about. The Tundra (4.7L) was nice, too, but with the extra room and style of the QC, well, I know what I want. By the way, those Tundra HP and torque figures are also what their broshures call out if I remember correctly. I remember being surprised at the torque beating the QC. But after driving them both, I think the QC has just a tad better acceleration.
  • lmeyer1lmeyer1 Member Posts: 215
    My dealer just told me today that he can't get me the 2000, so he's refunding my deposit. If you really want one my guess is you will have to take it off the lot.
    As for me, I've heard too much about how much fun the 4.7/5 speed combo is to pass that up, so I'm gonna wait it out.
  • stonehamdavestonehamdave Member Posts: 10
    First of all, thanks to everyone here who has shared their experiences. I've been reading this forum since I first thought about the QC and the opinions here convinced me to change my order from the 3.9 to the 4.7 (change #2), add the towing package (change #3) and attempt to add the LSD. I made the call too late for that one though, oh well. The first change order was the color.
    Never having had a 4x4 before, I was wondering if it is normal for certain types of bumps, like a raised manhole cover or a raised bridge expansion joint to bounce the truck slightly to the side.
    For the record:
    Two tone Patriot Blue QC SLT Plus, 4x4 T&H package HD cooling & battery 4.7 auto, fog lamps am/fm/cd/cassette, towing, 6x9 mirrors 4 wheel ABS, alarm...
    lol, almost everything except the LSD & the power driver seat, i couldn't bring myself to spend the bucks on that.
    Ordered 3/15, arrived at dealer 5/11, picked up 5/16 and I LOVE IT !
    What a great vehicle, roomy, comfortable, quiet, (much more so than my previous 95 Taurus), handles wonderfully and looks terrific. ONLY defects I have seen so far was a very tiny (less than 1/4 square), overspray of the lower driftwood onto the front passenger door and a tiny underspray on one of the fender skirts. Bed's aligned, weather stripping's tight and everything works.
    I pointed the overspray out to the salesman, asked him to mark it down and I'd have it taken care of when I came in for the 1st scheduled maintenance.
    By the time I got home, I had a message from the salesmanager asking me to come in as soon as I can so they can take care of it.
    I just passed 100 miles. Will post gas milage after first fillup.
  • engine16cengine16c Member Posts: 18
    FYI-have the security alarm on my quad. At first the alarm did not work at all. Now alarm works but no indication on dash that system is armed. Service Mgr is checking this. Also found out that once alarm is activated if you want to deactivate the system (not disarm) a new module ($1000) is needed.
    I think both of our dealers owe us an apology. D/C Customer Service told me that the dealers were notified that the cut off date for ordering any engine/drivetrain configuration Quad Cab was May 5th.
    Tommorrow, I'm going to drive an SLT Plus QC 4x4 with the 5.9L and old version automatic transmission. This truck takes the prize for having the highest sticker I have seen on a QC, with an MSRP of just over $29,000.
    In the entire state of Texas I have only been able to locate (1) 4.7L 5 speed 4x4 and its black. I'm wanting white so that one is out.
    I don't blame you in waiting on a 2001, if you have the time its best to wait and get exactly what you want. More to follow!
  • guannerguanner Member Posts: 31
    according to D/C my Quad should be going to rail in the morning.. what is the estimated time that it takes to be put in line on a rail car to be shipped? and how long do you estimate it to take to get to N. California? for a moment I thought that stonehamdave got my truck but I got the LSD..
    themacguy- did you say that you have the gullwing tonneau? I had heard that there was some prob. with the hinges.. do you have any in put on how you like it.. would you get the one piece if you had it to do again?
    Thanx,
    Scott
    P.S. got to go drive f-250 powerstroke beast for the next 48 hr. shift.. talk again on monday..
    gsu1 - I've been looking at a way to get everyone to send me or a_j their home cities / states or sign on to the owner's group that we are supposed to get around the end of April (oops) or May or ? (hey Edmunds, we're READY) and do some sort of 'geographizing' and then possibly (maybe) draw some lines and get 'centered' cities for get-togethers in regions around the U.S. in the future. eg - everyone in TX would have a 'center' around Brady, TX - the most anyone would have to drive would be about 3-4 hours (these are short drives in TX). Hope to get this done as soon as the group is up and running. I also want to meet some of the folks in far off regions such as the Northeast at some point. Porsche and Corvette groups / people (I'm one of em) have done this for decades with GREAT success and it's an amazing thing to behold. I've held many, many TSD (time, speed, distance) & poker rallies in the Midland, Big Bend and San Angelo areas of TX and in the Ruidosa, NM mountains and have attended them as far away as Oregon and Florida. My favorite is the Santa Fe, NM Memorial Day get together known to us as 'Fiesta del Porsche' Lots of fun, concours in the central plaza with 150+ Porsches, a great high speed autocross, a rally through the mountains, tech sessions and dances - with some unbelievable memories & relationship ties that even after 20 years are just incredible. And remember, with the Quad the kids & pets can come along too! Tough to do in the sports cars... I guess we should call them 'Super Quads' or Quad 'Super Coupes' or something. Believe me, these 'Fiestas' are something I REALLY WANT TO SEE HAPPEN! With full blown sponsors & the whole works, so stay tuned... Heck, I've got a 6" OEM Dodge Super Bee decal - Black circle with the little yellow running bee in the center as my 'mascot' on the driver side rear window - and my graphics guy is working on a similar decal with Quad logo. I already have a 'European origin' key fob with a screaming Quad graphic on it. I love this stuff!
    stonehamdave - it's pretty normal, this is a stiff chassis without IRS rear-ends, rear coils or anything; they're leafs (I believe the 4X4's have a dual stage leaf setup in back and torsion bars added in front) so it'll twitch and jostle on some of the rough stuff. You might check your tire pressure, mine was set at 45# on delivery - drove me crazy till I let 10# out of em, might soften the twitches just a bit. Oh, and LSD helps a bunch even on 2WD for the side to side twitches. I noticed that first thing when I went into the oil patch on the caliche roads graded like washboard. We travel 50 - 60 mph on some of the longer stretches and when we slide around a turn, without LSD, the truck twitches; with LSD it's barely noticeable, a LOT smoother ride & less 'stutter.'
    guanner - I'd heard the gullwing is on some kind of restriction - I guess it's the hinges though mine have been flawless (so far). I've got Porsches so I know about %#$@ hinges & struts. I'd buy it again - but like it a LOT better at half the $1,000 uninstalled price. I have no use for a one piece type of lid as I work out of different parts of the bed regularly. A roll-top type or fold-a-cover would work just about as well though. I also feel that (ease of) removing the fold-a-cover is probably best for most useful and durable 'type' of cover for the Quad - its only negative is the' black only' color. I do like the looks and workability of the gullwing on the truck. But a CD changer would've been a nice option to have for the price difference.
  • quark99quark99 Member Posts: 136
    Hate to sound like Joe Big Dummy...but for the life of me, I can't find the Damn Oil Filter!!
    Got 1200 miles and need to change out the filter and oil...will change to Mobil 1 at 3000 miles..
    Unbelievable that I can't find it...I change the oil myself on all my vehicles, but I'll be damned if I can see it under the QC...anybody care to enlighten this California boy??? Maybe I've sniffed too much MTBE...
    Side note:
    Average gas mileage keep getting better-my 100 mile commute each day is about 60% freeway (55-75mph), 40% city/highway w/stoplights (10-45mph)
    1st tank netted 16.8 avg mpg
    2nd tank netted 17.5 avg mpg
    3rd tank netted 17.9 avg mpg
    Best I've gotten during a pure freeway trip (about 50 miles with gentle inclines/declines) was 22.7 avg mpg...so I'm gonna go out on a limb and guess that a typical San Francisco to Los Angeles road trip (about 350 miles) would net around 22-24 mpg, with no stops..
    Also I figure that the trip computer is about 10% off (shows 10% less than what it's really getting)...Tank #2 fillup required 18.5 gallons (needle was slightly below 1/8 tank, which should be 3 gallons left)and distance travelled was 357 miles.
    17.5 (computer's avg mpg) x 1.1 = 19.25 (true avg)
    19.25 x 18.5 (gallons) = 356.125 miles..
    Needless to say, I'm extremely pleased with this gas mileage, especially since it's a "smokin" V8 moving a 4200 lb vehicle! I doubt the manual tranny will net better mileage, unless perfect shifts and driving with an egg between the pedal and your foot is your style..
    Just for laughs:
    My trade-in vehicle was a 1999 Neon R/T, with a Mopar performance computer (160 HP, 135 torque)
    I miss that car, but the point is:
    I only averaged about 28 mpg, and I HAD to use premium fuel. So the difference in gas costs per week for me (520 miles a week) was negligible..
    Neon: 520 miles divided by 28mpg = 18.6 gallons
    18.6 gallons x $1.95 (premium CA gas) = $36.25
    QuadCab: 520 miles divided by 19.25mpg = 27 gallons
    27 gallons x $1.75 (regular CA gas) = $47.25
    Are you kiddin' me?? $11 a week more? That's friggin' fantastic!
    Sorry for long post..someone PLEASE tell me where the oil filter is so I can feel REAL stupid-
    Quark
    On "Camp Jeep":
    I've worked on the "Camp Jeep" program for the agency that handles both Jeep and Dodge Truck for DC... Wouldn't count on a similar program for Quads in the near future!
    The problem is that the Dakota is such a relatively ADVANCED vehicle in comparison to, say, the Wrangler, there's no need for DC to promote the brand image. Conversely, DC feels that the Jeep brand needs a bit of image-boosting.
    On MSRP:
    The Monroni sticker on my quad (5.9 with toys) was $29,655. Not that the sticker means all that much! I took it out-the-door (including 6% tax and plate transfer) for 27,900... About $200 under dealer invoice (though the dealer has a hefty holdback to fall back on with such vehicles).
    On the DRIVING experience:
    Pulled the plate off the Ram, stuck it on the QC and treated myself to a drive down to writers' meeting about 25 miles away last night... What a pleasure it is to drive this vehicle!!!
    On the way home, I had someone in another pickup right up my rear... A bit annerving! The 2-laner switched to 4 lanes and he pulled out and around me to the right... Then promptly slowed down to gander the quad... The guy was in a blue Dakota Club... Obviously envious of the Quad... Turned to see him give me the "thumbs-up" before he made a right and disappeared. As I recall, he headed off in the direction of a local DC dealership.
    On BUMPER FASCIA:
    Again, I would ask anyone who's removed their front bumper fascia on a Sport to offer any advice/cautions they can.
    On the 5.9:
    The 5.9 in my '95 Ram is nowhere near as responsive as that in the Quad. I opened the hoods and compared... There are some obvious changes to the intake manifold, which probably accounts for the difference.
    I know the 5.9 is a guzzler, and I've said before that I'm a bit envious of you guys with the 4.7... Yet, the sound of that exhaust and punch when I barely tap the pedal are a real rush!
    290 miles on the Quad, and I'm one very pleased owner to date!
  • impy2impy2 Member Posts: 50
    I just purchased a Dakota Club Cab Sport 4x4 with the 4.7 Liter 5-speed combo. It has the 3.92 axle ratio, limited slip diff., and the bigger 31 inch tires. The truck has 300 miles on it. I noticed that in the last 100 miles the clutch pedal feels a little funny. While the truck is running, if I push in the clutch it feels like it has just a tad of drag in it. (it feels like like the old type clutches that used a cable, when the cable would get wore out you could feel some resistance or drag in the pedal) I know my truck has a hydraulic system and I was wondering if anyone else has experienced this "drag" feeling when they push their clutch in. Here is what baffles me.....If I turn the engine off and then push in the clutch, it feels smooth as silk. The only time I notice this little bit of "drag" is when the truck in running. It shifts great, and there is no slip in the clutch. The truck only has 300 miles on it. could this be because the clutch is still no broke in yet?. Any feedback would be greatly appreciated. One other thing. This has only happened once or twice.....I was in first gear coasting at about 2800 rpm's. I suddenly pushed in the clutch and the motor died. I have also noticed that the tachometer "bobs" up and down when I push in the clutch. It goes from 400 rpms to 800 rpms and then stabilizes at 600 rpms. Not sure if this is normal. Thanks
    What kind of mileage penalty can I expect with the 5.9 over the 4.7? The 5.9 I have found is a 4x4 with 3.55 axles. I'm still in disbelief that dealers here in Texas are not stocking the 5 speeds, perhaps that transmission was on restrictions earlier this spring.
    I'm not going to smoke you here, friend... You ARE going to suffer a mileage penalty of about 4-5 MPG with the 5.9.
    I've posted before, and suggested very honestly that I envy those with the 4.7 for that very reason. Yet, my experience with the 5.9 in the '95 Ram was so satisfactory that I decided to sacrifice the additional mileage for what I trust under both commuting and towing applications.
    I must say that my decision to go with the 5.9 was largely due to transmission differences more than "cubes." Whether right or wrong (I'll find out!), I was a bit hesitant about the "multi-speed" (two-stage second-gear) mated to the 4.7.
    AHHHHHH... But the burbling sound of that 5.9 exhaust!... Well, that's another story!
    I love the truck, and am nothing but happy I chose the "old" 5.9... She's purring like a kitten (hear me, Boo???), and feeling very, very good under the right foot!
    SIDE NOTES:
    1. The "Dodge Boys" did a GREAT job of anticipating market needs with the Quad! JEEZ! Those guys really do know what's coming down the pike!
    2. We're among those relatively few buyers who've foregone the "bigger is better" mentality and chosen the more reasonable concept of "what feels good and does the job is RIGHT."
    Enjoy your Quads, my friends! And share your experiences!
    Once again this forum proves to be a valuable source of information. The fleet salesman I spoke with told me the difference would be about 1 to 2 miles per gallon, which I can live with, however 4 to 5 is another story. I'm right there with you on the automatic transmission, matter of fact this same salesman volunteered that his dealership has seen (4) 4.7L tranny replacements on Dakotas since the first of the year. Of course that is the same guy who told the mileage difference in the two engines is "minimal", ha! The perfect marriage here is the 4.7L with the 5 speed transmission. Onward through the fog! Thanks again Towcrazy! And thanks to 1meyer1, Bookitty and all other posters here........
    Quark...See my post in #190....I responded to your first request but i guess you missed it...I miss a alot here to with 40-50 posts per day...By the way...Post 190 only applies if you have the 4.7L like me...Any thing else and someone else here will have to tell you where it is...
    You could also look at the Sales Brouchure on p16-17 where it shows the veiws and specs of the engine...All other engines look like the oil filters come off of the passenger side at an angle about 3/4-way back on the engine directly below the exhaust manifolds....The 4.7L is directly in front of the engine and you have to access it from a twist off cap under the front bumper fascia marked OIL FILTER--4.7L ONLY...Good luck
    CHAD
    My dealer confirmed the May 5 cutoff today. Left my order in for the 2001. Will have to wait to see final pricing, but whatever it is, he's going to seel it at "invoice", which tracks Edmunds except his $390 ad fee.
    Based on the other posts here, it sounds like the 5.9/auto will be a nice combination, too. Hope it works out for you.
  • quadhappyquadhappy Member Posts: 1
    Folks, this is my first time participating on this forum, even though I have been reading it for a while. I bougth a Quad (4.7 V8, Auto, SLT) in February 2000 and I am "quad" happy with this truck, which is the first truck I have ever owned.
    I have 5000 plus miles on it, and I have a couple of questions for the the forum:
    1) The truck seems to hesitate at idling ever since it was new. I took it to the dealer at 400 miles, and they said that it could be the type of gas I as using, and that they could not do anything to it until past the 500 mile mark anyway. Went back to dealer at 600 miles, and they say nothing was wrong, the computer did not showed any fail codes, and that must be the type of gas I was using (which I have used several brands to no avail), and that trucks in general run rougher.
    So now I am sitting at 5000 miles, and the truck still hesitates at idling, and I need to go back to the dealer again, but I am hoping I can get some advise on this issue, so I can talk more intelligenly to the dealer. Does any of you Quad owners have experience this?.
    2) The climate control knob, when I place it in the dual position UPPER and LOWER (third postion from OFF), I expect fresh air to flow, but in addition the air conditioner kicks in. There are settings on this knob for air conditioning (the first two from OFF (with snow flakes on the markings) and those work as expected. Is this the way it supposed to operate?. The manual reads that the air conditioner MAY or MAY NOT be kicj in this seeting. What does this mean?. What conditions are needed for the air conditioning to be off in the dual setting?.
    By the way when I place the knob in either UP only or LOW only the air conditioner does not kick in and only fresh air flows as expected.
    Thanks a lot for you help.
  • quadhogquadhog Member Posts: 6
    Have had my 4x2 for 3 wks .The best thing since sliced toast. Another two weeks and it goes in for the 1000 checkup. Having trouble keeping up with all the chat on this and frozen Dak topics.
    I have the same problem as most of u. The bed is out 3/4 at the wheels and 1/2 at the cab. Very noticable as I had the wheel flares put on. Is there a SERVICE BULLETIN on the issue that the dealer can refer to?? In some of ur listings I am reading horror stories of complete removal and redrilling (guess what...bare metal scratches then RUST). My dealer is not aware of any alignment issues.
    HELP PLEASE
    Allen
    I am not certain as to what you refer to as a hesitation at idle, but my F150 has always seemed a little rough at idle, but is smooth as glass in motion. It may be that for economy and emmisions or something, the vehicle is just idling a little low. Some people are more sensitive to this than others.
    On the A/C, there are several positions that use the A/C including the defrost. This is normal and helps to dehumidify the cab. Some people worry about wearing out the compressors and try to avoid using it, but the A/C will last longer if you use it frequently. It is like your vehicle, if you only use it occassionally, the seals and other components will dry out. The benefits usually out weigh any minor fuel usage. A/C compressors use very little power compared to the early models. The fourth position is vent only if you want it.
  • tecknoteckno Member Posts: 30
    I know what the literature says, I know what I saw, but a dealer tells me QCs have a cancelable airbag.
    Do those of you that have a QC have a cancelable front passenger airbag? What are you seeing on the lots?
    TECKNO
    There is no pass air bag cutoff. The QC, for air bag purposes, is considered a passenger veh (front and back seat). All on the lots are the same, no cut off.
    Allen
    Tex,
    My compliment on your choice of the 4.7 with 5-speed manual! From what I've gathered (and I ENVY you), the 4.7 is an outstanding engine! (Wish I could pocket the difference in mileage with the 5.9!!!)
    NOT to knock DC's efforts in power transmission in any way, but the "2-stage" second-gear unit mated to the 4.7 is still leading-edge. There are bound to be problems both in engine and power transmission devices, and I would commend (rather than condemn) DC for its efforts.
    Kind of funny, isn't it? We think of "engines" and "tranmissions" as seperate "units"... Yet they're so INTEGRAL to the performance of the vehicle!
    HEY OUT THERE! Can anyone give me a tip or two on front bumper fascia removal/replacement befor I drag my wife out there to hold things in place while I'm puttering!!??
    Hey Boo
    Has the "New Eagle" landed yet.I know u reordered on 3/19 and had Ernie kind of push this one thru.
    With these topics moving as fast as they do and with u popping up in several sites at a time, I can't keep up with the bouncing BOO. Mine took 13 wks while the paint dryed on CSX.
    Let me know
    Allen (now quadhog formally aolsen)
    Quadhog:
    Some postings back, Bookitty reported that his "New Eagle" had landed, at least once! But for all we know, Bookitty may well be back in orbit now behind the wheel of his QC for some time until some of that "New Eagle" adrenaline wears off!!
    BTW I'm finding that I haven't touched my Eagle Turbo since my new QC landed. This "New Eagle" 4.7L 5-spd Q-Ship is such a blast to drive that it gets driven on the weekends and the Turbo just sits gathering dust in the garage. Guess I'll give the "Old Eagle" to my son.
  • mailman54mailman54 Member Posts: 111
    What conditions allow the air conditioning to be off in the dual climate control settings?
    Quadhappy - I believe that the dual settings will run the air conditioner when the climate control knob is set to blue (cold) and not run the air conditioner when the knob is set to red (heat). The up only and down only positions are the only ones that the air conditioner does not operate, regardless of the climate control knob positions (blue or red).
    Thanks for the info macguy, stutter describes it perfectly, glad to know that it is normal.
    engine16c, I also have the alarm system and there's a little 'security' indicator on the dash that flashes when its armed.
    Did a bit of driving today and hit 200. Got the first fillup and I'm hoping that even though the gauge was on full when I picked it up, that it really wasn't full. Mileage for 196 mostly highway miles is 14.5. Now I really topped it off when I filled it so I figure that the next fillup will give a more accurate picture.
    Ordered a cap for it today and a drop in bedliner, (mostly because there's only so much money to go around, otherwise I would have gone for the spray on)
    The wife took it out for a spin today and she likes it.
    All is well.
    My QC was in assembly line trim stage (G) on 5/8/00. It was on Norfolk Southern by 5/12/00, transferred to UP lines on 5/13/00 and arrived at the Benicia distribution hub at 4:51am on 5/14/00. I do not know when it will be trucked to the dealer in Redwood City.
    You can trace it's progress via DC customer service line and the RR's tracing sites.
    Not sure if this'll help, but a week ago whilst troubleshooting a cooling fan relay problem, I looked at the fuse box on the left side (end) of the dash and noticed a fuse for each airbag, I believe. caveat: If you pull one of these fuses it may trigger an eject seat, cell phone call to Ralph Nader or something really nasty for all I know. Someone with a real manual will have to decipher this as an 'on / off' possibility, or a major catastrophe in the making... anyone?
    Like others, I'm a bit confused by the climate control on my Quad. Unlike the Ram, it's difficult to know whether the AC is "on" or "off." To date, that's the only thing that troubles me about the QC.
    Got the wife behind the wheel again last night for a spin up to the store... Some winding roads on the way. She remarked again on what a BIG difference there is between ride/handling in the Ram and the QC... Said the steering felt nearly as tight and precise as that of her Intrepid.
    Not sure what other makers have switched to R&P steering, but sure can attest to its effectiveness in the Quad!
  • sgtjeepsgtjeep Member Posts: 2
    great, and very informative sessions. but, i have only seen one post of prices for the Quad. am a jeep freak, and adding a new addition to the family of three,,,so, i think my days of 'Jeepin' are out. (wife still has a '97 Grand Lmtd), saw a Quad going down the road y'day, and started reading all i could on them. Am thinking this may be the new vehcle for me. previous minitruck owner('88 Mitsu), and got discouraged from owning another truck from that experience, until i saw the Quad. looking at a Sport, 4.7, a/t, 4x2. figuring on getting all the bells and whistles, and want to know the average prices you all have been paying. wanna know what dealers are doing on this 'new' vehicle.
