Visitor Agreement.
As I mentioned earlier I'm taking my time with the Fold-a-Cover installation. I'll post as I move along.
I completed Steps 1 through 3 yesterday:
1. Attach lift handles (6 small L-brackets) with rivets.
2. Attach protective foam strips to cover (temporary strips to prevent scratching the truck rails during test fit).
3. Install front lock (the "total access" cover is pre-drilled for the front locking mechanism, but a 2" hole must be drilled for the rear lock later).
IMPRESSIONS SO FAR?
-- The instructions are very thorough, and there are no missing parts.
-- A good quality rivet gun (about $15) is essential.
-- Time and material so far: 60 minutes and one cold beer.
I ran it for 1200 miles before hooking up my 2,200 lb. enclosed trailer with one 750 lb. motorcycle aboard... Just wanted to be sure it was fully loosened up before placing that kind of load on it.
ALSO... I took Chrysler's recommendation (in the owner's manual) at the time seriously, and had the dealership drain and replace the conventional rear-end lube with a synthetic blend... Bought an extra bottle of the stuff... When I took the truck in for "quick oil changes" and fluid checks, I made CERTAIN to bring the extra lube along and stress that if the rear end needed topping off, to use the synthetic.
Perhaps I'm over-cautious, but the Ram performed flawlessly over many thousands of miles towing loads up to about 5,200 lbs.
Good luck!
Tom
The dealer also has a chevy franchise several miles from the Dodge's. My Quad was kept at the chevy dealership for over a week while accesories were put on. They reported three offers for the Quad, presumably from Chevy shoppers.
Sorry to say (but I'll be perfectly honest), the Safari Bar install was halted midway through the project. I removed the plasic shroud under the oil pan to access the bumper mount bolts (required) and realized very quickly that the truck would have to go on a hoist to do the install... Replaced the shroud and struck a deal with the local Ziebart guy to do the install while they have the truck in to spray the Rhino Liner.
I'm not saying the Safari install couldn't be done in the driveway with a set of ramps... Just don't have that kind of time to burn, and felt the better route was to pay the guys to install while they have the truck in the bay.
As to lights... I'm still fishing for an appropriate set of blue visibility "bullet" lights... When the whole thing is wrapped up, I'll be happy to send digital images if you wish.
All-in-all, I'm extremely pleased with the accessorizing to date... The white/black theme (no chrome) is very appealing, and I'm certain the finished truck will be perfect for my purposes.
Your dealer's willingness to swap oil changes for the priviledge of "evaluating himself" on the CSI form doesn't surprise me in the least!
I have to assume that your dealer has attained Five-Star status (a marketing advantage). Retaining that status depends in part upon what shows up on those DC evaluation forms. Providing a couple of oil changes is a cheap and quick way for the dealer to help retain Five Star.
SO... What does Five Star REALLY mean??? Go figure!
leak coming from a hole in the back fire wall just
to the right of the LEFT exhaust tube." (see post #459) I see you mentioned "the right rear of the engine" in post #464. To simply clear up the location it is on the left of the engine compartment while standing in front of the Quad. As for reading my manual, I agree, I should but I didn't think it would give me an answer as to where that particular tube leads too. Again thanks for the response though bpeebles, I'm still learning.
4daughters
Carl
Take care and be safe all....
Zach
I have a 2000 Dakota club cab sport 4x4 with the 4.7 liter V8, 5-speed manual, 3.92 axle ratio, tow package, HD service, 31 inch tires, limited slip diff., and all the other good stuff. I read your message about how the computer needs to learn how to idle. I have 700 miles on my truck right now, and it has stalled maybe 2 or 3 times when I push in the clutch (every time it was in first gear and I was coming to a stop). I also notice that EVERY time I come to a stop, the idle will bob up and down from 300 to 800 and finally stabilize at 600. I tried searching for your previous message, but I could not find it. Can you give me a brief run down of what I need to do to fix this. How does the computer "learn" and is this problem an easy fix that I can do on my part, or will it have to go back to the dealer. I appreciate your help. I looked at your profile and it seems you really know your stuff. If there is any other problems, let me know. I am new at this message board, and this is the first truck I have ever owned. I really love the truck and cannot believe the power it has. By the way, a Pontiac GTO is a great dream car. I like the Dodge Viper, but WAY to expensive for my budget!!!
Thanks again.
Carl
The only time the Quad stalls is because of me being too fast off of the clutch on starts. Family has four vehicles some with autos so sometimes one forgets. I'll start using your "Accelerated Engine Teaching Process" today.
tmiller - Your dealer sounds like my dealer - Dodge (Five Star) first then expanded with Chevy. Also will provide free towing, within 15 miles of dealer, if their advertisement plates are on front and back. Again, I said "no" to all of that.
On free oil changes, they will use synthetics if you provide. Someone ought to get shot for needing that oil filter "trap door".
Good luck
Carl
carls5 - I had to make a flapper valve run tho the local Lowe's store today and parked next to a red QC Sport 4.7 auto with all the goodies and with a matching tonneau. Great looking vehicle! Anyway, after making my purchase, I decided to wait for a while to talk to the owner. He raved about it, couldn't say enough about how happy he is with it. He's getting about 15.5+ mpg now, started out 12-13mpg; the overhaed console computer a bit lower than his own calculations when he fills up. I am really beginning to work my wife, too. Also took my 4 year old grandson out last Sunday to look at some on the dealer's lot. Got him excited about a new truck, too. Can't hurt to have all the allies you can get!
(As soon as I came to a complete stop, the idle would 'lock in' at the proper setting.)
I brought this up to the dealer several times and each time they reported that the idle speed was correct. (The boneheads ignored the problem.)
I have the DODGE shop manual and have read thru it several times. The on-board computer has a 'fuzzy logic' algorithm that allows it to 'learn' certain settings (IdleSpeed, Ignitiontiming, InjectionPulsewith...etc) These settings are stored in memory based on a SIMILAR CONDITIONS WINDOW. (AirTemp, Humidity, BatteryTemp, ExhaustTemp, AidDensity, RoadSpeed ...etc) These are stored in both short-term and Long-term memory and included in the algorithm for learning.
Given this knowledge, I realized that the onboard computer needed time to 'adjust' to different conditions and 'learn' the best way to idle under these conditions.
I found that I could speed up the learning process by allowing the computer time enough to figure out how to idle. I began to hold the clutch in on long down-hills coasting along between 35-50 MPH. At first, the idle would 'hunt' for over 40 seconds before beginning to settle into a constant speed. After several 'teachings' over the course of a week, The idle began to 'learn' faster and settle into a solid speed much faster when I held the clutch in. The occurrence of stalling was reduced too.
Now, I have about 9000 miles on my Dakota and just for fun I held the clutch in for several minutes down a long hill yesterday...NO HUNTING AT ALL. I attrubute this to the onboard computer having learned how to idle under those conditions. (The long-term SIMILAR CONDITIONS WINDOW has some real data in it now)
Do not get me wrong... I still experience an occasional stall but this is usually during slow manovers. (Such as backing up a short hill) Rarly, after such a manover, When I push the clutch in, the idle drops to almost nothing and somtimes the engine stalls.
I hope this information is what you were looking for. Does any of this sound simular to your experience with your Dakota?
By making uncommon events more common we can help the truck to learn how to behave - that is why bpeebles clutch down coasting works well. I had a problem with warm reversing, but solved it by reversing into the garage at the end of the day for a while rather than reversing out in the morning.
Incidentally, much has been made of the polite and friendly attitude of the Dakota topics, but I saw a trend a few posts back that I think we should continue - b peebles was referred to as Mr. Peebles. I think in future you may call me Mr. Jordan, Sir, God - well you get the idea ;-)
Have a pleasant break for memorial day my friends, and regards to all my fellow veterans and current servicemen.
this topic has been "frozen." Please continue these discussions in Topic 1934 Dodge Dakota Crew Cab - IV. Thanks!
Front Porch Philosopher
