2007 Toyota Camry
12122242627102
  • dannyht2005dannyht2005 Member Posts: 6
    go to www.netcarshow.com
    click on Toyota. then either select
    2007 Toyoto Camry XLE or SE.
    There are a bunch of pictures. Enjoy
  • fredvhfredvh Member Posts: 857
    Thanks jchan2. I will wait for your pictures. What did you think of the Camry? Is it better than the 2006? Why do you think so? Styling is very subjective. Does the exterior of the hybrid differ at all from the LE?
    Thanks danny. There are quite a few that I have not seen before.
  • jaxs1jaxs1 Member Posts: 2,697
    They just read off a description of the car's specs.
    I wonder when there will be real reviews from road tests?
  • carrelman2carrelman2 Member Posts: 80
    From what I have been told the only Camry's that have folding mirrors are those that are built in Japan. The reason is to save space on the ships bringing them here.The serial numbers from Japan begin with "J". from Kentucky they begin with s "4".
  • petlpetl Member Posts: 610
    That doesn't make sense. I don't think Toyota would sell Camrys with and without folding mirrors in one country (my 2002 XLE was made in Japan and doesn't have them). If folding mirrored Camrys are built in Japan, they are most likely slated for the Japanese market.
    I personally would like to see pictures of the volume selling LE 4 cylinder- the exterior, interior especially- cloth seat fabric, center stack, instrumentation.
    Just in case any one is hitting the Detroit show in its last hours, or the Chicago show next week.
    Joe
  • agnostoagnosto Member Posts: 207
    I agree with that as my 2005 Camry 5 speed manual was built in Japan and has no folding mirrors... maybe the 2007 Camry XLE has folding mirrors.
  • lmacmillmacmil Member Posts: 1,758
    Great pix and much larger than available on the Toyota site. I like that blue SE and that lip spoiler. Thanks.
  • ben_canadaben_canada Member Posts: 14
    Yes, that will be great :P , as so far we've been only seeing the XLE and SE...I like to see some pics of the LEs....but I doubt anyone has any LE pics at all, probably NOT even one built yet :mad:
  • mackabeemackabee Member Posts: 4,709
    The Japan made Camry comes without the mirrors installed. They are put on at the dealership as part of the PDI (pre-delivery inspection).
    Mackabee
    These are the same pictures that are on www.pressroom.toyota.com link which I posted a few moons ago.
    Mackabee
    :shades:
  • jchan2jchan2 Member Posts: 4,956
    I thought it was a nice improvement style wise. My main complaint over the 2005/2006 models was the plain styling.
    The interior looked very modern and up to date. It was spacious and airy inside, and the seats were quite comfortable. The trunk in the Hybrid was good for a Hybrid; I didn't have time to check the trunks of the LE SE and XLE models.
    The Hybrid has a Hybrid Synergy Drive badge on the back, and a Hybrid badge on the left front and right front fenders. It also had different alloy wheels from the other models. Otherwise, it was pretty much the same car, except for the color. Everything was laid out nicely and was easy to reach for.
    I uploaded the few pictures that I had of the Camry from NAIAS.
    link title
  • dairyshickdairyshick Member Posts: 129
    Is there any hope for a manual trans on the 2007 camry? It completely removes it from any consideration by me without it....maybe I'm a miniscule minority that doesn't even warrant such consideration from Toyota, but it would be nice....especially now that the Accord sedan V6 can be had with a sexy 6-speed manual.
    "These are the same pictures that are on www.pressroom.toyota.com link which I posted a few moons ago."
    Yes but you can't get full size version on the pressroom site without press credentials.
    I thought I read that there would be a manual - several different places.
    No manual takes it off of my list as well.
  • mitchfloridamitchflorida Member Posts: 420
    Anyone know when the re-designed Solara will be in the showrooms?
  • larryt22larryt22 Member Posts: 125
    The 5 speed manual will only be available with the 4 cyl engine just like the past few years.
    I'm pretty sure that the 5 speed manual will be available only on the CE 4 cylinder and the SE 4 cylinder.
    All LE's and XLE's will be the 5A.
    Though I cannot find any conclusive evidence of this, maybe Im making it up? Can anyone confirm?
    ~alpha
    Figure it out. Toyota redesigns its models every 5 model years. Sometimes, but not always, they introduce a new model a few months early. Should be model year 2009 if the trend continues.
  • maxamillion1maxamillion1 Member Posts: 1,467
    According to the mini-brochure I got of the new Camry at the South Carolina Int'l Autoshow this evening.
    The Camry CE, LE and SE I4 will be available with the manual transmission. Makes perfect sense that the LE would be available with a manual, espeically in the SET region, where the LE is sold in higher numbers than the SE as far as manual trannies go.
    The mini brochure has a picture of the Camry CE, LE, SE and XLE in it. The Ce/Le models have wheel cover designs similar to the 2002-04 Camry LE models.
    Color Choices:
    Super White
    Titanium Metallic
    Desert Sand
    Barcelona Red
    Aloe Green
    Sky Blue
    Blue Ribbon
    Black
    18 inch 10-spoke TRD alloys/tires are OPTIONAL on the SE
    Is the titanium metallic the same as silver?
  • richardc2richardc2 Member Posts: 2
    Has anyone seen pictures of trunk space? I plan on doing travel and was disappointed that trunk size went down from large trunk on current model.
    Does it make perfect sense that the LE is available with the 5M? I think Toyota would be able to cut down build combinations by not offering the CE and LE both in 5M. I mean, theres basically no difference between the two models anyway, the LE just has an options list and the CE doesnt.
    ~alpha
  • jsleesi34jsleesi34 Member Posts: 3
    Please go http://www.toyota.com
    2007 Camry different models and pictures are showing. :D
  • joecarnutjoecarnut Member Posts: 215
    I was just reading the specs on the 2007 Camry pdfs and noticed for 2007 that the Camry m/t gets 34 mpg now and the a/t 33 mpg.
    http://pressroom.toyota.com/presstxt/2007toyotakit/2007Camry_s.pdf
    Sorry if its been mentioned before.
    Ken
  • kdhspyderkdhspyder Member Posts: 7,160
    LOL..He is somewhat aware of it,
    Yep, Titanium Metallic is the same as Silver.
    My Altima is about to send me to an early grave, I might trade up for the Camry SE V6.
    Thanks for the post on Titanium. I am anxiously waiting to see the 2007 Camry in person at my dealer.
    What is wrong with the Altima? I thought they were a fine car, almost as good as the Camry/Accord?
  • 328gtsi328gtsi Member Posts: 4
    HELLO THERE,
    WOULD YOU HAPPEN TO HAVE ANOTHER MINI BROCHURE OF THE 2007 CAMRY? I'M WILLING TO PURCHASE. ALSO IS THE ALPINE WHITE A METALLIC WHITE SIMILAR TO THE ONE ON THE AVALON? THANKS !
  • tuffytuffy Member Posts: 63
    What happened to the notion that the new Camry would get a redesigned more powerful and more economical 4 cylinder engine. I own a 2005 4 cylinder XLE and it is wonderful. I routinely average 38 to 42 MPG on the highway and the high 20s in the city, so the current 4 cylinder is a great engine. However, with a totally new redesign, wonder why Toyota didn't boost the power and MPG of its 4 cylinder model.
    Also, does anyone know if leather will be an option for the 2007 XLE 4 cylinder of if leather will only be available on the 6 cylinder.
    Any discussion of the 2007 having HID lights?
    This is the 6th year of this engine. Normally in midlife it's just a tweak. It always was foreseen as the same 2.4L with about the same hp. The BIG news is the Hybrid 2.4L of course, which to brings up your reported FE. Did you somehow get a prototype in your XLE. After 15 yrs in Camry's and with all the posts on this site I've never heard of anyone ever getting 42 mpg on a midsized 4c vehicle. Routinely? Yours is the best 4c ever from Toyota. If you are looking for an improvement over what you have I think you will be very disappointed. Keep it by all means.
    Yes there will be an option just as there was in the prior models.
    As far as I know the answer is NO on this one.
    My suspicion is that Toyota will be upgrading the 4 cylinder at some point PRIOR to the NEXT redesign, to include DUAL VVTi, as on the the 3.5L V6. This would bump fuel efficiency and power, most likely, as it would allow better "breathing" for the engine. It should be do-able because, from my understanding, it isnt a MAJOR design modification. I dont know why Toyota couldnt accomplish this for the current 07 redesign, and that is certainly a disappointment.
  • portknoxxaportknoxxa Member Posts: 69
    Two years ago I passed on a 2004 Camry SE V6, because the car had no sportiness to it even with the blacked out trim and the engine and driving xperience was not that great, so i purchased a '04 Galant GTS. Now looking at the car on the web I'll probably get a the new SE V6, depending on wheather Mitsu is going to put out that Ralliart Galant or a version close to it. So It'll be towards the end of the year when I make the purchase. The '07 Camry SE looks abosulutely 1derful, it's kinda mixed with a Lexus GS/Acura RL , but has the deep lines of the Mazdaspeed 6. This is the Camry I would have purchased two years ago.
  • objectiveviewobjectiveview Member Posts: 72
    Sorry if this has been posted before
    What are you talking about????
    The 2005 Camry isn't rated to get 38 to 42 MPG, so if you really get that, then you're beating EPA estimates and there isn't any reason for you to not continue beating EPA estimates on a 2007 Camry by the same amount if you drive it the same way.
  • tradscotttradscott Member Posts: 108
    Or continue to calculate the mileage the same, incorrect way. It always helps if you round up your trip mileage to the next 100 and round down the fuel to the nearest gallon before you top off the tank.
  • dampfnudeldampfnudel Member Posts: 131
    Is Barcelona Red different from Salsa Red Pearl ?
    I might, but I'm not sure. I typically try to sneak out 2-3 copies of a brochure when I go to car shows. (to collect :D )
  • 210delray210delray Member Posts: 4,721
    I would assume so; otherwise the name wouldn't be changed.
    But it could be similar.
    It's similar..same as the RAV and Prius color
    LET ME KNOW IF YOU FIND ONE AND PRICE. THANKS VERRY MUCH!
  • mk004mk004 Member Posts: 5
    Barcelona red is a brand new color found in the US on the new RAV4, new 2007 Camry and 2006 Prius - see Toyota color chart at:
    http://leforgeron.free.fr/Toyota06ColorChart.pdf
    I have seen the color on all three vehicles. It is elegant looking, lighter than the Salsa, but not too bright, and fully metallic. The lights at the Detroit show made it look brighter than it is outdoors. If there is no BR Prius at your dealer, have them call you when they get a RAV4 in.
    I just wondered why Toyota is advertising increased gas mileage for the 2007 Camry 4 cylinder when they list it at 33 highway and 23 city for an automatic when my 2005 XLE 4 cylinder was rated at 34 highway and 24 city? It is very strange that 2007 Camry didn't come with a revised version of more powerful and efficient 4 cylinder!
    Not really defending Toyota, but the new car does weigh a couple of hundred pounds more, and the gearing could be different. Maybe the new engine (and it is improved a little) would be slightly more economical in identical vehicles.
    Honda did the same thing with the Civic. Said it was more efficient, and the MT version is quite a bit less efficient.
    Where has Toyota claimed the Camry 4 is more efficient? I havent seen that claim?
    In actuality, the efficiency did improve on the 5M, for 06 it was 24/33, for 07, its 24/34. Its the MUCH more volume selling 5A that flip flopped due to the weight increase.
    I still cant determine how much the weight increase was, because thus far Toyota has only listed one weight, for example, for the CE and LE 4s... which cant be possible if two transmissions are offered...well, it could be... but VERY unlikely.
    ~alpha
    There was a full set of specs somewhere that listed all the weights, but I can't remember where. I think it ranged from a little under 3,300 lbs to nearly 3,500.
    Bad News- :(
    When I dug through my brochure bag, I only found 1 copy.
    I'll tell you if another one magically pops up though. I might have missed it last night when I searched for it.
  • alan_salan_s Member Posts: 362
    These are the the vehicle mass specifications in lbs for the 2007 Camry:
    4 cylinder:
    CE:3,285 LE:3,285 SE:3,330 XLE:3,340
    V6:
    LE:3,440 SE:3,485 XLE:3,495
    You can get the full specs here:
    2007 Camry Specifications (PDF)
    2007 Camry Features (PDF)
    2007 Camry Options (PDF)
    2007 Camry Hybrid Specifications (PDF)
    2007 Camry Hybrid Features (PDF)
    2007 Camry Hybrid Options (PDF)
    2007 Camry Images
    2007 Camry MSRP
    (MSRP will be posted on the above link when MSRP is announced.)
