http://today.reuters.com/news/articlebusiness.aspx?type=tnBusinessNews&storyID=n- T224910&imageid=&cap=&from=business
I have no dog in this fight. I'm someone who is interested in the car industry who has owned Camrys in the past and now happens to own two Subarus - a company which will soon be assembling Camrys for Toyota at its Indiana Legacy/Tribeca plant.
I've been following the Camry woes. It appears to be a classic example of too much expansion, too fast. It will be interesting to see what, if any, penalty Toyota pays for apparently letting quality slide.
I assume Honda will be the big winner, if the upcoming Accord is screwed together properly and is properly engineered.
There are a number of Toyota-related discussions over in Automotive News & Views to pursue this. One easy way to find them is click on that link and then use your browser's Find function for "Toyota". You'll see a number of discussions you'll want to check out.
I'm gonna go out on a limb and say that this has to be the most inaccurate statement ever made....
I'm confused. You refer to a post of one person's opinion that a mannual tranny is better, on page 42 of a 60 page thread (of which most of pages 43-60 appear to discredit everything you say). Not sure where reliability comes into play there.
Either way, how about this: Camry auto trannys are known to last 300,000+ miles with minimal maintenance. Show me one clutch that will last that long.
From what I am seeing on the net, the only Camry I would consider from a reliability standpoint is a manual. The new automatics seem to have a lot of problems. And Honda automatics still scare me too.
An overreaction. I just had my first OC on my 07 V6 XLE at 4992 miles. Watched the whole thing at a trusted quicklube place. The manager quipped that many cars are going to this because it leaks less than a spin-on. The jockeys knew what they were doing. The Camry canister is shaped to accept a normal oil filter wrench, the type that fits on the end. It also has a recess that appears to take a 3.8 socket extension directly, as if the canister were itself a socket. So the design was cool. :shades:
The Camry oil filter came with replacement seals for both the canister and the oil filler plug! Rubber O-Rings. So your canister gets a new seal at every OC, which emulates a spin-on. And so does the oil fill plug.
I think that this is a great idea. And my quicklube guys got it right the first time and did not mind at all.
Is the dealer right or just trying to sell me a more expensive car?
An option combination is available in a region or it is not. It is black and white yes or no.
If they have made a change to allow each buyer to pick and choose standalone options to order, then that is new and you are the first person to post here that they actually received a customized order made specially for them.
I'm clearly not a marketing person: in DC you can get VSC on an LE, but I live in a place with 7 foot of snow per year and can only get it if also buy the moonroof, leather and bluetooth...
It's a pitty, this VSC seems such a good idea, and fairly easy money for the manufacturer too: a few sensors (most of it was there for ABS anyway) and some smart software.
If you aren't ready to travel to buy or spend some time researching through the Toyota site with different zip codes, then listen to your dealer.
I placed an order with the dealer to get a car w/VSC and options I wanted, whenever they could. I continued to track the online southeast inventory, and then saw one LE vehicle show up in my color and options combination. A little while later it got assigned to my dealer, so I knew when it was going to be built and when I could expect delivery. I don't remember how long it took in each of these steps.
What the dealer and/or SouthEast area process is behind the scenes, I have no idea. But I ended up with the car I wanted, with the color and features I wanted, at the price I was willing to pay.
Now if only the cruise control was fixed, and the hesitations went away....
tends to fade faster than other colors. Thanks
I Zainoed mine (2 coats)the first week. Been 4 months and should do it again.
Step 1--scratch and old wax remover
Step 2-- Wet look glaze
Step 3-- Carnuba wax coating for deep lasting shine and protection.
Try it. :shades:
I'm told that not all areas of the country have this same capability, why.....I don't know.
I don't know much about cars, but I have a new Camry 2007 V6 XLE. I asked the salesman what gas to use, and he said regular (87) is fine. Does the car need better than that, or is 87 perfectly fine for the engine? Will better gas be *bad* for the engine??
For the 4-cylinder (which I have), 87 is preferred.
Perhaps I am on the wrong page, but I used the "fuel" entry in the index to find that information.
It says "higher" as in nothing lower than 87 octane.
And you can go as high as you want, as long as only automotive gas is used. 100+ octane gas available for aircraft or marine engines cause irreparable damage to automotive engines.
HTH
What he said is true for carburetor engines designed for 87 octane. As such engines haven't been made in the US in the last 20 or 30 years, he's nothing but repeating an outdated myth.
The Toyota V6 was designed for 91 octane and using this gas it can reach its advertised HP rating. However, the engine computer will change the tuning if 87 octane gas is used and protect the engine against damage, at the expense of about 10% less power.
If any engine equipped with a catalytic converter burned rich, it would damage it and cost the manufacturer a repair bill of over $1000 for each occurrence, as the emissions equipment is typically by law guaranteed for longer than the rest of the powertrain. There are a few sensors in an engine just to guarantee that the mixture is just right almost all of the time, no matter which automotive gas is used.
HTH
This is accurate, which is why the Owner's Manual says '.. for improved performance..' If one wants the full power of 268 horses then use 91 octane. If one is more concerned with the cost of fuel and 240 hp is perfectly sufficient for everyday driving there is no reason not to use 87 octane.
http://www.car.com/content/shared/articles/templates/index.cfm/article_id_int/14- 81
:confuse: :confuse:
Chintan Talati
Corporate Communications
Edmunds.com
Cheers!
"For years, our editors have been noticing a general degradation of build and materials quality in Japanese cars, but we’ve always written such observations off as oddities given the exceptional attention to detail these brands have historically exhibited. With our test sample, a 2007 Toyota Camry XLE V6 with less than 3,000 miles on the odometer, it’s time for us to stop making excuses. This test sample, more than any in recent memory, served to underscore that the domestics have made great strides in build quality, while vaunted brands like Toyota are beginning to struggle."
People buy from their past experiences mostly and word of mouth from family and friends. These are the two most important factors. If a current owner is happy with the current vehicle the replacement is likely to be from the same family.
There are likely 5 Million or more current owners of Camry's, Corolla's and Avalons out there who love their vehicles - I admit I am one - having had no problems for years and years. One reviewer's words aren't going to impact my decision in the least. It doesn't ring true. It actually seems planted.
To wit.
"For years, our editors have been noticing a general degradation of build and materials quality in Japanese cars,"
Well the editors might feel that way but current Accord. Prius, Camry, Civic owners might beg to differ.
But again it's good to have a perspective from the detroiters to keep things in balance.
That's why reputation takes a long time to catch up with the facts. It was so before Toyota led the car segment, and it might as well be the case now, only in the opposite direction.
Actually, three. There's Research Octane Number (RON) and Motor Octane Number (MON). The octane number at the pump is the average of both these numbers.
In Europe, RON is used instead.
At any rate, I doubt that planted 'detroiters' were responsible for the poor showing of the Camry in the car.com review. There is plenty of evidence (anecdotal and published) that the halo of that car needs some polishing.
Why not see for yourself?
Struggle? The plant is sold out with nearly no inventory in stock on dealers lots ( less than 15 day supply ). This is not the characteristic of a struggling brand/nameplate. It might be wishful thinking by competitors or others with a 'domestics' preference.
This review flies in the face of nearly all the other reviews to date, whether 'professional' or personal. But as I noted before it's good for balance.
I am not as happy with the 07 Camry's build quality as I should be. The sunglass storage door is warped and slightly crooked. The push-doors below the AC and where the second 12V outlet are stick. My daughter, who is petite and thin, managed to lockup the rear seat belt and I have to have it serviced. There are a couple of small rattles on VERY low mileage.
I expect perfection on cars, especially Toyota and Lexus (of which I have had both). This is my third Camry, and the other two were not as nicely appointed for sure, but they seemed to be built better.
But cosmetics and rattles don't equate to "general degradation." And my 07 XLE V6 still runs rings around the initial delivery quality of my wife's 04 Ford Freestar.
As for build materials quality, I think that the fake wood in the XLE is cheesy, but it is the highest quality fake wood I've ever seen. I am in the planning stages of replacing the fake wood with genuine birdseye, and I don't mean that cheesy no-quality stickon stuff. I found the rattle (top center AC Vent fixture, and when I put the nav in, I will quash that with a touch of foam tape.
Toyota needs to get a grip on QC issues. But, from what I read elsewhere, they are stopping production on several models to iron out all QC issues. So they're on it. Is car.com biased? Dunno. But the "general degradation" comment borders on libel.
Struggle? The plant is sold out...
The author means that Toyota's quality is beginning to suffer, not its sales.
Blind faith in a product brand is a poor buying decision.
