Visitor Agreement.
Just my .02
seems to be a bit on the kinky side. I'm not certain as to your intentions. Impy2, any marital advice from this forum may prove to be dangerous to your marriage, although as ferous said; 42 minutes isin't too bad.
Bookitty
Then you can incorporate it into your rotation schedule or save it untill you need a new set and only buy (3) tires instead of (4)...Then keep the best wore out one to put back under it when you sell/trade or trade/sell with the old steelspare and sell the alloy to a junkyard for $50 or so...
This way there is no need to worry about someone steeling it or getting it beat up or chipped by rocks/gravels
I agree with the person who reccommended Simple Green for tire cleaning...Works great..BUT use it on the tires only and NOT the rims....The factory alloys are plastic coadted and the simple green could cause them to "could" over time if used on a regular basis to clean and scrub the rims...Dont know for sure if this will happen but im not going to be the one to find out
CHAD
Is the VON Vehicle Order Number?
Is it standard practice for the dealer to cash in on your deposit when you order a vehicle. I placed my order for a 2001 Quad, gave my Credit card # for a deposit. They went ahead and billed my card for $500. This didn't seem right to me since they said my truck wouldn't be built till 7-26 and I wouldn't take delivery till August or Sept. Last time I ordered a Ford (sept '98), I left a check as a deposit and they never cashed it. What are your experiences with this? Do you think it is this dealer, all dodge dealers, ..?
http://www.cs.fredonia.edu/~stei0302/WWW/DAKOTA/dakota.html
The rear-end whine has been the subject of some discussion there. No answers, but you'll discover that you're not alone.
Sorry I can't offer any personal observations. Don't have a Dakota yet.
victx, yes the VON is the Vehicle Order Number. Having one doesn't mean much other than to confirm that I am in the system with a 2001 order. It will also let me track the status of the truck.
I've never factory ordered a new car before, so I have no experience with deposits other than the one my Dodge dealer took for the QC. He also actually charged the card, but I guess that's what I expected, at least until I read your post.
-- Check for missing parts (10 min.) Westin shorted me 2 lock washers, and packed two extra flat washers - A stop at the hardware when I have the chance.
-- Install driver side body mounts and bar
(40 min.) - Went on easily... Includes a bit of extra time brushing a couple of coats of rust preventative (Extend) on exposed threads, nuts & washers
-- Install passenger side body mounts and bar (25 min.) - No problems.
They look and function very well... Foot pads are poperly located for entry/exit front and rear. I'd recommend them to anyone who prefers to do their own wrenching.
You start out by pacing the mud flap in the desired position, which is over top of two of the screws that hold on the wheel flares. Once you have where you think its right you tap the flap with a hammer right where the screws are to leave and impression on the flap which notes the spot where you need to drill the first two holes. Unless you want to take off the wheels, you'll need a angled nut-driver to do this.
For me, this process took several adjustments to get all of the flaps to look right. Start with the passenger side rear wheel. If you make a mistake at least you don't have to look at it every time you walk up to your truck. Also be aware that the front wheel flares are a different height off of the ground than the backs so you can't copy the hole pattern in that direction. Also note that the wheel flare geometry is different on the front versus the backs.
After you get everything looking good but still hanging by two screws per flap, you go back in with the supplied screws (3-4 / flap) to better secure everything.
You have to love doing this to not pay the shop to avoid this kind of torture.
my dealer here in north TX did the same thing. I wrote a $500.00 check as a deposit (most of the dealers I talked to wanted at least $500.00 deposits).
Thankfuly I thought to ask the new truck manager if they would hold the check, or cash it. He acted offended when I asked him what they would do! i.e. . . . . of COURSE we are going to cash your check!!
Did'nt matter to me, just needed to xfer the funds. I hope this dealer is as quick with their service as they were with my check. that sucker cleared my bank within 30 hrs - I verified clearance!!!
Good Luck with the order!
Cowtown Aggie
Boo - did you have to put $500 down twice. Sorry
Friend of mine has the whine in his QC. 4.7L 2x4, automatic, trailer package. His dealer has ordered a new rear. He said there were only 2 in the US, (rears). Doesn't know when it will come in. Is still driving it. My QC 4.7L, 4x4, 5-sp, 2700 miles. No whine get.
1 Normandy brand part number sr-d-2852 sewer and drain 3" elbow, alternate p/n s42936
1 Normandy brand 3" coupling p/n s40130
12" 4" aluminum dryer vent tubing.
Remove the stock air hat and rubber flex tube to the filter box. Reuse the three stock clamps. Cut a 1/4 inch slot on the elbow (large end) and it fits perfectly onto the stock air horn with the stock clamp. (fits quite snugly) Clamp the stock rubber flex host to the elbow again with the stock clamp. Push the coupling onto the air box and clamp the other end of the flex hose to the coupling. remove the airbox intake 90 degree intake scoup, and mold the aluminum duct from the passenger side radiator area back to the air box. This is easier that it seems. There is a black rubber sheet on the radiator support that can be removed to allow the duct to pass through to the grill area and pick up forced air at speed. The ducting will fit inside the air box. The air conditioning aluminum tube can be "carefully" manipulated to the side for extra clearance. The aluminum tubing can be formed in place to provide a suitably smooth intake tract.
I moved the computer to the side about an inch for extra clearance but it is not that important. Just a little careful bending and smoothing of the aluminum ducting will do the trick.
After smoothing the elbow and coupling with sandpaper and painting black with engine paint the setup looks factory installed and gives a really cool "growl" during heave footed episodes.
I Have smoothed my airbox inside and installed a K&N filter.
I will have to clean the filter more often with this setup but with the k&N filter that is a simple issue to be done at oil changes.
I found the parts needed at Berings Hardware store in Houston, Tx The benifit of these parts is that schedule 40 pipi is larger and looks bulky where as the Normandy parts are much smaller and look "right" if that makes sense.
My dealer said this will not void my warranty as no "mechanical" modification was performed.
My highway mileage shows about 2 mph higher at 55 mph with this system installed verses the stock setup, But I have a flowmaster also so the intake helps take advantage of the increased exhaust flow. Seat of the pants passing is much improved. "like it neeeds to be?" yea right.But it sure sounds cool.
At 10,500 miles I am considering buying an extended warranty from either geautowarranty or a mopar warranty from a discounted internet site. I am trying to decide if the $1000 is worth extending what to me is a 1 year(36,000mile) to a 3 year (100,000) mile warranty. Any ideas Quadders.
Bookitty-belated anniversary congratulations. I am sure that your wife (like mine) is a saint to tolerate you. Although I've not posted in awhile, I have been following the advice to the newlywedded from yourself and others. Heaven help him.
CHAD
I would suggest looking at the Quad Cab. More than enough room in back for a child seat in this configuration.
STEP BAR SUGGESTION:
For those who've installed Westin (or other) black powdercoated step bars on your quad... You might consider carefully sealing off the surfaces of the bar and mounting plate where they meet, and also the bolt that attaches the bar to plate.
Rationale? Those new powdercoated bars may look great NOW, but like any other appendages that close to the road, they're probably going to need refinishing a couple of years down the road.
Had occasion to chat with a guy in the parking lot yesterday... Has Westin Step bars on his 2-year-old Chevy. They're riddled with stone chips and beginning to rust. Otherwise, his truck looks GREAT!
Asked him why he doesn't remove the bars and refinish them. Answer? The mounting bolts are frozen solid... He rounded a bolt head with a 12-point socket trying to get the bars off.
My solution? A bead of silicone around the bar/mount mating surfaces to prevent water and salt from entering the threaded plate inside the bar... Then several coats of rust preventative (EXTEND or similar) to seal off the exposed mounting bolt head.
FUEL PRICES:
Pulled up to the pump yesterday and bought
regular (87) at the "bargain" price of $2.09 per gallon... My wife wasn't so lucky... She paid $2.15 for regular.
While it's not directly related to the forum, it IS related to overall operating expense. I'm just curious about what others are paying for fuel in other parts of the country (I'm in Michigan).
Also- Wife and I both noticed a slight reduction in guel economy over the past 2 tankfulls. Do the new EPA addatives or oxegenators (or what ever they are coined) impact fuel economy?
Regarding your reformulated fuel there, I haven't heard any pro's or con's regarding fuel mileage, though I have heard (unsubstantiated) comments regarding a slight loss in performance.
Perhaps other contributors will chime in on both their local fuel costs and the RFG issue.
Average Gas prices in Ft Walton Beach FL. are $1.45 for regular unleaded. Average Gas mileage is 17.25 to 17.5. 4.7L, auto, 2 wd. No freeway driving.
The friend of mine that has the whine also had bed misaleignment
Of course, fuel prices in Michigan as they are, I'm finding lot's of fun stuff to do with the Quad as it sits in the drive!
Thanks all for sharing 87 Oct. fuel prices... Seems to support the notion that the midwest is being hammered at the pump... More input on prices across the country would be appreciated!
Carl
I'm working on accessories.....
I'm currently paying $1.57 - 1.65 / 87 RON (from different stations each end of my area), and this is where most of the U.S. - based stuff is 'made.'
vman - it depressses me every time I see the Amber Fire on a Quad. I very nearly bought it instead of black. Next time for sure - if Solar Yellow's n/a.
I still love this truck! I have not experienced any rear end whine although I have been listening closely now.
Just brainstroming here...Like i said, I have measured the rims from everything( Pumpkin, spring, bed, etc...) and everything is within an 1/8 inch and i have NO whine, vibrations, or any other noise coming fromthe driveline...My only complaint is the rear end creak which will be fixed under the TSB as soon as te parts come in...
CARSEAT---> For the person asking about the carseat in he club cab...There is no way i see to get a "normal" size carseat securely and safely fastened in the rear...It does, however have a passenger airbag cutoff seat, so one can safely hooked inthe front...
Only drawback...Your wife has to ride in the narrow seat in the back...Im expecting my first one in december, and it had alot to do with me buying the Quad...4-Doors, so no wrestling around trying to fold a seat up and lean over to secure a kid in the rear...
Chad
Oh yeah....Gas in Greensboro, NC is around $1.49 for 87 Oct and aroung $1.68 for 93 oct...Couldnt imagine over $2.00 per gallon.....Id definitly be driving one of those toyota Echos that get around 45-50mpg...
Looks & runs great. Had 4 miles on it when I first got in.
Quad 5spd manual
4.7L
4x4 / 3.55 lsd rear end
White exterior / Mist grey interior
tilt / cruise
A/C
HD Cooling
Boy, this truck can MOVE when you ask it to! This truck is gonna be fun
Will have bed liner & rec'vr hitch put in Monday. Looking for CD changer tomorrow after church. Any ideas where to put a 6 or 10 disk CD changer? I was thinking under one of the back seats???
75 miles old and counting . . .
Cowtown Aggie
Scott
BTW- after the flares, I put the custom fit MudFlaps on. For that, I wound up having to remove the tires anyway. Just wanted to mention it if you are planning the same
I'll be honest and say that when I saw a fire amber quad on my dealer's lot, I was less than impressed. HOWEVER... I guess it's one of those colors that sort of "grows on you." I've seen a couple on the road since, and it really is an unusual and attractive color!... Not a blinding "disco" hue, but very distinctive... Nice looking ride!!
NEWQUAD:
Just a suggestion -- If you don't already have one, short Torx bits are available singly through most good auto supply stores... Secure the bit into a 1/4-inch socket, and you're ready to rock!
AGGIE:
Congrats!! I suspect that you'll be finding plenty of "excuses" to keep the new ride out on the road today!!
ALL:
Thanks for your input on fuel prices so far! Here's a summary of numbers on 87 octane I've collected from fellow quadders (rounded to the next highest penny -- e.g., $1.49.9 becomes $1.50):
-- Ft. Walton Beach, FL: 1.46
-- St. Louis, MO (suburb) 1.50
-- Greensboro, NC 1.50
-- Baltimore, MD 1.58
-- Texas (general) 1.58 - 1.66
-- Syracuse, NY 1.63
-- San Fransisco, CA (suburb) 1.66
-- Kansas City, MO 1.79
-- Detroit, MI (suburb) 2.09 - 2.16
I know it's unrelated to our forum, but I think it reflects an interesting aspect of "driving conditions" we all face... Would like to hear from our Canadian posters (I'll do the conversion) and also anyone from Illinois.
87 Octane took another jump here north of Detroit today... Ranges between $2.14 and $2.20 per gallon.
Needless to say, I've been keeping the overhead console in the "real-time mileage" mode as a reminder.
Still crazy about the Quad, but not putting as many miles on it as I'd like!
Also, i'm getting a whining or whistle sound, but i've been told it is from the electric fuel pump.
