Honda Civic GX
I have found that at the ones with the "Fuelforce" setup, where you press R for receipt, then it asks for the hose # then enter, well just press the 1 (if hose#1) then enter repeatedly, eventually it will print the receipt.
What happens to me is the buses fill up and dont get receipts, so I have to do this every night, sometimes 5 or six times.
J
Jay
$3500 for a Used FM
$750 to rebuild every 4000 hours or 4000 gallons.
So that works out to $.19 cents per gallon plus your cost of CNG from home probably right around $1.25. Then add in the electricty. So for about $1.50 per gallon from home is it worth it?
John
BTW my (regular) fillups are now costing 5-6$ at the Hemet RTA Station $1.654
Murphy
Murphy
thanks,
epi
Murphy
01 and 02 models had an electric servo recall, but I do not think it affects your model.
One sure way to find out if the cvt trans has failed is to have the fluid changed. You must use the specified fluid. Sometimes this will cure the problem, but usually it gets better for a couple of hundred miles , then gets much worse.
A few shops will repair them, if it is only the starting clutch set (the part that replaces a torque converter in a cvt) You are looking at about $1200. A genuine honda re-manufactured trans is about $4500 + labor. If you have a hondacare warranty, it will be covered.
You might check with a honda dealer to see if the factory will fix it , even if the warranty has expired. Things like this sometimes do happen.
People with <100k need not apply! Who's furthest along??
epi
b
The tank capacity at 3600 psi and 70deg f. is 8 gge. That is under lab test conditions, not real world. Real world useable is about 5.5-6 at 3600.
If you are in so cal, get AAA plus , or some other towing plan that covers more than 5 miles. Sooner or later you will run out if you are stretching it. P.S. 2000 was a VERY good model year for the gx.
what is gge - gallons?
i am only suppose to use 3000 psi, i think (that is the number inside the gas door. are you saying i could use 3600? someone said that 3000 gas was "lite" and used up faster.
do you know anyone who would put in a bigger tank? or an additional one? I DON'T NEED BACK SEATS!
im glad to know that 2000 was a good year. i love the car. i just don't love how often i fill up. and i can't see getting a PHIL, i'm a renter!
and i do have a good tow plan. i will be moving to so cal end of the year!
thanks so much. i really appreciate your response!
ali
Also be advised that many station have capacity problems and do not always provide a complete fill, even if the indicator says 100 %. The older stations have a dial gauge to see actual pressure, the newer stations do not.
If I drive about 20 miles after the low fuel lite activates, I usually can put in 5.5 gge at 3600 psi.
GGE is Gasoline Gallon Equivalent.
Bigger tank ? forget that one, but extra tanks can be fitted. Don't know where, due to small trunk size on the 98-00.
Even with the smaller trunk, I would trade my 01 for a 2000 any day !
i would love to get an extra tank - id give up my back seats - id love to modify it to a two seater! do you know who puts in extra tanks?
when i filled it at an old station, the gauge was going past 3000 and i was a little worried - makes it seem like it is mislabeled!
thank you!
Curtis
Has anybody had occasion to search for wrecked CNG Civics to get CNG-specific parts?
Ate the tanks, so far, fully interchangeable?
i've been looking in the so cal area, and can't find any.
jon
and
John contact me anytime about a GX with an extra tank 602-331-4700
Murphy
The part numubers for fuel tanks for different years on Majestic's website are different, and would seem to indicate that one cannot easily replace an "out of date" tank with a newer tank from a wreck. But Majestic's discounted price is less overwhelming than the list price, when the 15-year "life" is reached and IF one decides to replace the tank.
The CO tax breaks are great for a GX. Around 6k state and 4k federal. I'm also considering a purchase. Actually, I'm convinced, I just need to convince the wifey.
With a few stations as there are, I think a phill will be a good idea.
Mark
Murphy
epi
I am fairly sure that my 99 has the same size tank as the new ones, 8gge.
The new GXs do get better mileage, I average about 35.5 with 85% highway speeds at 75.
Maybe if I change the fuel filter it will get even better because I've noticed some hesitation now and a little engine squeal I can't identify. It sounds something like a belt, but those were okay. I have 118,000 mi. on it now and live in AZ.
gariadea
adea
The general design of these cells includes an inch of rolled steel covered with fiberglass and kevlar. The tanks are literally bullet-proof. Video showing how safe these tanks are indicate that they just don't fail. They may have a nozzle broken off and fuel may vent as a result, but the nozzle can be replaced and the tank itself is fine.
If you apply any kind of rational thought to what he said, it makes a lot of sense.
Anyway, if you or someone you love are "freaking" about it and you decide to replace your tank, you may want to source one from Honda Canada (or anywhere else in the world). Same tank, no expiration date. But according to him, replacing these tanks is nothing short of barking at the moon.
Thank a lawyer for this tiny tidbit of automotive service lunacy.
Cordially, -Art
