Visitor Agreement.
Yeah lsd can be a bit of a fun stealer - but of course we are all safe, sensible truckers so that doesn't apply - well except Jack and I - and we are the spokes people - hmm, what does that tell you???
Of course if you believe everything posted in the limited slip differential topic then you would think that lsd adds to the fun by encouraging slip - I guess that's why we are all here.
Haven't actually thought about doing much auto-x in this thing, but I don't really have a great vehicle for auto-x right now, so maybe.
When I finally find my 'mog or Tatra maybe I could put a supercharger in that and auto-x it - now that would be fun!!!!!!
And you all thought boo was strange!
My understanding of fly by wire is as follows. Your input "gas pedal position" is converted to an electrical signal which goes by wire to a computer where it is processed and sent to a device "motor" where it is converted to mechanical position approximating the pedal input.
The reason I bring this up is what you posted in the Faqs on the owners group.
"Why does my brand new 4.7 V8 keep stalling?
Blame it on the computers. The 4.7 does not have
a throttle cable, rather the throttle is controlled by computers."
My Quad 4.7L is no different than the 5.2L MPI that was in my 93 Dakota. There IS a throttle cable which connects from the gas pedal to the throttle body which modulates the amount of air available to the engine. Based on the amount of air getting into the engine the computer provides an input signal to the fuel injectors which control the amount of fuel to meet the desired preprogramed conditions and desired air:fuel mixture (ratio). I'm sure this is a gross oversimplification but my point is there IS a throttle cable. Thanks Rick
Bookitty
In the meantime - here is some info on the engine:
http://www.dodgeram.com/technical/cammer/4_7_v8.html
Reference the "orange Bible", in the fuel system
section on page 14-27
Removal and Installation
Throttle Cable - 4.7L V-8 Engine
Not trying to be difficult - Rick
Bookitty
Whilst I follow up on this I will 'tweak' the faq to try and get rid of any confusion - just bear with me and it should be OK by tomorrow at the latest.
Bookitty
If the 4 critreia are met, the violator has a 99.9% chance of getting the verbal warning. I have been on the other side of this badge and know how it feels! This is just how I feel and I cannot speak for all other officers but I think it is a good policy and promotes good police/public relations.
Suspect it was caused by a strong pressure differential created by the tractor trailer. I had my AC on Max and all windows closed- no way for the outside pressure drop to equilibrate, so the higher pressure in the truck found relief in the weakest window!
Never heard of such a thing- but was reassured by both the the insurance company and glass repair outfit that it happens more than most folks realize on 2 lane roads accommodating higher speeds.
The glass is $175.00 and I should have it tomorrow, so I will probably install it then. I spent the last few hours cleaning out all of the glass out of the door and what had fallen into the truck. The Maintenance manual was real helpful in the entire disassembly of the door/window assembly. By the way, the panel comes off nice and easy- no prybars, pounding or tangs that break off (just follow the book).
Also was surprised when I contacted the GEICO insurance company for the claim- no clause for glass breakage, so I'm stock with the first $500 deductible (Boo Hoo). Glass outfit only wanted $60 or so to install the glass but, seeing how I already got the whole thing disassembled, I'll probably just put in the glass when I get it tomorrow.
I do have a couple of comments on recent appends.
FLY BY WIRE
My 4.7L V8 has a normal throttle cable...I have read about the 'fly-by'wire'on the 4.7L but the Dakota does NOT! Perhaps the 4.7L in the Jeep Grand Cherokee has the 'fly-by-wire'
STALLING
This subject is a good candidate for a Q/A section of the upcoming owners group.
THE STALLING WILL SUBSIDE AS THE COMPUTER 'LEARNS' YOUR DRIVING HABITS AND LOCAL WEATHER CONDITIONS. IT MAY TAKE UP TO 4000 MILES FOR THE LEARNING PROCESS TO COMPLETE. UNDER NO CONDITIONS SHOULD ONE ALLOW THE DEALER TO "RESET" THE COMPUTER...YOU WOULD HAVE TO START ALL OVER AGAIN!!
AUTO-LOCKING FRONT HUBS
The 2000 Dakota does NOT use torque sensing to engage the front axle. Instead, when 4WD is selected, there is a 'signal' to the front axle that locks the front wheels to the axle. Even with my poor hearing I can hear the front axle 'whine' while 4WD is selected. (The front differential gears tend to make some normal 'meshing' sounds)
I know awhile back, some people had trouble with the drivers seat squeaking. I have the same problem and I seem to remember that someone said a new seat rail assembly was needed to fix the problem. I took my truck in for it's 7500 mile check up, and the seat was supposedly fixed by tightening the bolts (I seem to remember that did not work for someone on this list). Well, it is squeaking more than ever!! So, would someone post what was necessary to fix it, so I can print it and show my dealership. They are very interested in knowing. I don't want to have to bring the truck in again, just to order the part, and then have to bring it in again after that!! Thanks in advance!
Susan
Of course it also happens to be TRUE - mine went through that phase. And I'd forgotten all about it until you brought it up... strange little beasty, this Dakota. Good call, and thanks for bringing it up - and returning to our 'controlled madness.' ;-)
I suspect as DC gets more data on the 4.7L, there will be 'updates' for the computer that can be 'flashed' into it. Hopefully improving the stalling and other 'quirks' that make the 4.7L unpleasant at times. (Have you ever tried to go real slow in 1st gear? The throttle has almost an ON/OFF effect that is temperamental to contend with.)
We (modern drivers) have become accustomed to the almost perfect throttle-response that fuel-injection provides. Those us familiar with CARBURETED engines may recall similar 'teething pains' that the carburetors went through.
Does anyone recall having to PUMP the throttle to squirt some fuel into the engine and 'set' the choke before starting? What about the ROARING idle on a cold morning? Having to jab the throttle to get the idle to come down? All things of the past... now we have BRAND NEW idiosyncrasies to deal with.
unlocking themselves? I have a 2000 Quad Cab 4x4 with 3500 miles. Two days ago the locks went haywire repeatedly unlocking every 2 seconds or so. I had to pull the fuse to keep the vehicle locked overnight. It's not the key fob, I pulled
the battery out of it and of course now that I'm taking it to the dealer the locks are back to normal.
He claims I was going 61 in a 45 zone. I really wasn't, really! In fact, I was on my way to play golf and I had just turned onto the road leading to the golf course. The cop was coming from the other way. He made a quick u-turn, pulled behind the truck ahead of me and on went the lights. The first truck pulled into the enterance to the golf course to get out of the way.
I pulled in also, to go to the clubhouse, when the constable signals me to pull over as well. After the traditional license and registration bit, I lamented that I could not being doing 61 since I just entered the road about 200 yards back. Obviously, he didn't believe me.
To add insult to injury, my boss, with whom I had the pleasure of sharing a golf cart with for the next two hours, passes us as I am sitting there. Finally, as I am paying for the round, the person working the counter states that they were right behind me and had me pegged at 45 mph. But, they have expired tags and don't want to get involved (yeah, sure).
Needless to say, the golf game was a disaster.
Well, to sum it up: Ticket: $97; Golf round: $62.50, Loosing to your boss: $36, having to tell your wife: Priceless.
Since you live in my neck of the woods I was curious how that xtang cover looks. I might be able to give you some advice about that ticket, might not but it depends on the precinct. If you are interested on one of those cold air intake systems I can probably cook one up for ya. Give me a shout.
And you'd lose the o/h console for sure. :-(
please forgive me if this has already been discussed.
I like the quad cab but am considering the club cab so that I can get the longer bed.
Has anyone with a quad cab wished they had a
longer bed? I'm a new homeowner and need a truck
to haul general home-related stuff.
Thanks for your thoughts!
Bookitty
in case you need the extra hauling room may influence
your opinion a bit? As this will be my only hauling
vehicle, I want to be covered in case I need more
than the 5' + change bed length in the quad.
Thanks for the advice!
than one passenger occasionally but with the increased cargo load (still not a full size truck, though).
Thanks for your thoughts.
I've got a 3yo son and a daughter on the way. I also need to haul occasionally and pull a pop-up camper several times a year. The Q/C was the best fit for us.
I'm about to order the 01 QC.
I'm a little confused about the rear end numbers. As I have it so far the lower the #,(292) the less torque and better gas mileage, the higher the #(392) the greater the low end power (towing) but worse mileage?
How did I do?
Any other tips on ordering.
I intend to get the "sport".
Can you get automatic lights? ( you know, lights on at dusk, switch off automaticlly?
Has anyone heard of a price better than $57 over invoice?
Your price sounds great, and I would check with the Farm Bureau to see if the $500.00 discount is still available. The URL link is www.fb.com. The cost is anywhere from $35.00 to $75.00 to join, and one must be a member for 30 days prior to taking actual possession of the truck. You may also join us as a member of the Dakota Owner's club by going to the conference link and clicking on "Owner's Clubs". Good luck, I absolutely love my Dakota Quad.
Bookitty
Bookitty
This all depends on your needs because I don't haul "anything" I chose the 3.55.Plus at 2500 rpms I'd be doing roughly 90mph!Don't let this fool you though,on this web page there are people who tow things(easily I might add)with the 3.55.
PS.If you have not signed up for the owners group,I suggest you do so.There a lot of smart people there to help with just about anything.
That goes for the rest of you huckleberries..LOL
Allen-
The clips on the cables that hold the tailgate horizontal in the down position are not great. The attachment of the spring to the cable is not tight. They can come off easily and get lost. The tailgate is also suprisingly heavy. Now that it is off I'll probably just leave it in the garage and hope the clips don't get lost.
