DODGE 5.7 HEMI
Love my 5.9 QC... But the hemi setup might just be too hard to resist!!!
Bookitty
Makes sense.
If your average commute is less than 25-30 miles, a UDP can (over the long term) cause shortened battery life, due to insufficient alternator rpms. Most vehicles do not have this problem, and even those vehicles with massive stereo systems that put a large load on the charging system don't usually exhibit problems. It has been theorized that accessories (alternator, P/S pump, A/C pump, etc.) actually last longer with a UDP, due to reduced rpms. Most newer vehicles are overdesigned with respect to charging/cooling systems, and in the case of the Quad, I'd suspect that this is also the case. Most of us opted for the heavy-duty service group with larger alternator, so I doubt any problems would surface, unless your normal driving mode includes hours of idling with A/C, lights, stereo, and other current usage...(police or emergency vehicles????) A UDP is a very cost-efficient way to increase power to the rear wheels. Typical cost is around $175-$225, including appropriate drive belt(s). Installation can be done at home, but most opt for the local mechanic at a charge between $50-$75. On my R/T Neon, I chose the biggest reduction UDP I could find (28% reduction), and it definatly gave a noticeable increase in acceleration (gain of about 6-7HP at the wheels). Remember, our vehicles are designed for the "lowest common denominator" driver, and have to survive being left idling for hours in the driveway with lights, fogs, stereo, A/C, laptop plugged in, and any other number of current drawing devices operating....I commute 105 miles a day, so probably a motorcycle battery would eventually recharge itself if I installed into the quad. One other note: aftermarket UDP's are usually substantially lighter than the stock, mass-produced iron pulleys. The lighter pulley is easier for the engine to get up to "spin", (rotational inertia), and some benefit is gained from that aspect also.
Hmmmmm...desicions,desicions,desicions
Yes... I suppose there will always be fools like us. Isn't it wonderful, though, to be a "kid!?"
QUARK:
You've definitely got a point regarding the 4.7 being "faster" than the 5.9. Were it not for the fact that I tow a rather substantial load, I certainly would have gone for the 4.7 rather than the 360.
BUT... Regardless of it's miserable mileage, the 5.9 gives me what I need... Supperior low-end grunt to get that load up to speed, and an "old-fashioned" tranny that's not going to let me down (knock on wood!).
So MANY ways of squeezing a few more suds out of these motors! Kinda fun, isn't it!!??
Underdrive pulleys don't affect warranties,but if you think Chrysler will warranty lets say your transmission after you add that Paxton huffer then you have totally lost touch with reality.Lets think about this...I manufacture a vehicle with a tranny to match a 230 horsepower engine and some guy comes in and says"Dude this tranny broke in my 475 horse Dakota"what am I gonna say.Exactly..."Sorry buddy read the fine print in that warranty,Doesn't cover problems due to misuse,or modification!"
With the limited parts available for the 4.7L you will be lucky to come close to 300 horse and retain your warranty,plus everything available for a 4.7L will end up available for the 5.7L.
I hate to act the prude here,or seem like I don't like the hotrod spirit,truth be known I applaude the effort to create a 4.7L powerhouse,but I just had to interject a little realism...Sorry
But in modern high performance engines, the trick is to use 4 or 5 tiny ones, that don't have to open so far, don't need so much duration and overlap. Then use a flat top piston, so the burning charge forces the piston down, instead of inward on itself.
I think this new hemi will probably be quite different than the original, while hopefully being able to trade on the enthusiast's association with performance.
Just a few additional thoughts-for "realism's sake"....
Proto HP/Torque numbers rarely equate to production. Those gaudy 350HP/400TQ #'s will probably end up closer to 310 HP and 380TQ. Thank OBDIII and emissions controls for that.
The all-alloy 5.7l proto is unlikely to make production in that configuration. Expect bottom-line DC considerations to recreate the motor as a cast-iron bottom/alloy head engine, like the 4.7l. This alone could account for about a 75lb weight differential. It's likely the main bearings and crank will be significantly larger than the 4.7l. Still, 75lbs is about what a blower and intercooler system would add to the 4.7l...so in that sense it's a tossup. In all fairness, if I was building up a Dakota I wouldn't start with a QuadCab, anyway...a regular cab with 5-speed would be a better choice..
The numbers I last seen for the new Hemi were 354 horsepower and 354 ft pounds of torque.
One quick note...horsepower,and 1/4 mile times mean little to nothing on the street...0-60 times are more indicative of street domination.
So moparmad, you're right. There is no reason why a hemi can't use multiple valves. In fact, they already do. It's called the 4.6L Cobra motor, or the 5.4 Navigator motor, or the 4.7L Toyota/Lexus motor. They're everywhere. Hemi's are no longer break through technology known only to Dodge.
Hemi's had a sperical dome shape to the piston crown. These new multi valve engines use flat top pistons with dished pockets for valve relief, and a centrally located spark plug.
Just a little irony for anyone interested...the new Hemi is slated to debut in the Chrysler 300 Hemi C,and is reported to be 354 cu. inches.The first Hemi ever to be used in the Chrysler 300 series was...354 cu. inches.
BTW, Corvette 5.7L makes 345 hp.
http://www.ouhsc.edu/jjoice/swirldam.jpg
So, no Ford modular engines are not "true" hemi's, but they do have valves on the opposite sides of the chambers, they are canted, a direct path for the fuel/ exhaust charges, a centrally located spark plug, yada yada yada.
The 5.4 Cobra R engine makes 385 hp.
http://moon.ouhsc.edu/jjoice/swirldam.jpg
Maybe with new technology a new hemi will work. The reason it didn't is I don't believe it's that efficient of a design because of compromises of the piston shape and fell way ward due to lousy fuel and emission laws. If true hemis were superior streetable motors they wouldn't have ever left us.
In the normally aspirated Pro stock class the motor to beat is the Olds wedge head and even the Chrysler camp when not being busted for running G.M. blocks(true story by the way) doesn't run a hemi and Glidden went back to the Ford wedge dropping the Boss heads due to detonation problems when he was still racing. I know moparmad will come back with top fuel Hemis dominance but remember you're running 30+ pounds of boost on nitromethane on a motor that's basically rebuilt every quarter mile.
I'm curious about the new Chrysler hemi but it's not some magic potion for ultimate performance.
http://moon.ouhsc.edu/jjoice/392heads.jpg
http://moon.ouhsc.edu/jjoice/hemi.jpg
http://www.ai-online.com/articles/mar00/0300f0.htm
http://www.car-truck.com/chryed/buzz/b102599.htm
O.K. I have dug out my April Mopar Action magazine they say this is an all new mill,it cranks out 354 horsepower at 4000 rpm and 354 ft pounds of torque at 3200 rpm.They also go on to say that this engine replaces the 360 in the trucks and will also power the up coming Charger R/T.It also features dual plugs per cylinder with a coil on plug ignition.
Finally you knew it was coming...Hemi's aren't used in the mountain motor pro stock classes because a huge domed piston isn't the hot ticket for high revs.Top fuelers run massive boost which require a very high flow cylinder head,otherwise you are just creating lots of useless manifold pressure.And don't fool yourself any of the super serious dragracers tear their motors down after every run.
I'm not saying that this new mill is the King Elephant reborn,I just think it is a bit closer to a true Hemi than anything we have seen lately.I'm also not saying that a Hemi head is the magical component to performance.I have been a subscriber to Mopar Performance magazine for many years and have found that they are almost always right when it comes to Mopars.They say it is a true Hemi,so I will believe them for now.
Moparmad, why so defensive? I actually said the new designs, from Ford in particular, AREN'T Hemis from the beginning. I also asked about the Chevy Hemi head that I've never heard of, doesn't mean it's not there, would like to learn about it if it exists. Also corrected you on the Twisted wedge quote. So who should be giving up on whom? Also seems the LSI Corvette motor puts out similar #'s without the benefit of a hemi head.(per Quadrunner) If you don't want to discuss it just say so and we'll all go away and praise the all new, not released hemi.
I'm still curious what DC is going to put it in? The trucks? Suvs? Prowler?
Wasn't one of the negative characteristics of the old hemi engines a fragile valvetrain? I seem to remember that in small collisions, the valvetrain assembly was prone to damage.....or do I have neurons still crossed from the late '60's?
-quark
I have always seen everyone in professional drag racing tearing apart thier funny cars and door slammers just as much as the top fuelers.In both cases it is generally just to check.If top fuelers have a higher failure rate then is it not possible that maybe it has more to do with stuffing 6000 horsepower into a 500 cube motor and less to do with an inferior engine design.
I haven't ever heard of Hemi valve trains being weak per say,just very complicated.Interesting article I saw in a back issue I dug out suggested the true demise of the Hemi was it's shear size making it difficult to fit in ever shrinking engine bays.
Whatever the reasons.I feel the Hemi is a good head.I feel the 5.7 Hemi might end up being a good engine,only time will tell.And I think that at least everyone should be happy that Dodge is at least trying to get back into performance V8's,if successfull it will force all manufacturers to raise the bar.Remember the Corvette V8 is high priced exotica,the proposed Hemi is slated to go into the Dakota,Ram and Charger R/T.This might make Chevy offer the Corvette V8(or something similar)to the masses,same with Ford.So I am done argueing,the 426 Hemi is legendary and I don't need to defend it's honor anymore,nor will I continue to speculate on an engine not yet in production.I am sorry if I sound arguementative at times I don't mean to.I enjoy seeing others opinions and some very good points were made.But I can't change your minds and you can't change mine so I will end by saying thanks for the conversation.
Moparmad, sorry if I caused any of your negative attitude toward trying to have a conversation. The 426 hemi was legendary, my opinion was it just out lived its efficiency due to changing fuels and emissions. Your point about its size is well taken but remember we still had 440's, 460's and 454's many years after. Like the Ford Cleveland head, it was a hard motor to lower compression on and make streetable because of the times.
I think you might be angry because I questioned your comments on Boss motors, Chevy hemis, and twisted wedge heads. I honestly was questioning you on the Chevy because I don't know of a factory hemi head. Now you're mistaken on the Corvette motor. All people are trying to say is that the #'s are already there with less "exotic" heads(Corvette) and we question what benefit a NEW hemi is going to bring to the table considering we still have crappy gas and strict emissions etc.
I don't believe anybody flamed you or questioned what the 426 accomplished. I for one am curious what benefit the new head will have over "newer" technology. If you don't want to continue that's fine but please don't continue for the wrong reasons.
Sorry for being uncivil and making smarta$$ comments at the beginning of this board...Your comments are well-founded and welcome anytime. I'm certainly not an expert on Hemis or the new 5.7l motor....You participated in a discussion that led to greater understanding amongst our fellow Mopar fans...and that's why we "hang out" here at the keyboard, exploring ideas, sharing knowledge, etc., etc,. I tend to "go off" a little sometimes, so again, please accept my apologies-
-quark
As a side note, and I've seen similar sentiments expressed elsewhere, doesn't it seem like all the automakers "hold back" a little on engine improvements? There's always a little something extra in "next year's model", so I guess that's part of the marketing scheme. Case in point:
In 1996, wasn't Ford's 4.6l only making 205 HP? Then suddenly, it's making 220 HP, or 240 HP in certain vehicles...now it's making 260 HP in the Mustang. Like the 5.4l in the F-150 and Expedition made 240 HP, then 260 HP, and now, of course, it makes 300 HP in the Navigator. Makes you wonder....Of course, in 2002, the 4.7l in the Dakota will probably be bumped up to, say 250 HP, and so on, and so on, ad infinitum. I remember when your basic 2.0l car made about 90-95 HP, then 110, then 125, then 140, then 150, then 170, now the Honda S2000 makes 240 HP! Of course, torque in these 2.0l cars (various automakers) has remained between 110 and 140 lbs....
-quark
If everything is set just right,sometimes the price of the nitro is actually higher than the gaskets and sealer they use.A lot of the time,it looks worse than it really is,when tey open it up,it's just burned/backsided pistons.The pistons are pretty cheap,actually.
A lot of the teams are just changing engines every round,and fixing them later.MAkes a lot of sense to me,with only 75 min.between rounds now.
I like the idea of a "new" hemi design. I just question the benefit that some of the early posts state. The projected #'s are already there with 2 valve technology. And the 4 valve technology still whups it in HP per liter. So why bother???
Besides, with moparmad gone and no more misinformation on 4 valve Corvette motors and Chevy Hemis and twisted wedge heads and Boss motors this topic is sort of dead. LOL!!
Don't know about you all, but speaking for myself, it'll be gratifying to see Chrysler put some bucks into the Winston series... Not that the cars will have anything at all in common with a production vehicle... But it's nice to see Dodge take an attitude shift toward racing again.
To the rest...
I have heard many Chevy guys refer to the 427 as a semi Hemi.I don't know nothing about Chevys and Fords just like most of you know nothing about Mopars.I left this topic because I was tired of talking to people who just argue and don't read.I don't know everything,but I do know a little.Which is more that can be said of some here.I will just take my leave now because I can finally see there is no intelligent conversation to be had here.
-quark
Fords have twisted wedge heads.....wrong
New Corvettes have 4 valve heads...wrong
Chrysler Hemis came after the Ford Hemi.....wrong
Moparmad, you're right there is no intelligent conversation here. All those "facts" above are wrong.........Oh, they're all from you........nevermind. Sorry you feel we're so dumb.
Modvptl...You are the one who told me that Ford never made a Hemi,except the 429 Boss.I said that Ford also made Hemi's and called them Boss's,so I was partially right.You are the one who said but it was after Mopar,I never said anything about any of them being first.
I was told by friends that the 427 Rat was almost a Hemi...wrong or right,don't know don't care.
Then someone says that the Corvette doesn't have four valve heads,except for the ZR-1.Well,last I knew the ZR-1 was a Corvette,so I was partially right.By the way,if four vavle heads are the last word in performance engines,why doesn't Chevy use them in the new Corvette?Don't get mad,just a question.
Finally I was making the point that new Fords are not Hemi's as was suggested by another person,I confused the aftermarket Twisted Wedge heads with the stock wedges...so sue me.If they are a wedge of any kind I guess they are not a Hemi.
Someone questioned the width point I brought up as to being an ingredient in the demise of the
Hemi.They mentioned that other big blocks survived after the Hemi.To clarify I was talking about the width of the head itself,not the width of the block.Look into a V6 Daytona and try imagining the valve covers about twice as wide as they are,if you can find them.
Now for the umteenth time...I am not saying the Hemi is any better than any current head,I'm just saying that it makes the power so what's the problem?Chrysler could have used any head and valve train they wanted,they chose the Hemi.Definately for the marketing aspect,but they must have seen something else there to invest the money in it.Remember,other than us gear heads alot of modern buyers don't know what a Hemi is,and could care less.
