1432433435437438854
    Father came back today with the rest of the cash and left with the keys and title. It is still in my driveway while they get it registered, but it seems like this is the end. I'm sad to see it go, but I know it is silly for me to hold onto it. I just hope it has a good life. :cry:
    edited September 2010
    Really nice looking Bronco on ebay. Has some needs but, other than a previous owner swap to part time 4X4, it looks original for the most part. Was bid up to $14K and seller didn't take it.
    A cousin of mine ordered one of these in '79 with the same engine, part time 4X4, the black bumpers (chrome was extra), etc. I remember the back seat was an option and he didn't order it for whatever reason. :surprise:
    Anyway his Bronco cost $8,200 back then and this ebay "survivor" was probably a bit more with the additional options/trim. My cousin's Bronco was a good, dependable truck which lasted a long time and I understand why they're still popular. But still I'm surprised to find bids like this on it, and apparently refused too.
    Well the restorer obviously has an enormous amount of money in it and can't stand the pain of selling at market value.
    Or above market value, IMHO. I mean, what is the point? Its not like it offers anything above and beyond a more modern SUV for the same money.
    Well you know, something different, stand out from the crowd, oohs and ahs, that sort of thing.
  • xwesxxwesx Member Posts: 17,924
    I managed to crib that engine just fine, replaced the intake manifolds, etc., and dropped it back in the truck on Saturday. Ugh, it sure is a pain to use a cherry picker on a gravel driveway! :P
    Anyway, I put it all back together yesterday and had it fired up by about 3pm. What a relief! Now I have to put new spark plugs and wires in it, adjust the carb & timing, and I should be good to go.
    I just hope the engine lasts on it. I was disappointed to see that one of the oil drain ports on the donor engine was clogged and that side of the head was (in my opinion) heavily sludged, but the engine ran well and has good compression, so I decided to move ahead, clear out the sludge, and take a chance on it.
    It has been beautiful, perfect weather here for more than a week, so there were many folks outside yesterday afternoon. They all know I am working on that thing, so when I fired it off successfully for a few moments, I heard a round of applause through the trees. Hah, I bet that will turn to gunfire pretty soon if I don't replace those glass-pack mufflers with something more appropriate for civilized life. :P
  • explorerx4explorerx4 Member Posts: 21,032
    A friend of mine had one of those. I like the desert stripes, but he took them off and went with the black look.
    I helped him swap out the original 351 to a 429, then to a 460.
    He did all the technical stuff.
    One time, we went out for a day of boating and we followed in our car.
    On the way back, a state cruiser pulled up and tried to get in between us, i was thinking to check the trailer plate, but I wouldn't let him.
    He eventually drove on.
    I put new plugs and wires on yesterday, which made a big difference. The engine now runs smoothly (turns out one of the wires wasn't getting a good connection, resulting in a "dead" #7 cylinder), but I still need to adjust the ignition timing and carburetor. I put the timing light on it last night and cannot see any of the marks on the balancer! I'm thinking that maybe marking it with chalk will help the lines to show up?
    Beyond that, it has been a long, long time since I adjusted timing on one of these engines... can any of you remind me of the procedure? I know the basic stuff like turning the distributor, but cannot remember details like if I should disconnect the vacuum advance, whether engine should be warm or cold, etc. I think it has been a solid ten years since I did any adjustments on my other rigs. :sick:
  • srs_49srs_49 Member Posts: 1,394
    IIRC (it's been a long time since I've had to do that also), timing at idle is done with the vacuum line disconnected and plugged. I don't think it matters if the engine is hot or cold.
    Do you have a timing spec? If not a couple of degree before TDC would be a good place to start.
    A little bit of white paint helps the timing mark show up.
    Thanks. The spec I have is 10 degrees before TDC for the automatic transmission.
    If you can't find a timing mark of any sort, let us know. There are TWO other ways to do this without timing marks---not quite as precise but they'll get you in the ballpark without blowing something up.
  • jlflemmonsjlflemmons Member Posts: 2,242
    have also used white-out, and bar soap rubbed into the notch. Hot or cold doesn't matter, as long as the idle speed is correct. Too fast and the mechanical weights can advance the timing.
    Yep, pull and plug the vacuum line, make sure the points are gapped correctly (going way old school on that one!) to set the dwell before setting the timing.
    Back in the day, Olds points were set to 32d on new points. After a brief time, they would settle at the correct 30d. The best thing GM had going for it back then was that the dwell could be set with the engine running by using a flex-shaft hex tool through a small door in the side of the distributor cap.
  • fintailfintail Member Posts: 58,766
    Took the fintail in for its yearly oil change today. Had the oil leak diagnosed, it is coming from the "front main crank seal areas", estimate to fix - $350. Also has a front left brake hose that is "chafing", estimate $125. I'll get these done next year along with a radiator overhaul and new thermostat. It'll deserve that as I didn't spend anything on it this year. In 2012 I'd like to do tires and maybe brakes. It keeps on tickin.
    I found the timing marks. I rotated the crank a couple of times with no luck, then took a wire brush to it as I turned. That did the trick well enough that I could at least see that there were timing marks, even though they were very faint. I then took a stick of sidewalk chalk (hey, it was handy!) and rubbed over the section with the marks. I took a towel, rubbed off the chalk, and only the chalk in the marks remained. After that, it was easy to set it. It was at about 10 degrees after TDC, so I backed it off to 10 before. Once I reconnected the vacuum, it looked like it was running at 15 before; I hope that's normal.
    Anyway, I have bigger problems... my oil pump is not working properly. :sick: This PITA may just have to sit another winter, because the season is coming on strong now and I do have other things to finish other than fiddling with this blasted thing. :mad:
    Like little chicks sitting in the nest with their mouths open ;)
  • lemmerlemmer Member Posts: 2,689
    I wish the season was coming on strong here in Birmingham. It was 98 yesterday.
    Hah! Yikes.
    I expect we will have snow (that stays until spring) within the next two or three weeks. I suspect we will get some before that, but it will likely melt.
    The fun of an unrestored car...technically it needs everything, but at the same time most of it is good enough as-is.
    New guy working at the MB specialist I patronize thought it was a great old car, too. Either he's being sincere or just thinking of job security :shades:
    I still haven't gotten my '67 Catalina to the mechanic yet, to have its transmission looked at. I wanted to wait for the next billing cycle on the credit card! :blush: I was going to try to get it in this week but he said he probably wouldn't be able to look at it. So now I'm looking at next Monday.
    I hope it's nothing serious...just an adjustment or shift modulator.
    It got up to 92 here today, in the DC area. I had no idea it was going to get that hot, so I didn't bother to turn the central air on, so I came home to a nice, stifling house. Also a helluva day to drive a '76 LeMans with a vinyl interior and broken a/c. :sick:
    That's one reason I am holding off on fintail repairs til next year (other than that the issues don't impact in town driving)...the modern car has sucked up a nice pile of money for tires and front brakes in the past 3 months, and I've spent as much as I want on car stuff for the year. Fintail gets the next go round.
    What about this puppy?
    I tried using the "img" tool but it wouldn't work... it used to, anyway...
    https://www.msu.edu/~steine13/image001.jpg
    Available locally for, I am told, hundreds rather than thousands of dollars, owned by a little old lady, it's an '89 New Yorker. Mileage unknown, let's assume 90k.
    What can you tell me about it? ;->
    I believe it's the last of the rear-drivers, no?
    I should mention it's 3 years almost to the day that I bought any car....
    Cheers -Mathias
  • tjc78tjc78 Member Posts: 17,363
    By 89 they were called the Fifth Avenue. RWD 318 V8 w/3 speed auto. My neighbor growing up had one of those IIRC an 86. He had probably 250K on it with the original engine and trans. It rode well and had great seats. 1989 was the last year of that design, "M-body", same as the Diplomat and Fury.
    The one pictured, would make a great winter beater.
    Yup, and they were in production for so long that they were the only car, AFAIK, to be marketed as a compact(1977-79), intermediate(1980-81), and full-size! (1982-89). Overall though, I'd say they slot in as midsize. Pretty good legroom, and headroom that's more like your typical modern car than something dating from the 70's, but shoulder room is only about 56", which to me was roughly the border between compact and midsize, so it's a far cry from the 60"+ that most "true" full-sized cars would have. The trunk is also a bit shallow, small, and oddly shaped. If you have a full-sized spare, it eats up a lot of space.
    The 318 engine was sturdy, although in 1989 there was a run of bad camshafts. The #8 lobe would usually disintegrate in the 70-90000 mile range. If you got a "good" one, they'd usually last, basically, forever! It has 140 hp, which may not sound so hot, but 265 ft-lb of torque! In comparison, the copcars, like my '89 Gran Fury, had 175 hp from a 4-bbl, but torque actually dropped, to 250 ft-lb.
    The biggest problem I had, as I recall, with my '89, was those little lightweight starters. My car had a hefty appetite for them, although I think part of the problem was shoddy rebuilt units.
    The engine and transmission were solid, though. In these civilian models, they shoved an extra-tall 2.26:1 axle, in an attempt to compete with the overdrive transmissions of competing cars, but they still couldn't quite compete. Something like this would've been EPA-rated at 16/22, and been hit with the guzzler tax, while something like a Crown Vic or Caprice V-8 would've scored a slightly better 17/24. Acceleration wasn't *too* bad though, as they changed first and second gear in the transmission to compensate for that tall rear.
    As for handling, I know this sounds contradictory, but in day-to-day driving, they feel vague and sloppy and floaty, but in emergency maneuvers they're actually pretty good. Comfort-wise, my biggest issue was with the steering wheel placement. While legroom was excellent, the steering wheel was too close for my comfort. I guess that was its 70's domestic compact roots showing through!
    Overall, it would make a pretty good beater I think.
    I'd buy it for $300-$500 if it ran okay, but it does look rusty, so I'd check very carefully for signs of water leakage into the passenger compartment and trunk, and also make sure the suspension isn't about to break off its anchors.
    The little old lady obviously delivered lumbbr or propane on weekends...
  • gsemikegsemike Member Posts: 2,452
    Salesmanship
    Parts car Since this is the least desired iteration of these cars, put the drivetrain and whatever else into a 70-73
    Could this price be right?
    Could be fair enough for a work truck
    Why wouldn't you fix the gas leak? I'd be afraid to sell it like this
    Never used as a taxi but it surely will be
    Crying uncle He went as far as downloading the diagram and then decided F that
    He can laugh about it now Actually looks real good for 10 grand
    '88 BMW 325i -- with a ripped top and 156K miles on it, busted radio and short in the tail lights, I'd say the price is too high, if anything. That top is very $$$ to fix. You can buy 80s BMW convertibles all day long in California for cheap, cheap, cheap, and nicer, too. It's really just an old used car of no collector value or interest. Looks like a $1500 car tops, to me.
    Here's one, for example, with a good top and less miles for the same price, and a California car (no rust) to boot. I could post ten like this.
    http://sfbay.craigslist.org/nby/cto/1965517554.html
    1995 Saab "Easy Fix" --- yep, easy once you remove the gearbox. The clutch slave is inside the bell housing. Been there, done that.
    Capri Convertible --- I wonder if the battery charger comes with it. That would be handy. He should have left the empty oil cans and tubs of Bondo in the photos.
    Why wouldn't you fix the gas leak? Because that location is the fuel filter, and I would bet money someone tried to change it without the right tools and twisted the fuel line, $$$ to replace. Solid design, and if you could fix the leak yourself, maybe reasonable.
    From experience, there are good S10's, and there are bad S10's. A good one will serve you long and well, a bad one will put you in the poor house.
  • stickguystickguy Member Posts: 54,081
    agreed on the BMW. sometimes the "cheap" one is not worth it.
    and that 4x4 for a grand looks like an interesting work truck, for a farm, something like that.
    too bad I missed the SAAB before it got flagged.
    the S10 looks nice enough. and that capri ad is quite something.
    you're good at taking out Saab gearboxes? Books says about 6.5 hours R&R, that's not too bad really. But of course "while you're in there" fixing the bad slave cylinder, you'd want to do the clutch, pressure plate, resurface the flywheel, etc.
    no, I am not going to be crawling upder a saab anytime soon to try and get a gearbox out. or any other reason for that matter.
    I did not want to buy the car, just see the ad!
    OHHHHH....I thought you had fallen and hit your head. I'm sorry for the misunderstanding.
    The ad was....well....either the work of an indefatigable (there's that word again) optimist, or some still grappling with the reality of their disaster and unable to give it a true voice.
    At best, it would have sent a buyer down the garden path. Not nice.
    Shifty, at one point you either presented a list (or spread it out over a few posts) of interesting cars that were true lemons with no hope of redemption. I am sure you had the Biturbo on the list and possibly the TR7.
    You've also less formally presented interesting cars that aren't lemons, but do require an ATM in the trunk, such as a 928. I'd be interested in seeing these lists again as a reminder.
    Well sure, although this is only my two cents of course.
    But it is interesting to at least dare to think that there are classic cars out there that are either a) unfixable or b) punishing to own.
    One problem with putting lists like this out into the Internet is that you will always find some aeronautical engineer who DID manage to keep a TR7 running (so he claims) by a few simple modifications, like re-casting his own cylinder head in his basement forge, or machining engine parts out of spare alloys laying around at his old NASA workbench.
    So lists like this would be for the 99% of us who have neither the skill nor the budget to correct factory defects or factory engineers' perverse ways of accomplishing something.
    Actually I'd like to hear others' opinions on cars that they deem "UNFIXABLE" and others they deem "BRUTAL TO OWN".
    I might learn a few more! :P
    well, I have told a few tales here about my '75 Opel Manta. Certainly not a classic, but brutal, and for many of the same reasons some older cars are.
    parts availability, and lack of anyone that knew what to do with the darned thing.
    Getting a 1 year only car with relatvily new/novel technology, that sold in small numbers new, bad idea.
    and in 1983 (I think), any parts for it were in Germany, and it was not easy to find someone thta could debug and fix the FI system.
    That got replaced by a well worn 1975 Corolla. Needed a carb rebuild. Kit was ~$12 at the dealer, and a local mechanic did a basic job for about $40. MPG jumped from 25 to 32 highway.
    There is a reason to go with a '65 mustang as your hobby car, instead of something that would be a stumper on the mystery car thread!
    to take my '67 Catalina to the repair shop to have its transmission looked at. And on the way in, it seemed to learn a new trick. At first, it was just holding the gears too long...1st through about 35-40 mph, 2nd though 65-ish. And if you had to accelerate from about 50 or so, it seemed like the engine would just rev up, but it would take awhile for the transmission to engage.
    Well, here's the new trick. I had to stop to make a left turn in front of oncoming traffic to get to the repair shop parking lot. When I had room to go, the car seemed really sluggish, like it was trying take off from second gear.
    I really HOPE this isn't a major deal, but like Han Solo and a few others said, "I have a baaaad feeling about this!" :sick:
    After owning a '78 VW Scirocco, I wonder what people are talking about when they say recent VW reliability has taken a nosedive. I really don't think VW has made a reliable water cooled car ever. I don't recall how many times my Scirocco left me stranded out in the middle of nowhere, but it always seemed to be near houses with "trespassers will be shot on sight" signs in the yard.
    Other than that, I've had really good luck with cars. Well, after the Scirocco I chose a lot more carefully. But that car was incredibly fun to drive during a time when almost nothing else was.
    I think sometimes when quality takes a "nosedive" nowadays, it's not that the cars are worse than models they replaced, but just that the competition has improved, so they look worse, when viewed against their peers.
    For example, let's say in 2005, VW was having a complaint rate of 3 problems per car when the industry average was 2.5. But fast foward to today, and VW is actually improved, to 2.5. But, the industry average has improved more, to 1.5.
    Circumstances like that will make a newer car show up with worse reliability ratings in publications like CR, even if the car really IS better than older models.
    And, in many cases, sometimes someone just happened to get one of the "good" ones, with an older car, and with the newer car they got one of the "bad" ones.
    For example, comparing my 2000 Park Ave to my grandmother's '85 LeSabre, so far I'm gonna have to say the LeSabre was the more reliable car. I broke a sway bar link at 59,000 miles, and now, around the 63,000 mile mark, the rear window defrost stopped working. And the gas gauge acts funny whenever it starts getting low, so I think it may need a new sending unit.
    None of that is really anything major. However, my grandparents bought that LeSabre brand-new, and I finally got rid of it when it had 157,000 miles on it. The only problem I can remember it having, until it started getting old, was the tape player breaking when it was about a year old. Otherwise, that thing never really needed anything other than maintenance until beyond 100,000 miles. And the gas gauge and rear window defroster NEVER stopped working, even at 157K miles and almost 18 years of age. And that car never even needed any suspension work until 144,000, when it needed new upper ball joints.
    However, on average, I'd expect the typical 2000 Park Ave was more reliable than the typical 1985 LeSabre. And over the long haul, I'd imagine the typical 2010 LaCrosse or Lucerne should be better, still. Probably more expensive when they DO break, and eventually becoming cost prohibitive toward the end, but, say over the first 10 years/150,000 miles, give or take, I'm sure the average experience would be better.
    Quite frankly, if I bought a brand new VW, I'd be worried about making it home, and not put at ease for at least a couple of weeks of trouble-free driving.
    Really?! So they really ARE still that bad? I don't know too many people with them, so I don't have much in the way of horror stories to tell. One of my friends bought the "2001.5" Passat when it was new, and got well over 100,000 miles on it before selling it. The only real problem he had was for a couple months, sometimes it would refuse to start, and the dealer couldn't diagnose the problem. Eventually, it was a neutral safety switch or something like that. It was a stick shift car, and I remember getting stuck once with him. It DID start eventually, after about 20 tries or so. That's just it, it WOULD start eventually, but you never knew whether it would fire up on the first try, or the 100th!
    He now has a newer Passat wagon. 2005 "4motion" or something like that. Hasn't said anything bad about it...yet!
    Now I did have a friend who had a 2002 Jetta, and that sucker leaked coolant all over the place a couple weeks after he bought it. I forget now, how long he kept that car.
    I am with you on that. I wouldn't even walk into the dealer. I know of two horror stories. One was a new beetle that the entire wiring harness was shot and on fire behind the dashboard, VW bought it back with about 200 miles on it. Second was a Passat that was so bad it was lemon lawed. I can't remember the specifics, but it basically wouldn't run for more than a few days between service visits.
    It's not that they are ALL bad, it's just that quality is so uneven and unpredictable...that's even WORSE for the consumer. I don't like playing russian roulette in a car showroom. "Hey, I bought one and the revolver just clicked, and am I happy!....but my neighbor....oh......"
    I had this notion, that the next car might be a Jetta TDI Sport Wagon...and then I drop into the TDI forums, and I'm freaking out again with these *stories*...
    Well, I hope to prove you wrong on this one. So far so good with the GTI. Only a CEL a few times for unknown reasons (sure, now that I have the cable and program to read it, it hasn't come on). I do believe, however, it may have been the cracked air filter housing (no doubt an overzealous previous owner tried to remove it incorrectly) since the CEL has not reared its head after I siliconed the cracks.
    To be honest, I can't say I would warn against any of my project cars. Believe it or not, only my newer volvos would get a "boo" from me. The 5-speed geartronic is a problem, as is the AWD.
    Well it's not the same thing. You bought it used, so it's had its shakedown cruise already. I was referring to buying brand new, and having to agonize over what *might* happen. It's the not-knowing that bothers me about VW.
    I guess what I'm saying here is that buying a VW is like hiring a convicted felon who appears completely rehabilitated, but in the back of your mind....... :shades:
    Ah, well, let's hope so.
    There is always the possibility someone got rid of it because of all the problems. It did just have 50k miles... the end of its bumper-to-bumper.
    So far, though, not alot of big problems on the GTI/Golf board. The most major is a cam follower for the fuel pump. Seems they wear away and can eventually destroy the cam and head. But if you know about it, you check it periodically and replace once in a while. Checked mine, it had plenty of life, but I replaced it anyway. A more minor issue is a PCV system with a habit of clogging. Eventually, you'll start pushing oil out the cap. I found my cap just wet a couple of times, so it seems to be just starting for me. The aftermarket system that eliminates the problem will be arriving on my doorstep today.
    There you go. Be proactive! I did the same with my MINI---researched all the weaknesses and corrected them....a protective shield for the power steering fan blades, (prone to debris/rock damage) a re-inforcement block for the shock towers (they distort), a re-designed motor mount, periodic lube of the sunroof mechanism----things like that....what's left is a biggie---I want to replace the dual-mass flywheel at some point.
    It's sad but true...the most expensive German cars can't match the reliability of a Scion. :cry:
  • michaellnomichaellno Member Posts: 4,120
    Shifty, I've forgotten what year your MINI is ... turbo- or supercharged?
    And, do your preventive measures apply to the NA version as well? My daughter bought a '10 MINI back in April and your comments above have me wondering. No sunroof on hers, and it's an automatic, so there are two things we don't have to worry about.
    yeah mine is supercharged. I prefer SC motors to turbos, and the supercharger was easy to modify with a reduction pulley, airbox and colder spark plugs. The little guy really flies now!
    I don't think there's anything in particular to worry about with a '10 model. They got rid of that CVT transmission, and pretty much corrected all the defects on the pre-2006 models.
    I don't thnk there's anything in particular to worry about with a '10 model. They got rid of that CVT transmission, and pretty much corrected all the defects on the pre-2006 models.
    Thanks .. yep, I think the transmission in ours is the same 6-speed Shiftronic (named for you?) that BMW puts into its other vehicles.
    Yes BMW did name that transmission after me---small payment for all I've done for them, but oh well.
