Visitor Agreement.
The TPS theory is intriguing because that's what it feels like when I'm driving, like my right foot's input is not registering for a while, like when I hit "enter" on my computer and nothing happens for a few seconds on the internet. Then, all of a sudden, ZOOOOOM!
I already know air mass units aren't cheap, how much would resetting the TPS (I assume this is a hardware part linked to a sending unit for the drive-by-wire) cost (ballpark)? Thanks
Chris
jbuchanan
jbuchanan
jbuchanan
I'm willing to bet anyone good money that the driver's driving style learning system goes BRAIN DEAD each time the ignition is switched off. Now that isn't to say that other learning aspects aren't remembered long term, the idle air bypass solenoid parameters for instance.
jbuchanan tells us that switching a MAF seemed to cure the problem. If I'm not mistaken installing a new MAF requires a fuse or battery disconnect so the learning system doesn't continue to use the parameters learned for the old MAF.
regardless I wonder how the "fixed" SUV ran after a few days to "learn" the operational parameters of the Toyota MAF.
Just sharing info on an experience that I had sounds like it could have been related
Now if the car had to relearn every start up how poorly would it run and how long would it take to relearn for each driver?
jbuchanan
I have found engineering "white papers" indicating, as an example, the system begins to "learn" your driving style the instance you put the vehicle in motion. Within 1 minute it has placed you in one of four categories. Within the next 2 minutes it refines it's "judgment" into one of sixteen categories.
To me it has become fairly clear that the engine/transaxle ECU is "experimenting" with the edges of the fuel/air mixture ratio total "map" to refine the parameters to obtain the absolute best in fuel economy.
In other words use the leanest fuel/air mixture possible, even below the detection range of the oxygen sensor, throughout the engine's RPM and loading range while avoiding engine knock/ping. That's going to make it extremely susceptible to engine knock/ping if you try to accelerate at low engine RPM, low torque, while also in an inappropreately higher gear ratio.
None of us have any trouble figuring out how the engine/transaxle ECU adjusts the timing if we fuel the vehicle up with an inappropreately low octane. The ECU detects engine pinging and adjusts the timing and/or the fuel/air mixtures accordingly.
But once we refuel with the proper octane, no knock or ping, how does it know to "reverse" those parameters it learned to use with the low octane.
It continuously "experiments" with the fuel/air mixture ratio.
If we could somehow prevent it from reaching mixture ratios so extreme as to cause knock/pinging then the "problem" would have a solution. Would a MAF sensor that indicates, to the ECU, intake airflow 20% below actual do this?
Maybe.
But now I begin to wonder if NOT clearing the memorized parameters for the previous MAF had a play in this drama? Maybe the new one is less accurate, overall, than the original, and always indicates, senses, less airflow than actual.
By how much would the new MAF have to be "off" in order to prevent the ECU from getting into the lean burn extremes. 5%, 20%....
Absent pulling the fuse the ECU will continue to use previously learned parameters based on the old MAF sensor. Which may be exactly what has happened here, all to the good.
In which case we might be able to accomplish the same "ends" without changing the MAF sensor at all. If we could somehow modify the MAF sensor's output signal, to be high or low(depending on which one works), above or below actual, disconnect the battery and let the ECU "learn" the mixture ratio parameter using this "false" signal, and then switch in the proper MAF sensor signals, that might do the job.
Remembering that if the battery should ever fail, or be disconnected, in the future we would need to repeat the false learning process.
The throttle positioning servomotor will have it's own dedicated position feedback device. Maybe even two since the gas pedal has redundant, dual, position sensors that are continuously cross checked against each other.
So doesn't that coincide with the theory that the initial categorization of driving style might be involved here (by setting the TPS calibration)? If true, the downside is that one would have to drive aggressively for the first few minutes after starting out, which of course since the engine is not warmed up would waste a lot of gas, and probably isn't the best thing for the engine and drivetrain either.
Search Edmunds Forums and/or Google for "MAF Clean", and see what you find. I've got one post in the mix myself.
Here is the copy of TSB
Reset Procedure 1
1. Connect the Toyota Diagnostic Tester to the vehicle.
2. Reset the ECM (PCM). Refer to the procedures below.
3. Start the engine and warm it up to normal operating temperatures before test-driving.
4. Perform a thorough test drive with several accelerations from a stop with "light throttle" application until proper transmission shifting is verified.
Reset Procedure 2
1. Disconnect the negative battery cable for 5 minutes.
2. Reconnect battery cable.
Assuming the battery disconnect continues to work as it has so far the next would normally be to figure out how to disconnect only the engine/transaxle ECU to force it to revert to the more conservative factory parameters.
But now with the new of the MAF sensor swapping eliminating the engine hesitation symptom we need to rethink this approach.
I'm thinking that we cause the ECU to learn FALSE MAFS signals and then revert to actual MAFS signal without "informing" the ECU.
would you post a link to the whitepaper on toyota's adaptive system if you have it please?
while we are talking MAF (Mass AirFlow) sensing, shouldn't we also be talking EGR (Exhaust Gas Recirculation) sensing as well? a poorly operating EGR valve can result in engine roughness, vague shifting, hesitation and stalling, can't it?
something from popular mechanics magazine:
http://www.popularmechanics.com/automotive/sub_care_sat/1272481.html
btw, when I was talking throttle position sensing, there are two places i was referring: the throttle body, and also the accelerator pedal. in a DBW system, wouldn't both have a position measurement device so it could be closed loop? my inclination, since the beginning is the root cause is there.
It seems that there is only one TPS but engine airflow can be used as a secondary feedback that the TPS is providing a "true" feedback.
And lastly, burned intake valves.
It might be worth removing that and only erase the single ECU memory.
You seem to be saying that the engine no longer hesitates, revs (immediately?) to 2000 RPM, is that the case?
If so that confirms my suspicion that the engine hesitation, delay, is the result of the need to allow the transaxle clutches time to fully and firmly seat. The fact that it needs to downshift at all is to prevent the engine from lugging, knock/ping, in an inappropreately high gear ratio.
If anyone has a sequential shift and is experiencing the problem we could ask them to nudge the shifter down one time, one "toggle", each time the gas pedal is fully released. That would most likely prevent the coastdown upshift and thereby eliminate the hesitation the next time the gas pedal is depressed.
Anyone.....?
Now it begins to look as if the engine/transaxle ECU is actually LEARNING how long it takes the transaxle to downshift and is learning to keep the throttle closed for those learned durations.
Awaiting confirmation from bknblk, #1923, but in the meantime does everyone agree?
Pilot?
This might help the Grand Am as well.
Next time I get to that part of the world, I'll message you here.
jbuchanan
Chris
jbuchanan
so - I wonder if someone with hesitation could swap out the MAF and see if it helps or not.
jbuchanan, with the scanner you've got, could you also perform a test on a vehicle and see if the accelerator when depressed linearly ramps up and down without a non-linearity? same with the throttle body position sensor?
$3800.00 - that sounds like one expensive scanner!
the $122 unit I pointed to which can read Toyota specific codes and capture real-time data to a laptop seems like a good value in comparison:
http://www.obd-2.com/
http://www.obd-2.com/toypida.htm
Read this, circa 2002:
cjts, "Toyota Camry" #4547, 16 Oct 2002 4:41 am
It sounds depressingly similar to your experience.
Note Toyota barely made the average, scoring lower than competitors such Nissan and Honda.
J.D. Power "APEAL" rankings This J.D. Power and Associates study is based on responses from more than 110,000 new-vehicle owners and measures what excites and delights them with their vehicle’s features and design. APEAL stands for "automotive performance, execution and layout."
Ranking is based on a 1,000-point scale
Porsche 908
Land Rover 906
Lexus 905
Jaguar 902
Mercedes-Benz 902
Infiniti 901
BMW 898
Hummer 897
Cadillac 896
Audi 895
Acura 886
Volvo 883
Mini 882
Lincoln 881
Nissan 863
Scion 862
GMC 860
Honda 859
Mercury 858
Saab 858
Toyota 857
INDUSTRY AVERAGE 855
Buick 854
Mazda 852
Mitsubishi 852
Pontiac 852
Chrysler 851
Isuzu 851
Ford 848
Volkswagen 848
Kia 845
Dodge 839
Chevrolet 838
Hyundai 836
Jeep 833
Subaru 830
Suzuki 828
Saturn 827
Source: J.D. Power and Associates
Maybe when they pay $50K for a problem in a Lexus, owners are less likely to admit not being "delighted" than when they only pay $25K for the problem?
Or, maybe with a Lexus, they give you a chocolate chip cookie when they tell you to live with it because "they all do it".
Just thought I'd post up that once again I can make the 2 second delay happen at will...I think I was jabbing the accelerator too hard the last time I tried to replicate it.
By driving real slow like I'm about 90 years old I can make it happen no problem...and if I want to drive like a maniac, it NEVER happens..of course then the gas mileage and safety factor (in a different way, due to the fast driving) suffer...
So if you want to give it a spin Pilot, I do think I can get replication of the 2 second delay now. I sure feel sorry for any 90 year old who buys one of these...
Are you saying that for some short period after you clear the memory the car shift normally?
