Diesels in the News
17273757778171
    No, I don't believe in the EPA tests for several reasons. Further discussion would not convince you or myself otherwise.
    I believe they are flawed from inception and do not believe they are even close to accurate where diesel cars are concerned.
    To me, the good news is the test IS infinitely repeatable under identical conditions. The bad news is probably NOBODY (in the real world) drives under those conditions! :)
    Another is most folks are almost totally clueless about the proper operation of a car. To many, it is an applicance that gets you from point A to point B, while one does a myraid of other things :(
  • gfr1gfr1 Member Posts: 55
    In this instance (the new 2008 fuel mileage ratings), the change in values was, in fact, arbitrary. They factored new ratings. The EPA page, explaining the conversion, has a chart where you can enter your old mileage figures and it will show the new mileage figures for any and all vehicles. You don't enter the vehicle data at all. However, it appears maybe that ruking1, posting 3811, may be interpreting the mileage range variances on the window sticker as pertaining to that vehicle, whereas, there is only one value for that vehicle and the mpg variances are those listed for other like vehicles within that class. GR
    Without graphically comparing and contrasting the test procedures side by side, I might be hesitant to say it was arbitrary, although it may seem that way. What I think it does (in neon lights)is to highlight the fuel savings, etc. advantages of diesel and the even WORSE fuel using disadvantages, etc. of gassers!!! We of course ignore the gasser effects! :)
    I was really speaking from the point of view of 100,000 miles actual diesel experiences and others's results on Jetta TDI and comparing it with results from others Jetta 1.8T gasser experiences (since I do not own a 1.8T gasser Jetta side by side with a TDI). The ranges are pretty true to life. Of course there can be and ARE HUGE individual differences for a whole host of reasons. An analysis of the statistical variance will probably show the normal deviation. Since I do not have access to this data I can only give anecdotal variance data.
    So for example, there is an almost startling difference between the Jetta TDI/1.8T @ 49/30 mpg= 19 mpg. for 39%. Critics might/will probably poo pooh the differences, but to me, the differences are HUGE. So for example, the part that makes me laugh every time I hear about "dirty" diesel is by default, detractors are saying it is environmentally cleaner to burn (100,000 miles/ 49/30) 3333 gals vs 2041 gals??? REALLY!!!???? If so, why don't those same detractors embrace SUV's instead of scorning them? It would seem to me a premium is placed on TALKING of fuel savings, and only IF the other guy is doing it! Actually saving fuel doesn't really matter!!!! To me this is multi level hypocrisy, a height of disengenuousness. This is not even talking about what happens upstream and downstream of the logistical pipeline!
    If governments (at all levels, from world to local) were REALLY serious about conserving fuel, it would be an easy thing to do to subsidize the diesel option, i.e., savings of 20-40%, so it cost the same as the gasser option. The intend would be to encourage a higher population of passenger car diesels, obviously. The advantages to the consumer are indeed a NO brainer. It is pretty obvious they are more interesting in taxation, cash flow, turf, etc. etc., and raisng all of the above!
    In contrast on the business side, up to 100,000 dollars per car per year was earmarked for SUV's that were used for business and business purposes; AKA the Hummer exemption. :) What this also meant in years past; a (GASSER) economy car couuld be depreciated in 14 years vs 5 years for the SUV that met the qualifications. So dollar for dollar, which would you buy!? :):( Even with these almost overwhelming advantages, the SUV at 12% of the passenger vehicle fleet is not uncommonly large.
    Your point is well taken. It is much easier for critics of diesel cars to point to the failed test procedures at the EPA for diesel cars and say it is not enough gain to justify letting them in.
    When in fact the owners are posting as you say much higher mileage than the EPA FORMULA would lead us to believe. That 39% difference when carried over to GHG measurements is significant. Instead of 6.1 tons per year CO2 it is closer to 3.7 tons per year. Which is better than ANY GAS CAR sold in the USA. That includes the Civic on CNG and all the hybrids. The EPA or CARB does not want that to become common knowledge.
  • goodcrdgoodcrd Member Posts: 253
    Go to the EPA web site and do a side by side comparison of the 2005 Jeep Liberty CRD 4wd and the 2005 Jeep liberty 4wd with a 3.7L gas engine and 4sp auto. You will find the combined mpg numbers at 22.9 for the CRD and 14.9 for the Gas engine. These numbers are from users of these vehicles. If you compare the performance of these two vehicles you will find them close with the edge going to the Diesel. The CRD gets 53.7% better combined mpg then the same gas powered version. Both are true 4wd. Now this is apples to apples. I drive about 60/40 Highway to City and average 26.5 mpg. On long trips it is more like 31 mpg if I stay on the interstate and drive 65 to 75 mph. Diesel is the way to go!!!!!!!
    "The CRD gets 53.7% better combined mpg then the same gas powered version."
    Indeed given your quote, my 39% example might be PESSIMISTIC (and I thought I was an optimist, or was that optimistic pessimist or pessimistic optimist (tired already) :) :sick: :confuse:
    But surely, the small car segment (from which I drew the examples) is a small minority of the passenger vehicle fleet, currently estimated (gov reported registrations) at 25%
    So if indeed the savings in mid to large to suv sized vehicles is GREATER (53% using your example); going to diesel for these (HIGHER consumption gasser)segments, MAGNIFIES the diesels' advantages!!! Indeed these segments represent the overwhelming majority of the passenger vehicle fleet!! I will leave the math examples out, although it would show even greater savings. I think you both have outlined the ramifications very clearly.
  • roland3roland3 Member Posts: 431
    ... Gagrice, Goodcrd, & Ruking, I don't believe CARB and EPA are intentionally trying to hide anything; HOWEVER they have the inbred tendency of any large organization to admit they have been WRONG forever about total fuel use. Even practical know nothings talk HC, CO, and NOx because that's the way it's been for 35 plus years. We actually need the general population to think of the amount of gasses exiting the tailpipe. None of those three measurments has any relation to quantity. IF we had an adjustable scale of regs the Diesels might be allowed to have slightly more tolerance in NOx. If it was not for the advent of general knowledge about green house gas and total carbon output there would no hope of waking the slumbering giants out of their lofty dozing.
    ... So for instance, next year, a TDI with common rail injection that can go sixty miles on a gallon of number two fuel oil, would have an incentive against, Navigators, Suburbans, and Jeep Commanders that can only go 18 MPG. The incentive (on NOx regs) would allow: more compression, get rid of EGR, a little more crisp injection timing and maybe a few drivers would go 70 MPG in oH-Nine. So, after the big three: HC, CO, NOx, we need a number like dash "60" for MPG or maybe the total carbon rating.
    The bottom line, if the system is SERIOUS about using less fuel; all we should really care about is having diesel options, NOT legislate the legislation against 50 mpg!!?? However as the European model has shown, that will probably put unleaded regular up around 6/7 dollars US ! As you can probably also see, this does nothing to the gas hogs the European oems continue to produce, of which a host of notable models continue to send over here! I am currently getting 50 mpg and they want to legislate the vehicle that ACTUALLY gets 50 mpg out of existence!!!! If that is NOT disingenuous, I really do not know what is. :):(
  • hypnosis44hypnosis44 Member Posts: 483
    The same continuous loop of the same self rationalization and sales pitch.
    If anyone was serious about oil dependency, fuel economy, pollution and far more we would be investing billions into mass transit. We would also be educating people about the enormous waste spiral we created through the same advertising and marketing monster that will drive the "new diesel" sales machine.
    Tick tock.
    And that would be a down fall! Every US city that has has as it's center piece "MASS TRANSIT" has an even bigger private transit infrastructure on which to rely!! You are advocating the creation of even more enormous "black holes" for money! tick tock.
    Mass transit is a worthless pursuit in all but the most densely populated areas. Gas tax should not be spent to subsidize a losing proposition like MASS TRANSIT. Our San Diego trolley system is a HUGE drain on a budget that is near bankruptcy. If a bus is not full it is a bigger polluter than the cars it replaces. You need to get out of that smog you are in. It is the port at San Pedro that is polluting your town. Not cars. Until they block all the stinking ships coming from Asia without any pollution controls you will be in a stink hole up against those mountains. How you can think it has anything to do with diesel cars is just ludicrous. Move up to Big Bear and ride your bike around the lake every day. You will forget about smog and mass transit.
    You have again stated, as well as misstated, the standard auto and oil industry responses. They have the same legitimacy as "clean exhaust", or "high mileage" have.
    People who are interested and aware, and not speaking for the auto and advertising industries, understand the nature and significance of mass transit as well as that of the fallacious statements used to oppose it. Mass transit will continue to grow as the impossibility of maintaining the "status quo" becomes more apparent.
    Tick tock.
  • blufz1blufz1 Member Posts: 2,045
    This is the U. S. We don't do mass transit. :)
    "This is the U. S. We don't do mass transit."
    That could pose a problem :P
    ..."That could pose a problem"...
    Indeed your statement is more true than you know.
    You might want to research the history of the railroads in this country for the trials, tribulations, rapid advance, steep decline, almost complete decimation and almost arrested decay, fits and starts, etc. etc., for a more historical view.
    Indeed, I have been going up to the mountains for at least the last 50 years, and love it especially during the winter (folks that do not live in snow have a warped sense of priorities:)) While I liked and have "enjoyed" and have survived by a camp fire and or furnance fire, common sense and any fire fighter can tell you this is almost an environmentally criminal action. :(:) There are very few emissions mitigations sold for camp fires and fireplaces.
    In a utopian world we would all get along in nice high rise apartments and ride buses, subways and trains to our needed destinations. Everyone would respect each others space and we would not hear any blasting boom boxes, gunshots and sirens.
    We don't have that kind of world, and those of us that can afford to get out of the quagmire we have made of our cities, do so. I and MILLIONS like me have gotten as far out as practical. I enjoy only hearing the birds and crickets. My neighbors are mostly retired like myself and like the same peace and quiet. That said, we do feel an urgency to conserve as best we can.
    To do so we should make best use of the natural resources. The MOST practical use of petroleum is in the form of diesel. You get the most energy from a barrel of oil using it that way. There are also many alternatives that will run in engines designed for diesel. Many biodiesel products are coming to market.
    You can tick tock all you like. Myself and MILLIONS like me are not going to join you in the filthy swamp known as cities. We will get in our individual vehicles and drive to WalMart. We will buy shoes and shirts from China, as that is all that is available. Ships will continue to dock at the ports spewing nasty stuff into the air. It will continue to be blown over the Los Angeles basin till it hits the San Berardino mountains.
    Your sacrificing by riding in a stinking bus filled with thieves and tramps will not clean the air one little teenie bit.
    Indeed our municipality which is part and parcel of a much greater sized metropolitian area, gets large regional state and fed monies, and on the EXPENSE side of the ledger pays app 60,000 dollars per year for membership to (the local TA)and for the municipal employees it employs to take "MASS TRANSIT"! FREE!!! Taxpayers pay for this and also for the transit expenses and must put monies into the fair boxes if used. They stopped reporting the (FREE)USAGE rate on cable TV meetings for... NO ONE used it!!!?? Instead of giving our mayor and council persons each between 450-650 per mo for their use of their OWN private vehicles, they should give em all a mass transit pass, as the employees do not use it anyway! Of course, they are still on the hook for the 60,000 dollar yearly fee. They only give it lip service when someone using part or parcel of their 3 min comment time and only at the annual budget meeting! :lemon:
    Reading the news, and especially the financial pages will help the understanding on this issue. For others, the oil and auto maker party line will always be their mantra.
    For the first time in history more people live in cities than do not. All projections, as well as current trends, point to more and more people moving to cities.
    Public and private infrastructure expenditures are on the rise everywhere, in large part as a result of this trend. The largest proportion of those expenditures are transportation related and many municipalities are putting money into mass transit as the only viable way to deal with massive traffic congestion and expanding economic activity, as well as pollution from "clean" exhaust.
    Transit ridership is up as a result of the rise in fuel prices which will go higher. Some cities are charging fees to drive within city "bounds", others are closing sections of their cities to any driving. As the economic pressures from all sources mount against driving and in favor of mass transit the pendulum will shift even further.
    As to transit systems not making any money; that is false, some do. But more to the point, they are not intended to; they serve to assist the general social and commercial enterprises within which they operate. They also create jobs and wealth which is part of economic growth.
    By using alternative transportation I am saving 5,000 dollars per year which goes into investments and purchases in the general economy. No one's car, unless operated for business only, has ever made them a dime - cars have become a black hole for money and dollar for dollar 10 times as expensive as transit has ever been.
    As for the so called "millions who have left the cities" - no evidence supports that claim. For those who have left, one need only remember the bomb shelters of the 50's to see the usefulness of it. Once they begin to pay the actual costs of what they consume in subsidized services they will suddenly find it useful to move.
    AS for the "... thieves and tramps..." on public transportation; they all speak well of you and are surprised at your feelings. As for me - I spent several years in corporate positions and have a real understanding of what the real thieves and tramps really do to us daily. The false notion of auto dependency is just one of the more criminal of their accomplishments.
    Tock, Tick.
    You have made a lot of statistical statements. Do you have any data to back them up? All that I read is the US suburbs are growing and except for a few cities the move is not downtown.
    I know of one city, London that charges to drive your car into the city limits. You care to tell us which cities in the USA do the same. I have heard that NYC has a decent rapid transit system. Yet they are in total gridlock most of the time on their streets. So what good is it? They could impose a charge to go into every major city in America and it would not impact me at all. I would go 100 miles out of my way to avoid most cities in the USA.
    Thankfully we still live in a free country where you can decide where you would like to live. I lived in Los Angeles when it was civilized. I do not think that can be said of any major city in the USA today. My motto is avoid cities at any cost. So whether my diesel pollutes or not, I will not be adding to yours or anyone else's pollution in any US city. And I would rather not subsidize your mass transit.
    Yeah,but how would I pull my 2 stroke bass boat to the lake without my own wheels?
    "Yeah,but how would I pull my 2 stroke bass boat to the lake without my own wheels?"
    Funny! If you wait long enough the lake will come to you. :P
    "Your air" does not stay in one place - any pollution ends up in everyone's face - we end up paying for medical treatment for ailments caused by pollution, thereby subsidizing you. As for NY and other cities and grid lock - the answer to your question is embarrassingly obvious in your statement itself . As for the stats; all of the information I quoted is recent and on the news wires, (along with plenty more like it), that is available to everyone - even if you drive a diesel. ;)
    ""Your air" does not stay in one place - any pollution ends up in everyone's face - we end up paying for medical treatment for ailments caused by pollution, thereby subsidizing you"
    Now is this your call for stopping airline traffic to all the airports close to cities, such as:NYC, San Francisco, Boston, Wash DC. Chicago, LA, Houston, etc. etc. Shipping traffic to ports? :lemon:
    Your non sequiters and contradictions aside; avoiding the issues and acting as if you are unaware of the fallacies in your statements, which most anyone will see, does not speak well of your other positions. Reading the news, as well as authoritative sources on pollution would affect the views of anyone truly interested in accuracy on this issue. Using the auto and oil industry party line comes only from those who work for them, those who think they will not be affected by their own actions, and those who believe in the mythical "no responsibility for one's own actions" frontier which has long ago died on a planet with seven billion people.
    There will soon be no mythical "choice" either as the deck stacks higher and higher against the possibility of a solution in time to help.
    But I think you know all of this already. "Tend your garden".:shades:
    Come on,man. Lighten up. All I know is that it is too hot to fish. :)
    "Come on,man. Lighten up. All I know is that it is too hot to fish."
    I was being "light" - they don't let me post my heavy stuff! :P
    Your Utopian view of the cities will never come to fruition. People in the cities are killing each other because of too much togetherness. Anyone that wants to live in an apartment or condo in a city has my blessing. I do not know anyone personally that wants to live like that. Some are forced by circumstances.
    Your arguments on cars causing major pollution is not based on the facts. You are like the politicians in Washington DC and Sacramento. Blame it on cars and let the trains, planes, buses, trucks etc etc pollute as they please.
    If you listen to mainstream media I know you are not getting much truth. Only what they want to feed the masses.
    Just come up with one bit of data to back your outrageous claims. What US city is growing faster than the suburbs surrounding it?
    7 billion people. And we have enabled them to get cars. We have sent our industry to China & India and other countries. China will soon be buying as many cars as we do. If you buy anything made in China you are as much to blame as any of the rest of us.
    I imagine within 10 years we will be buying our diesel car from WalMart.
    When I see the likes of Ted Kennedy, John Kerry, Obama and Hillary living in a downtown condo, riding the bus to work, I will think about changing my life style. And the clock is ticking. We will kill each other long before we die from pollution, global warming or oil depletion.
    Blufz1 will outlast us all. Out there on the water fishing is a grand way to spend your leisure time. Do they make a diesel outboard?
    No diesel outboards over here for freshwater sport fishing. They would be too heavy. The newer outboards are more enviro friendly. I am really looking forward to the diesel CRV. 250 + ft. pounds of torque in an economical 179" package that will fit neatly in my garage/toy box.
    And we didn't even cover the complex components of the fact that people in cities pollute more than people any suburb or rural area!! If people moving to cities are indeed the tread, it will exacerbate the VERY poolition problems you proport it will aleviate! ? :lemon:
  • larsblarsb Member Posts: 8,204
    So are you saying we need a SEPARATE EPA test just for diesels and another one for gassers?
    And can you point out to me exactly how and where the scientific method used in the EPA MPG test is flawed?
    Don't you think that if that test were flawed, scientifically speaking, that some scientist somewhere in the world would have challenged and disproved it's validity by now, after 40+ years of use?
    Um, Yep.
    You're not often flat out wrong Gary, but in disputing the scientific validity of the EPA test, you definitely are wrong this time.
    ..."If people moving to cities are indeed the tread, it will exacerbate the VERY poolition problems you proport it will alleviate! ? "...
    change from: "poolition" TO: pollution
    It is far cheaper to go from unleaded regular to diesel in the short term. (40 years)
    RDA Re "D" evelopment Agency ('s) activities are almost necessarily generational in nature. Indeed in San Francisco, there are more cars, traffic and (circulation) problems than ever before. This is interesting in light of the fact the metropolitan population rate has been FLAT since 1930!!! OVER TWO GENERATIONS!!
    http://www.city-data.com/county/San_Francisco_County-CA.html
    ..."The City and County of San Francisco (IPA: [ˌsæn frənˈsɪskoʊ]) is the fourth most populous city in California and the fourteenth-most populous in the United States, with a 2006 estimated population of 744,041.[3] San Francisco is the second most densely populated major city[4] in the U.S.[5]"...
    http://en.wikipedia.org/wiki/San_Francisco
    Arguably, if one has to live in the (A) city, San Francisco has to be literally a WORLD DESTINATION !! :(:)
  • bristol2bristol2 Member Posts: 736
    I seem to remember that on really digging into your supposed sources for data, it turned out that it was based on 'conversations with literally thousands of students'.
    Put a source for your statements. If you think that people are moving into cities and leaving the 'burbs, provide the background because I don't think you will find many agreeing with you.
    As for the tick tock stuff, come on, it's just silly.
    Well, at least in Phoenix, which right now is the 5th largest metropolitan area in the USA, people are moving to the City.
    To downtown.
    There are maybe dozens of urban renewal projects going on downtown. New luxury condos are sprouting up all over the place. Construction is rampant.
    It's part of a long-term process to revitalize the downtown area and bring residents down there to live and to work.
    It's working so far. Long-term, who knows? But for now, people are buying the condos.
    I think you are putting a shading on it that does not deserve to be there.
    The central issue (my .02 cents)is the dissonance between scientific and infinitely duplicate able EPA procedures and what happens in the real world. Indeed the only real problem is the so called EPA numbers of city/highway are in BOLD print. The solution is pretty easy: put the RANGE in BOLD print and the EPA city highway in small print!!!! :shades:
    Is that not what has happened for 2008? The reason being the Hybrids were so far off that they received complaints and threatened lawsuits. The truth is the old tests came closer to reality for diesels than it did gas hybrids.
    To dispute your earlier claim that one size DOES NOT fit all. They have ONE set of TESTS that is for all light vehicles. There is nothing taken into consideration for hybrids, diesels or regular gassers.
    IMO the EPA has accomplished nothing but to further muddy an already muddy stream. The one light at the end of the tunnel is the personal mileage claims they have included. A much better indicator of what to expect.
    So why did they change the tests if they were NOT flawed after 40 years?
    Do you think the conversion of apartments to condos will bring as many people into the city as does the huge subdivisions being built south of Phoenix. Phoenix and Las Vegas are very similar. They have spread out like Los Angeles. There growth is phenomenal. I would not in any way see that as a move to the inner city. In fact I would say that Phoenix may be the largest suburban community in the country. How long would it take you to get to Maricopa from downtown Phoenix on a bus. Two maybe three days? :)
    PS
    The question is: are people selling out from the suburbs and moving into the city. My guess is no they are not. The growth in Phoenix is all the retirees from around the country converging on the SW. They sell a home in LA for a cool million and buy a Phoenix condo for $400,000, and pocket the rest.
    They were "flawed" because DRIVER BEHAVIOR has changed since original inception of the test.
    Nothing about the test was flawed in a scientific sense.
    The old test did not consider the effect of air conditioning on MPG, nor the effects of high-speed highway driving. Those are the two main changes in the new test.
    And I suppose they could have different tests for different vehicles if they wanted to, but why do that?
    The "One test fits all cars" method is a better way to provide shopping comparison estimates for car shoppers, which is the ultimate goal of the test.
    Shouldn't we take this to an EPA Test forum, rather than here in the Diesel forum?
    We may indeed disagree. To me, it is much better,easier, duplicate-able to have one so called "placed" test and let the individual categories (hybrids, diesels, gassers, etc, etc., FALL into place. So in that sense, what I am saying agrees with Larsb's above post. In that sense the old test handily exposed the inherent weaknesses of the hybrid! The higher cost one pays for this weakness was a simple B/E calculation! Conversely the strength of the diesel was highlighted.
    Let us for example say ok, we do need a specfic test for each: 1. hybrids 2. diesels 3. regular gassers. So for example we already know that under the so called "old" EPA tests; hybrids under perform, diesels over perform and regular gassers may or may not perform at par. Lots of room for discontent!? Absolutely!! There were intense pressures to change the tests and in fact they were! All coincidently perform in the stated RANGE that each oems says; given the tests they conduct and certify to the EPA. EPA probaby does have the right to duplicate and or audit.
    So NOW if one considers a new car one issue that arises from this new test matrix is a whole NEW TEST MATRIX!!!! So now (for example )one would ask how would a Honda Civic (gasser old epa of 29/38 mpg) perform in the hybrid test, diesel test, etc!!! We think the level of complication is weird now!!?? So in that sense each cars stated range in facts covers thr RANGE! Perhaps the real flaw is of expectations. We NEED a city and highway figure !!??
    Those were some amusing and some amazing responses, non responses, and denial to an essentially benign post recapping current news about well known information. If this is a sampling of what to expect from those interested in diesel, I expect the diesel experience will be confined to hobbyists, trendies, survivalists, and celebrities.
    The artificially created mass hysteria of the endless highway and dependence on the automobile has with it the same denial that occurs with some of those who suddenly face a terminal illness. The patient denies that their is a problem, proceeds to expand the activity that caused the ailment, blames others for his fate, plans as if his life will not end, rejects all advice from specialists, and at the end leaves everything in chaos for everyone else.
    Maybe diesel gurneys are the answer? Diesel hearses?
    Tick tock.
    I think you are DEAD WRONG ! :)
    I think you are kidding and did not really miss the reports on the shift of populations to the cities. So You will have to pretend to do your own research.
    As you will recall, my post about students had to do with automobile trends and how to determine their future direction - ask the students what they want to buy when they are working. If detroit had listened to the students in mid century they would still be on top. The reference to students had to do with the direction of the auto, it is is a prediction based on the opinions of those who will do the buying. In contrast, the statement about the shift in populations is factual, well known, and being responded to, sometimes frantically, by public and private sectors around the world.
    More study, fewer diesel fumes. ;)
    How droll.
    I'm not comparing reasons why people move where they do.
    I just stated that people are moving into downtown Phoenix, which plays into the "mass transit" and the pollution discussion.
    And the Maricopa bus ride thing? There is a Rapid bus which goes from 40th Street/Pecos Park-N-Ride to downtown in 34 minutes. So drive your car from your home in Maricopa to the Park-N-Ride, about 20 minutes, and be downtown barely over an hour from leaving home in Maricopa.
    Oh dear.
    Death in the cities, media lies, cars don't cause pollution, missed the news on city growth, chinese goods, WalMart madness, death from apocalypse, corrupt politicians, but diesel cars will save us. I see a movie in the works - "Diesel Man".
    As for Bfluz, I hope he lasts a long, long time - but I expect he hopes the cities don't collapse, because if they do his lake will sadly be history in 24 hours. Not a good ending for anyone. ;)
    Tick tock
    What do you actually predict is the problem, fix and end-product if there is no fix?
    I don't think you should be surprised that most of the conversation in a forum on diesels in the news relates to diesels. You could start a public transport forum.
    The cryptic references to the end of the world seem a pointless and, of course, offer no opportunity for a conversation since we have no idea what you are referring to. Is it global warming? Are we all going to suffocate on the fumes? Are we all going to die in our homes as gasoline runs out?
    In summary, what is your point and lets debate it.
    If there is no point, that's fair also. Just don't be surprised if you get responses that are not positive.
    Actually it is your take that is DROLL! Your take really reminds me of the very liberal and common social science thinking in the mid 60's to 70's. Essentially that 3rd world countries like India and China would have to literally institute die backs as a governmental policy as they would lose out on the distribution of limited resources (essentially not worth saving) while we slid into the new ice age. :):( Funny how a new attitude and a little capital and human ingenuity goes, now ain't it? All in a tad more than a generation or so!! So how did global warming trump the new ice age!? :)
    droll
    Function: intransitive verb
    to make fun : JEST, SPORT :P
