Visitor Agreement.
BTW Obyone, rate your Tundra for us ;^)
Is hoping the Tundra is about the same size to drive as the landcruiser.
It´s not easy for me to get to a dealer, since i Live in Denmark, Scandinavia EC, where the car is not marketed (So something´s still rotten in Denmark, to quote William). But, maybe I´ll import one myself.
I have hauled 1200 lbs in my truck (verified by the scales at the dump) with two additional passengers. The truck handled the load beutifully. I had to add two 3X6 sheets of plywood to each side of the bed to accomadate loading to the top of the cab, but it handled it flawlessly.
The Tundra is absolutely the quitest, best riding, most reliable, besty quality, best braking 1/2 ton truck on the market. The towing and hauling ratings are at least as good as the Big2.
Now expect to see some unfortunate Chevy owners posting to this topic - it is just sour grapes.
The best 1/2 ton pickup on the planet - Tundra.
Welcome ken0 [Preferences] [My Profile] [Logout]
fifth wheeling witha Tundra
2 messages,Last post on Feb 14, 2001 at 04:52 AM
Msg#
Tried to get discussion pertaining strictly to trailering with a Trundra but apparently that's not allowed . If any of you have input on this subject - please respond ,:
Dissapointments with all 3 of big 3 are causing me to look elsewhere. Am looking for imput on Tundra. I haul a 22 ft. fifthwheel ,5200 lbs total wet weight including people,food,etc. Does the Tundra have a "tow package" , what are it's handling characteristics , etc.
Talking to the Tundra Service people in California left me with the impression of"My gosh ! what is a trailer ? Tow package ? oil coolers ? what are they?."
How about some info from you Tundra trailer haulers?
Ken-o in Texas
does Tundra have choice of rear end ratios?
how do they handle and break with a trailer load?
what does their towing package consist of?
been pulling rig with a 97 silverado for the last 4 years and i don't think the weights are any problem
I think the positioning of the pedistal will be all right but what is distance rearaxel to cab?
what is hegt of bed sides?
I asked all these questions of Toyota customer service and he sounded like I was from another planet asking such foolish questions .,but if I go Tundra , it won't be like it was with dodge and ford - I will know or not buy
Mine handles great. The breaking is consistent. My personal experience has shown me that I get better with every trip of hitting the right combination of brake pedal and distance. Emergency breaking has given me no scares.
I bought the truck with the towing package which consisted of a reece hitch (no weight distributing hitch), the receiver (class IV), and a four plug wiring harness. I converted the 4 plug into a 7 plug. Later in life, I bought the weight distributing hitch and I bought the trailer brake controller for inside the cab. Here again, the transmission cooler is standard. Toyota also has a large alternator standard.
The distance from rearaxle to cab is dependent on which model you would get. I have regular cab longbed and the distance is 36 inches. The height of bed to top is 16.5 and the height of wheelwheel to top is 9.75. However all these measurements are in cosideration that I have a bedliner.
According to the brochure I have the difference between bed lengths is 27 inches. Since the wheelbase is the same. I would assume that the distance from wheelwheel to cab is 9 inches with a bedliner. I would ask rooster for correct measurements for the extended cab model. He tows a 6500 pound trailer.
Let me know if any other questions!
http://www.trailerlife.com/test/0002tundra.cfm
One thing to keep in mind - the Tundra has a 5 yr, 60,000 mile drivetrain warranty, the Chevy only has 3yr, 36,000. The Toyota also has a bulletproof reputation for making quality, long lasting vehicles.
It all depends on what is important to you. To find details on fifth wheel towing do a search at http://www.tundrasolutions.com
Good Luck.
Oby - What does aftermarket airbags have to do with the price of tea in China? Don't you have a lemon Silverado?
Ken-o
I towed a trailer with my Tundra from NY to LA and kept the speed over 75 in the rural areas. In some places I hit 100 without any problems. The truck is strong and stable. In the rockies I could hold 65 up any mountain on I70.
Since I didn't know about this chat line untl this month I just read this Mike - are you kidding or what? If you actually did that even with out getting a ticket , I'm sure glad I was way down in Texas at the time
I like the TRD 4x4... but the extended cab back seat room is VERY limited and I want a FULL SIZE BED.... not that short bed. Had that with a Z71 Chewy and could never haul that much with it.
Can someone set my record straight please?
TGinOC
I have only seen one ever in existence and it was a 2000 model.
I agree with you wanting a regular cab longbed because that is what I got.
Now Ken, you have an interesting question that people are missing the particular problem you have. The Tundra is a fantastic tow vehicle and requires nothing more than a hitch and wiring added to it in order to get up to its capacity. There are no options for different rear end ratios and the transmission cooler is standard.
The problem you have is payload with a 5th wheel. Unlike conventional trailers, you put a huge amount of weight on the rear axle. This counts against your payload capacity. Typical tongue weight on a 5000 pound trailer is 350 to 500 pounds and that doesn't hurt you much with a 1500 (roughly) pound payload rating.
With the 5th wheel, your "tongue" weight can easily exceed 1000 pounds. This means that you can't have more than 500 pounds worth of people and gear in the truck. This is why most 5th wheel trailers are hauled with a 3/4 or 1 ton truck which Toyota does not make.
I currently tow a 4200 pound boat and am very pleased with how it handles. Braking is solid, sway is minimal and acceleration is great. I'd be a bit leery about a 5th wheel on it though unless I took it to a company who could modify the thing to handle it.
What about Toyota dropping the 4x4 reg cab long bed? Both people who bought them want to know (lol). Are they coming out with a X-cab long bed? Toyota could sell maybe 10 of those per year (if they came with a $6,000 rebate).
I was wondering if you know of Toyota's plans for 2002 Tundras. Will a Access Cab long bed be available? Will we be able to get Sequoia options like sunroof, compass, outside temp, and heated mirrors?
I currently own a 2001 BMW 330ci and I have owned a 1999 Dodge Dakota R/T which I enjoyed driving, it handled very well for a truck. Unfortunately, the truck had a few quality issues and one very big towing issue. Dodge offered a Dakota R/T buyback because of the towing discrepancy (being told your truck can tow 6400 lbs and then finding out that it is only rated for 2000 lbs is a pretty big surprise). Anyways, I enjoy vehicles that handle well. So now you know how much I value handling. I would like the security that a 4x4 offers even though I would use it only about 4 or 5 times a year. I am one of those people who buy a feature "just in case". Is the 4x4 worth the tradeoff? Is the 4x4 worth the $3000 difference?
Thank you for any help you can give me.
I also opted for the ABS. It works great! All my stops are straight and well controlled regardless of the road conditions.
The 4WD in combination with the ABS make the Tundra an amazingly competent snow vehicle. You will be glad you have it the first time it snows. 4WD trucks also have better resale.
A full size pickup will never handle as well as your beemer of course, but I don't think you will be disappointed with the Tundra.
As far as I know, the 2002 will be pretty much unchanged. Current rumor is that we will have a second, more powerful V8 coming within the next two years but I have no details. I'll post them here when I lean more.
I also suspect we will have a double cab but that is only a guess and not something I've heard from official sources. I would doubt we will get a longer frame before the new engine is out.
Dianne
(the same Dianne with tundrasolutions.com)
900 dollars seems low to me unless the 4Runner is in terrible shape - though you did say "V-4" and I'd assume it was a 4x2. 24,300 seems to be a reasonable (not great) price on the Tundra IF it's free of all dings, scratches, etc... that is, IF it looks like new.
900 dollars is not worth messing around with the dealer over (in terms of a monthly payment). You could certainly do better selling it yourself - take your time and somebody would probably give you more.
I'd say close the deal on the Tundra and sell the 4Runner yourself.
However, look around and see if you can still find a NEW 2000 Tundra. I just bought a new 2000 V8 4x4 Tundra LTD for $26.5K (MSRP $31.2K). I just made him an offer assuming $2200 depreciation ($1500 per year) taken from invoice price (approx $28K).
For some good car buying/selling advice, visit www.fightingchance.com
I don't know if what he told me was true but it sounded good. Keep on trucking.
If you are financing the deal be careful - the interest rate on a used car (truck) loan will be higher than the rate on a new truck loan. Which means you could pay more for a new one and your payment would be about the same. Based on the way you are being treated I would guess they will also try to screw you on the interest rate.
Why does someone buy a new truck and then trade it in after only 6,000 miles? Always makes me wonder. Was it a lemon? Did it have the shake problem? or maybe the owner could not afford the payments. The only way I would buy a truck with 6,000 miles is if the deal was very good, for the price you are being ask to pay you may as well get a new one.
I'll give you one other site to check out but a word of caution is in order. www.tundrasolutions.com is a great source for Tundra owners and shoppers. There are hundreds of people who post there who are very happy with their trucks. There are a few who are not. Even some of the happy ones have had a few problems. This site is a resource for Tundra owners to resolve some of those problems.
The V8 runs like a watch, is torquey and runs like a bat out of He**. You will not be disappointed.
I have a 5 speed regular cab. It averages between 16 to 20 miles to a gallon. It averages 11.5 to 13.8 when towing my camping trailer. The price difference is close between the V6 and the V8 access cab models as bamatundra said above. However, if you want the manual, I would get the V6. If you plan to tow(over 4800 lbs.)in the future, I would spend the extra money and get the V8. However, if extreme towing is not in your future, I would get the V6. You may have a slight problem in finding one though. My V6 model was a no-brainer when I bought mine in July 99. I paid 16,300 for it.
